I’ve collected some of info but can’t myself see anything here.
Kernel: 5.16.11-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=dd714ad3-d5ff-4ea8-bb3a-52ba1e21aca0 rw udev.log_priority=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire E5-774G v: V1.27
serial: <superuser required>
Mobo: Acer model: Hulk_SK v: V1.27 serial: <superuser required>
UEFI: Insyde v: 1.27 date: 05/26/2017
ID-1: BAT1 charge: 28.4 Wh (100.0%) condition: 28.4/32.6 Wh (87.3%)
volts: 16.6 min: 14.8 model: SIMPLO AS16A7K type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
RAM: total: 11.56 GiB used: 2.58 GiB (22.3%)
RAM Report:
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3100 high: 3101 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 3101 3: 3099
4: 3100 bogomips: 21607
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel ports: active: HDMI-A-1 off: eDP-1 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Acer Incorporated ALI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:179c class-ID: 0302
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:7
chip-ID: 04f2:b573 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: HDMI-1 mapped: HDMI-A-1 model: BenQ ZOWIE XL LCD
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x298mm (20.9x11.7") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
Device-3: C-Media CM102-A+/102S+ Audio Controller type: USB
driver: snd-usb-audio bus-ID: 1-3.4:8 chip-ID: 0d8c:0103 class-ID: 0102
Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0f1 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-5:5 chip-ID: 04ca:3015 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Device-1: luks-e752cce6-f105-41cc-ab87-ab1f97df1fc5 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.5 GiB
Components:
p-1: sda maj-min: 8:0 size: 931.51 GiB
Local Storage: total: 1.14 TiB used: 706.81 GiB (60.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A9E680
type: HDD rpm: 5400 serial: <filter> rev: A560
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: HFS256G39TND-N210A
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1P10 scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XA11
dev-links: cdrom
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 18.32 GiB (37.5%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: dd714ad3-d5ff-4ea8-bb3a-52ba1e21aca0
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: CB4B-F8B2
ID-3: /home raw-size: 16 GiB size: 15.58 GiB (97.38%)
used: 4.63 GiB (29.7%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: a1a9ae94-1fd1-448c-b9b4-b987e58344be
ID-4: /mnt/Storage raw-size: 931.5 GiB size: 931.04 GiB (99.95%)
used: 626.54 GiB (67.3%) fs: xfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-e752cce6-f105-41cc-ab87-ab1f97df1fc5 label: Storage
uuid: 42db42a4-67a2-4ae3-80d8-fcdfbe7af9f0
ID-5: /mnt/Stuff raw-size: 172.18 GiB size: 168.42 GiB (97.82%)
used: 57.31 GiB (34.0%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: Stuff
uuid: 1ba01698-8904-4e2d-a663-82e94562a903
ID-1: swap-1 type: file size: 3 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-3:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 1-3.1:4 info: Kingston HyperX Alloy Elite type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 0951:16bf class-ID: 0301
Device-2: 1-3.2:6 info: SteelSeries ApS Rival 600 type: HID,Mouse
power: 200mA chip-ID: 1038:1724 class-ID: 0300
Device-3: 1-3.4:8 info: C-Media CM102-A+/102S+ Audio Controller
type: Audio driver: snd-usb-audio interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 0d8c:0103 class-ID: 0102
Device-4: 1-4:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-5: 1-5:5 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04ca:3015 class-ID: e001
Device-6: 1-7:7 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b573
class-ID: 0e02
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 62.0 C pch: 61.5 C mobo: N/A
Processes: 241 Uptime: 16m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1414 lib: 445
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.13
Mar 03 17:04:04 acer-pc kernel:
Mar 03 17:04:06 acer-pc kernel: snd_hda_intel 0000:01:00.1: no codecs found!
Mar 03 17:04:07 acer-pc kernel: snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
Mar 03 17:04:11 acer-pc systemd[729]: Failed to start Update XDG user dir configuration.
-- Subject: A start job for unit UNIT has failed
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- A start job for unit UNIT has finished with a failure.
-- The job identifier is 27 and the job result is failed.
Mar 03 17:04:18 acer-pc nmbd[896]: [2022/03/03 17:04:18.909750, 0] ../../source3/nmbd/nmbd.c:901(main)
Mar 03 17:04:18 acer-pc nmbd[896]: nmbd version 4.15.5 started.
Mar 03 17:04:18 acer-pc nmbd[896]: Copyright Andrew Tridgell and the Samba Team 1992-2021
Mar 03 17:04:19 acer-pc smbd[909]: [2022/03/03 17:04:19.019661, 0] ../../source3/smbd/server.c:1734(main)
Mar 03 17:04:19 acer-pc smbd[909]: smbd version 4.15.5 started.
Mar 03 17:04:19 acer-pc smbd[909]: Copyright Andrew Tridgell and the Samba Team 1992-2021
Mar 03 17:04:21 acer-pc bluetoothd[505]: Failed to set mode: Blocked through rfkill (0x12)
Mar 03 17:04:22 acer-pc pulseaudio[1078]: Failed to find a working profile.
Mar 03 17:04:22 acer-pc pulseaudio[1078]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
Mar 03 17:04:51 acer-pc nmbd[896]: [2022/03/03 17:04:51.978090, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mar 03 17:04:51 acer-pc nmbd[896]: *****
Mar 03 17:04:51 acer-pc nmbd[896]: Samba name server ACER-PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.189
Mar 03 17:04:51 acer-pc nmbd[896]: [2022/03/03 17:04:51.979944, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mar 03 17:04:51 acer-pc nmbd[896]: Samba name server ACER-PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.122.1
Mar 03 18:50:41 acer-pc kdeconnectd[46099]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Mar 03 18:50:41 acer-pc kdesud[2304]: kf.su.kdesud: Fatal IO error, exiting...
Mar 03 18:50:41 acer-pc nmbd[896]: [2022/03/03 18:50:41.255216, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Mar 03 18:50:41 acer-pc nmbd[896]: Got SIGTERM: going down...
Mar 03 18:50:41 acer-pc systemd-coredump[46111]: Failed to connect to coredump service: Connection refused
Mar 03 18:50:41 acer-pc pulseaudio[1078]: Error opening PCM device front:0: No such file or directory
Mar 03 18:50:46 acer-pc kernel: watchdog: watchdog0: watchdog did not stop!
journalctl -p err..alert PIPE|0 ✔ 4s
Mar 03 12:01:53 acer-pc kernel: x86/cpu: SGX disabled by BIOS.
Mar 03 12:01:54 acer-pc kernel:
Mar 03 12:01:55 acer-pc kernel: snd_hda_intel 0000:01:00.1: no codecs found!
Mar 03 12:02:22 acer-pc systemd[511]: Failed to start Update XDG user dir configuration.
Mar 03 12:02:33 acer-pc pulseaudio[695]: Failed to find a working profile.
Mar 03 12:02:33 acer-pc pulseaudio[695]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_0>
Mar 03 12:12:10 acer-pc systemd-udevd[244]: /usr/lib/udev/rules.d/60-tpm-udev.rules:3 Unknown user 'tss', ignoring
Mar 03 12:12:10 acer-pc systemd-udevd[244]: /usr/lib/udev/rules.d/60-tpm-udev.rules:4 Unknown user 'tss', ignoring
Mar 03 12:12:10 acer-pc systemd-udevd[244]: /usr/lib/udev/rules.d/60-tpm-udev.rules:4 Unknown group 'tss', ignoring
Mar 03 12:13:36 acer-pc systemd-coredump[8104]: Failed to connect to coredump service: Connection refused
Mar 03 12:13:36 acer-pc pulseaudio[8209]: Failed to find a working profile.
Mar 03 12:13:36 acer-pc pulseaudio[8209]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_>
Mar 03 12:13:37 acer-pc systemd-coredump[8216]: Failed to connect to coredump service: Connection refused
Mar 03 12:13:37 acer-pc kded5[8215]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this>
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite->
Mar 03 12:13:37 acer-pc systemd-coredump[8217]: Failed to connect to coredump service: Connection refused
Mar 03 12:13:37 acer-pc systemd-coredump[8227]: Failed to connect to coredump service: Connection refused
Mar 03 12:13:38 acer-pc pulseaudio[8209]: Failed to acquire org.PulseAudio1: org.freedesktop.DBus.Error.Disconnected: Connection was disconnected before a reply wa>
Mar 03 12:13:39 acer-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot 9603e071532e477685087e766a84e308 --
Mar 03 12:13:57 acer-pc kernel: x86/cpu: SGX disabled by BIOS.
Mar 03 12:13:58 acer-pc kernel:
Mar 03 12:13:59 acer-pc kernel: snd_hda_intel 0000:01:00.1: no codecs found!
Mar 03 12:14:04 acer-pc systemd[504]: Failed to start Update XDG user dir configuration.
Mar 03 12:14:17 acer-pc pulseaudio[736]: Failed to find a working profile.
Mar 03 12:14:17 acer-pc pulseaudio[736]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_0>
Mar 03 12:16:51 acer-pc systemd-coredump[5012]: Failed to connect to coredump service: Connection refused
Mar 03 12:16:52 acer-pc kded5[5011]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this>
Mar 03 12:16:52 acer-pc systemd-coredump[5024]: Failed to connect to coredump service: Connection refused
Mar 03 12:16:52 acer-pc pulseaudio[736]: Error opening PCM device front:0: No such file or directory
Mar 03 12:16:54 acer-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot 6b8b58c9cf0a4b48a9032d28cd2b2175 --
Mar 03 12:17:08 acer-pc kernel: x86/cpu: SGX disabled by BIOS.
