I reinstalled Manjaro and now I have no sound. I am not really sure what is wrong with it.
pulseaudio -D
E: [pulseaudio] main.c: Daemon startup failed.
[wired@BigBertha ~]$ systemctl list-units --type=target
UNIT LOAD ACTIVE SUB DESCRIPTION
basic.target loaded active active Basic System
bluetooth.target loaded active active Bluetooth
cryptsetup.target loaded active active Local Encrypted Volumes
getty.target loaded active active Login Prompts
graphical.target loaded active active Graphical Interface
local-fs-pre.target loaded active active Local File Systems (Pre)
local-fs.target loaded active active Local File Systems
multi-user.target loaded active active Multi-User System
network.target loaded active active Network
paths.target loaded active active Paths
remote-fs.target loaded active active Remote File Systems
slices.target loaded active active Slices
sockets.target loaded active active Sockets
sound.target loaded active active Sound Card
swap.target loaded active active Swap
sysinit.target loaded active active System Initialization
timers.target loaded active active Timers
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
17 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
[wired@BigBertha ~]$ journalctl --user -xe
Feb 12 00:49:02 BigBertha kded5[1239]: Registering ":1.59/StatusNotifierItem" to system tray
Feb 12 00:49:02 BigBertha xembedsniproxy[1305]: Container window visible, stack below
Feb 12 00:49:04 BigBertha ktraderclient5[2103]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/spotify" not found
Feb 12 00:49:04 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45175, resource id: 73400321, major code: 15 (QueryTree), minor code: 0
Feb 12 00:49:04 BigBertha systemd[1167]: Started Firefox - Web Browser.
ββ Subject: A start job for unit UNIT has finished successfully
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit UNIT has finished successfully.
ββ
ββ The job identifier is 138.
Feb 12 00:49:04 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45400, resource id: 90177541, major code: 18 (ChangeProperty), minor code: 0
Feb 12 00:49:04 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45405, resource id: 90177542, major code: 18 (ChangeProperty), minor code: 0
Feb 12 00:49:04 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45409, resource id: 90177543, major code: 18 (ChangeProperty), minor code: 0
Feb 12 00:49:04 BigBertha systemd[1167]: app-firefox-cc9b2c29f87748ec85b4a98fef17d57b.scope: Succeeded.
ββ Subject: Unit succeeded
ββ
ββ The unit UNIT has successfully entered the 'dead' state.
Feb 12 00:49:07 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49545, resource id: 35651758, major code: 15 (QueryTree), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53819, resource id: 35651750, major code: 19 (DeleteProperty), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53822, resource id: 35651750, major code: 19 (DeleteProperty), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53823, resource id: 35651750, major code: 18 (ChangeProperty), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53824, resource id: 35651750, major code: 19 (DeleteProperty), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53825, resource id: 35651750, major code: 19 (DeleteProperty), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53826, resource id: 35651750, major code: 19 (DeleteProperty), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53827, resource id: 35651750, major code: 7 (ReparentWindow), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53828, resource id: 35651750, major code: 6 (ChangeSaveSet), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53829, resource id: 35651750, major code: 2 (ChangeWindowAttributes), minor code: 0
Feb 12 00:49:11 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53830, resource id: 35651750, major code: 10 (UnmapWindow), minor code: 0
Feb 12 00:49:18 BigBertha pulseaudio[1336]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Feb 12 00:49:18 BigBertha pulseaudio[1336]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Feb 12 00:49:18 BigBertha pulseaudio[1336]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Feb 12 00:49:29 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2254, resource id: 35651775, major code: 18 (ChangeProperty), minor code: 0
Feb 12 00:49:29 BigBertha systemd[1167]: Started Konsole - Terminal.
ββ
ββ
ββ The job identifier is 142.
Feb 12 00:49:39 BigBertha sudo[2255]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Feb 12 00:49:39 BigBertha sudo[2255]: wired : TTY=pts/2 ; PWD=/home/wired ; USER=root ; COMMAND=/usr/bin/pacman -Syu
Feb 12 00:49:39 BigBertha sudo[2255]: pam_unix(sudo:session): session opened for user root(uid=0) by wired(uid=1000)
Feb 12 00:49:40 BigBertha sudo[2255]: pam_unix(sudo:session): session closed for user root
Feb 12 00:49:51 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16621, resource id: 56623167, major code: 15 (QueryTree), minor code: 0
Feb 12 00:49:51 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16717, resource id: 56623107, major code: 15 (QueryTree), minor code: 0
ββ
ββ
ββ
ββ
ββ
Feb 12 00:49:51 BigBertha kwin_x11[1243]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17033, resource id: 35651776, major code: 18 (ChangeProperty), minor code: 0
Feb 12 00:49:51 BigBertha systemd[1167]: app-firefox-958188663ae94ad598e6ce777277200e.scope: Succeeded.
ββ
Feb 12 00:50:26 BigBertha plasmashell[1309]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 00:50:26 BigBertha systemd[1167]: Started Firefox - Web Browser.
ββ
ββ
ββ The job identifier is 146.
Feb 12 00:50:26 BigBertha plasmashell[1309]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
Feb 12 00:53:32 BigBertha pulseaudio[2750]: Daemon already running.
Feb 12 00:53:46 BigBertha pulseaudio[2762]: Daemon already running.
Feb 12 00:53:46 BigBertha pulseaudio[2762]: pa_pid_file_create() failed.
Feb 12 00:54:13 BigBertha pulseaudio[2793]: Daemon already running.
Feb 12 00:54:13 BigBertha pulseaudio[2793]: pa_pid_file_create() failed.
Feb 12 00:55:16 BigBertha kwin_x11[1243]: file:///usr/share/kwin/outline/plasma/outline.qml:46:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
[wired@BigBertha ~]$ systemctl --user status pulseaudio.service
β pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
Active: active (running) since Fri 2021-02-12 00:47:55 PST; 18min ago
TriggeredBy: β pulseaudio.socket
Main PID: 1336 (pulseaudio)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.service
ββ1336 /usr/bin/pulseaudio --daemonize=no --log-target=journal
ββ1448 /usr/lib/pulse/gsettings-helper
Feb 12 00:47:55 BigBertha systemd[1167]: Starting Sound Service...
Feb 12 00:47:55 BigBertha systemd[1167]: Started Sound Service.
Please help. I am not sure what is wrong.
and this is way above my
. Could you have a look when you wake up, please?
