No Wifi Adapter found
Hello, i’ve got a problem.
I get the message No Wi-Fi Adapter Found, and don’t know how to solve it
How can I solve this problem ?
Thanks in advance !!!
Hello, thanks for replying. The problem is that when I paste the content of the terminal, it doesn’t accept to be sent. It says “you aren’t allowed to post links” So I cant post what you ask…
I’m sorry, but how do I solve this other problem ?
Even with preformatting?
Sorry, I confused ’ with `. So here’s the information you asked.
 inxi --admin --verbosity=7 --filter --width         ✔
  Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=3ec49352-a223-427d-b3b5-91d3830b1fb9 rw quiet splash apparmor=1
  Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: HP product: HP Stream Notebook v: Type1ProductConfigId
  Mobo: HP model: 815E v: 32.25 serial: <superuser required> UEFI: Insyde
    v: F.15 date: 06/28/2016
  ID-1: BAT0 charge: 0% condition: 25.3/25.3 Wh (100.0%) volts: 7.6 min: 7.6
    model: Hewlett-Packard Primary type: Li-ion serial: N/A status: N/A
  RAM: total: 1.79 GiB used: 1.77 GiB (98.6%)
  RAM Report:
  Info: model: Intel Celeron N3050 bits: 64 type: MCP arch: Airmont family: 6
    model-id: 0x4C (76) stepping: 3 microcode: 0x368
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
    desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 2160 min/max: 480/2160 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2160 2: 2160 bogomips: 6402
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
    clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    erms est fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor
    movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni
    popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq tsc_reliable vme xtopology xtpr
  Type: spec_store_bypass status: Not affected
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
    Integrated Graphics
    vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
    chip-ID: 8086:22b1 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD
    type: USB driver: uvcvideo bus-ID: 1-3:4 chip-ID: 05c8:0379 class-ID: 0e02
  Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
    High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:2284 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: yes
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard
    driver: bcma-pci-bridge v: N/A modules: bcma bus-ID: 02:00.0
    chip-ID: 14e4:4365 class-ID: 0280
  IF-ID-1: enp0s20u2 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
    bus-ID: 1-4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 29.12 GiB used: 9.31 GiB (32.0%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SK Hynix model: HBG4e
    size: 29.12 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0x7 scheme: GPT
  ID-1: / raw-size: 28.83 GiB size: 28.21 GiB (97.85%) used: 9.31 GiB (33.0%)
    fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
    uuid: 3ec49352-a223-427d-b3b5-91d3830b1fb9
    used: 288 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
    label: NO_LABEL uuid: F46C-D29A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
  Device-1: 1-2:7 info: OnePlus (Shenzhen) BE2013 type: CDC-Data
    driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
    chip-ID: 2a70:f00e class-ID: 0a00 serial: <filter>
  Device-2: 1-3:4
    info: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: Video
  Device-3: 1-4:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 43.0 C mobo: N/A
  Processes: 201 Uptime: 1h 49m wakeups: 6 Init: systemd v: 250
  tool: systemctl Compilers: gcc: N/A Packages: pacman: 1169 lib: 332
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
Thanks for helping me.
Try installing the Broadcom STA wireless driver from thew community repository:
pamac install broadcom-wl-dkms
Note: I have no idea if this’ll work, just a random thought based on a search result
Thanks for helping, but it didn’t work. It gives me this output (it’s only the last line because there’s hundreds of failure lines for each thing he wanted to download but didn’t find)
Error: Failed to commit transaction: failed to retrieve some files
Thanks for helping.
Apologies.
I made a mistake, which I’ve corrected. I used build when I should’ve used install. And it seems to have worked for me, so there must an internet connectivity issue.
Edit:
Make sure the computer has a temporary connection to the internet before attempting the installation. If it doesn’t work, report back with the full output from the terminal.
When I use Install instead of build it says this :
Preparing...
Waiting for another package manager to quit...
Transaction cancelled: Timeout expired.
I thought you might find this interesting :thinking:
And of course I had a wired connexion with all my attempts of doing what you suggested :wink:
I’m communicating with you via my computer after all.
It could have been a pone or tablet, so I just made sure.
That makes it sound like there is some other pamac running somewhere.
If you’re absolutely sure there isn’t, delete the lock file,
sudo rm /var/lib/pacman/db.lck
Or reboot, and try again.
I only know of one package manager being installed on my computer. But why do I have to delete my package manager ? Sorry to ask…
It’s not the package manager itself. It’s just a lock file, stopping the same application from simultaneously performing two actions and causing issues that way.
ok, thanks. I’ll do it, and then retry to install it with the install command.
Here’s the output. Is it worth it to apply the transaction even though it said that everything is unknown? Every time I did it with the build command, it still failed.
pamac install broadcom-wl-dkms                      ✔  8s 
Preparing...
https://repo.rhindon.net/manjaro/stable/core/x86_64/core.db: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/extra/x86_64/extra.db: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/community/x86_64/community.db: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/multilib/x86_64/multilib.db: Error resolving “repo.rhindon.net”: Name or service not known
Warning: python-pyqt5: local (5.15.6-7.1) is newer than extra (5.15.6-7)
Resolving dependencies...
Checking inter-conflicts...
To install (6):
  gc                8.2.0-2          (Required By: broadcom-wl-dkms)  extra
  guile             2.2.7-2          (Required By: broadcom-wl-dkms)  extra
  make              4.3-3            (Required By: broadcom-wl-dkms)  core
  patch             2.7.6-8          (Required By: broadcom-wl-dkms)  core
  dkms              3.0.3-1          (Required By: broadcom-wl-dkms)  extra
  broadcom-wl-dkms  6.30.223.271-28                                   community
Total installed size: 56.9 MB
Apply transaction ? [y/N] ^C
I’ll do it and post the output
Here’s the output. I believe it somehow succeeded… But I don’t understand what just happened…
Apply transaction ? [y/N] ^Cy
https://repo.rhindon.net/manjaro/stable/extra/x86_64/gc-8.2.0-2-x86_64.pkg.tar.zst: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/extra/x86_64/guile-2.2.7-2-x86_64.pkg.tar.zst: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/core/x86_64/make-4.3-3-x86_64.pkg.tar.zst: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/core/x86_64/patch-2.7.6-8-x86_64.pkg.tar.xz: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/extra/x86_64/dkms-3.0.3-1-any.pkg.tar.zst: Error resolving “repo.rhindon.net”: Name or service not known
https://repo.rhindon.net/manjaro/stable/community/x86_64/broadcom-wl-dkms-6.30.223.271-28-x86_64.pkg.tar.zst: Error resolving “repo.rhindon.net”: Name or service not known
Checking keyring...                                                  [6/6]
Checking integrity...                                                [6/6]
Loading package files...                                             [6/6]
Checking file conflicts...                                           [6/6]
Checking available disc space...                                     [6/6]
Installing gc (8.2.0-2)...                                           [1/6]
Installing guile (2.2.7-2)...                                        [2/6]
Installing make (4.3-3)...                                           [3/6]
Installing patch (2.7.6-8)...                                        [4/6]
Installing dkms (3.0.3-1)...                                         [5/6]
Installing broadcom-wl-dkms (6.30.223.271-28)...                     [6/6]
Unload and load kernel modules (wl is provided by broadcom-wl-dkms):
  rmmod b43 b43legacy bcm43xx bcma brcm80211 brcmfmac brcmsmac ssb tg3 wl
  modprobe wl
Arming ConditionNeedsUpdate...                                       [1/3]
Install DKMS modules                                                 [2/3]
==> ERROR: Missing sys kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing sbin kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing proc kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing mnt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing srv kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing lib kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing run kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing etc kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing tmp kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing lib64 kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing boot kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing dev kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing home kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing root kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing var kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing opt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing bin kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing usr kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing lost+found kernel headers for module broadcom-wl/6.30.223.271.
Updating the info directory file...                                  [3/3]
Yes, that looks correct. Well, at least to me.
And of those packages it needs to download to install is once-off. If you’ve got it, you’ve got it. Except for updates, of course. And you’ll need them at some stage anyway. Or most people do.
I just posted the output a second before you answered my previous message.
Because it tries to install a dkms module, it needs the kernel headers, which aren’t installed.
I see you have kernel version 5.15:
So install the headers for it:
pamac install linux515-headers
And then try the previous install again.
Did it, and now he says that the previous install was already done. Here’s output :
Preparing...
Warning: broadcom-wl-dkms-6.30.223.271-28 is up to date -- skipping
Nothing to do.
What do I do next ?
Hold your thumbs, cross your heart, and reboot to see if it works.
