Greetings, encountered a problem that in the proposals that are in the default ( settings and the like ) if they will be in windowed mode there will be no text, iso image downloaded today
Delete the screenshot, and describe your issue with words… yes, words. Also, provide some information about your system and detail your problem so that others can help more effectively.
Hi @Faldiko and welcome to the Manjaro community.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit.
To that end, some or all these links will be invaluable:
- [How to] Request Support
- [How to] Find Error Logs
- [How to] Find System Information
- [How to] Post
Screenshots andLinks
Please do not post screenshots - [How to] Post Command Output and File Content as Formatted Text
- Tutorials category, generally
- Forum Rules
- Strict Forum Rules and Guidelines
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information.
I seem to recall a similar issue mentioned many times; please search the forum for any threads that might be related.
You did this already, before posting, right?
I hope this helps. Cheers.
I’ve tried to find the problem everywhere I can and I can’t find any information
