I have read similar posts on here that talk about their backlight key not working. My situation seems different. When I first boot into Manjaro it works fine. My backlight key has 3 levels. Bright, dim and off. Everytime I press the key it cycles through these steps.
With the testing I have done so far it seems that after the computer goes to sleep and wakes up the key changes its function to when I hit the key it goes to sleep. I hit the key again and the laptop wakes up. Very weird. Also during this time the light no longer functions.
I have a feeling it is a kernel issue but not sure how to go about troubleshooting to be sure.
I was thinking about downgrading the kernel as a try but didn’t know how far back to go.
I will include my inxi results below.
I don’t know exactly when this started. I have done several kernel upgrades and don’t always use the backlight on the keyboard.
Thanks
Kernel: 6.10.6-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet
udev.log_priority=3 libata.noacpi=1 iwlwifi.bt_coex_active=0
iwlwifi.power_save=0
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_x11
tools: xscreensaver,xscreensaver-systemd dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 863F v: 54.24 serial: <filter> part-nu: 7UT64UA#ABA
uuid: 39444335-3134-5142-354e-4e5131344435 UEFI: AMI v: F.32
date: 12/08/2023
ID-1: BAT0 charge: 64.0 Wh (100.0%) condition: 64.0/64.0 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 250
Device-1: hid-0018:04F3:2992.0003-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
System RAM: total: 16 GiB available: 15.26 GiB used: 3.45 GiB (22.6%)
igpu: 64 MiB
Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
size: 8 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1K43CB1-CTD serial: <filter>
Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
bus-ID: 00:01.0
Info: model: Intel Core i7-10510U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xFC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4900 base/boost: 2673/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 36812
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: 545.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b67b
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 300 s-size: 325x182mm (12.80x7.17")
s-diag: 372mm (14.66")
Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
hz: 60 dpi: 284 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green: x: 0.310
y: 0.608 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 3840x2160
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9b41 memory: 7.45 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:9b41 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0401
API: ALSA v: k6.10.6-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Local Storage: total: 931.51 GiB used: 271.12 GiB (29.1%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 82d 7h cycles: 3,072
read-units: 60,902,704 [31.1 TB] written-units: 45,324,936 [23.2 TB]
ID-1: / raw-size: 163 GiB size: 160.13 GiB (98.24%) used: 51.7 GiB (32.3%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8
label: Manjaro uuid: 45ca132d-4a37-4dc3-afa0-be2e80d6a4a2
ID-2: /boot/efi raw-size: 499 MiB size: 498 MiB (99.80%)
used: 72.1 MiB (14.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 385A-127E
ID-3: /home raw-size: 382.57 GiB size: 375.5 GiB (98.15%)
used: 219.34 GiB (58.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: Data for Manjaro
uuid: 1f7a0eb8-f3e9-46ef-a88a-e3ae0ed0233d
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p10 maj-min: 259:10 size: 2 GiB fs: ext4 label: N/A
uuid: 7b881044-e7f4-4adb-8f7c-03a4bf158c1a
ID-3: /dev/nvme0n1p11 maj-min: 259:11 size: 16 GiB fs: swap label: N/A
uuid: 24f2c822-affd-40ce-a183-d76c98c31df5
ID-4: /dev/nvme0n1p12 maj-min: 259:12 size: 3 MiB fs: ufs label: N/A
uuid: 6354a81a1b0b8929
ID-5: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-6: /dev/nvme0n1p4 maj-min: 259:4 size: 218.98 GiB fs: ntfs label: N/A
uuid: EAEA681CEA67E375
ID-7: /dev/nvme0n1p5 maj-min: 259:5 size: 961 MiB fs: ntfs label: N/A
uuid: 863E127D3E126709
ID-8: /dev/nvme0n1p6 maj-min: 259:6 size: 90 GiB fs: ext4 label: N/A
uuid: d702f568-b918-4354-874a-f1d82eaf1f37
ID-9: /dev/nvme0n1p9 maj-min: 259:9 size: 57 GiB fs: ext4
label: Arch Linux uuid: 91f4ccdf-2376-48ab-a390-91ea0bc4b02a
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: MosArt Wireless Keyboard/Mouse type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4101 class-ID: 0301
Device-2: 1-5:3 info: Chicony HP Wide Vision FHD Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b67b class-ID: 0e02
serial: <filter>
Device-3: 1-9:4 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:00bb class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 62.0 C pch: 58.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1738 libs: 348 tools: pamac,yay
1: https://volico.mm.fcix.net/manjaro/unstable/$repo/$arch
2: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
3: https://ohioix.mm.fcix.net/manjaro/unstable/$repo/$arch
4: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
6: https://ridgewireless.mm.fcix.net/manjaro/unstable/$repo/$arch
7: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
8: http://mirror.fcix.net/manjaro/unstable/$repo/$arch
9: https://ask4.mm.fcix.net/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 274
1: cpu: 100% command: ps pid: 3116 mem: 3.57 MiB (0.0%)
2: cpu: 26.2% command: vivaldi-bin pid: 1995 mem: 232.3 MiB (1.4%)
3: cpu: 18.5% command: vivaldi-bin pid: 1961 mem: 178.9 MiB (1.1%)
4: cpu: 9.1% command: kwin_x11 pid: 1403 mem: 221.7 MiB (1.4%)
5: cpu: 7.0% command: vivaldi-bin pid: 2235 mem: 228.6 MiB (1.4%)
Memory top: 5 of 274
1: mem: 438.1 MiB (2.8%) command: vivaldi-bin pid: 1911 cpu: 3.7%
2: mem: 422.3 MiB (2.7%) command: plasmashell pid: 1430 cpu: 1.6%
3: mem: 232.3 MiB (1.4%) command: vivaldi-bin pid: 1995 cpu: 26.2%
4: mem: 229.5 MiB (1.4%) command: vivaldi-bin pid: 1966 cpu: 0.4%
5: mem: 228.6 MiB (1.4%) command: vivaldi-bin pid: 2235 cpu: 7.0%
Processes: 274 Power: uptime: 11m states: freeze,mem,disk suspend: s2idle
image: 6.08 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 256
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: mymenu.sh (sudo) default: Bash
v: 5.2.32 running-in: alacritty inxi: 3.3.35
I put "code /code " in but it didn’t seem to work
but it does work ...
base: Arch Linux
v: N/A serial: Chassis: type: 31 serial:
Mobo: HP model: 863F v: 54.24 serial: part-nu: 7UT64UA#ABA
date: 12/08/2023
igpu: 64 MiB
bus-ID: 00:01.0
bogomips: 36812
loop
class-ID: 0300
class-ID: 0e02 serial:
modes: 3840x2160
inactive: wayland
class-ID: 0401
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
wpa_supplicant
WAN IP:
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
uuid: N/A
uuid: N/A
serial:
Device-3: 1-9:4 info: Synaptics type: driver: N/A
Processes:
CPU top: 5 of 274
no idea re your issue - my backlight can’t be switched on/off - it’s dependent on ambient brightness and automatic
No mine don’t work off of ambient brightness. When I start to type it lights up.
same for mine - what I meant is:
it won’t turn on when the ambient brightness is high enough for all the keys to be clearly visible
there is no switch or key to turn the feature on/off
if it’s dark outside - it will turn on as soon as a key is touched - and will turn off again a few seconds later
(I responded too quickly - you where still writing, it seems - and now my post doesn’t make sense …)
Never tested that but there is a key. It is the f5 function key on my laptop.
New info I use xscreensaver. When the screensaver kicked in and I clicked my mouse to activate the screen the function key for the keyboard light changed to putting the computer to sleep and no longer lights up the keyboard when I hit it or start typing,
I tried the things in the arch wiki on keyboard brightness but none of that worked for me.
I couldn’t get the service to start. It said it couldn’t find the service and the python script gave me errors.
I also noticed that when the keyboard doesn’t light up while typing that if I press the Caps lock button it doesn’t stay light . It just flashes the light on and off but it is in Caps lock mode.
It might be early but it looks like this kernel update fixed my issue.
demo@Manjaro ~]$ uname -a
Linux Manjaro 6.10.6-8-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Aug 23 11:48:22 UTC 2024 x86_64 GNU/Linux
[demo@Manjaro ~]$
I was wrong I still have the problem.
I know I’m not supposed to create a new reply but nobody has suggested anything for me.
I am at a loss for what to do here. I have been through several kernel updates and none of them are making a difference.
I’m not sure what to try to figure this out.
I Have decided to try some different kernels to see if that is the issue.
Right now I installed:
[demo@Manjaro ~]$ uname -a
Linux Manjaro 5.15.165-1-MANJARO #1 SMP PREEMPT Mon Aug 19 08:27:54 UTC 2024 x86_64 GNU/Linux
And it is working
Linux Manjaro 6.1.106-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Aug 19 10:07:05 UTC 2024 x86_64 GNU/Linux
works
Linux Manjaro 6.6.47-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Aug 19 09:51:26 UTC 2024 x86_64 GNU/Linux
[demo@Manjaro ~]$
works
Well I was hoping somebody would respond with something that could make me sure I was on the right path for this issue.
Since it is working with kernel 6.6.47-1-MANJARO I will conclude that something in the newer kernels has broken my backlight keyboard light.
Maybe there is a bug report out there but I don’t know where to look for that.
I will mark this solved once again.
Thanks
system
Closed
27 August 2024 23:00
7
