Laptop shuts down after closing the lid after the update
I updated the packages and now laptop shuts down after I close the lid.
Why is it happening if I did not request it? Were the updates tinkering with BIOS?
the fix/corrective-action depends on which desktop-environment you are in. please provide more info.
inxi -v7azy
KDE Plasma v: 5.27.4
Hi @carpe,
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
it’s unlikely a update will change system settings, but you can start by going to system settings → power management → button events handling → when laptop lid closes and check whether it is set to shut down. if this is not the cause there is nothing we can do without more info
it is set to Sleep
What information would you need?
I am pretty sure it is an update, I have had this before and after a while it fixed itself, now I just updated the system and I saw that there were kernel updates linux-515 or something like that and after that this thing happened again.
So my settings are the following:
On AC Power:
When laptop lid is closed - Sleep
On Battery:
When laptop lid is closed - Turn off screen
when the laptop is plugged in after I close the lid laptop shuts down instead of sleep.
When on battery power it does not.
I suspect there is something wrong with the setting ‘Sleep’ here?
No.
See the responses you received last week above. :point_up:
