ok. see you in a minute
nope, still no wifi adaptor found…
Nothing has changed
OK, well then I have no idea further. Post an updated inxi
as above and hope and pray someone can help. Because:
- My knowledge has been exhausted; and
- I’ve got to be off now.
Hope you manage!
Well, thanks anyway. Ill post an updated inxi. And thank you for your time !
By the way, I’ve got homework to do myself, so…
I’ll be off too.
You are very welcome, my friend! And homework’s no fun, no. Just like going to the dentist. You don’t want to, you don’t like it but you have to and when done you realize it could’ve been worse…
Here’s new inxi :
inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3ec49352-a223-427d-b3b5-91d3830b1fb9 rw quiet splash apparmor=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: HP product: HP Stream Notebook v: Type1ProductConfigId
Mobo: HP model: 815E v: 32.25 serial: <superuser required> UEFI: Insyde
v: F.15 date: 06/28/2016
ID-1: BAT0 charge: 0% condition: 25.3/25.3 Wh (100.0%) volts: 7.6 min: 7.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: N/A
RAM: total: 1.79 GiB used: 1.39 GiB (77.5%)
RAM Report:
Info: model: Intel Celeron N3050 bits: 64 type: MCP arch: Airmont family: 6
model-id: 0x4C (76) stepping: 3 microcode: 0x368
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 525 high: 529 min/max: 480/2160 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 529 2: 522
bogomips: 6402
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
erms est fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni
popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
tsc_known_freq tsc_reliable vme xtopology xtpr
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:22b1 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD
type: USB driver: uvcvideo bus-ID: 1-3:2 chip-ID: 05c8:0379 class-ID: 0e02
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: N/A
modules: bcma bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF-ID-1: enp0s20u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Local Storage: total: 29.12 GiB used: 9.81 GiB (33.7%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SK Hynix model: HBG4e
size: 29.12 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x7 scheme: GPT
ID-1: / raw-size: 28.83 GiB size: 28.21 GiB (97.85%) used: 9.81 GiB (34.8%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
uuid: 3ec49352-a223-427d-b3b5-91d3830b1fb9
used: 288 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
label: NO_LABEL uuid: F46C-D29A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-2:5 info: OnePlus (Shenzhen) BE2013 type: CDC-Data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 2a70:f00e class-ID: 0a00 serial: <filter>
Device-2: 1-3:2
info: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: Video
Device-3: 1-4:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 195 Uptime: 10m wakeups: 6 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1178 lib: 332 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.12
Who has an idea on how to fix this problem ?
Homework in itself isn’t fun, but the stuff i’m learning interests me, so I have to swim through it anyway
Makes the swimming easier!
You may need to force a reinstallation.
pamac reinstall broadcom-wl-dkms
Thanks for helping. Something took an abnormal turn when I executed the command and proceeded to the reinstallation…
pamac reinstall broadcom-wl-dkms ✔
Preparing...
Warning: broadcom-wl-dkms-6.30.223.271-28 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To reinstall (1):
broadcom-wl-dkms 6.30.223.271-28 community
Apply transaction ? [y/N] y
https://repo.rhindon.net/manjaro/stable/community/x86_64/broadcom-wl-dkms-6.30.223.271-28-x86_64.pkg.tar.zst: Error resolving “repo.rhindon.net”: Name or service not known
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading package files... [1/1]
Checking file conflicts... [1/1]
Checking available disc space... [1/1]
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade... [1/2]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules [2/2]
==> dkms remove broadcom-wl/6.30.223.271
Reinstalling broadcom-wl-dkms (6.30.223.271-28)... [1/1]
Unload and load kernel modules (wl is provided by broadcom-wl-dkms):
rmmod b43 b43legacy bcm43xx bcma brcm80211 brcmfmac brcmsmac ssb tg3 wl
modprobe wl
Arming ConditionNeedsUpdate... [1/2]
Install DKMS modules [2/2]
==> dkms install --no-depmod broadcom-wl/6.30.223.271 -k 5.15.21-1-MANJARO
Error! Bad return status for module build on kernel: 5.15.21-1-MANJARO (x86_64)
Consult /var/lib/dkms/broadcom-wl/6.30.223.271/build/make.log for more information.
==> WARNING: `dkms install --no-depmod broadcom-wl/6.30.223.271 -k 5.15.21-1-MANJARO' exited 10
What do I do now ?
I have some aditionnal information though : I booted on the installation medium I created to see if it could find wifi, but it doesn’t. It gives the same error.
I don’t knowif this will help, but I also tried booting on Slitaz, which is also Debian-based, and it couldn’t find any wifi aswell… I know however that both installation mediums work fine, as they did work perfectly on another computer I have. i couldconnect to wifi on that computer on both slitaz and Manjaro, installed from the same bootable USB.
I hope this can be usefull…
What does the log say?
It says this :
DKMS make.log for broadcom-wl-6.30.223.271 for kernel 5.15.21-1-MANJARO (x86_64)
Sun 20 Feb 19:49:15 CET 2022
make: Entering directory '/usr/lib/modules/5.15.21-1-MANJARO/build'
CFG80211 API is prefered for this kernel version
Using CFG80211 API
CC [M] /var/lib/dkms/broadcom-wl/6.30.223.271/build/src/shared/linux_osl.o
CC [M] /var/lib/dkms/broadcom-wl/6.30.223.271/build/src/wl/sys/wl_linux.o
gcc: fatal error: cannot execute ‘cc1’: execvp: No such file or directory
compilation terminated.
make[1]: *** [scripts/Makefile.build:277: /var/lib/dkms/broadcom-wl/6.30.223.271/build/src/shared/linux_osl.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [scripts/Makefile.build:277: /var/lib/dkms/broadcom-wl/6.30.223.271/build/src/wl/sys/wl_linux.o] Error 1
make: *** [Makefile:1868: /var/lib/dkms/broadcom-wl/6.30.223.271/build] Error 2
make: Leaving directory '/usr/lib/modules/5.15.21-1-MANJARO/build'
Looks like there’s afatal error somewhere…
Do you know what to do next ?
I’ve found the solution to my problem.
I booted with open source drivers, but that didn’t work.
When I tried to boot with closed source drivers, poof, I got Wifi access.
So this explains that…
