No sound settings possible in Gnome 49
The sound card is recognized, and I can hear sound when I switch to alsamixer, but the setting isn’t saved. The headphone option is selectable in the GNOME settings, but I can’t test it; sudo alsactl store doesn’t do anything either.
Is sof-firmware installed?
[$] pacman -Ss sof-firmware
extra/sof-firmware 2025.12.2-1 [installed]
    Sound Open Firmware
The following links might be helpful;
If not, then provide system information and other details that might assist others to help you. :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
