Plasma-wayland freezing problem with 2nd monitor
plasma-wayland session (complete computer) freezing problem here.
  • Occurs when I plug in a new hdmi screen.
  • No other tty is working. I have to do a hard shutdown and reboot.
  • I’ve tried to spot errors on next startup and found some powerdevil errors but they are here when it’s working.
  • Works fine when the hdmi screen is plugged in on startup. But if it is shutdown, it goes to sleep or it is disconnected for some reason, I can’t plug it in back without freezing.
  • X11 session works fine.
  • Same behavior with 6.12 and 6.6 kernels.
  • I’ve tried the last live cd (25.0.10) and got the same problem .. versus an old one (25.0.4) that is working without the issue.
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: LENOVO product: 20Y4S2U000 v: ThinkPad P1 Gen 4i
  Info: 8-core model: 11th Gen Intel Core i7-11850H bits: 64 type: MT MCP
    arch: Tiger Lake rev: 1 cache: L1: 640 KiB L2: 10 MiB L3: 24 MiB
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Xe ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a60
  Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
    driver: nouveau v: kernel arch: Ampere pcie: speed: 2.5 GT/s lanes: 16
    ports: active: HDMI-A-2 empty: DP-5,DP-6 bus-ID: 01:00.0
    chip-ID: 10de:249d
    alternate: fbdev,vesa dri: iris,zink gpu: i915,nouveau d-rect: 3840x4560
    display-ID: 0
  Monitor-1: HDMI-A-2 pos: primary,top model: Sony TV 00 res: 3840x2160
    hz: 60 dpi: 92 diag: 1220mm
  Monitor-2: eDP-1 pos: bottom model: LG Display 0x06aa res: 3840x2400
    hz: 60 dpi: 284 diag: 406mm
  API: EGL v: 1.5 platforms: device: 0 drv: zink device: 1 drv: iris
    device: 2 drv: swrast gbm: drv: zink surfaceless: drv: zink wayland:
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
    device-ID: 8086:9a60 display-ID: :1.0
  API: Vulkan v: 1.4.321 surfaces: N/A device: 0 type: integrated-gpu
    driver: mesa intel device-ID: 8086:9a60 device: 1 type: discrete-gpu
    driver: mesa nvk device-ID: 10de:249d
Any help would be apreciated :slight_smile:
Your post has been moved to a dedicated topic.
Please provide your full inxi output as described (below) – edit your first post and replace the text there rather than creating another post for it.
You haven’t mentioned how this monitor is connected – via a direct HDMI <=> HDMI cable or an adapter cable of some kind. Have you tried other ports that might be available?
Please provide logs rather than relying on what you might or might not see during boot. If you are unfamiliar with how to generate appropriate logs, manjaro-log-helper might be … helpful.
sudo pacman -S manjaro-log-helper
There is also this tutorial:
Please provide as much detail as you can to help others help you. I’m sure someone will assist when they are able.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Since you are using stable branch it is likely the issue has been solved with the next plasma release.
 $ mbn info plasma-desktop -q
Branch         : archlinux
Version        : 6.4.5-4
Repository     : extra
Build Date     : Fri 10 Oct 2025 15:37:03
Packager       : Antonio Rojas <arojas@archlinux.org>
Branch         : unstable
Version        : 6.4.5-4
Repository     : extra
Branch         : testing
Version        : 6.4.5-4
Repository     : extra
Branch         : stable
Version        : 6.3.6-1
Repository     : extra
Build Date     : Tue 08 Jul 2025 18:10:33
Packager       : Manjaro Build Server <build@manjaro.org>
Thanks for the REISUB tip! It helped me retrieve control of my screen and it could help me get more info on that hdmi-wayland problem…. but I have little time to follow all the troubleshooting process and report as I am indeed an infrequent forum user.
I’ll probably roll back and wait for the next update to see if the problem is still there. Hoping it’s not… or try other things in between. I’ll keep you posted if somethings comes up.
Thank you very much for the answers!
Unfortunately, it’s part of the process; it’s normally suggested to make time, especially given that minimal information can often point in many directions.
The topic has been closed without a solution.
If you discover the issue persists beyond the next influx of updates, ask a Moderation staff member to re-open this topic, if you like.
Make sure to add a full description of additional details you might have found in the meantime.
