Odroid C4 kde up to date.
[nlc4@c4 ~]$ pacman -V
.--. Pacman v6.0.0 - libalpm v13.0.0
/ _.-' .-. .-. .-. Copyright (C) 2006-2021 Pacman Development Team
\ '-. '-' '-' '-' Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
[nlc4@c4 ~]$
I hope soon the Odroid C2 :-)
https://forum.manjaro.org/t/ideas-to-unify-arm-boot-sequences-and-kernel-namings/70061/30
Strit
14 June 2021 11:59
2
Just a quick suggestion about that. Have you tried changing the kernel to linux-vim
, which is based on Tobetters (froim hardkernel) source?
Thanks for our answer.
No I don’t, yesterday I built a stable image for the C2, it don’ t boot.
Where to find the linux-vim kernel?
How to install the linux-vim kernel on the emmc module? copy past as root ?
I have time this afternoon for some test.
some details during the image I did yesterday.
==> Proceeding....
-> Getting package lists ready for oc2 kde-plasma edition...
==> Getting /dev/sdb ready with ext4 for oc2...
archlinux-appstream-data-20210423-1
linux-firmware-20210511.7685cf4-1
util-linux-2.36.2-1
linux-5.12.8-1
Editing extlinux.conf...
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
-> -k 5.12.8-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
==> WARNING: errors were encountered during the build. The image may not be complete.
error: command failed to execute correctly
( 1/26) Creating system user accounts...
the extlinux.conf file is looking so
LABEL Manjaro ARM
KERNEL /Image
FDT /dtbs/amlogic/meson-gxbb-odroidc2.dtb
APPEND initrd=/initramfs-linux.img console=tty1 console=ttyAML0,115200n8 root=LABEL=ROOT rw rootwait quiet splash plymouth.ignore-serial-consoles
The boot is looking so on the emmc module
Strit
14 June 2021 13:46
4
You can add it when you are building the image.
So before running buildarmimg, you can go to /usr/share/manjaro-arm-tools/arm-profiles. Find the devices/oc2 file and change linux
to linux-vim
. Save the file and then run your buildarmimg command.
This will build an image with the other kernel for you.
Thanks, I did
Now I build an image for the C2, see you later with my test report.
## Maintained by Strit ##
# Kernel and bootloader stuff
linux-vim
uboot-odroid-c2-mainline
plymouth
plymouth-theme-manjaro
# Video driver
xf86-video-fbturbo-git
# Other device specific packages
btrfs-progs
fbset
amlogic
oc2-post-install
Nice, the C2 boot right now, the blue led is blinking, on screen the manjaro logo with the rolling circle and then nothing happen.
now I build an image with the manjaro-arm-installer
The Odroid C2 device don’t boot with the manjaro arm installer image I built.
Strit
14 June 2021 15:19
8
Because it’s using the normal profile. You need to build an image with the buildarmimg command, if you change something in the profile.
First I built an image like it
sudo buildarmimg -d oc2 -e kde-plasma -v 2021.06.14 -n
secondly
I build the last image with the manjaro-arm-installer
I don’t know how to buid the image with the buildarming
Yes, it’s what I did with the buildarming
nl.smart:
Strit
14 June 2021 15:49
10
nl.smart:
And what happens when you press ESC, so you can see what happens behind that screen?
The image I build with
I made some test and nothing happen, the keyboard and the mouse are recognize
However I don’t use tty…
Hi,
After the boot and then nothing
With the esc key
Strit
15 June 2021 04:36
13
What is the content of your /boot/extlinux.conf file?
The /boot/extlinux.conf file is looking so
LABEL Manjaro ARM
KERNEL /Image
Strit
15 June 2021 12:11
15
nl.smart:
root=LABEL=ROOT
Is your root LABEL called ROOT or ROOT_MNJRO?
ROOT_MNJRO
If you look the partition is full…
Strit
15 June 2021 13:04
17
Yes. In the extlinux.conf file, change it to ROOT_MNJRO instead and see if that makes it boot?
Strit:
ROOT_MNJRO
LABEL Manjaro ARM
KERNEL /Image
APPEND initrd=/initramfs-linux.img console=tty1 console=ttyAML0,115200n8 root=LABEL=ROOT_MNJRO rw rootwait quiet splash plymouth.ignore-serial-consoles
I did, I’m back with the test report in a few minutes.
ok, the Odroid C2 boot, I finish the manjaro arm install.
choose your keyboard layout and so on …
is it necessary to run with the linux-vim kernel ?
Strit
15 June 2021 13:14
20
It seems it is,. Don’t know why though, so that’s something I will have to check out.
