Odroid C2 no longer booting
I have no Ethernet connection with this working C2, how to solve it ?
[nlc2@c2 ~]$ inxi -F
System:    Host: c2.21.06 Kernel: 5.12.1-1-MANJARO-ARM aarch64 bits: 64 Desktop: KDE Plasma 5.21.5 Distro: Manjaro ARM
Machine:   Type: ARM Device System: Hardkernel ODROID-C2 details: N/A serial:
CPU:       Info: Quad Core model: N/A variant: cortex-a53 bits: 64 type: MCP
           Speed: N/A min/max: N/A Core speeds (MHz): No per core speed data found.
Graphics:  Device-1: meson-gxbb-dw-hdmi driver: meson_dw_hdmi v: N/A
           Device-2: meson-gxbb-vpu driver: meson_drm v: N/A
           Device-3: meson-gxbb-mali driver: lima v: kernel
           Display: x11 server: X.org 1.20.11 driver: loaded: fbturbo resolution: <missing: xdpyinfo>
Audio:     Device-1: meson-gxbb-dw-hdmi driver: meson_dw_hdmi
           Device-2: gx-sound-card driver: gx_sound_card
           Sound Server-1: ALSA v: k5.12.1-1-MANJARO-ARM running: yes
           Sound Server-2: PipeWire v: 0.3.28 running: yes
Network:   Device-1: meson-gxbb-dwmac driver: meson8b_dwmac
           IF: eth0 state: down mac:
           IF-ID-1: ip6tnl0 state: down mac: 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
Drives:    Local Storage: total: 58.24 GiB used: 5.23 GiB (9.0%)
           ID-1: /dev/mmcblk1 model: CJTD4R size: 58.24 GiB
Partition: ID-1: / size: 57.86 GiB used: 5.17 GiB (8.9%) fs: ext4 dev: /dev/mmcblk1p2
           ID-2: /boot size: 213.4 MiB used: 61.7 MiB (28.9%) fs: vfat dev: /dev/mmcblk1p1
Swap:      ID-1: swap-1 type: zram size: 2.86 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:   Message: No sensor data found. Is lm-sensors configured?
Info:      Processes: 165 Uptime: 5m Memory: 1.91 GiB used: 715.3 MiB (36.6%) Shell: Bash inxi: 3.3.04
[nlc2@c2 ~]$
Right now I build an image with the linux kernel, and not the linux-vim kernel
## Maintained by Strit ##
# Kernel and bootloader stuff
linux
uboot-odroid-c2-mainline
plymouth
plymouth-theme-manjaro
The odroid C2 don’t boot with the linux kernel, no screen and no blinking blue led.
Only issue with the linux-vim kernel, the Ethernet connection.
It sound like the first Odroid C4 image, Ethernet issue.
@Strit and @Lila-Kuh
I wrote this message with the Odroid C2, It is working again, thanks a lot to Strit for his help.
[nlc2@c2 ~]$ uname -a
Linux c2.21.06 5.12.1-1-MANJARO-ARM #1 SMP PREEMPT Fri May 14 19:17:02 +03 2021 aarch64 GNU/Linux
[nlc2@c2 ~]$
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Drives:    Local Storage: total: 114.56 GiB used: 47.83 GiB (41.7%)
           ID-2: /dev/sda type: USB vendor: Transcend model: JetFlash Transcend 64GB size: 56.32 GiB
Partition: ID-1: / size: 57.86 GiB used: 5.49 GiB (9.5%) fs: ext4 dev: /dev/mmcblk1p2
Swap:      ID-1: swap-1 type: zram size: 2.86 GiB used: 37.8 MiB (1.3%) dev: /dev/zram0
Info:      Processes: 192 Uptime: 9m Memory: 1.91 GiB used: 1.35 GiB (71.0%) Shell: Bash inxi: 3.3.04
[nlc2@c2 ~]$
First I modify the arm-profiles, devices, oc2 file by adding linux-vim instead of linux
linux-vim
plymouth
# Video driver
xf86-video-fbturbo-git
# Other device specific packages
btrfs-progs
fbset
amlogic
oc2-post-install
I modify the original arm-profiles, editions, kde-plasma by adding for example smbclient, full file used here
Summary
Maintained by Strit
Minimal packages
sudo
parted
openssh
haveged
xorg-server
xorg-xinit
inxi
ncdu
nano
man-pages
man-db
ntfs-3g
zswap-arm
exfat-utils
smbclient
Sound, Video and bluetooth
alsa-utils
smplayer
#pulseaudio-alsa
#pulseaudio-bluetooth
pipewire-alsa
pipewire-pulse
vlc
Display Manager
sddm
sddm-kcm
Plasma packages
bluedevil
breeze
drkonqi
kde-gtk-config
kinfocenter
kcalc
kscreen
kscreenlocker
ksysguard
kwallet-pam
kwayland-integration
#plasma-wayland-session
kwin
plasma-desktop
plasma-nm
plasma-pa
plasma-workspace
powerdevil
systemsettings
plasma-vault
plasma-firewall
oxygen
oxygen-icons
KDE applications
dolphin
dolphin-plugins
kate
konsole
ark
okular
gwenview
krfb
krdc
Themes
breath2-icon-themes
gtk-theme-breath
plasma5-themes-breath2
sddm-breath2-theme
manjaro-arm-wallpapers
breeze-gtk
manjaro-icons
Office suite
libreoffice-fresh
Browser
firefox
firefox-ublock-origin
Package Manager
pamac-gtk
pamac-tray-icon-plasma
Fonts
ttf-bitstream-vera
noto-fonts
wqy-microhei #chinese
Manjaro tools
manjaro-settings-manager
manjaro-settings-manager-kcm
manjaro-hotfixes
manjaro-arm-flasher
manjaro-arm-installer
mntray
Other packages
openresolv
wget
tlp
flameshot
xdg-user-dirs
networkmanager-openvpn
firewalld
Next I built an image
sudo buildarmimg -d oc2 -e kde-plasma -v 2021.06.15 -n
I flashed the image on an emmc module (sd card not tested, sorry)
Next I modified the extlinux.conf file with root=LABEL=ROOT_MNJRO
LABEL Manjaro ARM
KERNEL /Image
FDT /dtbs/amlogic/meson-gxbb-odroidc2.dtb
APPEND initrd=/initramfs-linux.img console=tty1 console=ttyAML0,115200n8 root=LABEL=ROOT rw rootwait quiet splash plymouth.ignore-serial-consoles
Only issue, I can’t install any package with pacman or pamac (failed to commit transaction)
any idea to solve it ?
[nlc2@c2 ~]$ sudo pacman -S screenfetch
resolving dependencies...
Packages (3) bc-1.07.1-4  xorg-xdpyinfo-1.3.2-4  screenfetch-3.9.1-1
Total Installed Size:  0,45 MiB
:: Proceed with installation? [Y/n] y
(3/3) checking keys in keyring                                                    [##############################################] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
[nlc2@c2 ~]$
The C2 Ethernet connexion don’t work today, strange, error message :
Could not get PHY for Ethernet…
https://forum.odroid.com/viewtopic.php?t=41873
Message wrote with the C2.
An usb wifi key connect the C2 to internet.
[nlc2@c2 ~]$ sudo pacman-key --init
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
gpg: Generating pacman keyring master key...
gpg: key 82A35F9104355DB8 marked as ultimately trusted
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/E08F75C8CECD4993CA7F214082A35F9104355DB8.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
[nlc2@c2 ~]$
to install a software, it’s down
Total Download Size:   0,15 MiB
:: Retrieving packages...
 bc-1.07.1-4-aarch64                                         83,6 KiB  1194 KiB/s 00:00 [##################################################] 100%
 xorg-xdpyinfo-1.3.2-4-aarch64                               15,7 KiB  0,00   B/s 00:00 [##################################################] 100%
 screenfetch-3.9.1-1-any                                     50,9 KiB  2,49 MiB/s 00:00 [##################################################] 100%
(3/3) checking keys in keyring                                                          [##################################################] 100%
(3/3) checking package integrity                                                        [##################################################] 100%
error: bc: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust
:: File /var/cache/pacman/pkg/bc-1.07.1-4-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: xorg-xdpyinfo: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust
:: File /var/cache/pacman/pkg/xorg-xdpyinfo-1.3.2-4-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: screenfetch: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust
:: File /var/cache/pacman/pkg/screenfetch-3.9.1-1-any.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
[nlc2@c2 ~]$
issue with pamac
invalid or corrupted package (PGP signature):
Run these commands to get the keys working:
sudo pacman-key --populate archlinux archlinuxarm manjaro manjaro-arm
Thanks a lot, it works :-)
gpg: next trustdb check due at 2021-08-02
 bc-1.07.1-4-aarch64                                         83,6 KiB  1672 KiB/s 00:00 [##################################################] 100%
(3/3) loading package files                                                             [##################################################] 100%
(3/3) checking for file conflicts                                                       [##################################################] 100%
(3/3) checking available disk space                                                     [##################################################] 100%
(1/3) installing bc        [##################################################] 100%
(2/3) installing xorg-xdpyinfo                                                          [##################################################] 100%
(3/3) installing screenfetch                                                            [##################################################] 100%
Optional dependencies for screenfetch
    scrot: to take screenshot
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the info directory file...
[nlc2@c2 ~]$ screenfetch
                             nlc2@c2.21.06
                             OS: Manjaro-ARM 21.05
                             Kernel: aarch64 Linux 5.12.1-1-MANJARO-ARM
         #####               Uptime: 51m
        #######              Packages: Unknown
        ##O#O##              Shell: bash 5.1.8
        #######              Resolution: 1920x1080
      ###########            DE: KDE 5.82.0 / Plasma 5.21.5
     #############           WM: KWin
    ###############          GTK Theme: Breeze [GTK2/3]
    ################         Icon Theme: oxygen
   #################         Disk: 5,7G / 59G (10%)
 #####################       CPU: 4x Unknown
 #####################       RAM: 1460MiB / 1952MiB
[nlc2@c2 ~]$ date -u
mer. 16 juin 2021 11:07:51 UTC
[nlc2@c2 ~]$
So you can create a working odroid C2 image, and the only change you did was switching to linux-vim?
Yes, I created the image and so on, I modify the extlinux.conf file…
read my other post, I don’t understand why the ethernet connection was fine !
I added some soft with the arm-profiles, editions, kde-plasma by adding for example smbclient
https://forum.manjaro.org/t/arm-testing-update-2021-06-13-plasma-5-22-boost-1-76-plamo-gear-21-06-pacman-6-and-kernels/70135/40
yesterday the Ethernet connection was fine and not today…
I think I now know what went wrong. I’ll do a couple of tests and push out a fix if I was correct.
Thanks a lot, I stay tuned for some test.
A Manjaro user have a working Manjaro arm C2 on this earth.
Applied your workaround, until I get time to look into it more.
So if you update your profiles with sudo getarmprofiles -f and build using unstable branch with -b unstable, you should get a working image.
Manjaro ARM Installer installs won’t work until the fix hits stable branch.
Ok, I note your message, I can’t do it now, but later, for sure :-)
I hope no issue with the Ethernet connection, the wifi is tricky for me…
I invite the other C2 User tot test it.
I wrote this message with the C2.
I updated the profiles with sudo getarmprofiles -f
I build the unstable image as suggested.
sudo buildarmimg -d oc2 -e kde-plasma -v 2021.06.16-01 -b unstable -n
keyring issue solve with your command lines
Ethernet connection is working by default
                             nlc2@c2.21.06
                             OS: Manjaro-ARM 21.06
                             Kernel: aarch64 Linux 5.12.9-1-MANJARO-ARM
         #####               Uptime: 16m
      ###########            DE: KDE 5.83.0 / Plasma 5.22.1
    ###############          GTK Theme: Breeze [GTK2], Breath-Dark [GTK3]
   #################         Disk: 51G / 115G (46%)
 #####################       RAM: 1521MiB / 1952MiB
[nlc2@c2 ~]$ pacman-mirrors --get-branch
arm-unstable
mer. 16 juin 2021 15:19:37 UTC
Linux c2.21.06 5.12.9-1-MANJARO-ARM #1 SMP PREEMPT Tue Jun 8 21:04:14 UTC 2021 aarch64 GNU/Linux
[nlc2@c2 ~]$
System:    Host: c2.21.06 Kernel: 5.12.9-1-MANJARO-ARM aarch64 bits: 64 Desktop: KDE Plasma 5.22.1
           Distro: Manjaro ARM
           Display: x11 server: X.Org 1.20.11 driver: loaded: fbturbo s-res: 1920x1080
           Sound Server-1: ALSA v: k5.12.9-1-MANJARO-ARM running: yes
           Sound Server-2: PipeWire v: 0.3.30 running: yes
Drives:    Local Storage: total: 114.56 GiB used: 50.86 GiB (44.4%)
           ID-1: /dev/mmcblk1 vendor: Samsung model: CGND3R size: 58.24 GiB
           ID-2: /dev/sdb type: USB vendor: Transcend model: JetFlash Transcend 64GB size: 56.32 GiB
Partition: ID-1: / size: 57.85 GiB used: 5.78 GiB (10.0%) fs: ext4 dev: /dev/mmcblk1p2
Swap:      ID-1: swap-1 type: zram size: 2.86 GiB used: 325.2 MiB (11.1%) dev: /dev/zram0
Info:      Processes: 195 Uptime: 27m Memory: 1.91 GiB used: 1.48 GiB (77.7%) Shell: Bash inxi: 3.3.04
[nlc2@c2 ~]$
my kde-plasma conf file
Summary
Maintained by Strit
Minimal packages
sudo
parted
openssh
haveged
xorg-server
xorg-xinit
inxi
ncdu
nano
man-pages
man-db
ntfs-3g
zswap-arm
alsa-utils
smplayer
#pulseaudio-alsa
pipewire-alsa
pipewire-pulse
vlc
Display Manager
sddm
sddm-kcm
Plasma packages
bluedevil
breeze
drkonqi
kde-gtk-config
kinfocenter
kcalc
kscreen
kscreenlocker
ksysguard
kwallet-pam
kwin
plasma-desktop
plasma-nm
plasma-pa
plasma-workspace
powerdevil
systemsettings
plasma-vault
plasma-firewall
oxygen
oxygen-icons
KDE applications
dolphin
dolphin-plugins
kate
konsole
ark
okular
gwenview
krfb
krdc
Themes
breath2-icon-themes
gtk-theme-breath
sddm-breath2-theme
breeze-gtk
manjaro-icons
Office suite
libreoffice-fresh
libreoffice-fresh-fr
Browser
firefox
Package Manager
pamac-gtk
Fonts
ttf-bitstream-vera
noto-fonts
Manjaro tools
manjaro-hotfixes
manjaro-arm-flasher
mntray
Other packages
openresolv
wget
tlp
flameshot
xdg-user-dirs
firewalld
samba
smbclient
android-file-transfer
filezilla
gparted
partitionmanager
exfat-utils
smbclient
Today I up dated the c2
ven. 18 juin 2021 19:58:17 UTC
                             nlc2@c2.21.06
         #####               Uptime: 10h 59m
   #################         Disk: 6,2G / 59G (11%)
 #####################       RAM: 813MiB / 1952MiB
[nlc2@c2 ~]$ sudo pacman -Syyuu
[sudo] password for nlc2:
:: Synchronising package databases...
 core                                      234,8 KiB   451 KiB/s 00:01 [#######################################] 100%
 extra                                       2,4 MiB   888 KiB/s 00:03 [#######################################] 100%
 community                                   5,9 MiB   859 KiB/s 00:07 [#######################################] 100%
Packages (3) editorconfig-core-c-0.12.5-1  libva-2.12.0-0.1  mkinitcpio-busybox-1.33.1-1
Total Download Size:   0,48 MiB
Total Installed Size:  1,45 MiB
Net Upgrade Size:      0,01 MiB
 editorconfig-core-c-0.12.5-1-aarch64       29,5 KiB   123 KiB/s 00:00 [#######################################] 100%
 libva-2.12.0-0.1-aarch64                  222,7 KiB   428 KiB/s 00:01 [#######################################] 100%
 mkinitcpio-busybox-1.33.1-1-aarch64       241,2 KiB   574 KiB/s 00:00 [#######################################] 100%
 Total (3/3)                               493,5 KiB   352 KiB/s 00:01 [#######################################] 100%
(3/3) checking keys in keyring                                         [#######################################] 100%
(3/3) checking package integrity                                       [#######################################] 100%
(3/3) loading package files                                            [#######################################] 100%
(3/3) checking for file conflicts                                      [#######################################] 100%
(3/3) checking available disk space                                    [#######################################] 100%
(1/3) upgrading editorconfig-core-c                                    [#######################################] 100%
(2/3) upgrading libva                                                  [#######################################] 100%
(3/3) upgrading mkinitcpio-busybox                                     [#######################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating linux-vim initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-vim.preset: 'default'
  -> -k 5.12.9-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.12.9-1-MANJARO-ARM
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
(3/3) Updating linux initcpios...
[nlc2@c2 ~]$ reboot
Unfortunately the device don’t reboot, should I build an unstable image, testing or stable ?
Did you change to linux-vim, like you found out would work?
I don’t think the ā€œfixedā€ package got into this update.
Linux-vim is by default install, I only up date the device, no more no less.
linux-vim
plymouth
# Video driver
btrfs-progs
fbset
amlogic
oc2-post-install
Right now I build a testing image.
That was changed in the last couple of days.
If you need to build a new image, use unstable branch for now.
Although the packages needed are all in stable branch at this point.
linux or linux-vim kernel ?
linux-vim, but with uboot package 2021.04-2.
