No sound on my Realme Wireless 3 Bluetooth Earphones
I have been trying to connect my Bluetooth earphones but there is no sound.
i have tried changing profile. only HSP/HFP works but with very bad quality.
Hi @SenpaiShane ,
Welcome to the forum!!
I wonder whether you could post the output of the following terminal command, in order help you:
inxi -v7azy
Regards,
here
Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=d6f5ce5e-0043-47bb-a8f0-fd6d82114888 rw quiet splash
    resume=UUID=2426c5c3-9c1f-4023-8929-dbbf6eb0c08d udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
  Mobo: HP model: 8934 v: 80.73 serial: <superuser required>
    part-nu: 4N0W7PA#ACJ uuid: <superuser required> UEFI: AMI v: F.19
    date: 10/17/2023
  ID-1: BAT0 charge: 59.0 Wh (100.0%) condition: 59.0/59.0 Wh (100.0%)
    power: 36.6 W volts: 15.9 min: 15.4 model: HP Primary type: Li-ion
    serial: <filter> status: discharging cycles: 45
  System RAM: total: 8 GiB available: 7.1 GiB used: 3.28 GiB (46.2%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 8ATF1G64HZ-3G2R1 serial: <filter>
  Device-2: Bottom - Slot 2 (right) type: no module installed
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000F
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 653 high: 1429 min/max: 400/4280 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
    4: 1397 5: 400 6: 1429 7: 400 8: 400 9: 400 10: 400 11: 400 12: 1414
    bogomips: 79086
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
    process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:7340
    class-ID: 0380
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1
    bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 40.0 C
  Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:5425
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu,amdgpu display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    device: 1 drv: radeonsi device: 2 drv: swrast surfaceless: drv: radeonsi
    wayland: drv: radeonsi x11: drv: radeonsi inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 17.0.6 DRM 3.57 6.9.2-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :1.0
  Device-1: AMD Navi 10 HDMI Audio vendor: Hewlett-Packard
    bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8852
    class-ID: 0280
  IP v4: <filter> type: dynamic scope: global broadcast: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 0bda:2852
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 29.04 GiB (6.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL2512HCJQ-00BH1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS3NGXH temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 150.04 GiB size: 146.62 GiB (97.72%) used: 11.47 GiB (7.8%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: d6f5ce5e-0043-47bb-a8f0-fd6d82114888
    used: 58.7 MiB (61.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 962F-DDC1
  ID-3: /home/<filter>/My Drive raw-size: 109.85 GiB
    size: 109.85 GiB (100.00%) used: 17.51 GiB (15.9%) fs: ntfs
    dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A uuid: 01DAB1A3EBE8D060
  ID-1: swap-1 type: partition size: 16 GiB used: 32 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 2426c5c3-9c1f-4023-8929-dbbf6eb0c08d
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 200.19 GiB fs: ntfs label: N/A
    uuid: 01DAB1A400AD20F0
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 768 MiB fs: ntfs label: N/A
    uuid: A4225FDA225FB052
  Device-1: 1-2:2 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
  Device-2: 1-3:3 info: Quanta HP Wide Vision HD Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
  Device-3: 1-4:4 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
    interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  GPU: device: amdgpu temp: 40.0 C mem: 0.0 C fan: 65535 watts: 4.00
    device: amdgpu temp: 41.0 C
  Processes: 323 Power: uptime: 3h 21m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 2.82 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1217 libs: 352 tools: octopi,pamac,yay
    pm: flatpak pkgs: 0 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9
    running-in: kitty inxi: 3.3.34
Hi @SenpaiShane ,
I wonder whether you could read the following posts in order to solve the problem:
Switched to pipewire, no A2DP profile for headphones
[HowTo] Enhance your Linux audio with EasyEffects or PulseEffects Legacy
Hope it help, regards.
tried both but no sound…a2dp profiles are available but none of them works. only hsp ones are working but sound quality is bad
Hi @SenpaiShane,
I understand that the problem is not easy to solve. Please, consider to read the following post and check whether you have installed all the packages for pipewire.
Bluetooth headset - ArchWiki
Also based on the bluetooth client you have installed on KDE Plasma this post may be interesting, in order to solve the problem.
Bluetooth - ArchWiki
Regards,
i tried what ever i could but still not resolved. Through the process i did get a workaround. my headset supports dual pairing. when ever i play anything on my phone and then connect it with my laptop it works with a2dp profile till i switch the connection.
Hi @SenpaiShane ,
Can you post the output of the following terminal commands?
pactl list
and
journalctl -f
Regards,
➜  ~ pactl list
Module #1
	Argument: {
            nice.level    = -11
            rt.prio       = 88
            #rt.time.soft = -1
            #rt.time.hard = -1
            #uclamp.min = 0
            #uclamp.max = 1024
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-rt"
		object.id = "1"
		object.serial = "1"
		module.author = "Wim Taymans <wim.taymans@gmail.com>"
		module.description = "Use realtime thread scheduling, falling back to RTKit"
		module.usage = "( nice.level=<priority: default 20(don't change)> ) ( rt.prio=<priority: default 83> ) ( rt.time.soft=<in usec: default -1> ) ( rt.time.hard=<in usec: default -1> ) ( rlimits.enabled=<default true> ) ( rtportal.enabled=<default true> ) ( rtkit.enabled=<default true> ) ( uclamp.min=<default 0> ) ( uclamp.max=<default 1024> )"
		module.version = "1.0.7"
		nice.level = "-11"
		rt.prio = "88"
Module #2
	Argument: {
            # List of server Unix sockets, and optionally permissions
            #sockets = [ { name = "pipewire-0" }, { name = "pipewire-0-manager" } ]
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-protocol-native"
		object.id = "2"
		object.serial = "2"
		module.description = "Native protocol using unix sockets"
Module #3
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-profiler"
		object.id = "3"
		object.serial = "3"
		module.description = "Generate Profiling data"
Module #5
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-metadata"
		object.id = "5"
		object.serial = "5"
		module.description = "Allow clients to create metadata store"
Module #7
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-spa-device-factory"
		object.id = "7"
		object.serial = "7"
		module.description = "Provide a factory to make SPA devices"
Module #9
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-spa-node-factory"
		object.id = "9"
		object.serial = "9"
		module.description = "Provide a factory to make SPA nodes"
Module #11
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-client-node"
		object.id = "11"
		object.serial = "11"
		module.description = "Allow clients to create and control remote nodes"
Module #13
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-client-device"
		object.id = "13"
		object.serial = "13"
		module.description = "Allow clients to create and control remote devices"
Module #15
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-portal"
		object.id = "15"
		object.serial = "15"
Module #16
	Argument: {
            # Socket-specific access permissions
            #access.socket = { pipewire-0 = "default", pipewire-0-manager = "unrestricted" }
            # Deprecated legacy mode (not socket-based),
            # for now enabled by default if access.socket is not specified
            #access.legacy = true
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-access"
		object.id = "16"
		object.serial = "16"
		module.description = "Perform access check"
		module.usage = "( access.socket={ <socket>=<access>, ... } ) ( access.legacy=true ) "
Module #17
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-adapter"
		object.id = "17"
		object.serial = "17"
		module.description = "Manage adapter nodes"
Module #19
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-link-factory"
		object.id = "19"
		object.serial = "19"
		module.description = "Allow clients to create links"
		module.usage = "( allow.link.passive=<bool, default false> ) "
Module #21
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-session-manager"
		object.id = "21"
		object.serial = "21"
		module.author = "George Kiagiadakis <george.kiagiadakis@collabora.com>"
		module.description = "Implements objects for session management"
Module #28
	Argument: {
            #sink.name = "@DEFAULT_SINK@"
            #sample.name = "bell-window-system"
            #x11.display = null
            #x11.xauthority = null
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-x11-bell"
		object.id = "28"
		object.serial = "28"
		module.description = "X11 Bell interceptor"
		module.usage = "( sink.name=<name for the sink> ) ( sample.name=<the sample name> ) ( x11.display=<the X11 display> ) .x11.xauthority=<the X11 XAuthority> )"
Module #536870912
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Pauli Virtanen <pav@iki.fi>"
		module.description = "Always keeps at least one sink loaded even if it's a null one"
		module.usage = "sink_name=<name of sink>"
Sink #50
	State: SUSPENDED
	Description: Family 17h/19h HD Audio Controller Speaker + Headphones
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 36854 /  56% / -15.00 dB,   front-right: 36854 /  56% / -15.00 dB
	       balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_08_00.6.HiFi__hw_Generic_1__sink.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "2"
		alsa.card_name = "HD-Audio Generic"
		alsa.class = "generic"
		alsa.components = "HDA:10ec0245,103c8934,00100001"
		alsa.device = "0"
		alsa.id = "Generic_1"
		alsa.long_card_name = "HD-Audio Generic at 0xfc9c0000 irq 83"
		alsa.mixer_device = "_ucm0004.hw:Generic_1"
		alsa.mixer_name = "Realtek ALC245"
		alsa.name = "ALC245 Analog"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		api.alsa.card.longname = "HD-Audio Generic at 0xfc9c0000 irq 83"
		api.alsa.card.name = "HD-Audio Generic"
		api.alsa.open.ucm = "true"
		api.alsa.path = "hw:Generic_1"
		api.alsa.pcm.card = "2"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "0"
		device.api = "alsa"
		device.class = "sound"
		device.id = "44"
		device.profile.description = "Speaker + Headphones"
		device.profile.name = "HiFi: hw:Generic_1: sink"
		device.routes = "2"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		device.description = "Family 17h/19h HD Audio Controller"
		node.name = "alsa_output.pci-0000_08_00.6.HiFi__hw_Generic_1__sink"
		node.nick = "ALC245 Analog"
		node.pause-on-idle = "false"
		object.path = "alsa:pcm:2:hw:Generic_1:playback"
		priority.driver = "1000"
		priority.session = "1000"
		factory.id = "18"
		clock.quantum-limit = "8192"
		client.id = "41"
		node.driver = "true"
		factory.mode = "merge"
		audio.adapt.follower = ""
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "50"
		object.serial = "50"
		api.acp.auto-port = "false"
		api.alsa.card = "2"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1 = "Audio2"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.bus = "pci"
		device.bus_path = "pci-0000:08:00.6"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_08_00.6"
		device.nick = "HD-Audio Generic"
		device.plugged.usec = "7633894"
		device.product.id = "0x15e3"
		device.product.name = "Family 17h/19h HD Audio Controller"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2"
		device.vendor.id = "0x1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		device.string = "2"
	Ports:
		[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
		[Out] Headphones: Headphones (type: Headphones, priority: 200, availability group: Headphone, not available)
	Active Port: [Out] Speaker
	Formats:
		pcm
Sink #160
	State: SUSPENDED
	Description: realme Buds Wireless 3
	Driver: PipeWire
	Sample Specification: s16le 2ch 48000Hz
	Mute: no
	Volume: front-left: 32113 /  49% / -18.59 dB,   front-right: 32113 /  49% / -18.59 dB
	       balance 0.00
	Monitor Source: bluez_output.98_47_44_23_C2_67.1.monitor
	Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		api.bluez5.address = "98:47:44:23:C2:67"
		api.bluez5.codec = "aac"
		api.bluez5.profile = "a2dp-sink"
		api.bluez5.transport = ""
		bluez5.loopback = "false"
		card.profile.device = "1"
		device.id = "82"
		device.routes = "1"
		factory.name = "api.bluez5.a2dp.sink"
		device.description = "realme Buds Wireless 3"
		node.name = "bluez_output.98_47_44_23_C2_67.1"
		priority.driver = "1010"
		priority.session = "1010"
		factory.id = "11"
		device.api = "bluez5"
		media.name = "realme Buds Wireless 3"
		object.id = "90"
		object.serial = "160"
		client.id = "41"
		api.bluez5.class = "0x240404"
		api.bluez5.connection = "disconnected"
		api.bluez5.device = ""
		api.bluez5.icon = "audio-headset"
		api.bluez5.id = "6"
		api.bluez5.path = "/org/bluez/hci0/dev_98_47_44_23_C2_67"
		bluez5.profile = "off"
		device.alias = "realme Buds Wireless 3"
		device.bus = "bluetooth"
		device.form_factor = "headset"
		device.icon_name = "audio-headset-bluetooth"
		device.name = "bluez_card.98_47_44_23_C2_67"
		device.string = "98:47:44:23:C2:67"
	Ports:
		headset-output: Headset (type: Headset, priority: 0, available)
	Active Port: headset-output
	Formats:
		pcm
Source #50
	State: SUSPENDED
	Description: Monitor of Family 17h/19h HD Audio Controller Speaker + Headphones
	Driver: PipeWire
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	       balance 0.00
	Monitor of Sink: alsa_output.pci-0000_08_00.6.HiFi__hw_Generic_1__sink
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "2"
		alsa.device = "0"
		device.api = "alsa"
		device.class = "monitor"
		device.id = "44"
		device.routes = "2"
		factory.id = "18"
		client.id = "41"
		object.id = "50"
		api.alsa.card = "2"
		device.bus = "pci"
		device.string = "2"
	Ports:
	Formats:
		pcm
Source #51
	State: SUSPENDED
	Description: Family 17h/19h HD Audio Controller Headphones Stereo Microphone
	Driver: PipeWire
	Mute: no
	       balance 0.00
	Monitor of Sink: n/a
	Properties:
		alsa.card = "2"
		alsa.device = "0"
		api.alsa.pcm.stream = "capture"
		device.api = "alsa"
		device.id = "44"
		device.profile.description = "Headphones Stereo Microphone"
		device.profile.name = "HiFi: hw:Generic_1: source"
		device.routes = "1"
		factory.name = "api.alsa.pcm.source"
		media.class = "Audio/Source"
		node.name = "alsa_input.pci-0000_08_00.6.HiFi__hw_Generic_1__source"
		object.path = "alsa:pcm:2:hw:Generic_1:capture"
		priority.driver = "2000"
		priority.session = "2000"
		factory.id = "18"
		client.id = "41"
		factory.mode = "split"
		object.id = "51"
		object.serial = "51"
		api.alsa.card = "2"
		device.bus = "pci"
		device.string = "2"
	Ports:
		[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, availability group: Mic, not available)
	Active Port: [In] Mic2
	Formats:
		pcm
Source #52
	State: SUSPENDED
	Description: Family 17h/19h HD Audio Controller Digital Microphone
	Driver: PipeWire
	Mute: no
	       balance 0.00
	Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "3"
		alsa.card_name = "acp"
		alsa.device = "0"
		alsa.driver_name = "snd_acp3x_rn"
		alsa.id = "acp"
		alsa.long_card_name = "HP-VictusbyHPLaptop16_e0xxx--8934"
		alsa.name = ""
		alsa.resolution_bits = "32"
		api.alsa.path = "hw:acp"
		card.profile.device = "2"
		device.api = "alsa"
		device.id = "44"
		device.profile.description = "Digital Microphone"
		device.profile.name = "HiFi: hw:acp: source"
		device.routes = "1"
		node.name = "alsa_input.pci-0000_08_00.6.HiFi__hw_acp__source"
		node.nick = "Digital Microphone"
		object.path = "alsa:pcm:2:hw:acp:capture"
		factory.id = "18"
		client.id = "41"
		object.id = "52"
		object.serial = "52"
		api.alsa.card = "2"
		device.bus = "pci"
		device.string = "2"
	Ports:
		[In] Mic1: Digital Microphone (type: Mic, priority: 100, availability unknown)
	Active Port: [In] Mic1
	Formats:
		pcm
Source #158
	State: SUSPENDED
	Driver: PipeWire
	Sample Specification: float32le 1ch 48000Hz
	Channel Map: mono
	Mute: no
	Volume: mono: 65536 / 100% / 0.00 dB
	       balance 0.00
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		audio.position = "[MONO]"
		filter.smart = "true"
		filter.smart.target = "{\"bluez5.loopback-target\":true, \"device.id\":82, \"bluez5.loopback\":false}"
		priority.driver = "2010"
		priority.session = "2010"
		device.id = "82"
		bluez5.loopback = "true"
		node.name = "bluez_input.98:47:44:23:C2:67"
		node.group = "loopback-901-18"
		node.link-group = "loopback-901-18"
		node.virtual = "true"
		resample.prefill = "true"
		resample.disable = "true"
		media.name = "realme Buds Wireless 3 output"
		stream.is-live = "true"
		node.want-driver = "true"
		node.autoconnect = "true"
		node.trigger = "true"
		adapt.follower.spa-node = ""
		object.register = "false"
		factory.id = "11"
		client.id = "91"
		object.id = "93"
		object.serial = "158"
		api.bluez5.id = "6"
	Formats:
		pcm
Source #160
	State: SUSPENDED
	Description: Monitor of realme Buds Wireless 3
	Driver: PipeWire
	Mute: no
	       balance 0.00
	Monitor of Sink: bluez_output.98_47_44_23_C2_67.1
	Properties:
		device.id = "82"
		device.routes = "1"
		factory.id = "11"
		object.id = "90"
		client.id = "41"
		api.bluez5.id = "6"
	Ports:
	Formats:
		pcm
Client #32
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.protocol = "protocol-native"
		pipewire.sec.socket = "pipewire-0"
		pipewire.sec.pid = "835"
		pipewire.sec.uid = "1000"
		pipewire.sec.gid = "1000"
		module.id = "2"
		object.id = "32"
		object.serial = "32"
		application.name = "kwin_wayland"
		application.process.binary = "kwin_wayland"
		application.language = "en_IN"
		application.process.id = "835"
		application.process.user = "anurag"
		application.process.host = "anurag-victus"
		application.process.session_id = "2"
		log.level = "0"
		cpu.max-align = "32"
		default.clock.rate = "48000"
		default.clock.quantum = "1024"
		default.clock.min-quantum = "32"
		default.clock.max-quantum = "2048"
		default.clock.quantum-limit = "8192"
		default.clock.quantum-floor = "4"
		default.video.width = "640"
		default.video.height = "480"
		default.video.rate.num = "25"
		default.video.rate.denom = "1"
		clock.power-of-two-quantum = "true"
		link.max-buffers = "64"
		mem.warn-mlock = "false"
		mem.allow-mlock = "true"
		settings.check-quantum = "false"
		settings.check-rate = "false"
		core.version = "1.0.7"
		core.name = "pipewire-anurag-835"
		pipewire.access = "unrestricted"
Client #33
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.sec.socket = "pipewire-0-manager"
		pipewire.sec.pid = "901"
		module.id = "2"
		object.id = "33"
		object.serial = "33"
		application.name = "WirePlumber"
		application.version = "0.5.2"
		wireplumber.daemon = "true"
		wireplumber.profile = "main"
		remote.name = "[pipewire-0-manager,pipewire-0]"
		config.name = "null"
		context.modules.allow-empty = "true"
		application.process.binary = "wireplumber"
		application.process.id = "901"
		window.x11.display = ":1"
		log.level = "2"
		core.name = "pipewire-anurag-901"
Client #41
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "41"
		object.serial = "41"
		application.name = "WirePlumber [export]"
		wireplumber.export-core = "true"
		log.level = "2"
Client #71
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.sec.pid = "843"
		module.id = "2"
		object.id = "69"
		object.serial = "71"
		pipewire.access.portal.is_portal = "true"
		portal.monitor = "Camera"
		application.name = "xdg-desktop-portal"
		application.process.binary = "xdg-desktop-portal"
		application.process.id = "843"
		log.level = "0"
		core.name = "pipewire-anurag-843"
Client #72
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.sec.pid = "1063"
		module.id = "2"
		object.id = "70"
		object.serial = "72"
		application.name = "plasmashell"
		application.process.binary = "plasmashell"
		application.process.id = "1063"
		log.level = "0"
		core.name = "pipewire-anurag-1063"
Client #73
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.sec.pid = "1437"
		module.id = "2"
		object.id = "71"
		object.serial = "73"
		config.name = "pipewire-pulse.conf"
		application.name = "pipewire"
		application.process.binary = "pipewire"
		application.process.id = "1437"
		log.level = "2"
		core.name = "pipewire-anurag-1437"
Client #74
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "72"
		object.serial = "74"
		client.api = "pipewire-pulse"
		pulse.server.type = "unix"
		application.name = "libcanberra"
		application.version = "0.30"
		application.id = "org.freedesktop.libcanberra"
		application.process.machine_id = "f12fd9a803634f68a37c72e731df4710"
		log.level = "2"
Client #75
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "73"
		object.serial = "75"
		application.name = "Plasma PA"
		application.id = "org.kde.plasma-pa"
		application.icon_name = "audio-card"
		log.level = "2"
Client #104
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "78"
		object.serial = "104"
		application.name = "Firefox"
		application.process.id = "1604"
		application.process.binary = "firefox"
		log.level = "2"
Client #157
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "91"
		object.serial = "157"
		log.level = "2"
Client #224
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "80"
		object.serial = "224"
		application.version = "126.0.1"
		application.icon_name = "firefox"
		log.level = "2"
Client #250
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "106"
		object.serial = "250"
		application.process.id = "5053"
		application.process.user = ""
		application.process.binary = "pactl"
		application.name = "pactl"
		log.level = "2"
Sample #0
	       balance 0.00
	Duration: 0.3s
	Lazy: no
	Filename: n/a
	Properties:
		event.id = "audio-volume-change"
		event.description = "Volume Control Feedback Sound"
		media.role = "event"
		media.name = "audio-volume-change"
		media.filename = "/usr/share/sounds/ocean/stereo/audio-volume-change.oga"
Card #42
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "0"
		api.alsa.card.longname = "HDA ATI HDMI at 0xfcaa0000 irq 81"
		api.alsa.card.name = "HDA ATI HDMI"
		api.alsa.path = "hw:0"
		device.api = "alsa"
		device.bus = "pci"
		device.bus_path = "pci-0000:03:00.1"
		device.description = "Navi 10 HDMI Audio"
		device.name = "alsa_card.pci-0000_03_00.1"
		device.nick = "HDA ATI HDMI"
		device.plugged.usec = "7466665"
		device.product.id = "0xab38"
		device.product.name = "Navi 10 HDMI Audio"
		sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card0"
		device.vendor.id = "0x1002"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
		media.class = "Audio/Device"
		factory.id = "14"
		client.id = "41"
		object.id = "42"
		object.serial = "42"
		object.path = "alsa:pcm:0"
		alsa.card = "0"
		alsa.card_name = "HDA ATI HDMI"
		alsa.long_card_name = "HDA ATI HDMI at 0xfcaa0000 irq 81"
		alsa.mixer_name = "ATI R6xx HDMI"
		alsa.components = "HDA:1002aa01,00aa0100,00100700"
		alsa.id = "HDMI"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		HiFi: Play HiFi quality Music (sinks: 1, sources: 0, priority: 8000, available: no)
		pro-audio: Pro Audio (sinks: 1, sources: 0, priority: 1, available: yes)
	Active Profile: off
	Ports:
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 1100, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=3"
				card.profile.port = "0"
			Part of profile(s): HiFi
Card #43
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "1"
		api.alsa.card.longname = "HD-Audio Generic at 0xfc9c8000 irq 82"
		api.alsa.path = "hw:1"
		api.dbus.ReserveDevice1 = "Audio1"
		device.api = "alsa"
		device.bus = "pci"
		device.bus_path = "pci-0000:08:00.1"
		device.description = "Renoir Radeon High Definition Audio Controller"
		device.name = "alsa_card.pci-0000_08_00.1"
		device.plugged.usec = "7466928"
		device.product.id = "0x1637"
		device.product.name = "Renoir Radeon High Definition Audio Controller"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card1"
		factory.id = "14"
		client.id = "41"
		object.id = "43"
		object.serial = "43"
		object.path = "alsa:pcm:1"
		alsa.card = "1"
		alsa.long_card_name = "HD-Audio Generic at 0xfc9c8000 irq 82"
		alsa.id = "Generic"
		device.string = "1"
	Profiles:
	Active Profile: off
	Ports:
			Properties:
				port.type = "hdmi"
Card #44
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "2"
		api.alsa.path = "hw:2"
		device.api = "alsa"
		device.bus = "pci"
		factory.id = "14"
		client.id = "41"
		object.id = "44"
		object.serial = "44"
		object.path = "alsa:pcm:2"
		alsa.card = "2"
		device.string = "2"
	Profiles:
		HiFi: Play HiFi quality Music (sinks: 1, sources: 2, priority: 8000, available: yes)
		pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
	Active Profile: HiFi
	Ports:
		[Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "speaker"
		[Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone, not available)
			Properties:
				port.type = "headphones"
				port.availability-group = "Headphone"
				card.profile.port = "1"
		[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Mic, not available)
			Properties:
				port.type = "mic"
				port.availability-group = "Mic"
				card.profile.port = "2"
		[In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "mic"
				card.profile.port = "3"
Card #156
	Driver: module-bluez5-device.c
	Owner Module: n/a
	Properties:
		api.bluez5.id = "6"
		factory.id = "14"
		client.id = "41"
		object.id = "82"
		object.serial = "156"
	Profiles:
		headset-head-unit: Headset Head Unit (HSP/HFP) (sinks: 1, sources: 1, priority: 1, available: yes)
		a2dp-sink-sbc: High Fidelity Playback (A2DP Sink, codec SBC) (sinks: 1, sources: 0, priority: 18, available: yes)
		a2dp-sink-sbc_xq: High Fidelity Playback (A2DP Sink, codec SBC-XQ) (sinks: 1, sources: 0, priority: 17, available: yes)
		a2dp-sink: High Fidelity Playback (A2DP Sink, codec AAC) (sinks: 1, sources: 0, priority: 19, available: yes)
		headset-head-unit-cvsd: Headset Head Unit (HSP/HFP, codec CVSD) (sinks: 1, sources: 1, priority: 2, available: yes)
		headset-head-unit-msbc: Headset Head Unit (HSP/HFP, codec mSBC) (sinks: 1, sources: 1, priority: 3, available: yes)
	Active Profile: a2dp-sink
	Ports:
		headset-output: Headset (type: Headset, priority: 0, latency offset: 0 usec, available)
			Properties:
				port.type = "headset"
			Part of profile(s): a2dp-sink-sbc, a2dp-sink-sbc_xq, a2dp-sink
		headset-hf-input: Handsfree (type: Headset, priority: 0, latency offset: 0 usec, available)
			Properties:
			Part of profile(s): headset-head-unit, headset-head-unit-cvsd, headset-head-unit-msbc
		headset-hf-output: Handsfree (type: Headset, priority: 0, latency offset: 0 usec, available)
			Properties:
➜  ~ journalctl -f
Jun 10 23:45:39 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:45:42 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:45:45 anurag-victus systemd[1]: flatpak-system-helper.service: Deactivated successfully.
Jun 10 23:45:47 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:45:49 anurag-victus plasmashell[1063]: kf.windowsystem.wayland: Failed to recreate shadow for PlasmaQuick::AppletPopup(0x5cd3d56df8d0, name="popupWindow")
Jun 10 23:45:49 anurag-victus plasmashell[1063]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Jun 10 23:45:49 anurag-victus plasmashell[1063]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:775:17: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Jun 10 23:45:54 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:05 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:08 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:09 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:10 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:13 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:14 anurag-victus plasmashell[1063]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:775:17: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Jun 10 23:46:19 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:22 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:29 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:31 anurag-victus bluealsa[629]: Device not available: /org/bluez/hci0/dev_98_47_44_23_C2_67/fd3
Jun 10 23:46:32 anurag-victus plasmashell[1063]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:775:17: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Hi @SenpaiShane ,
Do you have installed bluez-utils?. Please, post the output of the following terminal command:
sudo pacman -Ss bluez-utils
Maybe, you can try to execute the following terminal commands, in order to solve the problem.
sudo systemctl stop bluetooth
sudo rm -rf /var/lib/bluetooth
sudo systemctl start bluetooth
Your a2dp profile is sinked, you will not see it. I wonder whether you could read this post in order to solve the problem. Read section 1.1.1. Using WirePlumber.
Hope it help, reards
I suggest you uninstall bluez-alsa-git and restart system
because AUR package is not compatible with pipewire-pulse for Bluetooth audio
BlueALSA is designed specifically for use on small, low-powered, dedicated audio or audio/visual systems where the high-level audio management features of PulseAudio or PipeWire are not required
bluez-alsa - Troubleshooting - Using BlueALSA alongside PulseAudio or PipeWire
It is not advisable to run BlueALSA if either PulseAudio or PipeWire are also running with their own Bluetooth modules enabled. If one would like to have a deterministic setup, it is first necessary to disable Bluetooth in those applications.
Well… after trying the steps mentioned by @j8a i was stuck with 3 hsp profiles. Now i have uninstalled bluezalsa-git and i can see a2dp profiles but none of them work.
Hi @SenpaiShane ,
I am sorry to red this, maybe you can consider the suggestions made by @nikgnomic which are better than mines.
Regards
The issue is present in Windows 11 and openSUSE TW. To get A2DP playback on PC, I have to connect the device with an Android with Dual device pairing and play any audio from the phone while the PC is also connected. Now pause the playback in Android and try playing anything from the PC, You will get high quality audio playback from PC to headset till you pause the playback for like 2 minutes. Repeat the process from start to get A2DP again in PC.
@afsalmc
While we appreciate your enthusiasm, however, this topic seems to have been abandoned by the OP for a very long time.
The topic will now be closed.
Topic re-opened at the request of the OP.
While we are happy to re-open the thread for you, Support topics are generally not expected to remain open for the major part of a year after your last post.
Keep in mind that if there is no significant activity within a reasonable time the topic may likely be closed again.
PipeWire Wiki - Troubleshooting - Missing Bluetooth Profiles / Volume Control / etc.
If a Bluetooth device is missing some profiles, hardware volume doesn’t work properly, or there are other problems, the problem may also be in the Linux Bluetooth stack below pipewire (BlueZ, kernel drivers, firmware, hardware), or on the headset device side. So consider, in order:
  1. Unpair device, pair device again.
  2. Clear BlueZ cache: Delete all files and directories under /var/lib/bluetooth/ and systemctl restart bluetooth. This forgets all devices and you need to pair devices again.
  3. Check BlueZ version. Consider upgrading if possible with your distro. You can see what is the latest version here [Manjaro branch compare - bluez].
[quote="afsalmc, post:14, topic:163328, full:true"]
The issue is present in Windows 11 and openSUSE TW. To get A2DP playback on PC, I have to connect the device with an Android phone using dual device pairing and play any audio from the phone while the PC is also connected. Then, pause the playback on Android and try playing anything from the PC. You’ll get high-quality audio playback from the PC to the headset until you pause playback for around 2 minutes. After that, you’ll need to repeat the process to get A2DP working again on the PC.
[/quote]
This workaround is currently the only way I’ve managed to make it work.
In the meantime, I’ve tested various distros, and so far the only one where my earphones consistently work is Fedora Workstation.
@nikgnomic – I tried all the suggested steps, but the only reliable method for this headset has been using dual pairing and starting audio playback on the other device first.
Update: I did a full system upgrade after quite some time, and now all profiles are working without any issues. It looks like something got fixed with the recent updates.
Update 2: New update breaks functionality again. Headset gets disconnected after 5 second after connecting
