Arif12
16 December 2023 18:29
1
Hello,
I get an error when I want to install a package via pamac.
Error: Daemon Error: trans_run: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: The message type “(bbbbiasasasasasasasas)” does not correspond to the expected type “(bbbbiasasasasasasas)”
Thanks for help
Hanzel
16 December 2023 18:36
2
What are you installing, please give some context, does this happen with updates, just one package, does the installation continue, have you rebooted etc. Also please post info about your system.
Difficulty: ★☆☆☆☆
Rather than providing the commercial reference of a computer or piece of hardware, it is usually better to directly ask the system to describe itself. On top of saving time to everyone, this also often provides more details, including something specific to the running system.
Below is a (not exhaustive) list of commands for retrieving system information.
If you don’t know how to use those commands, or how to provide them to support, see: [HowTo] Use the terminal / TTY …
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
Arif12
16 December 2023 18:46
3
I tried it again and it worked.
I have had this problem for a few days.
The computer has been running for 11 days because I usually only use standby mode, but I will try it out.
inxi -v7azy
Kernel: 6.6.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=473530e2-ac8f-4496-b185-a444c0addf7b rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.B0
date: 08/25/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 10.46 GiB (33.4%)
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3166 high: 4364 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2414
3: 2200 4: 2399 5: 4364 6: 2150 7: 3748 8: 4178 9: 4284 10: 3670 11: 2149
12: 2150 13: 3536 14: 2459 15: 3638 16: 2154 17: 4298 18: 2151 19: 4234
20: 2566 21: 4296 22: 4287 23: 2860 24: 2200 bogomips: 182472
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: ASRock driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 ports:
active: DP-1,DVI-D-1,HDMI-A-1 empty: none bus-ID: 2b:00.0
chip-ID: 1002:699f class-ID: 0300 temp: 41.0 C
Device-2: Microdia HDP Webcam USB driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 0c45:636b
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: left model: Acer CB242Y
serial: <filter> built: 2020 res: 1920x1080 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-1 mapped: DisplayPort-0 pos: right model: Acer CB242Y
serial: <filter> built: 2020 res: 1920x1080 hz: 75 dpi: 93 gamma: 1.2
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,center model: Acer CB242Y
serial: <filter> built: 2021 res: 1920x1080 hz: 75 dpi: 93 gamma: 1.2
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 16.0.6 DRM 3.54 6.6.3-1-MANJARO) device-ID: 1002:699f
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:699f surfaces: xcb,xlib
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 bus-ID: 2b:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. LCS USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 0c76:2018 class-ID: 0300 serial: <filter>
Device-4: Microdia HDP Webcam USB driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-3: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.1:5 chip-ID: 8087:0032
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 26 state: up address: see --recommends
Local Storage: total: 4.09 TiB used: 289.57 GiB (6.9%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZRZ-00Z5HB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80
Optical-1: /dev/sr0 vendor: hp model: DVDRAM GT30L rev: mP04
dev-links: cdrom
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 180.51 GiB (39.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 473530e2-ac8f-4496-b185-a444c0addf7b
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 717D-DF0C
ID-3: /run/media/arif/Storage raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 109.06 GiB (5.9%) fs: btrfs dev: /dev/sda maj-min: 8:0 label: N/A
uuid: 3296d40e-d328-4a93-8318-324326ee65aa
Hub-2: 1-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-2.1:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Device-2: 1-5:10 info: XP-Pen Star G960 Graphic Tablet type: mouse,HID
driver: hid-generic,usbfs,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 46mA
chip-ID: 28bd:0920 class-ID: 0300
Device-3: 1-6:6 info: Apple Aluminium Keyboard (ANSI) type: keyboard,mouse
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 05ac:024f class-ID: 0301
Device-4: 1-8:7 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c91 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: JMTek LLC. LCS USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-5: 3-2:3 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 3-2.3:5 info: Initio INIC-1618L SATA type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 2mA chip-ID: 13fd:0840 class-ID: 0802
serial: <filter>
Device-2: 3-3:4 info: Microdia HDP Webcam USB type: video,audio
chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
Hub-6: 3-4:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Hub-7: 3-4.1:7 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 3-4.4:8 info: MosArt Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4102 class-ID: 0301
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 4-4:2 info: Realtek Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-10: 4-4.1:3 info: Realtek Hub ports: 4 rev: 3.0
System Temperatures: cpu: 39.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1061
Processes: 509 Uptime: 11d 2h 47m wakeups: 25 Init: systemd v: 254
Packages: 2053 pm: pacman pkgs: 2019 libs: 439 tools: pamac pm: flatpak
pkgs: 34 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: yakuake
inxi: 3.3.31
Well, try editing your post so we can read it. Using quotes for terminal output is not acceptable.
Please see:
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to form…
It did?
No problem anymore?
Arif12
16 December 2023 20:25
7
I rebooted and tried to install 5 packages but without success.
I have realized that jdk-opendjdk and jre-openjdk are in conflict with each other, but I still cant remove jre-openjdk because it is needed by jdk-openjdk?
cscs
16 December 2023 20:59
8
See one of update announcements or one the other dozen threads people similarly ignored it.
philm
17 December 2023 00:10
9
libpamac 11.6.3 changed dbus api, maybe an old pamac-daemon instance should run after upgrade.can be ignored.
Arif12
17 December 2023 00:43
10
I upgraded the linux kernel to 6.6 but didnt updated other components because I was too lazy. Maybe this was the cause.
cscs
17 December 2023 01:08
11
Partial upgrades are not supported and should be considered equal to broken.
Arif12
17 December 2023 01:14
12
So I solved all the dependencies and followed the instructions. Now the problem seems to be solved. Thanks to all
