And yet, you still do it, despite being given the necessary information needed to correct that.
You have not told us how you have narrowed down this list of what you call suspect packages…
- What leads you to suspect these packages?
- What are the results of any diagnosis you have performed?
All you have given us so far is a list of packages and the vague presumption that there must be a bug; yet you provide nothing that supports that.
Let me ask YOU… how is that helpful?
Where is this *actual bug documented?
While it is always possible that (as yet) undiscovered bugs may exist in software, until a bug is actually diagnosed and defined (and is clearly reproducable by others) I’m afraid it is not a bug.
This typically indicates that the issue you’re experiencing is specific to your system, and does not affect everyone using KDE Plasma 6.2.
And this is understandable, as Plasma 6.2 hasn’t reached the Stable branch yet – 6.2.2-1 is in Unstable, and 6.2.1-1 is in Testing.
Now, if you had taken the time to specify that you are using either of these branches, that would potentially have saved time from the onset.
I suggest you heed the advice already given by @scotty65:
You should always read these announcements before posting; it can often save much wasted time.
There already exist known issues (with solutions) that may well be related to your problem. Read through the respective Update Announcements and they should magically reveal themselves unto you.
But, don’t stop there; continue reading through those announcement threads, as important information may be gleaned throughout the general comments also.
Incidentally, it seems apparent that you are refusing to provide the requested information.
In depth system information will usually allow others a better insight to other factors that might be contributing to your problem.
Please provide the command output of:
inxi --admin --verbosity=8 --filter --no-host --width
