Running fully updated Plasma edition of Manjaro and trying to install the torguard
package from the AUR.
When attempting this in the “Add / Remove Software” GUI application the install fails. When executing pamac install torguard
in Konsole the install completes.
Any thoughts as to why the different experience?
Hi @ChaosDaemon and welcome to the Manjaro community.
My guess is that you may not have the AUR configured in pamac-manager
(the Pamac GUI version that ‘Add/Remove Software’ actually launches).
Please see:
Without specific information such as an actual error message and related logs, for example, there is not much else to be offered.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum effectively. The following links will help you achieve that.
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information.
I hope this helps. Cheers.
I just installed torguard successfully via the Pamac GUI, however it did pop up a message saying:
Error while configuring torguard
So the package was installed successfully, however it may require manual configuration.
I then removed torguard & ran the same command you ran in the CLI, installing the package successfully. However, the same error regarding configuration did appear in the terminal, although there was no pop-up alert (unlike what occurred with Pamac GUI):
Checking available disk space... [1/1]
/tmp/alpm_9jSTgF/.INSTALL: line 10: syntax error near unexpected token `}'
/tmp/alpm_9jSTgF/.INSTALL: line 10: `}'
Configuring torguard... [1/1]
Arming ConditionNeedsUpdate... [1/2]
Updating the desktop file MIME type cache... [2/2]
So, torguard installs but may not automatically configure.
