Okular reader turns to light theme after the update
My Okular reader turns to light theme after the update. Not sure know how to switch it back or there is a bug.
Maybe just go to Settings > Color Scheme and set it to Default.
The color scheme is already in default.
Btw my DE is Gnome
Ah, so are you using Kvantum, Qt5/Qt6 Settings (qt5ct) or Gnome Platform for Qt applications? It might be related to your /etc/environment … This should help:
I think it is Gnome Platform as I don’t have Kvantum and qt5ct installed.
Following the post you mentioned I set QT_QPA_PLATFORMTHEME and QT_STYLE_OVERRIDE in /etc/environment but it has no effect to Okular.
Other QT based apps like Telegram, QDBusViewer are still respecting dark theme after this stable update.
Here’s my current /etc/environment:
# This file is parsed by pam_env module
# Syntax: simple "KEY=VAL" pairs on separate lines
# https://doc.qt.io/qt-5/highdpi.html#high-dpi-support-in-qt
QT_AUTO_SCREEN_SCALE_FACTOR=1
# Available options: gtk2, gnome, kde, qt5ct, xcb
QT_QPA_PLATFORMTHEME=gnome
# Available styles: HighContrastInverse, HighContrast, Adwaita-HighContrastInverse,
# Adwaita-HighContrast, Adwaita-Dark, Adwaita, kvantum-dark, kvantum, qt5ct-style,
# Windows, Fusion
QT_STYLE_OVERRIDE=Adwaita-Dark
EDITOR=/usr/bin/nano
and what’re being updated today:
[2022-09-13T09:58:39+0200] [ALPM] upgraded yt-dlp (2022.07.18-1 -> 2022.09.01-1)
[2022-09-13T09:58:39+0200] [ALPM] upgraded wireless-regdb (2022.06.06-1 -> 2022.08.12-1)
[2022-09-13T09:58:39+0200] [ALPM] upgraded webkit2gtk-4.1 (2.36.6-1 -> 2.36.7-1)
[2022-09-13T09:58:39+0200] [ALPM] upgraded webapp-manager (1.2.4-1 -> 1.2.5-1)
[2022-09-13T09:58:39+0200] [ALPM] upgraded vivaldi-ffmpeg-codecs (104.0.5112.79-1 -> 104.0.5112.101-1)
[2022-09-13T09:58:39+0200] [ALPM] upgraded virtualbox (6.1.36-1 -> 6.1.38-1)
[2022-09-13T09:58:38+0200] [ALPM] upgraded telegram-desktop (4.1.0-1 -> 4.1.1-1)
[2022-09-13T09:58:38+0200] [ALPM] upgraded taglib (1.12-1 -> 1.12-2)
[2022-09-13T09:58:38+0200] [ALPM] upgraded sof-firmware (2.2-1 -> 2.2.1-1)
[2022-09-13T09:58:38+0200] [ALPM] upgraded snapd-glib (1.60-1 -> 1.63-1)
[2022-09-13T09:58:38+0200] [ALPM] upgraded snapd (2.57.1-1 -> 2.57.1-2)
[2022-09-13T09:58:38+0200] [ALPM] upgraded signal-desktop (5.54.0-1 -> 5.57.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded rsync (3.2.5pre2-1 -> 3.2.5-2)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-desktop (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-virtiofsd (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-vhost-user-gpu (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-spice-app (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-sdl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded sdl2_image (2.6.1-1 -> 2.6.2-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-gtk (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-egl-headless (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-dbus (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-curses (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-tools (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-system-x86 (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded seabios (1.16.0-2 -> 1.16.0-3)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-pr-helper (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-img (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-usb-smartcard (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-usb-redirect (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-usb-host (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-s390x-virtio-gpu-ccw (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-virtio-vga (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-hw-display-qxl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-chardev-spice (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-block-ssh (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-block-nfs (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-block-dmg (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-block-curl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-spice (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-spice-core (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-ui-opengl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-sdl (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-pa (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-oss (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-jack (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-dbus (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-audio-alsa (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded qemu-common (7.0.0-10 -> 7.0.0-12)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-systemd (234-11 -> 235-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-setproctitle (1.2.3-1 -> 1.3.1-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-keyring (23.4.0-1 -> 23.9.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-secretstorage (3.3.2-1 -> 3.3.3-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-importlib-metadata (4.8.1-3 -> 4.8.3-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-google-api-python-client (2.56.0-1 -> 2.57.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-protobuf (21.4-1 -> 21.5-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-six (1.16.0-5 -> 1.16.0-6)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-google-auth (1.34.0-4 -> 1.35.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-gnupg (0.4.9-1 -> 0.5.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-filelock (3.6.0-1 -> 3.8.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded python-bcrypt (3.2.2-1 -> 4.0.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded plymouth-theme-manjaro (2.1-2 -> 2.2-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded plymouth (22.02.122-4 -> 22.02.122-10)
[2022-09-13T09:58:37+0200] [ALPM] upgraded perl-alien-build (2.51-1 -> 2.53-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded okular (22.04.3-1 -> 22.08.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded purpose (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded threadweaver (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded poppler-qt5 (22.08.0-1 -> 22.09.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded npm (8.17.0-1 -> 8.19.1-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded nodejs-nopt (5.0.0-2 -> 6.0.0-1)
[2022-09-13T09:58:37+0200] [ALPM] upgraded nodejs (18.7.0-1 -> 18.8.0-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded networkmanager-openvpn (1.8.18-2 -> 1.10.0-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded networkmanager (1.38.4-1 -> 1.40.0-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded slang (2.3.2-2 -> 2.3.3-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded nerd-fonts-noto-sans-mono (2.1.0-1 -> 2.2.2-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded nautilus-admin (1.1.9+5+ga51885e-1 -> 1.1.9+5+ga51885e-2)
[2022-09-13T09:58:36+0200] [ALPM] upgraded osinfo-db (20220727-1 -> 20220830-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded poppler-glib (22.08.0-1 -> 22.09.0-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.7-6 -> 0.5.7-9)
[2022-09-13T09:58:36+0200] [ALPM] upgraded manjaro-settings-manager (0.5.7-6 -> 0.5.7-9)
[2022-09-13T09:58:36+0200] [ALPM] upgraded manjaro-release (21.3.7-1 -> 22.0.0pre2-1)
[2022-09-13T09:58:36+0200] [ALPM] upgraded lollypop (1.4.34-1 -> 1.4.35-2)
[2022-09-13T09:58:28+0200] [ALPM] upgraded linux515-virtualbox-host-modules (6.1.36-8 -> 6.1.38-2)
[2022-09-13T09:58:19+0200] [ALPM] upgraded linux515-nvidia (515.65.01-2 -> 515.65.01-8)
[2022-09-13T09:58:19+0200] [ALPM] upgraded linux515 (5.15.60-1 -> 5.15.65-1)
[2022-09-13T09:58:18+0200] [ALPM] upgraded linux-firmware (20220708.be7798e-1 -> 20220815.8413c63-1)
[2022-09-13T09:58:18+0200] [ALPM] upgraded linux-firmware-whence (20220708.be7798e-1 -> 20220815.8413c63-1)
[2022-09-13T09:58:18+0200] [ALPM] upgraded libvirt (1:8.6.0-2 -> 1:8.7.0-1)
[2022-09-13T09:58:17+0200] [ALPM] upgraded libvips (8.13.0-1 -> 8.13.1-1)
[2022-09-13T09:58:17+0200] [ALPM] upgraded libreoffice-fresh (7.3.5-3 -> 7.4.0-3)
[2022-09-13T09:58:16+0200] [ALPM] upgraded xmlsec (1.2.34-1 -> 1.2.34-2)
[2022-09-13T09:58:16+0200] [ALPM] upgraded libnm (1.38.4-1 -> 1.40.0-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded liblouis (3.22.0-1 -> 3.23.0-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded libkexiv2 (22.04.3-1 -> 22.08.0-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded libgnomekbd (1:3.26.1+r5+g54da436-1 -> 1:3.28.1-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded libatomic_ops (7.6.12-1 -> 7.6.14-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded lib32-mesa (22.1.6-1 -> 22.1.7-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded lib32-libxml2 (2.9.14-1 -> 2.10.2-2)
[2022-09-13T09:58:16+0200] [ALPM] upgraded lib32-curl (7.84.0-1 -> 7.85.0-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded lib32-krb5 (1.19.3-2 -> 1.20-1)
[2022-09-13T09:58:16+0200] [ALPM] upgraded lib32-gcc-libs (12.1.1-4 -> 12.2.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded less (1:590-1 -> 1:608-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kpty (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kparts (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kjs (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kitemmodels (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kirigami2 (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded qt5-quickcontrols2 (5.15.5+kde+r5-1 -> 5.15.5+kde+r6-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kactivities (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kaccounts-integration (22.04.3-1 -> 22.08.0-2)
[2022-09-13T09:58:15+0200] [ALPM] upgraded libaccounts-glib (1.25-7 -> 1.26-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded signon-kwallet-extension (22.04.3-1 -> 22.08.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kcmutils (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kdeclarative (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kpackage (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kio (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kded (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded ktextwidgets (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded sonnet (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kcompletion (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kwallet (5.96.0-1 -> 5.97.0-4)
[2022-09-13T09:58:15+0200] [ALPM] installed qca-qt5 (2.3.4-3)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kservice (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded knotifications (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kbookmarks (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kxmlgui (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kiconthemes (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded karchive (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kitemviews (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kconfigwidgets (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded ki18n (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kguiaddons (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kcodecs (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kauth (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kglobalaccel (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kcrash (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:15+0200] [ALPM] upgraded kwindowsystem (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded kconfig (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded kdbusaddons (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded kjobwidgets (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded kwidgetsaddons (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded kcoreaddons (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded solid (5.96.0-1 -> 5.97.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded xfsprogs (5.18.0-1 -> 5.19.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded liburcu (0.13.1-1 -> 0.13.2-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded ndctl (73-1 -> 74-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded qt5-base (5.15.5+kde+r174-1 -> 5.15.5+kde+r182-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded js91 (91.12.0-1 -> 91.13.0-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded inetutils (2.2-1 -> 2.3-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded ibus (1.5.26-2 -> 1.5.27-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded libibus (1.5.26-2 -> 1.5.27-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded hunspell (1.7.0-4 -> 1.7.1-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded gvim (9.0.0135-1 -> 9.0.0354-1)
[2022-09-13T09:58:14+0200] [ALPM] upgraded vim-runtime (9.0.0135-1 -> 9.0.0354-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded gtksourceview-pkgbuild (4+1+g69f930f-2 -> 5-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded grilo-plugins (1:0.3.14-1 -> 1:0.3.15-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded webkit2gtk (2.36.6-1 -> 2.36.7-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded libwpe (1.12.2-1 -> 1.12.3-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded imagemagick (7.1.0.45-1 -> 7.1.0.47-2)
[2022-09-13T09:58:13+0200] [ALPM] upgraded neon (0.32.2-1 -> 0.32.3-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded libopenmpt (0.6.4-1 -> 0.6.5-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded libltc (1.3.1-3 -> 1.3.2-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded libdmapsharing (2.9.41-1 -> 2.9.41-2)
[2022-09-13T09:58:13+0200] [ALPM] upgraded grilo (0.3.14-1 -> 0.3.15-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded gnome-bluetooth-3.0 (42.2-1 -> 42.4-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded gnome-appfolders-manager (0.4.5-2 -> 0.4.6-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-setuptools (1:61.3.1-1 -> 1:62.3.4-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-validate-pyproject (0.9-1 -> 0.10.1-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-trove-classifiers (2022.8.7-1 -> 2022.8.31-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-ordered-set (4.0.2-6 -> 4.1.0-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-nspektr (0.4.0-1 -> 0.4.0-2)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-jaraco.text (3.8.1-1 -> 3.9.1-1)
[2022-09-13T09:58:13+0200] [ALPM] installed python-inflect (6.0.0-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-pydantic (1.9.2-1 -> 1.10.2-1)
[2022-09-13T09:58:13+0200] [ALPM] installed python-autocommand (2.2.1-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-jaraco.context (4.1.1-2 -> 4.1.2-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded python-appdirs (1.4.4-6 -> 1.4.4-7)
[2022-09-13T09:58:13+0200] [ALPM] upgraded gmime3 (3.2.12-1 -> 3.2.13-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded gmic (3.1.5-1 -> 3.1.6-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded openmpi (4.1.4-1 -> 4.1.4-2)
[2022-09-13T09:58:13+0200] [ALPM] upgraded openpmix (4.1.2-1 -> 4.2.0-1)
[2022-09-13T09:58:13+0200] [ALPM] upgraded opencv (4.6.0-3 -> 4.6.0-4)
[2022-09-13T09:58:13+0200] [ALPM] upgraded libheif (1.12.0-3 -> 1.13.0-2)
[2022-09-13T09:58:13+0200] [ALPM] upgraded graphicsmagick (1.3.38-3 -> 1.3.38-4)
[2022-09-13T09:58:12+0200] [ALPM] upgraded libtool (2.4.7-3 -> 2.4.7-5)
[2022-09-13T09:58:12+0200] [ALPM] upgraded git (2.37.2-1 -> 2.37.3-1)
[2022-09-13T09:58:12+0200] [ALPM] upgraded gcc (12.1.1-4 -> 12.2.0-1)
[2022-09-13T09:58:12+0200] [ALPM] upgraded fwupd (1.8.3-1 -> 1.8.4-1)
[2022-09-13T09:58:12+0200] [ALPM] upgraded protobuf (21.4-1 -> 21.5-1)
[2022-09-13T09:58:12+0200] [ALPM] upgraded flatpak (1:1.12.7-1 -> 1:1.14.0-1)
[2022-09-13T09:58:12+0200] [ALPM] upgraded ldns (1.8.1-1 -> 1.8.3-1)
[2022-09-13T09:58:11+0200] [ALPM] upgraded libadwaita (1:1.1.4-1 -> 1:1.1.5-1)
[2022-09-13T09:58:11+0200] [ALPM] upgraded gtk4 (1:4.6.6-1 -> 1:4.6.7-1)
[2022-09-13T09:58:11+0200] [ALPM] upgraded pipewire (1:0.3.56-1 -> 1:0.3.57-1)
[2022-09-13T09:58:11+0200] [ALPM] installed appstream (0.15.5-1)
[2022-09-13T09:58:11+0200] [ALPM] upgraded ostree (2022.5-2 -> 2022.5-4)
[2022-09-13T09:58:11+0200] [ALPM] upgraded firefox (103.0.2-1 -> 104.0.2-1)
[2022-09-13T09:58:11+0200] [ALPM] upgraded exa (0.10.1-5 -> 0.10.1-6)
[2022-09-13T09:58:11+0200] [ALPM] upgraded electron19 (19.0.10-1 -> 19.0.13-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded libxslt (1.1.35-1 -> 1.1.37-2)
[2022-09-13T09:58:10+0200] [ALPM] upgraded edk2-ovmf (202205-2 -> 202208-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded cython (0.29.32-1 -> 0.29.32-2)
[2022-09-13T09:58:10+0200] [ALPM] upgraded cups-pk-helper (0.2.6-5 -> 0.2.7-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded cups-filters (1.28.15-2 -> 1.28.16-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded poppler (22.08.0-1 -> 22.09.0-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded nss (3.81-1 -> 3.82-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded chromaprint (1.5.1-3 -> 1.5.1-4)
[2022-09-13T09:58:10+0200] [ALPM] upgraded ffmpeg (2:5.0.1-3 -> 2:5.1.1-3)
[2022-09-13T09:58:10+0200] [ALPM] upgraded lib32-glibc (2.36-2 -> 2.36-3)
[2022-09-13T09:58:10+0200] [ALPM] upgraded svt-av1 (1.1.0-1 -> 1.2.1-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded sdl2 (2.0.22-2 -> 2.24.0-1)
[2022-09-13T09:58:10+0200] [ALPM] installed ocl-icd (2.3.1-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded x264 (3:0.164.r3081.19856cc-2 -> 3:0.164.r3095.baee400-4)
[2022-09-13T09:58:10+0200] [ALPM] upgraded libva (2.15.0-1 -> 2.15.0-6)
[2022-09-13T09:58:10+0200] [ALPM] upgraded libssh (0.9.6-1 -> 0.10.3-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded rav1e (0.4.1-2 -> 0.5.1-2)
[2022-09-13T09:58:10+0200] [ALPM] upgraded btrfs-progs (5.18.1-1 -> 5.19-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded bolt (0.9.2-1 -> 0.9.3-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded bmenu (0.18-1 -> 0.20-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded mhwd-nvidia (515.65.01-2 -> 515.65.01-3)
[2022-09-13T09:58:10+0200] [ALPM] upgraded mesa (22.1.6-1 -> 22.1.7-1)
[2022-09-13T09:58:10+0200] [ALPM] upgraded nvidia-utils (515.65.01-2 -> 515.65.01-3)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libxfont2 (2.0.5-1 -> 2.0.6-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libfontenc (1.1.4-3 -> 1.1.6-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libsoup3 (3.0.7-1 -> 3.0.8-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded xkeyboard-config (2.36-2.1 -> 2.36-3)
[2022-09-13T09:58:09+0200] [ALPM] upgraded gtk-update-icon-cache (1:4.6.6-1 -> 1:4.6.7-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded librsvg (2:2.54.4-1 -> 2:2.54.5-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libxft (2.3.4-1 -> 2.3.5-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libtiff (4.4.0-3 -> 4.4.0-4)
[2022-09-13T09:58:09+0200] [ALPM] upgraded shared-mime-info (2.0+144+g13695c7-1 -> 2.0+155+gf4e7cbc-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libjpeg-turbo (2.1.3-2 -> 2.1.4-2)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libxau (1.0.9-4 -> 1.0.10-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded egl-wayland (2:1.1.10-1 -> 2:1.1.11-2)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libdrm (2.4.112-1 -> 2.4.113-2)
[2022-09-13T09:58:09+0200] [ALPM] upgraded libpciaccess (0.16-3 -> 0.16-4)
[2022-09-13T09:58:09+0200] [ALPM] upgraded python-urllib3 (1.26.11-1 -> 1.26.12-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded file (5.42-1 -> 5.42-2)
[2022-09-13T09:58:09+0200] [ALPM] upgraded gnupg (2.2.36-1 -> 2.2.39-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded sqlite (3.39.2-2 -> 3.39.3-1)
[2022-09-13T09:58:09+0200] [ALPM] upgraded gnutls (3.7.7-1 -> 3.7.7-3)
[2022-09-13T09:58:09+0200] [ALPM] upgraded lshw (B.02.19.2-4 -> B.02.19.2-5)
[2022-09-13T09:58:08+0200] [ALPM] upgraded fzf (0.32.1-1 -> 0.33.0-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded bluez-libs (5.65-2 -> 5.65-3)
[2022-09-13T09:58:08+0200] [ALPM] upgraded bluez (5.65-2 -> 5.65-3)
[2022-09-13T09:58:08+0200] [ALPM] upgraded libxml2 (2.9.14-1 -> 2.10.2-2)
[2022-09-13T09:58:08+0200] [ALPM] upgraded glib2 (2.72.3-1 -> 2.72.3-3)
[2022-09-13T09:58:08+0200] [ALPM] upgraded binutils (2.39-2 -> 2.39-3)
[2022-09-13T09:58:08+0200] [ALPM] upgraded curl (7.84.0-2 -> 7.85.0-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded ca-certificates-mozilla (3.81-1 -> 3.82-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded libtasn1 (4.18.0-1 -> 4.19.0-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded lz4 (1:1.9.3-2 -> 1:1.9.4-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded libnghttp2 (1.48.0-1 -> 1.49.0-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded bat (0.21.0-2 -> 0.21.0-3)
[2022-09-13T09:58:08+0200] [ALPM] upgraded libgit2 (1:1.4.4-1 -> 1:1.5.0-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded pcre (8.45-1 -> 8.45-2)
[2022-09-13T09:58:08+0200] [ALPM] upgraded archlinux-appstream-data (20220727-1 -> 20220830-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded apparmor (3.0.7-1 -> 3.1.1-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded python (3.10.5-2 -> 3.10.6-1)
[2022-09-13T09:58:08+0200] [ALPM] upgraded gcc-libs (12.1.1-4 -> 12.2.0-1)
[2022-09-13T09:58:06+0200] [ALPM] upgraded glibc (2.36-2 -> 2.36-3)
[2022-09-13T09:58:06+0200] [ALPM] upgraded iana-etc (20220603-1 -> 20220715-1)
[2022-09-13T09:58:06+0200] [ALPM] upgraded tzdata (2022b-1 -> 2022c-1)
[2022-09-13T09:58:06+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.56-1 -> 1:0.3.57-1)
[2022-09-13T09:58:06+0200] [ALPM] upgraded abseil-cpp (20220623.0-1 -> 20220623.1-1)
[2022-09-13T09:54:40+0200] [ALPM] upgraded archlinux-keyring (20220727-1 -> 20220831-1)
I would comment all those in etc/environment
Here is how i have it on my other install:
# Available options: gnome, kde, qt5ct, xcb
#QT_QPA_PLATFORMTHEME="qt5ct"
#QT_QPA_PLATFORMTHEME="gnome"
#QT_STYLE_OVERRIDE="kvantum"
# Force to use Xwayland backend
#QT_QPA_PLATFORM=xcb
#QT_QPA_PLATFORM=wayland
#Not tested: this should disable window decorations
# QT_WAYLAND_DISABLE_WINDOWDECORATION=1
The one you’re showing is the same as my original /etc/environment so it doesn’t work.
Check this if it applies to you:
If it does:
echo XDG_CURRENT_DESKTOP=KDE | sudo tee -a /etc/environment
Just checked. This line doesn’t resolve the problem.
Just wanted to chime in and say that I’ve been having same issue with Okular after the update. All thee icons are half visible, the text is blurry, menu items disappear when I hover my mouse over it, all around unusable. I don’t think I deleted or changed anything while update. I’ve also tried flatpak and snaps but the issue was still there.
@archerindigo were able to resolve this issue?
Unfortunately no. After 2 stable updates, the issue still persist
Any advance in this discussion? I have the same problem.
Using gnome with dark mode, but Okular default color scheme remains light.
The only way to workaround/fix for now seems to be to install Kvantum-manjaro e manually set the Color Scheme in Okular.
I don’t see how to solve the problem without Kvantum.
I read your Topic with great interest because all gtk users will cross this bridge. Although I use Xfce, this should work in GNOME. I used okular to verify the options below. A side note, I’m a former kde user, and have found evince an acceptable alternative, although I really miss the traditional window layout.
I use number 2 below. I select the theme in kvantum and change attributes like font in qt5ct.
Just double-checking, is okular installed from the package repositories or flatpak?
Options:
  1. qt5ct only - themes like matcha
    edit: nano ~/.profile
    add: export QT_QPA_PLATFORMTHEME="qt5ct" # gnome, qt5ct, kvantum
    Topic
  2. qt5ct + kvantum to get the themes
    execute: qt5ct
    change: Style: kvantum
  3. qgnomeplateform-qt5 + kvantum
    add: export QT_QPA_PLATFORMTHEME="gnome" # gnome, qt5ct, kvantum
    add: export QT_STYLE_OVERRIDE="kvantum"
    NOTE: According to this Manjaro Topic this is the default setup for GNOME.
  4. qgnomeplateform only adwaita themes
TIP:
  • If you do not recall what .profile contained initially, check /etc/skel/.profile
Links
That post is quite old, that’s no longer default.
See manjaro/gnome/desktop-overlay/etc/environment · master · Profiles & Settings / iso-profiles · GitLab
# To use QGnomePlaform with AdwaitaQt style, comment out the following keys:
# Note: Don't use in combination with QT_STYLE_OVERRIDE
# Windows, Fusion
# Note: Don't use in combination with QT_QPA_PLATFORMTHEME
#QT_STYLE_OVERRIDE=""
Just a head-up: The recent stable update made the dark theme work again.
