I tried upgrading the kernel to 6.6.65-1-MANJARO but the problem persists.
Here are my journalctl and inxi output. The journalctl output was too big to be pasted here, but I ran journalctl --priority=warning..crit --no-pager --boot=-1 to produce it.
journalctl: https://pastebin.com/raw/t5X34ivE
INXI Output:
sudo inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ea871510-c4d2-42e8-9618-bd238d87ccb8 rw quiet ibt=off
thinkpad_acpi.fan_control=1
cryptdevice=UUID=0db0041f-ff15-4fb4-a223-7c78ca6bf4fb:luks-0db0041f-ff15-4fb4-a223-7c78ca6bf4fb
root=/dev/mapper/luks-0db0041f-ff15-4fb4-a223-7c78ca6bf4fb
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20VX009QUK v: ThinkPad P14s Gen 2i
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20VX009QUK v: SDK0J40697 WIN serial: <filter>
part-nu: LENOVO_MT_20VX_BU_Think_FM_ThinkPad P14s Gen 2i
uuid: bd3df4cc-3564-11b2-a85c-cef770e830ba UEFI: LENOVO v: N34ET53W (1.53 )
date: 08/31/2022
ID-1: BAT0 charge: 47.1 Wh (100.0%) condition: 47.1/50.5 Wh (93.3%)
volts: 12.9 min: 11.5 model: SMP 5B10W51827 type: Li-poly serial: <filter>
status: full cycles: 59
Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 5% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 48 GiB available: 46.78 GiB used: 10.25 GiB (21.9%)
igpu: 64 MiB
Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATS2G64HZ-3G2B1 serial: N/A
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 32 GiB speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: Crucial Technology part-no: CT32G4SFD832A.C16FF
serial: <filter>
Slot: N/A type: N/A status: available length: other bus-ID: 00ff:ff:1f.7
Info: model: 11th Gen Intel Core i7-1165G7 socket: U3E1 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 889 min/max: 400/4700 base/boost: 2800/2800 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 889 2: 889 3: 889 4: 889 5: 889 6: 889 7: 889 8: 889
bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T500 Mobile] vendor: Lenovo
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1fbb class-ID: 0302
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 30c9:003b
Device-4: Trust QHD Webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.3.3:10
chip-ID: 145f:02e7 class-ID: 0102 serial: <filter>
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: BenQ EX3415R
serial: <filter> built: 2021 res: 3440x1440 dpi: 109 gamma: 1.2 chroma: red:
x: 0.690 y: 0.310 green: x: 0.259 y: 0.671 blue: x: 0.145 y: 0.059 white:
x: 0.314 y: 0.329 size: 800x335mm (31.5x13.19") diag: 867mm (34.1")
modes: 3440x1440, 3840x2160, 2560x1440, 2560x1080, 1920x1080, 1680x1050,
1600x900, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90 2: parse_edid:
unhandled CEA mode 91 3: parse_edid: unhandled CEA mode 92 4: parse_edid:
unhandled CEA mode 93 5: parse_edid: unhandled CEA mode 94 6: parse_edid:
unhandled CEA mode 95 7: parse_edid: unhandled CEA mode 96 8: parse_edid:
unhandled CEA mode 97
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x323d built: 2018
res: 3440x1440 dpi: 158 gamma: 1.2 chroma: red: x: 0.561 y: 0.333 green:
x: 0.353 y: 0.576 blue: x: 0.165 y: 0.122 white: x: 0.314 y: 0.329
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 22.84 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA T500 driver: N/A device-ID: 10de:1fbb surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Device-2: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-2.1.1.4:9 chip-ID: 17ef:30cf class-ID: 0300
serial: <filter>
Device-3: Trust QHD Webcam driver: snd-usb-audio,uvcvideo type: USB
Device-4: Trust USB microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.3.4:11
chip-ID: 145f:02b4 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fc class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-3: Lenovo ThinkPad TBT 3 Dock driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2.1.2:5 chip-ID: 17ef:3082
class-ID: 0000 serial: <filter>
IF: enp82s0u2u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
class-ID: e001
Device-1: luks-0db0041f-ff15-4fb4-a223-7c78ca6bf4fb maj-min: 254:0
type: LUKS dm: dm-0 size: 476.64 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 476.64 GiB
Local Storage: total: 476.94 GiB used: 415.22 GiB (87.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPETJ512MGE2QDQ size: 476.94 GiB block-size: physical: 512 B
fw-rev: 1.5Q0630 temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 199d 21h cycles: 864
read-units: 15,633,278 [8.00 TB] written-units: 15,918,934 [8.15 TB]
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 415.21 GiB (88.7%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-0db0041f-ff15-4fb4-a223-7c78ca6bf4fb label: N/A
uuid: ea871510-c4d2-42e8-9618-bd238d87ccb8
used: 472 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: EAF1-E969
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-2: 3-4:3 info: Luxvisions Innotech Integrated Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 30c9:003b class-ID: fe01 serial: <filter>
Device-3: 3-9:4 info: Alcor Micro AU9540 Smartcard Reader type: smart card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 5-2:2 info: Lenovo USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:3080
Hub-7: 5-2.1:3 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
Hub-8: 5-2.1.1:6 info: Lenovo USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 17ef:3081 class-ID: 0900
Device-1: 5-2.1.1.4:9 info: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 17ef:30cf class-ID: 0300 serial: <filter>
Hub-9: 5-2.3:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-2.3.1:7 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-2: 5-2.3.2:8 info: Kinesis Advantage2 Keyboard
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 29ea:0102 class-ID: 0300 serial: <filter>
Device-3: 5-2.3.3:10 info: Trust QHD Webcam type: video,audio
Device-4: 5-2.3.4:11 info: Trust USB microphone type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-5: 5-2.5:5 info: VIA Labs 40AN type: billboard driver: N/A
power: 100mA chip-ID: 2109:8887 class-ID: 1100 serial: <filter>
Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-11: 6-2:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:307f
Hub-12: 6-2.1:3 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
Device-1: 6-2.1.2:5 info: Lenovo ThinkPad TBT 3 Dock type: Network
driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 288mA chip-ID: 17ef:3082 class-ID: 0000
serial: <filter>
Hub-13: 6-2.3:4 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2235
Packages: pm: pacman pkgs: 1732 libs: 440 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
2: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
3: https://mirror.koddos.net/manjaro/stable/$repo/$arch
4: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
5: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
7: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
8: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 310
1: cpu: 64.8% command: zoom pid: 11909 mem: 884.3 MiB (1.8%)
2: cpu: 19.8% command: firefox pid: 2011 mem: 706.5 MiB (1.4%)
3: cpu: 5.5% command: slack pid: 3958 mem: 473.9 MiB (0.9%)
4: cpu: 5.4% command: kwin_x11 pid: 1176 mem: 205.4 MiB (0.4%)
5: cpu: 4.4% command: firefox pid: 20852 mem: 305.2 MiB (0.6%)
Memory top: 5 of 310
1: mem: 884.3 MiB (1.8%) command: zoom pid: 11909 cpu: 64.8%
2: mem: 706.5 MiB (1.4%) command: firefox pid: 2011 cpu: 19.8%
3: mem: 611.8 MiB (1.2%) command: firefox pid: 2519 cpu: 1.0%
4: mem: 589.0 MiB (1.2%) command: thunderbird pid: 4582 cpu: 0.6%
5: mem: 577.3 MiB (1.2%) command: firefox pid: 2186 cpu: 2.2%
Processes: 310 Power: uptime: 2h 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.7 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: terminator inxi: 3.3.36
Mod edit:- It seems you were having some difficulty with formatting. I’ve taken the liberty of fixing that for you. If you like, click the ‘Edit’ button to see how it was done. Cheers.
