Quexos
August 7, 2021, 2:55am
1
Does anyone know why “image sharpening” is not available? I would love to try it out but the slider is greyed out and I can’t sort out how to enable it.
edit: …and while I’m at it, ticking the box for “FXAA” in nvidia-settings does not appear to work at all in Rise of the Tomb Raider. Opengl only, not Vulkan, or just borked?
Quexos
August 8, 2021, 1:06am
3
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9f9a5f06-b391-4eff-ae97-400be5a5e07b rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: ASRock model: B450 Gaming K4 serial: <filter>
BIOS: American Megatrends v: P5.00 date: 05/10/2021
RAM: total: 15.55 GiB used: 1.21 GiB (7.8%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 40808
Speed: 1271 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1271 2: 1272 3: 2336 4: 1375 5: 1378 6: 1377
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: PNY driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DP-0 res: 1920x1080 hz: 144 dpi: 94 size: 519x293mm (20.4x11.5")
diag: 596mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.83 TiB used: 204.14 GiB (10.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM22.4 temp: 26.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00BN5A0
type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD4
type: SSD serial: <filter> rev: 023 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH14NS40 rev: 1.03
dev-links: cdrom
ID-1: / raw-size: 88.01 GiB size: 86.07 GiB (97.80%) used: 12.54 GiB (14.6%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 9f9a5f06-b391-4eff-ae97-400be5a5e07b
ID-2: /run/media/elvin/HDD raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 191.5 GiB (20.6%) fs: ntfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: HDD uuid: B658C2F9228BD30D
ID-3: /run/media/elvin/NVME raw-size: 380 GiB size: 380 GiB (100.00%)
used: 102.7 MiB (0.0%) fs: ntfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: NVME uuid: 20A8BCA1A8BC773E
Kernel: swappiness: 15 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 458 GiB fs: ntfs label: WIN10
uuid: 50344E12344DFB8A
Device-1: 1-10:2 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:a09f class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-2:2 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 258a:002a class-ID: 0300
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.5 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 230 Uptime: 1m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1147 lib: 336
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
nvidia-smi
Sat Aug 7 21:05:29 2021
| NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:09:00.0 On | N/A |
| 38% 36C P8 23W / 125W | 161MiB / 5936MiB | 2% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 545 G /usr/lib/Xorg 157MiB |
| 0 N/A N/A 1068 G xfwm4 2MiB |
Fabby
August 8, 2021, 10:02am
4
That all looks good, so where exactly are you trying to set the image sharpening???
Quexos
August 8, 2021, 1:05pm
5
nvidia-settings > DP-0 (name of display) > Controls > Image Sharpening (slider at bottom).
It is greyed out in other distros too, so I am guessing it’s just some goofy nvidia thing where it only works on a certain model GPU or something. Don’t sweat it, it’s not a big deal…just “typical linux” where things only half work most of the time.
Fabby
August 8, 2021, 2:10pm
6
That’s apparently intentional and the same here:
Fabby
7
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
system
Closed
August 23, 2021, 2:10pm
8
