Hello,
after changing Windows by Manjaro I have no sound, I give you all the information I can give you:
inxi -Fazy
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=47cb7fab-3fe4-4284-beff-4080974c86ff rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HUAWEI product: NBD-WXX9 v: M1010
serial: <superuser required>
Mobo: HUAWEI model: NBD-WXX9-PCB-B3 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 2.29 date: 04/21/2022
ID-1: BAT1 charge: 3.4 Wh (6.1%) condition: 56.0/54.9 Wh (102.0%) volts: 7.2
min: 7.6 model: Sunwoda-H HB4692Z9ECW-22T type: Li-ion serial: <filter>
status: discharging cycles: 3
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 878 high: 1025 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 997 2: 1025 3: 601 4: 931
5: 884 6: 950 7: 1006 8: 636 bogomips: 38720
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: QUANTA
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 13d3:5476 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1404 built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 48.77 GiB (10.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: 311CD0512GB size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: EDFOB0.7 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 48.77 GiB
(10.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 284 Uptime: 2h 17m wakeups: 5275 Memory: 15.43 GiB used: 5.75 GiB
(37.3%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: 1128 pm: pacman pkgs: 1113 libs: 325
tools: pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 15 Shell: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.21
pacmd dump
### Configuration dump generated at Fri Sep 9 22:52:12 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-null-sink sink_name=auto_null sink_properties='device.description="Sortie factice"'
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/amine/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/amine/.Xauthority session_manager=local/amine:@/tmp/.ICE-unix/1039,unix/amine:/tmp/.ICE-unix/1039
load-module module-cli-protocol-unix
set-sink-volume auto_null 0xf333
set-sink-mute auto_null no
suspend-sink auto_null yes
set-source-volume auto_null.monitor 0x10000
set-source-mute auto_null.monitor no
suspend-source auto_null.monitor yes
set-default-sink auto_null
set-default-source auto_null.monitor
amixer --card=0
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'Dmic0',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 70
Front Left: Capture 65 [93%] [15.00dB] [on]
Front Right: Capture 65 [93%] [15.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
Front Left: Capture 64 [91%] [14.00dB]
Front Right: Capture 64 [91%] [14.00dB]
Simple mixer control 'PGA2.0 2 Master',0
Capabilities: pvolume
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA3.0 3 Master',0
Mono:
Simple mixer control 'PGA4.0 4 Master',0
Mono:
