Only Dummy Sound Output
Hello,
my problem: I only get the Dummy Audio Output with the Internal SoundCard. With external SoundCard (my USB Hub has a 3.5mm jack) is it all fine. The System dosn’t detect the internal SoundCard. It isn’t listed in ALSA. But with “lspci” i see my SoundCard. And also the SoundCard workes fine under Ubuntu 20.04 and Windows.
I am completly new at Arch based Distributions.
Thanks in advance
If you need it, I am using:
Manjaro with KDE (Software is up to date)
Lenovo Yoga C740 (SSD UEFI encrypted, but without encyption it also dosn’t work)
Please provide better information so that someone can help:
For the bgeinning this could help:
inxi -Axza
Hello haschdag_baum,
could you try
arecord -l
in a terminal to see if it shows up as a sound card there?
For me it is
[julius@Pinebook ~]$ arecord -l **** Liste der Hardware-Geräte (CAPTURE) **** Karte 0: rockchipes8316c [rockchip,es8316-codec], Gerät 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 [ff890000.i2s-ES8316 HiFi ES8316 HiFi-0] Sub-Geräte: 1/1 Sub-Gerät #0: subdevice #0
found the command here
Best Regards, Julius
Okay, here the missing informations:
arecord -l
Karte 0: Device [USB PnP Audio Device], Gerät 0: USB Audio [USB Audio]
  Sub-Geräte: 1/1
[marian@Computer ~]$ inxi -Axza
  Device-1: Intel vendor: Lenovo driver: sof-audio-pci
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:02c8
  Sound Server: ALSA v: k5.6.15-1-MANJARO
inxi -Fxza
  Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
  root=UUID=0da83ece-4abf-4bb8-b87e-e2f54cf76748 rw quiet apparmor=1
  security=apparmor resume=UUID=bc646a16-ac8a-40a6-8f40-a0c9836cc68e
  udev.log_priority=3
  Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Convertible System: LENOVO product: 81TD
  v: Lenovo Yoga C740-15IML serial: <filter> Chassis: type: 31
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
  UEFI: LENOVO v: BNCN35WW date: 11/18/2019
  ID-1: BAT0 charge: 60.6 Wh condition: 60.6/60.3 Wh (101%)
  volts: 13.1/11.5 model: Sunwoda L18D3PF2 type: Li-poly serial: <filter>
  status: Full cycles: 11
  Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12)
  microcode: CA L2 cache: 6144 KiB
  bogomips: 33615
  Speed: 1000 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 995 2: 996
  3: 997 4: 993 5: 978 6: 994 7: 973 8: 989
  Type: spectre_v2
  mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
  Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:9b41
  Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
  bus ID: 1-7:3 chip ID: 174f:2426 serial: <filter>
  Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
  size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.5
  direct render: Yes
  chip ID: 8086:02c8
  Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
  bus ID: 00:14.3 chip ID: 8086:02f0
  IF: wlp0s20f3 state: down mac: <filter>
  Local Storage: total: 476.94 GiB used: 11.18 GiB (2.3%)
  ID-1: /dev/nvme0n1 vendor: Western Digital
  model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB block size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: 11130001 scheme: GPT
  ID-1: / raw size: 459.76 GiB size: 451.54 GiB (98.21%)
  used: 11.18 GiB (2.5%) fs: ext4 dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/nvme0n1p3
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 258 Uptime: 50m Memory: 15.35 GiB used: 2.44 GiB (15.9%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1223 pacman: 1219
  lib: 329 flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: konsole
  inxi: 3.1.05
arecord -l
arecord: device_list:274: keine Soundkarten gefunden ...
In English: “No SoundCard Detected”
Thank you
Hello, thanks for the info.
is your USB Dac, I believe. Please correct me if I’m wrong
It doesn’t seem to show up, unfortunately.
  • Do you know from what vendor your sound card is from? Maybe some are experiencing similar issues with this.
  • lspci makes it show up, so it should be connected to the computer. Following this guide, you could try sudo alsa force-reload, exit with Ctrl+C (oder Strg+C für die mit einer deutschen Tastatur), and reboot.
    The guide also shows other methods and I would recommend that you look at it since most should work even if the guide was written for ubuntu, originally.
Duplicate threads:
Please also see https://forum.manjaro.org/t/sound-not-working-after-upgrade/
Hi,
yes, that is my USB Hub.
I tried “your” guide and the fifth point (for the Lenovo Carbon X1) worked.
I created there the file and reboote.
Now I have sound.
Thank you a lot
