Please help me out through this, I have been trying to connect my external display with the Manjaro but i am unable to do so since last month, earlier “xrandr” used to read my external display but not its not even reading it…
Please help me through this, just because of this issue i dont want to discontinue using linux…
I am Using HP Pavilion , RYZEN 4000 series, nvidia graphics card.
PS- I am a noob to linux…
You should try the “SEARCH” function in this Forum,
there is a small magnifying glass in the right corner on the top of the forum-window
==> search for external display…
let’s do a cut and resume. first post the actual (!) output of
and
glxinfo | grep server
and
echo $XDG_SESSION_TYPE
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
~ echo $XDG_SESSION_TYPE
wayland
idk why but i am unable to uplaod the Screenshot…but this was the output…
THIS can’t run anyway.
First: you’re running wayland on a 2060. THIS does not function !
Second: You’re running on the intel iGPU actually. post the output of the inxi-command above.
Then log out and search the left-bottom of the login-screen. there should be a option-window to switch between X11 and wayland. switch to X11 and keep in mind that nvidia does not work with wayland !
Then post the actual state of your situation. post the output of the glxinfo and session command i posted above again.
keep in mind i’m in a hurry so don’t waste time.
Kernel: 6.3.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=6c12fc4c-a557-4104-bea6-486f3fe499ec rw quiet splash apparmor=1
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
Mobo: HP model: 87B2 v: 31.23 serial: <superuser required> UEFI: AMI
v: F.25 date: 08/18/2021
ID-1: BAT0 charge: 25.5 Wh (61.6%) condition: 41.4/41.4 Wh (100.0%)
volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: charging cycles: 372
Device-1: hidpp_battery_0 model: Logitech Wireless KeyboarWir
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 5% (should be ignored) rechargeable: yes status: discharging
System RAM: available: 7.13 GiB used: 3.43 GiB (48.2%)
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 48 MiB desc: 12x4 MiB
Speed (MHz): avg: 1540 high: 3000 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 3000
3: 1400 4: 1400 5: 1398 6: 1400 7: 1400 8: 1400 9: 1488 10: 1400 11: 1400
12: 1400 bogomips: 71894
are you joking ?
post the full output of the inxi cammand i posted ! use the option “preformatted text” and insert it !
the
</> Option
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 470.182.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95
class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 43.0 C
Display: wayland server: X. org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.4-2-MANJARO) direct-render: Yes
What have you done to install an acient 470-series driver ? The valid version number is 530.xxx. use the package manager and install the actual driver first.
inxi -G
shows the graphic details and you’ll need a 530.
How did this happen ?
I suggest that you are a really noob. deleting and installing this weird installation isn’t easy and my opinion is that you start a new install, choose the propietary driver support at the beginning of the installation and do this first.
i already know this is a way faster than clearing up this mess.
if you’re finished with the install post the state and we can go on.
sidenote:
Make Backups:
Please install 2 kernels (one of them LTS)
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
How to increase your chances of solving your issue:
Looks similar but not thre same I presume?
The system isn’t fully update either. Stable 6.3 kernel is at 6.3.5-1. If you choose to do a fresh install (you should), immediately update.
