I am using a ethernet connection but from past few days internet is not working on my device.
Mod edit: Removed picture of text. Please see: [HowTo] Post command output and file content as formatted text
how can I resolve this issue?
There isn’t enough information here to begin to address what the issue might be. Is the computer connected to a router? Do you get a connection if you connect directly to the modem, thereby ruling out router configuration issues?
Please read:
Welcome to the Manjaro forum. Here is another good starting point.
I am using a lan connection of my building so I am not connected to any router directly.
One more thing, the internet is working fine on my other machine which has MS-windows.
Few days ago it was working fine on this machine as well but now it is not, is it possible that I might have changed network settings and forgot to change them back because one day I was trying to send files over wired connection in between two devices.
Below is my inix output
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=b2093c5a-8153-45b9-a2e3-d02ae92eaf25 rw quiet splash
resume=UUID=2225189c-fc69-422c-8c97-d63dc418f29c udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X409DA_M409DA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X409DA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X409DA.306 date: 10/08/2021
ID-1: BAT0 charge: 22.7 Wh (95.8%) condition: 23.7/32.1 Wh (74.0%)
power: 7.7 W volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 567
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1296 high: 1400 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1222 2: 1400
3: 1223 4: 1400 5: 1222 6: 1400 7: 1245 8: 1261 bogomips: 33550
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 44.0 C
Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:5
chip-ID: 13d3:5a11 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14e5 built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 16.0.6 DRM 3.54 6.5.13-7-MANJARO) device-ID: 1002:15d8
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:15d8 surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:3
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp3s0f3u1u4 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:4 chip-ID: 8087:0a2b
class-ID: e001
Local Storage: total: 1.36 TiB used: 131.28 GiB (9.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 25.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0D scheme: GPT
ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.74%) used: 11.87 GiB (15.2%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 375.26 GiB size: 368.3 GiB (98.15%)
used: 119.41 GiB (32.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): cpu: 0
Processes: 259 Uptime: 8m wakeups: 0 Memory: total: 6 GiB available: 5.74 GiB
used: 2.24 GiB (39.0%) Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1234 libs: 350 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
What should I do to fix the internet issue?
Please help me solve it.
Inxi is showing that the Ethernet state is up. Have you tried the troubleshooting guide noted above? Maybe you have a DNS issue? Check your Ethernet connection settings in Network Manager. I am running Xfce, but right click network manager applet here and Enable Networking is checked.
You could try edit connections, remove the connection and recreate the Ethernet connection and reboot, maybe?
Are you using firewall or other security software. If so, try disabling and see if that is causing the issue.
Also, if you get up and running, note that kernel 6.5 is End of Life (EOL). It would be a good idea to switch to a LTS kernel, either 6.1 or 6.6 and make certain that your system is fully updated.
Okay thanks for the help.
It is working fine now, although I didn’t do much other than deleting the connection and restarting the system.
