Hello everyone,
I am trying (and failing) to get the sound of the integrated loudspeakers working for my HUAWEI MateBook D 15 (Specs [German]: https:// consumer.huawei. com/de/laptops/matebook-d-15/specs/ (remove spaces)) running on Intel Core i3-10110U. I have listed the things I tried and the logs below. I am running Manjaro with GNOME desktop.
What did I expect:
I expected to hear sound through the integrated loudspeakers.
What did happen instead:
When I set the volume (or look into pavucontrol) I can only see a “Dummy Output” which does not make any sound. When playing YouTube via browser I can see via pactl list that something is playing (kernel 5.14 and dsp_driver=0):
Driver: protocol-native.c
Owner Module: 12
Client: 9
Sink: 0
Sample Specification: float32le 2ch 44100Hz
Channel Map: front-left,front-right
Format: pcm, format.sample_format = "\"float32le\"" format.rate = "44100" format.channels = "2" format.channel_map = "\"front-left,front-right\""
Corked: no
Mute: no
Volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Buffer Latency: 124988 usec
Sink Latency: 17165 usec
Resample method: copy
Properties:
media.name = "Chillout Lounge - Calm & Relaxing Background Music | Study, Work, Sleep, Meditation, Chill - YouTube"
application.name = "Firefox"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "35"
application.process.id = "2134"
application.process.user = "someone"
application.process.host = "someone-bohbwax9"
application.process.binary = "firefox"
application.language = "en_US.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "somemachineid"
application.icon_name = "firefox"
module-stream-restore.id = "sink-input-by-application-name:Firefox"
When I pair a bluetooth speaker I can hear the sound of the device via it. I think the integrated soundcard somehow fails to be initialized but I ran out of ideas of what to do. System is up-to-date (pacman -Syu shows no updates).
Running aplay -l only shows HDMI audio devices (but audio does not work via HDMI or audio jack)
**** List of PLAYBACK Hardware Devices ****
card 0: sofhdadsp [sof-hda-dsp], device 1: HDMI1 (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 2: HDMI2 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI3 (*) []
Subdevices: 1/1
When running in default configuration (dsp_driver=0) both of the digital mics work. With dsp_driver=1 neither mics nor speaker work.
Things I tried (rebooted in between):
Tried to install newest kernel: 5.14.7-2-MANJARO
Tried latest stable kernel: 5.10.63-1-MANJARO
and for each tried the following:
Tried to set the following, rebooted in between:
In
/etc/modprobe.d/dsp-fix.conf:
options snd_intel_dspcfg dsp_driver=1 -
In setting older driver via kernel parameters:
vi /etc/default/grub
and adding:snd-intel-dspcfg.dsp_driver=1
to the end ofGRUB_CMDLINE_LINUX_DEFAULT
then running:
update-grub -
Deleting old configs etc:
rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie -
Setting
/etc/modprobe.d/sound.conf(withdsp_driver=1)
options snd_hda_intel model=generic
or
options snd_hda_intel model=auto -
Setting the deprecated config option:
echo “options snd-hda-intel dmic_detect=0” | sudo tee /etc/modprobe.d/alsa-fix.conf
Attached are the logs of kernel version 5.14 and dsp_driver settings 0.
inxi reflects this: eg. diff between kernel 5.10 dsp_driver 0 and 1:
< Device-1: Intel Comet Lake PCH-LP cAVS vendor: QUANTA driver: sof-audio-pci
< alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
> Device-1: Intel Comet Lake PCH-LP cAVS vendor: QUANTA driver: snd_hda_intel
> v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Reading https:// bugzilla. kernel. org/show_bug. cgi?id=210633#c16 (remove spaces) I copied some debug settings into /etc/modprobe/sof-dyndbg.conf:
options snd_sof_intel_hda_common dyndbg=+p
options snd_sof_intel_hda dyndbg=+p
options snd_sof dyndbg=+p
options snd_sof_pci dyndbg=+p
options soundwire_bus dyndbg=+p
options soundwire_generic_allocation dyndbg=+p
options soundwire_cadence dyndbg=+p
options soundwire_intel_init dyndbg=+p
options soundwire_intel dyndbg=+p
options snd_soc_skl_hda_dsp dyndbg=+p
options snd_intel_dspcfg dyndbg=+p
This results in very verbose dmesg messages, I did not see anything wrong here:
[ 7.444166] fb0: switching to inteldrmfb from EFI VGA
[ 7.444220] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 7.444676] iTCO_vendor_support: vendor-support=0
[ 7.445073] loop0: detected capacity change from 0 to 8
[ 7.445428] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 7.445443] snd_hda_intel 0000:00:1f.3: intel_nhlt_get_dmic_geo: found 2 format definitions
[ 7.445445] snd_hda_intel 0000:00:1f.3: intel_nhlt_get_dmic_geo: max channels found 2
[ 7.445446] snd_hda_intel 0000:00:1f.3: intel_nhlt_get_dmic_geo: Array with 2 dmics
[ 7.445448] snd_hda_intel 0000:00:1f.3: intel_nhlt_get_dmic_geo: dmic number 2 max_ch 2
[ 7.445450] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 7.450761] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 7.451614] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 7.457449] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.459995] dw-apb-uart.3: ttyS4 at MMIO 0x9b803000 (irq = 20, base_baud = 7500000) is a 16550A
[ 7.466816] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.467894] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 7.468926] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 7.477636] input: ETD2204:00 04F3:31DC Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ETD2204:00/0018:04F3:31DC.0001/input/input9
[ 7.478290] input: ETD2204:00 04F3:31DC Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ETD2204:00/0018:04F3:31DC.0001/input/input11
[ 7.478424] hid-multitouch 0018:04F3:31DC.0001: input,hidraw0: I2C HID v1.00 Mouse [ETD2204:00 04F3:31DC] on i2c-ETD2204:00
[ 7.489916] iwlwifi 0000:00:14.3: Detected RF JF, rfid=0x105110
[ 7.501983] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 7.503946] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 7.504348] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
[ 7.507748] mousedev: PS/2 mouse device common for all mice
[ 7.546717] iwlwifi 0000:00:14.3: base HW address: f8:5e:a0:20:c8:08
[ 7.567642] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 7.628185] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 7.628205] snd_soc_skl 0000:00:1f.3: intel_nhlt_get_dmic_geo: found 2 format definitions
[ 7.628207] snd_soc_skl 0000:00:1f.3: intel_nhlt_get_dmic_geo: max channels found 2
[ 7.628208] snd_soc_skl 0000:00:1f.3: intel_nhlt_get_dmic_geo: Array with 2 dmics
[ 7.628210] snd_soc_skl 0000:00:1f.3: intel_nhlt_get_dmic_geo: dmic number 2 max_ch 2
[ 7.628212] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 7.691708] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 7.691727] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: found 2 format definitions
[ 7.691730] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: max channels found 2
[ 7.691731] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: Array with 2 dmics
[ 7.691733] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: dmic number 2 max_ch 2
[ 7.691735] sof-audio-pci-intel-cnl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 7.691736] sof-audio-pci-intel-cnl 0000:00:1f.3: PCI DSP detected
[ 7.691750] sof-audio-pci-intel-cnl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 7.691916] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 7.789369] fbcon: i915 (fb0) is primary device
[ 7.789371] fbcon: Deferring console take-over
[ 7.789373] i915 0000:00:02.0: [drm] fb0: i915 frame buffer device
[ 7.789318] sof-audio-pci-intel-cnl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 7.796020] sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0xc00
[ 7.796026] sof-audio-pci-intel-cnl 0000:00:1f.3: found ML capability at 0xc00
[ 7.796028] sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x800
[ 7.796033] sof-audio-pci-intel-cnl 0000:00:1f.3: found DSP capability at 0x800
[ 7.796035] sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x500
[ 7.796040] sof-audio-pci-intel-cnl 0000:00:1f.3: found GTS capability at 0x500
[ 7.796041] sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x1f00
[ 7.796047] sof-audio-pci-intel-cnl 0000:00:1f.3: found DRSM capability at 0x1f00
[ 7.796048] sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x700
[ 7.796053] sof-audio-pci-intel-cnl 0000:00:1f.3: found SPIB capability at 0x700
[ 7.796085] sof-audio-pci-intel-cnl 0000:00:1f.3: hda global caps = 0x1009701
[ 7.796087] sof-audio-pci-intel-cnl 0000:00:1f.3: detected 9 playback and 7 capture streams
[ 7.796176] sof-audio-pci-intel-cnl 0000:00:1f.3: use msi interrupt mode
[ 7.796177] sof-audio-pci-intel-cnl 0000:00:1f.3: using IPC IRQ 140
[ 7.796318] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000044
[ 7.796320] sof-audio-pci-intel-cnl 0000:00:1f.3: PP capability, will probe DSP later.
[ 7.799340] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at 00000048
[ 7.799346] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at 00000048
[ 7.803571] sof-audio-pci-intel-cnl 0000:00:1f.3: codec_mask = 0x4
[ 7.803579] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000048
[ 7.803582] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at 00000048
[ 7.805101] sof-audio-pci-intel-cnl 0000:00:1f.3: skipping SoundWire, no links enabled
[ 7.805212] sof-audio-pci-intel-cnl 0000:00:1f.3: HDA codec #2 probed OK: response: 8086280b
[ 7.806016] hdaudio ehdaudio0D2: loading codec module: hdaudio:v8086280Br00100000a01
[ 7.828888] sof-audio-pci-intel-cnl 0000:00:1f.3: hda codecs found, mask 4
[ 7.828892] sof-audio-pci-intel-cnl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 7.828896] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: found 2 format definitions
[ 7.828898] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: max channels found 2
[ 7.828900] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: Array with 2 dmics
[ 7.828901] sof-audio-pci-intel-cnl 0000:00:1f.3: intel_nhlt_get_dmic_geo: dmic number 2 max_ch 2
[ 7.828906] sof-audio-pci-intel-cnl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 7.828915] sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
[ 7.830279] sof-audio-pci-intel-cnl 0000:00:1f.3: request_firmware intel/sof/sof-cml.ri successful
[ 7.830282] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 1 size 0x1A0
[ 7.830284] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 6 size 0x20
[ 7.830286] sof-audio-pci-intel-cnl 0000:00:1f.3: FW clock config: HPRO
[ 7.830288] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 0 size 0x50
[ 7.830289] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[ 7.830291] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
[ 7.830294] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 2 size 0x70
[ 7.830295] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: used compiler XCC 12:0:8 <RG-2017.8-linux> used optimization flags -O2
[ 7.830300] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 3 size 0x30
[ 7.830302] sof-audio-pci-intel-cnl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 7.830303] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 4 size 0x20
[ 7.830305] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: DBG_ABI 5:3:0
[ 7.830306] sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 5 size 0x20
[ 7.830308] sof-audio-pci-intel-cnl 0000:00:1f.3: ext_man_get_config_data can hold up to 3 config elements
[ 7.830309] sof-audio-pci-intel-cnl 0000:00:1f.3: ext_man_get_config_data get index 0 token 1 val 384
[ 7.830311] sof-audio-pci-intel-cnl 0000:00:1f.3: ext_man_get_config_data get index 1 token 2 val 1
[ 7.830315] sof-audio-pci-intel-cnl 0000:00:1f.3: ext_man_get_config_data get index 2 token 0 val 0
[ 7.830322] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at 00000048
[ 7.830327] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at 00000048
[ 7.830334] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000044
[ 7.830336] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at 00000044
[ 7.830338] sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
[ 7.830377] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 7.830390] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 7.830393] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x0
[ 7.830395] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:1
[ 7.830422] sof-audio-pci-intel-cnl 0000:00:1f.3: Attempting iteration 0 of Core En/ROM load...
[ 7.830427] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
[ 7.830435] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
[ 7.830442] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f00 successful
[ 7.830446] sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = f
[ 7.830453] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask f
[ 7.830465] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0000 successful
[ 7.830469] sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
[ 7.830475] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
[ 7.830985] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
[ 7.830994] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
[ 7.831504] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
[ 7.831508] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
[ 7.896162] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5000001 successful
[ 7.910947] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
[ 7.911459] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 7.911463] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware download successful, booting...
[ 7.919215] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
[ 7.919219] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc: DSP is ready 0x70000000 offset 0x81000
[ 7.919336] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[ 7.919338] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
[ 7.919363] sof-audio-pci-intel-cnl 0000:00:1f.3: mailbox upstream 0x81000 - size 0x1000
[ 7.919365] sof-audio-pci-intel-cnl 0000:00:1f.3: mailbox downstream 0xa0000 - size 0x2000
[ 7.919366] sof-audio-pci-intel-cnl 0000:00:1f.3: stream region 0xc1000 - size 0x1000
[ 7.919368] sof-audio-pci-intel-cnl 0000:00:1f.3: debug region 0xc0000 - size 0x800
[ 7.919370] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
[ 7.919372] sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
[ 7.919392] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000048
[ 7.919399] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at 00000048
[ 7.919409] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at 00000044
[ 7.919413] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at 00000044
[ 7.919415] sof-audio-pci-intel-cnl 0000:00:1f.3: SOF firmware trace disabled
[ 7.919466] sof-audio-pci-intel-cnl 0000:00:1f.3: created machine skl_hda_dsp_generic
[ 7.919468] sof-audio-pci-intel-cnl 0000:00:1f.3: Completing SOF PCI probe
[ 7.932259] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_audio_probe: entry
[ 7.932265] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - iDisp1
[ 7.932277] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - iDisp2
[ 7.932286] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - iDisp3
[ 7.932299] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - dmic01
[ 7.932305] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - dmic16k
[ 7.932330] sof-audio-pci-intel-cnl 0000:00:1f.3: loading topology:intel/sof-tplg/sof-hda-generic-idisp-2ch.tplg
[ 7.932794] sof-audio-pci-intel-cnl 0000:00:1f.3: Topology: ABI 3:18:1 Kernel ABI 3:18:0
[ 7.932800] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 0 pipe 0 type 7 name : iDisp3 Tx stream none
[ 7.932803] sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 7 name iDisp3 Tx not handled
[ 7.932806] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 1 pipe 1 type 7 name : iDisp2 Tx stream none
[ 7.932808] sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 7 name iDisp2 Tx not handled
[ 7.932812] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 2 pipe 2 type 23 name : PCM1P stream Passthrough Playback 1
[ 7.932815] sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM1P
[ 7.932817] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 0 fmt 0
[ 7.932821] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.933018] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.933022] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 2 Master Playback Volume
[ 7.933027] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 3 chans 2
[ 7.933029] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 3 pipe 2 type 6 name : PGA2.0 stream none
[ 7.933032] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.933036] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.933173] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.933176] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 4 pipe 2 type 31 name : BUF2.0 stream none
[ 7.933179] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF2.0: size 768 caps 0x71
[ 7.933182] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.933309] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.933312] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 5 pipe 2 type 31 name : BUF2.1 stream none
[ 7.933314] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF2.1: size 768 caps 0x71
[ 7.933317] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.933431] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.933434] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 6 pipe 2 type 27 name : HDA0.OUT stream iDisp1
[ 7.933437] sof-audio-pci-intel-cnl 0000:00:1f.3: dai HDA0.OUT: type 3 index 0
[ 7.933439] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 0 src 2 fmt 2
[ 7.933442] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.933627] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.933629] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget HDA0.OUT -> DAI link iDisp1
[ 7.933632] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 7 pipe 2 type 32 name : PIPELINE.2.HDA0.OUT stream HDA0.OUT
[ 7.933634] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: pipeline id 2 comp 7 scheduling comp id 6
[ 7.933637] sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.2.HDA0.OUT: period 1000 pri 0 mips 5000 core 0 frames 0
[ 7.933640] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 7.933761] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 7.933764] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 8 pipe 2 type 1 name : iDisp1_out stream none
[ 7.933766] sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 1 name iDisp1_out not handled
[ 7.933768] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 9 pipe 2 type 7 name : iDisp1 Tx stream none
[ 7.933770] sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 7 name iDisp1 Tx not handled
[ 7.933772] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 10 pipe 3 type 23 name : PCM2P stream Passthrough Playback 2
[ 7.933775] sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM2P
[ 7.933776] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 0 fmt 0
[ 7.933779] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.933933] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.933936] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 3 Master Playback Volume
[ 7.933940] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 11 chans 2
[ 7.933942] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 11 pipe 3 type 6 name : PGA3.0 stream none
[ 7.933944] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.933948] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.934084] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.934087] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 12 pipe 3 type 31 name : BUF3.0 stream none
[ 7.934089] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF3.0: size 768 caps 0x71
[ 7.934092] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.934205] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.934208] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 13 pipe 3 type 31 name : BUF3.1 stream none
[ 7.934210] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF3.1: size 768 caps 0x71
[ 7.934212] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.934324] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.934326] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 14 pipe 3 type 27 name : HDA1.OUT stream iDisp2
[ 7.934329] sof-audio-pci-intel-cnl 0000:00:1f.3: dai HDA1.OUT: type 3 index 1
[ 7.934331] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 0 src 2 fmt 2
[ 7.934334] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.934481] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.934483] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget HDA1.OUT -> DAI link iDisp2
[ 7.934485] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 15 pipe 3 type 32 name : PIPELINE.3.HDA1.OUT stream HDA1.OUT
[ 7.934487] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: pipeline id 3 comp 15 scheduling comp id 14
[ 7.934489] sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.3.HDA1.OUT: period 1000 pri 0 mips 5000 core 0 frames 0
[ 7.934493] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 7.934614] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 7.934616] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 16 pipe 3 type 1 name : iDisp2_out stream none
[ 7.934618] sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 1 name iDisp2_out not handled
[ 7.934621] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 17 pipe 4 type 23 name : PCM3P stream Passthrough Playback 3
[ 7.934623] sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM3P
[ 7.934624] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 0 fmt 0
[ 7.934628] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.934770] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.934773] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 4 Master Playback Volume
[ 7.934777] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 18 chans 2
[ 7.934780] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 18 pipe 4 type 6 name : PGA4.0 stream none
[ 7.934782] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.934786] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.934912] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.934914] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 19 pipe 4 type 31 name : BUF4.0 stream none
[ 7.934916] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF4.0: size 768 caps 0x71
[ 7.934919] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.935033] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.935035] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 20 pipe 4 type 31 name : BUF4.1 stream none
[ 7.935037] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF4.1: size 768 caps 0x71
[ 7.935039] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.935152] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.935155] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 21 pipe 4 type 27 name : HDA2.OUT stream iDisp3
[ 7.935158] sof-audio-pci-intel-cnl 0000:00:1f.3: dai HDA2.OUT: type 3 index 2
[ 7.935159] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 0 src 2 fmt 2
[ 7.935162] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.935320] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.935322] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget HDA2.OUT -> DAI link iDisp3
[ 7.935324] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 22 pipe 4 type 32 name : PIPELINE.4.HDA2.OUT stream HDA2.OUT
[ 7.935326] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: pipeline id 4 comp 22 scheduling comp id 21
[ 7.935328] sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.4.HDA2.OUT: period 1000 pri 0 mips 5000 core 0 frames 0
[ 7.935331] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 7.935452] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 7.935454] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 23 pipe 4 type 1 name : iDisp3_out stream none
[ 7.935456] sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 1 name iDisp3_out not handled
[ 7.935459] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 24 pipe 5 type 24 name : PCM6C stream Highpass Capture 6
[ 7.935461] sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM6C
[ 7.935462] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 0 src 2 fmt 0
[ 7.935465] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.935609] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.935611] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : Capture Volume
[ 7.935617] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 25 chans 2
[ 7.935619] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : Capture Switch
[ 7.935620] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 25 chans 2
[ 7.935622] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 25 pipe 5 type 6 name : Dmic0 stream none
[ 7.935625] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.935628] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.935762] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.935765] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 2 name : eqiir_coef_5
[ 7.935766] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 26 chans 0
[ 7.935768] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 26 pipe 5 type 33 name : EQIIR5.0 stream none
[ 7.935771] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.935778] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.935921] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.935923] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 27 pipe 5 type 31 name : BUF5.0 stream none
[ 7.935925] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF5.0: size 768 caps 0x71
[ 7.935928] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.936043] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.936046] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 28 pipe 5 type 31 name : BUF5.1 stream none
[ 7.936048] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF5.1: size 768 caps 0x71
[ 7.936050] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.936164] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.936166] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 29 pipe 5 type 31 name : BUF5.2 stream none
[ 7.936168] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF5.2: size 768 caps 0x71
[ 7.936171] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.936285] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.936288] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 30 pipe 5 type 28 name : DMIC0.IN stream dmic01
[ 7.936290] sof-audio-pci-intel-cnl 0000:00:1f.3: dai DMIC0.IN: type 2 index 0
[ 7.936292] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 0 fmt 2
[ 7.936295] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.936518] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.936520] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget DMIC0.IN -> DAI link dmic01
[ 7.936522] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 31 pipe 5 type 32 name : PIPELINE.5.DMIC0.IN stream DMIC0.IN
[ 7.936525] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: pipeline id 5 comp 31 scheduling comp id 30
[ 7.936527] sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.5.DMIC0.IN: period 1000 pri 0 mips 5000 core 0 frames 0
[ 7.936530] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 7.936658] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 7.936661] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 32 pipe 6 type 24 name : PCM7C stream Highpass Capture 7
[ 7.936663] sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM7C
[ 7.936664] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 0 src 2 fmt 0
[ 7.936667] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.936794] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.936796] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 2nd Capture Volume
[ 7.936803] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 33 chans 2
[ 7.936804] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 33 pipe 6 type 6 name : Dmic1 stream none
[ 7.936807] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.936810] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.936927] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.936930] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 2 name : eqiir_coef_6
[ 7.936931] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 34 chans 0
[ 7.936933] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 34 pipe 6 type 33 name : EQIIR6.0 stream none
[ 7.936936] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 2 fmt 2
[ 7.936944] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.937105] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.937107] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 35 pipe 6 type 31 name : BUF6.0 stream none
[ 7.937109] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF6.0: size 256 caps 0x71
[ 7.937111] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.937227] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.937230] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 36 pipe 6 type 31 name : BUF6.1 stream none
[ 7.937232] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF6.1: size 256 caps 0x71
[ 7.937234] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.937348] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.937351] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 37 pipe 6 type 31 name : BUF6.2 stream none
[ 7.937352] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF6.2: size 256 caps 0x71
[ 7.937355] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 7.937469] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 7.937472] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 38 pipe 6 type 28 name : DMIC1.IN stream dmic16k
[ 7.937474] sof-audio-pci-intel-cnl 0000:00:1f.3: dai DMIC1.IN: type 2 index 1
[ 7.937476] sof-audio-pci-intel-cnl 0000:00:1f.3: config: periods snk 2 src 0 fmt 2
[ 7.937479] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 7.937701] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 7.937703] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget DMIC1.IN -> DAI link dmic16k
[ 7.937705] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: ready widget id 39 pipe 6 type 32 name : PIPELINE.6.DMIC1.IN stream DMIC1.IN
[ 7.937707] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: pipeline id 6 comp 39 scheduling comp id 38
[ 7.937709] sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.6.DMIC1.IN: period 1000 pri 0 mips 5000 core 0 frames 0
[ 7.937712] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 7.937867] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 7.937870] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm DMIC 6
[ 7.937875] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - DMIC
[ 7.937889] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm DMIC16kHz 7
[ 7.937892] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - DMIC16kHz
[ 7.937900] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm HDMI1 1
[ 7.937907] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - HDMI1
[ 7.937918] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm HDMI2 2
[ 7.937922] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - HDMI2
[ 7.937930] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm HDMI3 3
[ 7.937933] skl_hda_dsp_generic skl_hda_dsp_generic: skl_hda_add_dai_link: dai link name - HDMI3
[ 7.937943] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF2.0 control none source PCM1P
[ 7.937947] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938036] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938039] sof-audio-pci-intel-cnl 0000:00:1f.3: sink PGA2.0 control none source BUF2.0
[ 7.938042] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938125] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938127] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF2.1 control none source PGA2.0
[ 7.938129] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938212] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938214] sof-audio-pci-intel-cnl 0000:00:1f.3: sink HDA0.OUT control none source BUF2.1
[ 7.938216] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938299] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938302] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF3.0 control none source PCM2P
[ 7.938304] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938388] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938390] sof-audio-pci-intel-cnl 0000:00:1f.3: sink PGA3.0 control none source BUF3.0
[ 7.938393] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938477] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938479] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF3.1 control none source PGA3.0
[ 7.938481] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938565] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938567] sof-audio-pci-intel-cnl 0000:00:1f.3: sink HDA1.OUT control none source BUF3.1
[ 7.938570] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938654] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938658] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF4.0 control none source PCM3P
[ 7.938660] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938745] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938748] sof-audio-pci-intel-cnl 0000:00:1f.3: sink PGA4.0 control none source BUF4.0
[ 7.938750] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938859] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938861] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF4.1 control none source PGA4.0
[ 7.938863] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.938949] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.938952] sof-audio-pci-intel-cnl 0000:00:1f.3: sink HDA2.OUT control none source BUF4.1
[ 7.938954] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939040] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939042] sof-audio-pci-intel-cnl 0000:00:1f.3: sink iDisp1_out control none source HDA0.OUT
[ 7.939045] sof-audio-pci-intel-cnl 0000:00:1f.3: sink iDisp2_out control none source HDA1.OUT
[ 7.939048] sof-audio-pci-intel-cnl 0000:00:1f.3: sink iDisp3_out control none source HDA2.OUT
[ 7.939051] sof-audio-pci-intel-cnl 0000:00:1f.3: sink PCM6C control none source BUF5.0
[ 7.939054] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939143] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939145] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF5.0 control none source Dmic0
[ 7.939148] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939235] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939238] sof-audio-pci-intel-cnl 0000:00:1f.3: sink Dmic0 control none source BUF5.1
[ 7.939240] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939327] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939330] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF5.1 control none source EQIIR5.0
[ 7.939332] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939420] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939422] sof-audio-pci-intel-cnl 0000:00:1f.3: sink EQIIR5.0 control none source BUF5.2
[ 7.939425] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939512] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939515] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF5.2 control none source DMIC0.IN
[ 7.939517] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939606] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939609] sof-audio-pci-intel-cnl 0000:00:1f.3: sink PCM7C control none source BUF6.0
[ 7.939612] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939701] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939704] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF6.0 control none source Dmic1
[ 7.939706] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939788] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939790] sof-audio-pci-intel-cnl 0000:00:1f.3: sink Dmic1 control none source BUF6.1
[ 7.939796] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939881] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939883] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF6.1 control none source EQIIR6.0
[ 7.939885] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.939976] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.939979] sof-audio-pci-intel-cnl 0000:00:1f.3: sink EQIIR6.0 control none source BUF6.2
[ 7.939981] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.940071] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.940073] sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF6.2 control none source DMIC1.IN
[ 7.940075] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 7.940166] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 7.940170] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 6!
[ 7.940173] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: config DMIC0 driver version 1
[ 7.940174] sof-audio-pci-intel-cnl 0000:00:1f.3: pdmclk_min 2400000 pdm_clkmax 4800000 duty_min 40
[ 7.940177] sof-audio-pci-intel-cnl 0000:00:1f.3: duty_max 60 fifo_fs 48000 num_pdms active 1
[ 7.940178] sof-audio-pci-intel-cnl 0000:00:1f.3: fifo word length 32
[ 7.940180] sof-audio-pci-intel-cnl 0000:00:1f.3: pdm 0 mic a 1 mic b 1
[ 7.940182] sof-audio-pci-intel-cnl 0000:00:1f.3: pdm 0 polarity a 0 polarity b 0
[ 7.940183] sof-audio-pci-intel-cnl 0000:00:1f.3: pdm 0 clk_edge 0 skew 0
[ 7.940185] sof-audio-pci-intel-cnl 0000:00:1f.3: set DAI config for dmic01 index 0
[ 7.940192] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 7.940480] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 7.940483] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 7!
[ 7.940485] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: config DMIC1 driver version 1
[ 7.940487] sof-audio-pci-intel-cnl 0000:00:1f.3: pdmclk_min 2400000 pdm_clkmax 4800000 duty_min 40
[ 7.940488] sof-audio-pci-intel-cnl 0000:00:1f.3: duty_max 60 fifo_fs 16000 num_pdms active 1
[ 7.940490] sof-audio-pci-intel-cnl 0000:00:1f.3: fifo word length 32
[ 7.940491] sof-audio-pci-intel-cnl 0000:00:1f.3: pdm 0 mic a 1 mic b 1
[ 7.940493] sof-audio-pci-intel-cnl 0000:00:1f.3: pdm 0 polarity a 0 polarity b 0
[ 7.940495] sof-audio-pci-intel-cnl 0000:00:1f.3: pdm 0 clk_edge 0 skew 0
[ 7.940496] sof-audio-pci-intel-cnl 0000:00:1f.3: set DAI config for dmic16k index 1
[ 7.940503] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 7.940875] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 7.940877] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 1!
[ 7.940878] sof-audio-pci-intel-cnl 0000:00:1f.3: HDA config rate 48000 channels 2
[ 7.940880] sof-audio-pci-intel-cnl 0000:00:1f.3: set DAI config for iDisp1 index 0
[ 7.940885] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 7.941027] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 7.941028] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 2!
[ 7.941030] sof-audio-pci-intel-cnl 0000:00:1f.3: HDA config rate 48000 channels 2
[ 7.941032] sof-audio-pci-intel-cnl 0000:00:1f.3: set DAI config for iDisp2 index 1
[ 7.941037] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 7.941180] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 7.941183] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 3!
[ 7.941185] sof-audio-pci-intel-cnl 0000:00:1f.3: HDA config rate 48000 channels 2
[ 7.941186] sof-audio-pci-intel-cnl 0000:00:1f.3: set DAI config for iDisp3 index 2
[ 7.941191] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 7.941331] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 7.941333] sof-audio-pci-intel-cnl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[ 7.941335] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.6.DMIC1.IN id 39
[ 7.941337] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 7.941603] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 7.941605] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.5.DMIC0.IN id 31
[ 7.941607] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 7.941715] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 7.941716] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.4.HDA2.OUT id 22
[ 7.941718] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 7.941800] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 7.941802] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.3.HDA1.OUT id 15
[ 7.941804] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 7.941887] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 7.941889] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.2.HDA0.OUT id 7
[ 7.941890] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 7.941976] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 7.941981] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50040000
[ 7.942293] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50040000
[ 7.942296] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50020000
[ 7.942500] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50020000
[ 7.942505] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50040000
[ 7.942805] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50040000
[ 7.942810] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50020000
[ 7.943023] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50020000
[ 7.943027] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50020000
[ 7.943247] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50020000
[ 7.943253] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50020000
[ 7.943462] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50020000
[ 7.943467] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50020000
[ 7.943676] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50020000
[ 7.943681] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50020000
[ 7.943852] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50020000
[ 7.948797] sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM DMIC
[ 7.948799] sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Highpass Capture 6 capture DMA buffer size 0x10000 max 0x10000
[ 7.948807] sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM DMIC16kHz
[ 7.948809] sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Highpass Capture 7 capture DMA buffer size 0x10000 max 0x10000
[ 7.948815] sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM HDMI1
[ 7.948816] sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Passthrough Playback 1 playback DMA buffer size 0x10000 max 0x10000
[ 7.948824] sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM HDMI2
[ 7.948825] sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Passthrough Playback 2 playback DMA buffer size 0x10000 max 0x10000
[ 7.948832] sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM HDMI3
[ 7.948833] sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Passthrough Playback 3 playback DMA buffer size 0x10000 max 0x10000
[ 7.949801] random: crng init done
[ 7.949803] random: 4 urandom warning(s) missed due to ratelimiting
[ 7.961084] input: sof-hda-dsp HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input13
[ 7.961140] input: sof-hda-dsp HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input14
[ 7.961185] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input15
[ 7.981673] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.981874] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.981982] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.982187] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.982203] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.982494] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.982512] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.982718] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.982736] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.983079] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.983490] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.984755] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.984788] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.985462] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.992589] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.992795] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.992881] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.993087] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.993101] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.993303] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.993321] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.993528] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.993544] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.993752] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.993764] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.993981] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 7.993998] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 7.994203] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 8.012064] mc: Linux media interface: v0.10
[ 8.030255] videodev: Linux video capture interface: v2.00
[ 8.069857] Bluetooth: Core ver 2.22
[ 8.069889] NET: Registered PF_BLUETOOTH protocol family
[ 8.069890] Bluetooth: HCI device and connection manager initialized
[ 8.069893] Bluetooth: HCI socket layer initialized
[ 8.069895] Bluetooth: L2CAP socket layer initialized
[ 8.069898] Bluetooth: SCO socket layer initialized
[ 8.316805] usbcore: registered new interface driver btusb
[ 8.318608] Bluetooth: hci0: Firmware revision 0.0 build 191 week 21 2021
[ 8.320070] usb 1-6: Found UVC 1.10 device HD Camera (13d3:5480)
[ 8.320886] input: HD Camera: HD Camera as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input16
[ 8.320925] usbcore: registered new interface driver uvcvideo
[ 8.340011] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.340014] Bluetooth: BNEP filters: protocol multicast
[ 8.340016] Bluetooth: BNEP socket layer initialized
[ 8.385611] Bluetooth: hci0: MSFT filter_enable is already on
[ 8.400022] NET: Registered PF_ALG protocol family
[ 9.767744] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 9.767747] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 9.767748] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 9.767749] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 9.767866] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.768018] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.768037] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 9.768047] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 9.768048] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 0000000091ddc3a9 size 0x4af4 pages 5
[ 9.768056] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.768076] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.768080] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 9.768080] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 9.768097] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 9.768100] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 9.768353] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 9.768354] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 9.768664] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 9.768667] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 9.768796] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 9.768808] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.768971] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.769005] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 9.788532] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 9.788537] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 9.788539] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 9.788541] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 9.788672] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.788880] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.788901] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 9.788910] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 9.788912] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 0000000091ddc3a9 size 0x4af4 pages 5
[ 9.788921] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 9.788942] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.788946] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 9.788947] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 9.788965] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 9.788969] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 9.789241] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 9.789244] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 9.789593] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 9.789596] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 9.789735] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 9.789748] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.791005] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.791139] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 9.802939] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 9.802943] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 9.802945] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 9.802947] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 9.803097] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.803253] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.803279] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 9.803292] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 9.803294] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 000000005afda297 size 0x4af4 pages 5
[ 9.803313] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 9.803339] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.803343] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 9.803344] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 9.803365] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 9.803368] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 9.803623] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 9.803625] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 9.803985] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 9.803988] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 9.804153] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 9.804177] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.804313] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.804363] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 9.815656] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 9.815659] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 9.815661] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 9.815662] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 9.815771] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.815905] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.815925] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 9.815934] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 9.815935] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 0000000085c0ce93 size 0x4af4 pages 5
[ 9.815944] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 9.815963] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.815967] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 9.815968] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 9.815985] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 9.815987] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 9.816230] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 9.816232] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 9.816512] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 9.816515] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 9.816655] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 9.816665] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.816794] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.816826] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 9.827720] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 9.827725] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 9.827727] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 9.827728] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 9.827871] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.828015] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.828033] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 9.828043] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 9.828045] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 00000000b1523010 size 0x4af4 pages 5
[ 9.828054] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 9.828077] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.828082] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 9.828083] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 9.828102] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 9.828106] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 9.828351] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 9.828353] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 9.828699] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 9.828702] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 9.828868] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 9.828884] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.829024] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.829063] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 9.845006] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 9.845011] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 9.845014] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 9.845015] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 9.845143] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.845478] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.845499] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 9.845509] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 9.845511] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 000000003509cae2 size 0x4af4 pages 5
[ 9.845520] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 9.845541] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 9.845545] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 9.845546] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 9.845563] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 9.845567] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 9.845834] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 9.845837] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 9.846312] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 9.846316] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 9.848311] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 9.848337] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 9.848568] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 9.848603] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 12.023241] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
[ 12.023489] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x40010000
[ 12.023553] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
[ 12.024151] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
[ 12.024173] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask 1
[ 12.024259] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000044
[ 12.024274] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000010 at 00000044
[ 12.024286] sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
[ 12.024291] sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
[ 32.006636] sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
[ 32.011194] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000044
[ 32.014297] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at 00000048
[ 32.014303] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at 00000048
[ 32.017624] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000048
[ 32.017635] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at 00000048
[ 32.019254] sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
[ 32.019266] sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
[ 32.019269] sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
[ 32.019276] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at 00000048
[ 32.019281] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at 00000048
[ 32.019286] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000044
[ 32.019290] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at 00000044
[ 32.019292] sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
[ 32.019359] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.019382] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.019386] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x0
[ 32.019388] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:1
[ 32.019445] sof-audio-pci-intel-cnl 0000:00:1f.3: Attempting iteration 0 of Core En/ROM load...
[ 32.019451] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
[ 32.019455] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
[ 32.019460] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f00 successful
[ 32.019464] sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = f
[ 32.019467] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask f
[ 32.019473] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0000 successful
[ 32.019476] sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
[ 32.019480] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
[ 32.020336] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
[ 32.020345] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
[ 32.020351] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
[ 32.020354] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
[ 32.097503] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5000001 successful
[ 32.112347] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
[ 32.112873] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 32.112880] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware download successful, booting...
[ 32.120528] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
[ 32.120533] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc: DSP is ready 0x70000000 offset 0x81000
[ 32.120540] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
[ 32.120545] sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
[ 32.120554] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at 00000048
[ 32.120559] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at 00000048
[ 32.120566] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at 00000044
[ 32.120571] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at 00000044
[ 32.120579] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.120781] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.120789] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.120915] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.120922] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.121036] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.121042] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.121189] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.121197] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.121389] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.121395] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 32.121514] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 32.121521] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.121667] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.121676] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.121811] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.121817] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.121934] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.121939] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.122053] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.122060] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.122247] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.122253] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 32.122368] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 32.122374] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.122522] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.122529] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.122667] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.122673] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.123180] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.123188] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.123309] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.123318] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.123505] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.123511] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 32.123641] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 32.123648] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.123793] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.123799] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.123935] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.123943] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.124096] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.124101] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.124215] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.124219] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.124337] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.124341] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.124461] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.124470] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.124690] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.124696] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 32.124824] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 32.124829] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.124976] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.124982] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.125116] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.125124] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.125264] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.125271] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.125388] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.125393] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.125509] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.125514] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
[ 32.125631] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30200000
[ 32.125637] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
[ 32.125865] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30010000
[ 32.125870] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
[ 32.126003] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30100000
[ 32.126008] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.126094] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.126100] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.126189] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.126194] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.126283] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.126287] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.126378] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.126382] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.126492] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.126496] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.129822] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.129830] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.129952] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.129959] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130058] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130062] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130192] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130197] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130310] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130315] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130416] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130419] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130519] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130522] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130620] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130624] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130723] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130726] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130826] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130830] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.130919] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.130922] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131011] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131014] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131100] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131103] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131191] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131194] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131286] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131289] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131380] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131383] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131474] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131476] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131568] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131570] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
[ 32.131662] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30030000
[ 32.131670] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.131802] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.131810] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.131936] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.131944] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.132071] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.132078] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.132367] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.132374] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.132713] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.132715] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.6.DMIC1.IN id 39
[ 32.132719] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 32.132989] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 32.132992] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.5.DMIC0.IN id 31
[ 32.132995] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 32.133099] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 32.133102] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.4.HDA2.OUT id 22
[ 32.133104] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 32.133215] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 32.133219] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.3.HDA1.OUT id 15
[ 32.133222] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 32.133320] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 32.133323] sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.2.HDA0.OUT id 7
[ 32.133326] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
[ 32.133416] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x30130000
[ 32.133424] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50030000
[ 32.133749] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50030000
[ 32.133756] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 32.133966] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 32.133975] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50030000
[ 32.134299] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50030000
[ 32.134305] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 32.134514] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 32.134521] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 32.134724] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 32.134731] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 32.134937] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 32.134944] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 32.135133] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 32.135139] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
[ 32.135343] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x50010000
[ 32.135349] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
[ 32.135436] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x40020000
[ 32.144205] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 32.144211] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 32.144214] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 32.144217] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 32.144410] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.144567] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.144589] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 32.144601] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 32.144603] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 00000000268d8a46 size 0x4af4 pages 5
[ 32.144619] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.144646] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.144652] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 32.144654] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 32.144676] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 32.144683] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 32.144956] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 32.144960] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 32.145400] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 32.145405] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 32.145573] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 32.145604] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.145757] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.145802] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 32.201775] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 32.201780] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 32.201782] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 32.201784] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 32.201964] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.202097] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.202117] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 32.202127] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 32.202129] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 00000000dd28f13b size 0x4af4 pages 5
[ 32.202138] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 32.202161] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.202165] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 32.202166] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 32.202186] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 32.202190] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 32.202443] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 32.202445] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 32.202900] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 32.202905] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 32.203051] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 32.203070] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.204281] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.204419] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 32.222613] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 32.222619] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 32.222622] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 32.222625] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 32.222818] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.223040] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.223064] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 32.223075] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 32.223077] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 000000003084df72 size 0x4af4 pages 5
[ 32.223086] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 32.223109] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.223114] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 32.223115] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 32.223178] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 32.223183] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 32.223444] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 32.223448] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 32.223868] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 32.223873] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 32.224024] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 32.224045] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.224063] Bluetooth: RFCOMM TTY layer initialized
[ 32.224073] Bluetooth: RFCOMM socket layer initialized
[ 32.224078] Bluetooth: RFCOMM ver 1.11
[ 32.224220] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.224269] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 32.242645] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 32.242651] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 32.242655] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 32.242657] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 32.242845] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.242999] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.243022] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 32.243034] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 32.243037] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 00000000268d8a46 size 0x4af4 pages 5
[ 32.243051] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 32.243073] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.243078] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 32.243080] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 32.243152] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 32.243158] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 32.243412] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 32.243416] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 32.243837] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 32.243842] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 32.243986] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 32.244006] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.244175] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.244232] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 32.258646] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 32.258651] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 32.258653] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 32.258655] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 32.258837] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.258985] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.259007] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 32.259017] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 32.259019] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 00000000dd28f13b size 0x4af4 pages 5
[ 32.259028] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 32.259051] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.259055] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 32.259056] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 32.259076] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 32.259080] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 32.259336] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 32.259338] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 32.259808] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 32.259813] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 32.259960] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 32.259982] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.260127] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.260249] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 32.275823] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
[ 32.275829] sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
[ 32.275832] sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
[ 32.275835] sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
[ 32.276014] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.276291] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.276314] sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=49, rate=48000, ch=2, format=10
[ 32.276324] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
[ 32.276326] sof-audio-pci-intel-cnl 0000:00:1f.3: generating page table for 000000003084df72 size 0x4af4 pages 5
[ 32.276335] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
[ 32.276358] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
[ 32.276362] sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x18fc
[ 32.276363] sof-audio-pci-intel-cnl 0000:00:1f.3: periods:3
[ 32.276383] sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
[ 32.276387] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
[ 32.276645] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60010000
[ 32.276649] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790680
[ 32.277048] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
[ 32.277053] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
[ 32.277385] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x60030000
[ 32.277411] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
[ 32.277554] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x80010000
[ 32.277616] sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
[ 32.742749] rfkill: input handler disabled
[ 34.643143] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
[ 34.643276] sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx succeeded: 0x40010000
[ 34.643312] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
[ 34.643834] sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
[ 34.643841] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask 1
[ 34.643911] sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000010 at 00000044
[ 34.643916] sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
[ 34.643918] sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
[ 40.101266] kauditd_printk_skb: 14 callbacks suppressed
With default settings (dsp_driver=0/not set) I am seeing logs like below for pulseaudio in journalctl (journalctl --user-unit pulseaudio):
pulseaudio[1236]: No _conflictingdevs for device Headphones
pulseaudio[1236]: No _supporteddevs for device Headphones
pulseaudio[1236]: Found UCM profiles
pulseaudio[1236]: UCM mapping: HiFi: hw:sofhdadsp,3: sink dev HDMI1
pulseaudio[1236]: UCM mapping: HiFi: hw:sofhdadsp: source dev Mic2
pulseaudio[1236]: UCM mapping: HiFi: hw:sofhdadsp,6: source dev Mic1
pulseaudio[1236]: UCM mapping: HiFi: hw:sofhdadsp: sink dev Speaker
pulseaudio[1236]: UCM mapping: HiFi: hw:sofhdadsp: sink dev Headphones
pulseaudio[1236]: Profile HiFi (Play HiFi quality Music), input=(null), output=(null) priority=8000, supported=yes n_input_mappings=2, n_output_mappings=2
pulseaudio[1236]: Input HiFi: hw:sofhdadsp: source
pulseaudio[1236]: Input HiFi: hw:sofhdadsp,6: source
pulseaudio[1236]: Output HiFi: hw:sofhdadsp,3: sink
pulseaudio[1236]: Output HiFi: hw:sofhdadsp: sink
pulseaudio[1236]: Set ucm verb to HiFi
pulseaudio[1236]: Trying _ucm0001.hw:sofhdadsp,3 with SND_PCM_NO_AUTO_FORMAT ...
pulseaudio[1236]: Managed to open _ucm0001.hw:sofhdadsp,3
pulseaudio[1236]: Maximum hw buffer size is 341 ms
pulseaudio[1236]: Set buffer size first (to 4797 samples), period size second (to 1199 samples).
pulseaudio[1236]: Device hw:sofhdadsp,3 doesn't support 44100 Hz, changed to 48000 Hz.
pulseaudio[1236]: Trying _ucm0001.hw:sofhdadsp with SND_PCM_NO_AUTO_FORMAT ...
pulseaudio[1236]: Error opening PCM device _ucm0001.hw:sofhdadsp: No such file or directory
pulseaudio[1236]: Profile set 0x55708d6352b0, auto_profiles=no, probed=yes, n_mappings=0, n_profiles=0, n_decibel_fixes=0
pulseaudio[1236]: Failed to find a working profile.
pulseaudio[1236]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-plat
form-skl_hda_dsp_generic" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization
failed.
pulseaudio[1236]: Card /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0 (alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic) failed to load module.
pulseaudio[1236]: Found 1 cards.
pulseaudio[1236]: Loaded "module-udev-detect" (index: #5; argument: "").
pulseaudio[1236]: Checking for existence of '/usr/lib/pulse-15.0/modules/module-jackdbus-detect.so': success
pulseaudio[1236]: Successfully connected to D-Bus session bus d7a7373092ca90c64b1bd2cc614f8463 as :1.32
pulseaudio[1236]: jackdbus isn't running.
pulseaudio[1236]: Loaded "module-jackdbus-detect" (index: #7; argument: "channels=2").
pulseaudio[1236]: Checking for existence of '/usr/lib/pulse-15.0/modules/module-bluetooth-policy.so': success
pulseaudio[1236]: Loaded "module-bluetooth-policy" (index: #8; argument: "").
pulseaudio[1236]: Checking for existence of '/usr/lib/pulse-15.0/modules/module-bluetooth-discover.so': success
pulseaudio[1236]: Checking for existence of '/usr/lib/pulse-15.0/modules/module-bluez5-discover.so': success
pulseaudio[1236]: Successfully connected to D-Bus system bus 30d9470745247d35f63402f3614f845a as :1.69
pulseaudio[1236]: Loaded "module-bluez5-discover" (index: #10; argument: "").
pulseaudio[1236]: Loaded "module-bluetooth-discover" (index: #9; argument: "").
pulseaudio[1236]: Interface org.PulseAudio.Core1.Memstats added for object /org/pulseaudio/core1/memstats
Especially this part seems to be the problem to me:
failed.
Maybe the problem is similiar to this post? https:// forum. manjaro. org/t/no-sound-dummy-output/82608/5
Any ideas what can be done?
The logs for inxi --admin --verbosity=7 --filter --no-host --width, pa-info and lspci -nnk is in next post due to post length limit.
