Pacman works but pamac is giving out error
Greetings, i’m able to use pacman to update and do general stuff but trying to use pamac & the “Add/Remove Sofware” frontend doesn’t work. Unsure on what to share as logs, i’ll share what i see fit here.
pamac update --force-refresh         ✔
Preparing...
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Refreshing multilib.db...
Database file for core does not exist.
Database file for extra does not exist.
Database file for community does not exist.
Database file for multilib does not exist.
Refreshing core.files...
Refreshing extra.files...
Refreshing community.files...
Refreshing multilib.files...
Warning: multilib.files: lock file missing /var/tmp/pamac/dbs/db.lck
Nothing to do.
ls /var/lib/pacman/sync        20s
community.db  core.db  extra.db  multilib.db
In the GUI frontend & the Core repository “No package found”
In other repositories in the same frontend “No package found”
In the updates page “Error - Failed to synchronise databases”
Moderator edit: Fixed formatting
Hello,
Please read the announcement
Also possible that you might need to refresh mirrors before updating (from terminal):
sudo pacman-mirrors -f5 && sudo pacman -Syyu
I… Think that fixed it? Though
Preparing...
Failed to synchronize databases
Nothing to do.
Third line is a bit concerning.
Pamac is currently broken. Hopefully it will be fixed soon.
It already is.
Update once more with pacman, and then you can go back to pamac.
Yeah, had to select Refresh databases from the gui and then it worked again :+1:
