Hi all,
i have an issue with my old 4k Asus PQ321 Display.
As its one of the first 4k Screens it consists of two panels build into one screen. Each panel has a resolution of 1920x2160 therefore they have in sum a resolution of 3840*2160.
The monitor is connected to a Nvidia Geforce GTX 1080 Ti via DisplayPort cable (Display Port is the only connector on the monitor).
Operating System is newest Manjaro Gnome using most recent drivers from Nvidia (495.46).
The screen always behaves like two screens. (e.g. if i maximize a window, it gets maximized to the half of the screen. Obviously i want the screen to behave as “one screen”.
I played around with NVIDIA TwinView in my xorg.conf but nothing works.
inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.16-x86_64
root=UUID=95f7291c-068c-4796-ab27-c17678062e8b rw rootflags=subvol=@ quiet
cryptdevice=UUID=cc842f03-b24e-40af-960e-1bea21320816:luks-cc842f03-b24e-40af-960e-1bea21320816
root=/dev/mapper/luks-cc842f03-b24e-40af-960e-1bea21320816
udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5861
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
Device-2: hidpp_battery_1 model: Logitech MX Master 3 for Mac
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.59 GiB used: 3.14 GiB (20.1%)
RAM Report:
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1925 high: 2163 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1888 2: 1891
3: 1887 4: 1864 5: 1891 6: 1887 7: 2140 8: 1983 9: 1887 10: 1882 11: 1890
12: 1890 13: 1890 14: 1884 15: 2163 16: 1892 bogomips: 118433
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:1b06
class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 09:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-2: Focusrite-Novation Scarlett Solo (3rd Gen.) type: USB
driver: snd-usb-audio bus-ID: 1-8:2 chip-ID: 1235:8211 class-ID: 0102
serial: <filter>
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: e000 bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: luks-cc842f03-b24e-40af-960e-1bea21320816 maj-min: 254:0
type: LUKS dm: dm-0 size: 465.46 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 465.46 GiB
Device-2: nvme1n1p1_crypt maj-min: 254:1 type: LUKS dm: dm-1
Components:
p-1: nvme1n1p1 maj-min: 259:4 size: 931.51 GiB
Local Storage: total: 1.36 TiB used: 253.8 GiB (18.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 29.9 C scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
used: 54.38 GiB (11.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cc842f03-b24e-40af-960e-1bea21320816 label: N/A
uuid: 95f7291c-068c-4796-ab27-c17678062e8b
used: 712 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 1BDE-5084
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-4: /mnt/1tb raw-size: 931.5 GiB size: 915.8 GiB (98.32%)
used: 199.42 GiB (21.8%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
mapped: nvme1n1p1_crypt label: N/A uuid: N/A
ID-5: /swap raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-6: /var/cache raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-7: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-8:2 info: Focusrite-Novation Scarlett Solo (3rd Gen.)
type: Audio driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 1235:8211 class-ID: 0102 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 48 C
Processes: 384 Uptime: 1h 31m wakeups: 11 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1315
lib: 437 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
xrandr output:
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
DP-0.8 connected primary 1920x2160+0+0 (normal left inverted right x axis y axis) 349mm x 393mm
1920x2160 60.00*+ 50.00
1920x1200 59.95
1920x1080 60.00 59.94 50.00 23.98
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1400x1050 59.98
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-0.1.8 connected 1920x2160+1920+0 (normal left inverted right x axis y axis) 349mm x 393mm
1920x1200 59.95
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1400x1050 59.98
1280x960 60.00
1280x800 59.81
720x576 50.00
720x480 59.94
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected (normal left inverted right x axis y axis)
2560x1440 59.95 + 74.97
2048x1080 60.00 24.00
1920x1080 60.00 59.94 50.00 25.00 23.98 60.00 50.04 50.04
1600x900 60.00
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
I recreated the xorg.conf file with the command nvidia-xconfig as my last fruitless tries killed my system. Therefore its currently in its original status:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 495.46
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
xorg.conf after pasting data from nvidia-settings:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 470.57.01
Screen 0 "Screen0" 0 0
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "Ancor Communications Inc PQ321"
HorizSync 24.0 - 140.0
VertRefresh 20.0 - 77.0
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
BoardName "NVIDIA GeForce GTX 1080 Ti"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-3.8"
Option "metamodes" "DP-0.1.8: nvidia-auto-select +1920+0, DP-0.8: nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
Depth 24
EndSubSection
EndSection
Thank you very much!
PS: I also posted the question on askubuntu (as i also experimented with Ubuntu), but didnt get an answer there.
Edit: Seems to be the same issue as described here: In Archlinux Forums Thread with ID 247064 (sorry dont have enough karma to post links)
