sudo inxi -Fxxxa
sudo inxi -Fxxxa
ziadb@ziad-vpcj118fg:~$ sudo inxi -Fxxxa
System: Host: ziad-vpcj118fg Kernel: 5.4.0-47-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4.0-47-generic root=UUID=58439673-23fd-4402-afe7-40cf97401679 ro quiet
splash vt.handoff=7
Console: tty 2 wm: kwin_x11 dm: SDDM Distro: KDE neon 20.04 5.19 base: Ubuntu 20.04 LTS Focal
Machine: Type: Desktop System: Sony product: VPCJ118FG v: C6U1GNZM serial: 27525472-7000411 Chassis: type: 13 serial: N/A
Mobo: Sony model: VAIO serial: N/A BIOS: American Megatrends v: R1011W7 date: 08/09/2010
CPU: Topology: Dual Core model: Intel Core i5 M 520 bits: 64 type: MT MCP arch: Nehalem family: 6 model-id: 25 (37)
stepping: 2 microcode: 11 L1 cache: 128 KiB L2 cache: 3072 KiB L3 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19152
Speed: 1340 MHz min/max: 1199/2400 MHz boost: enabled Core speeds (MHz): 1: 1340 2: 1452 3: 1380 4: 1392
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GT218M [GeForce 310M] vendor: Sony driver: nvidia v: 340.108 bus ID: 01:00.0 chip ID: 10de:0a75
Display: server: X.Org 1.20.8 driver: nvidia compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce 310M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:3b56
Device-2: NVIDIA High Definition Audio vendor: Sony driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0be3
Sound Server: ALSA v: k5.4.0-47-generic
Network: Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn T77H126.00 802.11bgn driver: ath9k
v: kernel port: d000 bus ID: 02:00.0 chip ID: 168c:002b
IF: wlp2s0 state: down mac: 78:dd:08:dd:7d:c8
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB] vendor: Sony driver: sky2 v: 1.30
port: a000 bus ID: 04:00.0 chip ID: 11ab:4381
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: 54:42:49:5d:38:45
IF-ID-1: enxda1c79ae9738 state: down mac: da:1c:79:ae:97:38
Drives: Local Storage: total: 465.77 GiB used: 8.23 GiB (1.8%)
ID-1: /dev/sda vendor: Intel model: SSDSC2BF180A5L size: 167.68 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s serial: CVTS452003PH180IGN rev: LT6i temp: 34 C scheme: MBR
ID-2: /dev/sdb vendor: Toshiba model: MK3255GSXF size: 298.09 GiB block size: physical: 512 B logical: 512 B
speed: 1.5 Gb/s rotation: 5400 rpm serial: 40DIP0BFT rev: 5B temp: 44 C scheme: MBR
Partition: ID-1: / raw size: 58.13 GiB size: 56.97 GiB (98.00%) used: 8.23 GiB (14.5%) fs: ext4 block size: 4096 B
dev: /dev/sda3
Sensors: System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 54 C
Info: Processes: 187 Uptime: 12m Memory: 7.63 GiB used: 1.85 GiB (24.2%) Init: systemd v: 245 runlevel: 5 Compilers:
gcc: 9.3.0 alt: 9 Shell: bash (sudo) v: 5.0.17 running in: guake inxi: 3.0.38
Please with ``` like this:
Thank you
I am sorry I dont get it ! I am new to Linux -
When you put ``` on the first line and the end line like in the gif, the the code becomes well readable.
Now it looks so ugly and unreadable
‘’'System: Host: ziad-vpcj118fg Kernel: 5.4.0-47-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
splash vt.handoff=7
chip ID: 10de:0be3
dev: /dev/sda3
Hi!
You need to put before and after the text
‘’’ System: Host: ziad-vpcj118fg Kernel: 5.4.0-47-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
splash vt.handoff=7
chip ID: 10de:0be3
dev: /dev/sda3
gcc: 9.3.0 alt: 9 Shell: bash (sudo) v: 5.0.17 running in: guake inxi: 3.0.38’’’
Ok bro… now slowly:
Finished
And please edit the text., not create new ones
splash vt.handoff=7
chip ID: 10de:0be3
dev: /dev/sda3
it worked ?
And yes here we have the problem. Only Driver 340xx supports this Mobile GPU, anything higher not. On this ISO is only Nvidia 450xx available, so that it doesn’t find any configs. So no bug.
So I should be able to install nvidia 340.xx when installing with architect ???
One moment… i will check again.
No, seems not possible from the menu, but you can chroot into the installation (there is a menu for that in architect) after installation. And install it with:
sudo mhwd -i pci video-nvidia-390xx
Or install after reboot.
Normally it will choose nouveau as driver.
You mean 340xx ? Right ?
Huch… yeah you are right. I misread that… That are the cards which are supported by my card…
> 0000:01:00.0 (0300:10de:1c82) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-450xx 2019.10.25 false PCI
video-nvidia-440xx 2019.10.25 false PCI
video-nvidia-435xx 2019.10.25 false PCI
video-nvidia-430xx 2019.10.25 false PCI
video-nvidia-418xx 2019.10.25 false PCI
video-nvidia-390xx 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
340xx doesn’t work on my system, so it is not there. But 340xx is there:
pacman -Ss 340xx
core/mhwd-nvidia-340xx 340.108-1 [Installiert]
MHWD module-ids for nvidia 340.108
extra/linux414-nvidia-340xx 340.108-40 (linux414-extramodules)
NVIDIA drivers for linux.
extra/linux419-nvidia-340xx 340.108-57 (linux419-extramodules)
extra/linux44-nvidia-340xx 340.108-32 (linux44-extramodules)
extra/linux49-nvidia-340xx 340.108-32 (linux49-extramodules)
extra/linux54-nvidia-340xx 340.108-65 (linux54-extramodules)
extra/linux57-nvidia-340xx 340.108-26 (linux57-extramodules)
extra/nvidia-340xx-utils 340.108-1
NVIDIA drivers utilities
extra/opencl-nvidia-340xx 340.108-1
OpenCL implemention for NVIDIA
community/linux-latest-nvidia-340xx 5.7-2 (linux-latest-extramodules)
Legacy NVIDIA drivers for Linux (metapackage)
community/linux-lts-nvidia-340xx 1:5.4-3 (linux-lts-extramodules)
community/linux-rt-lts-manjaro-nvidia-340xx 5.4-1 (linux-rt-lts-manjaro-extramodules)
community/linux-rt-manjaro-nvidia-340xx 5.6-2 (linux-rt-manjaro-extramodules)
community/linux54-rt-nvidia-340xx 340.108-23 (linux54-rt-extramodules)
community/linux56-rt-nvidia-340xx 340.108-8 (linux56-rt-extramodules)
multilib/lib32-nvidia-340xx-utils 340.108-1
NVIDIA drivers utilities (32-bit)
multilib/lib32-opencl-nvidia-340xx 340.108-1
OpenCL implemention for NVIDIA (32-bit)
Please read also this:
Wow, I have good news !!!
Just installed Gnome with architect. I uses auto install properietry drivers during installation. It detected the driver and I just booted into Manjaro after a fresh install for the first time -
Thank you very much for your support and help.
And nvidia 340xx already installed. It is perfect
