Hi 🙋🏻,
pantheon lockscreen doesn’t have avatar
also when I unlock the locksreen my opened applications are closed
mouse&touch plug crash the whole system settings without even entering it
applications with system tray do not show their icons in panel
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=42d6f726-2cdb-4b0c-b1a7-d03ea3a531aa rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: Pantheon info: plank wm: gala dm: LightDM 1.30.0
Type: Desktop Mobo: HC . model: HCAR4000-MI serial: <superuser required>
UEFI: American Megatrends v: 5.16 date: 06/08/2021
RAM: total: 7.25 GiB used: 3.55 GiB (48.9%)
RAM Report:
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2116 high: 3988 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3988 2: 1464
3: 3055 4: 1397 5: 1397 6: 1397 bogomips: 28458
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.12-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Realtek driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
driver: r8169 v: kernel port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169 v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 281.19 GiB used: 173.62 GiB (61.7%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: ATA SSD PLUS
size: 223.57 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 04RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Lexar
model: USB Flash Drive size: 57.62 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: GPT
ID-1: / raw-size: 57.32 GiB size: 57.32 GiB (100.00%)
used: 35.48 GiB (61.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 42d6f726-2cdb-4b0c-b1a7-d03ea3a531aa
used: 568 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D13E-48C3
ID-3: /home raw-size: 57.32 GiB size: 57.32 GiB (100.00%)
ID-4: /run/media/darkeye/SanDisk raw-size: 223.57 GiB
size: 219.06 GiB (97.98%) used: 138.14 GiB (63.1%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: SanDisk uuid: 074a401b-a285-43c9-98ab-ebdde2b6947b
ID-5: /var/cache raw-size: 57.32 GiB size: 57.32 GiB (100.00%)
ID-6: /var/log raw-size: 57.32 GiB size: 57.32 GiB (100.00%)
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-3:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 214b:7250 class-ID: 0900
Hub-3: 1-3.1:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-3.1.2:6 info: Lexar USB Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 300mA
chip-ID: 21c4:0cd1 class-ID: 0806 serial: <filter>
Device-2: 1-3.1.3:8 info: MXT microSD CardReader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: aaaa:8816 class-ID: 0806 serial: <filter>
Device-3: 1-3.2:5 info: CASUE USB KB type: Keyboard,HID
power: 100mA chip-ID: 2a7a:9587 class-ID: 0300
Device-4: 1-3.3:7 info: SiGma Micro XM102K Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 1c4f:0034 class-ID: 0301
Device-5: 1-4:3 info: Shenzhen Riitek mini keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 1997:2535 class-ID: 0301
Hub-4: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: Norelsys NS1068/NS1068X SATA Bridge Controller
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 8mA chip-ID: 2537:1068 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 309 Uptime: 20h 55m wakeups: 12 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1728
pacman: 1711 lib: 460 flatpak: 17 Shell: Zsh v: 5.8
running-in: io.elementary.t inxi: 3.3.11
what should I do?
help me please
thanks
pardon my ignorance
