Switched to pipewire, no A2DP profile for headphones
Hi
Another sound related thread but I have one more issue. After switching to Pipewire, following these steps, I’ve got everything working but there are only HSP codecs available for my headphone. So the sound quality is very poor.
Any ideas on how to get it to work? As far as my Google and search skills can tell me this should just work out of the box.
As you can see my headphones only have these two options:
I’m using a B&O h9i bluetooth headphone which supports AAC.
Thanks a lot.
For problems impacting specific packages (like pipewire in this case), it might be faster to get help if you file an issue with the the package itself. For pipewire it’s here: Issues · PipeWire / pipewire · GitLab
Also please share more details- For exampele:
inxi -A
Ok will do.
Also, inxi -A output:
Audio:     Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
           Sound Server-1: ALSA v: k5.10.43-1-MANJARO running: yes
           Sound Server-2: PipeWire v: 0.3.30 running: yes
I see someone else has reported the same issue:
Do you see A2DP profiles in bluetooth-manager?
Can you post the output of:
pactl list
No. I only have HSP/HFP or HSP/HFP CVSD but no A2DP or any other high quality codecs. I’ve posted a screenshot in my first post (I’m on Gnome though, I think your screenshot is of KDE?)
pact list output:
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 35
Is Local: yes
Client Index: 66
Tile Size: 65472
User Name: denis
Host Name: denis-manjaro
Server Name: PulseAudio (on PipeWire 0.3.30)
Server Version: 14.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: bluez_output.00_09_A7_2A_8F_05.headset-head-unit
Default Source: alsa_input.pci-0000_00_1f.3.analog-stereo
Cookie: 7c41:9594
The thread I mentioned above seems to be the exact same problem. So I’m keeping an eye on that as well.
There seems to be a lot going on when I connect my headphones as well.
This is the journalctl -f output:
jul 05 17:23:20 denis-manjaro bluetoothd[882]: profiles/audio/avdtp.c:avdtp_parse_rej() SET_CONFIGURATION request rejected: Configuration not supported (41)
jul 05 17:23:21 denis-manjaro gnome-control-c[18769]: No permissions store proxy yet, come back later
jul 05 17:23:22 denis-manjaro systemd[1822]: app-gnome-gnome\x2dcontrol\x2dcenter-18769.scope: Deactivated successfully.
jul 05 17:23:22 denis-manjaro systemd[1822]: app-gnome-gnome\x2dcontrol\x2dcenter-18769.scope: Consumed 1.192s CPU time.
jul 05 17:23:22 denis-manjaro kernel: input: Beoplay H9i (AVRCP) as /devices/virtual/input/input41
jul 05 17:23:22 denis-manjaro systemd-logind[679]: Watching system buttons on /dev/input/event22 (Beoplay H9i (AVRCP))
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) config/udev: Adding input device Beoplay H9i (AVRCP) (/dev/input/event22)
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Beoplay H9i (AVRCP): Applying InputClass "evdev keyboard catchall"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Beoplay H9i (AVRCP): Applying InputClass "libinput keyboard catchall"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Beoplay H9i (AVRCP): Applying InputClass "system-keyboard"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) Using input driver 'libinput' for 'Beoplay H9i (AVRCP)'
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 95 paused 0
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Beoplay H9i (AVRCP): always reports core events
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Option "Device" "/dev/input/event22"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Option "_source" "server/udev"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) event22 - Beoplay H9i (AVRCP): is tagged by udev as: Keyboard
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) event22 - Beoplay H9i (AVRCP): device is a keyboard
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) event22 - Beoplay H9i (AVRCP): device removed
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input41/event22"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) XINPUT: Adding extended input device "Beoplay H9i (AVRCP)" (type: KEYBOARD, id 20)
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Option "xkb_layout" "us"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Option "xkb_variant" "euro"
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: The XKEYBOARD keymap compiler (xkbcomp) reports:
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86BrightnessAuto
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86DisplayOff
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Info
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86AspectRatio
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86DVD
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Audio
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86ChannelUp
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86ChannelDown
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Break
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86VideoPhone
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86ZoomReset
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Editor
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86GraphicsEditor
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Presentation
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Database
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Voicemail
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Addressbook
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86DisplayToggle
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86SpellCheck
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86ContextMenu
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MediaRepeat
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF8610ChannelsUp
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF8610ChannelsDown
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Images
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NotificationCenter
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86PickupPhone
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86HangupPhone
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Fn
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Fn_Esc
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86FnRightShift
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric0
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric1
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric2
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric3
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric4
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric5
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric6
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric7
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric8
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric9
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NumericStar
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NumericPound
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NumericA
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NumericB
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NumericC
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NumericD
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraFocus
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86WPSButton
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraZoomIn
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraZoomOut
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraUp
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraDown
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraLeft
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86CameraRight
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86AttendantOn
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86AttendantOff
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86AttendantToggle
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86LightsToggle
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86ALSToggle
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Buttonconfig
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Taskmanager
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Journal
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86ControlPanel
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86AppSelect
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Screensaver
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86VoiceCommand
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Assistant
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86BrightnessMin
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86BrightnessMax
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdInputAssistPrev
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdInputAssistNext
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdInputAssistPrevgroup
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdInputAssistNextgroup
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdInputAssistAccept
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdInputAssistCancel
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86RightUp
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86RightDown
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86LeftUp
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86LeftDown
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86RootMenu
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MediaTopMenu
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric11
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Numeric12
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86AudioDesc
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF863DMode
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86NextFavorite
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86StopRecord
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86PauseRecord
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86VOD
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Unmute
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86FastReverse
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86SlowReverse
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86OnScreenKeyboard
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86PrivacyScreenToggle
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86SelectiveScreenshot
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro1
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro2
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro3
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro4
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro5
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro6
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro7
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro8
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro9
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro10
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro11
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro12
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro13
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro14
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro15
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro16
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro17
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro18
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro19
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro20
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro21
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro22
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro23
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro24
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro25
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro26
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro27
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro28
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro29
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86Macro30
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MacroRecordStart
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MacroRecordStop
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MacroPresetCycle
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MacroPreset1
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MacroPreset2
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86MacroPreset3
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdLcdMenu1
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdLcdMenu2
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdLcdMenu3
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdLcdMenu4
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: > Warning:          Could not resolve keysym XF86KbdLcdMenu5
jul 05 17:23:22 denis-manjaro /usr/lib/gdm-x-session[18801]: Errors from xkbcomp are not fatal to the X server
jul 05 17:23:26 denis-manjaro bluetoothd[882]: profiles/audio/avdtp.c:avdtp_parse_rej() SET_CONFIGURATION request rejected: Configuration not supported (41)
jul 05 17:23:27 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) config/udev: removing device Beoplay H9i (AVRCP)
jul 05 17:23:27 denis-manjaro /usr/lib/gdm-x-session[1839]: (**) Option "fd" "95"
jul 05 17:23:27 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) event22 - Beoplay H9i (AVRCP): device removed
jul 05 17:23:27 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) UnloadModule: "libinput"
jul 05 17:23:27 denis-manjaro /usr/lib/gdm-x-session[1839]: (II) systemd-logind: releasing fd for 13:86
Despite thinking it’s a keyboard and throwing all these warnings it does remain connected and play audio. It’s in my bluetooth and sound settings. Just not with the A2DP configuration. Only the HSP ones.
That’s not the command I wrote:
I’m on cinnamon, but I don’t mean the audio settings.
My screenshot is from bluetooth-manager
Maybr this BlueZ issue is relevant?
Yes @pobrn the downgrade did fix it, I’ll keep sticking with it until the patch is available. It didn’t occur to me to look at bluez. Thanks a lot!
Bluez 5.60 is out with the fix, but Manjaro hasn’t caught up yet. Is there a way to know if our admins are aware or to notify them without spamming? (Still new to the community and tools)
It’s on the testing branch:
Thank you for the heads up and the link!
I got the instructions on how to switch branches from here and tried to upgrade only Bluez, to no avail.
Then I went full unstable for possible dependency issue, nothing.
Funny to see the codec options there, they do change the quality.
I guess my issue is different than the one you opened the thread for, oh well.
I will try a fresh install next.
[EDIT]
Fixed! I just had to do this
sudo systemctl stop bluetooth
sudo rm -rf /var/lib/bluetooth
sudo systemctl start bluetooth
From here
[/EDIT]
I’m observing the same on my end.
