Kizuo
June 21, 2022, 9:07pm
#1
When you try to install something to add to your appearance (widgets, icons, Plasma themes, gnome themes etc.) it doesn’t work and instead says an error about “number of concurrent streams”- do you guys know whats up? Thanks!
Did you know that the forum has a search function?
And had you used it, then you would have found these threads…
[Screenshot_20220620_181955]
the error message i get is
Download of “Quarks Splash Darker” failed, error: SETTINGS invalid number of concurrent streams
It also happened on my Manjaro. I tried to install it via global theme - system setting. Everything on appearance (system setting) could not be installed. it says “Download of “We10XOS-light-alt Global Theme” failed, error: SETTINGS invalid number of concurrent streams”
Hello Friends.
I installed the fresh Manjaro on a new SSD and I am having trouble installing some Widgets, Themes and Scripts. When I try to do this, an error message appears:
Download of … failed, error: SETTINGS invalid number of concurrent streams
Have you encountered something similar?
Please, see the answer here:
I also get this issue since the Plasma 5.25 update, maybe even before that. Hard to estimate, because I don’t use that options everyday.
My guess is, this is some regression, and it will be fixed. This happened many times already…
In the meantime, I suggest you go to:
Find what you are looking for and install from there. If you want an easy install, without thinking what goes where, I suggest installing from AUR ocs-url package. Then you will be able to click on “Install” button and the res…
or here:
This is probably some regression that will be fixed eventually. I also have this issue lately.
Find what you are looking for and install from there. If you want an easy install, without thinking what goes where, I suggest installing from AUR ocs-url package. Then you will be able to click on “Install” button and the rest will go automatically.
Aragorn is correct if you had searched the forum you would of found plenty of threads covering this. That said looks to be fixed in the 5.25.1 Plasma point release.
