System shows No output or input devices in kde audio applet ,bluetooth audio device working fine
System info
KDE Plasma Version: 5.22.5
KDE Frameworks Version: 5.87.0
Qt Version: 5.15.2
Kernel Version: 5.13.19-2-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × 11th Gen Intel® Core™ i5-1135G7 @ 2.40GHz
Memory: 7.6 GiB of RAM
Graphics Processor: Mesa Intel® Xe Graphics
inxi -Aa
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
systemctl status alsa-state
○ alsa-state.service - Manage Sound Card State (restore and store)
Loaded: loaded (/usr/lib/systemd/system/alsa-state.service; static)
Active: inactive (dead)
System data is showing 2 incompatible sound servers running
PipeWire cannot support audio unless PulseAudio is removed and replaced, but it can impede PulseAudio functions
To continue using PulseAudio, use this command to stop, disable and mask PipeWire service and socket
systemctl --user disable --now pipewire.socket pipewire.service && systemctl --user mask pipewire.socket
OR
Install metapackage manjaro-pipewire to remove and replace PulseAudio
pamac install manjaro-pipewire
it didn’t workout
At first i tried first command for disabling and masking pipewire and didn’t workout , after that i installed manjaro-pipewie and unmasked, enabled pipeware service using the commands .It also didn’t workout
systemctl --user unmask pipewire.socket && systemctl --user enable --now pipewire.socket pipewire.service
inxi -Aa
Sound Server-3: PulseAudio v: 15.0 running: no
Sorry for my english
If PulseAudio was fully replaced by PipeWire I would expect system data to show PulseAudio is no longer present, like this
Sound Server-3: PipeWire v: 0.3.38 running: yes
I suspect manjaro-pipewire has not installed all dependencies correctly to replace PulseAudio
Please post response to this command to show status of systemd services
systemctl status --user --full --no-pager pipewire.{socket,sevice} pulseaudio.{socket,sevice}
The incompatible sound servers was the only thing that appeared to be a problem from the data available
Both sound servers not working might also be due to audio devices not detected properly in ALSA
Please post more information about ALSA configuration
sudo alsa-info.sh --upload
You need to download sof-firmware. And then reboot your computer.
I have a Lenovo laptop also. I had to download sof-firmware to get audio to work also.
Thanks all ,I disabled & removed Pipewire and reinstalled & enabled pulsaudio using these commands and rebooted .Audio works fine now
sudo pacman -S manjaro-pulse pulseaudio pulseaudio-alsa pulseaudi
o-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth pulseaudio-ctl sol-firmware
systemctl --user unmask pulseaudio
systemctl --user --now enable pulseaudio.service pulseaudio.socket
Data shows Sound Open Firmware driver sof-audio-pci-intel-tgl is already installed to support Intel SST device
Only the metapackage manjaro-pulse package needs to be installed to revert to PulseAudio
The metapackage has Dependencies – pulseaudio pulseaudio-alsa pulseaudio-bluetooth pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
And package manager should offer to install Optional Dependencies – paprefs pasystray pavucontrol pavucontrol-qt pulseaudio-ctl pulseaudio-equalizer
If the systemctl command was effective and system has been reverted to using PulseAudio, the sound servers should look like this:
Sound Server-4: PipeWire v: 0.3.38 running: no
