Hello everybody,
I noticed I don’t have sound on my laptop. Even worse, I have no audio device to select in Gnome Settings > Audio, Evolution hangs when a mail arrives (the biggest issue), YouTube videos don’t start playing (i.e. Vivaldi hangs and taints the kernel, or something along those lines)
I’m running up-to-date Manjaro Gnome on Lenovo X1 Carbon, which has Intel Tiger Lake audio device:
> sudo lspci -s "00:1f.3" -v
00:1f.3 Audio device: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20) (prog-if 80)
Subsystem: Lenovo Device 22d5
Flags: bus master, fast devsel, latency 64, IRQ 186, IOMMU group 13
Memory at 603d1c8000 (64-bit, non-prefetchable) [size=16K]
Memory at 603d000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [50] Power Management version 3
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: sof-audio-pci-intel-tgl
Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
According to a quick dmesg
, the firmware and kernel modules seem to load fine (abeit the firmware seems to be on newer ABI?):
> sudo dmesg | grep -E "(sof|hda_intel)"
[ 0.672182] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.672183] software IO TLB: mapped [mem 0x0000000085715000-0x0000000089715000] (64MB)
[ 5.603336] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 5.604883] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 6.111825] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 6.112374] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 6.113054] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
[ 7.072035] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 7.079270] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 7.121555] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[ 7.121558] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 7.121562] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 7.122940] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 7.122942] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:19:1
[ 7.122943] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 7.122946] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 7.233346] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 7.233352] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:19:1
[ 7.233354] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 7.264598] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:19:1
[ 7.264603] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: topology ABI is more recent than kernel
[ 7.414863] input: sof-hda-dsp Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input41
[ 7.414898] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input42
[ 7.414916] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input43
[ 7.414936] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input44
[ 7.414953] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input45
Systemd service pipewire
has something to tell:
> systemctl --user status pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Mon 2022-07-18 09:45:53 EEST; 28min ago
TriggeredBy: ● pipewire.socket
Main PID: 2119 (pipewire)
Tasks: 2 (limit: 38154)
Memory: 16.1M
CPU: 349ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─2119 /usr/bin/pipewire
heinä 18 09:45:53 carbon-x1 systemd[1991]: Started PipeWire Multimedia Service.
heinä 18 09:52:06 carbon-x1 pipewire[2119]: ALSA lib parser.c:1194:(parse_sequence) error: sequence command 'devdisall' is ignored
With that as the lead, I found that ALSA 1.2.7.2 fixed a typo from ‘devdisall’ to ‘disdevall’. Sure enough, I have 1.2.7.1 installed:
> pacman -Qs alsa-ucm-conf
local/alsa-ucm-conf 1.2.7.1-1
ALSA Use Case Manager configuration (and topologies)
Any ideas how to tackle this? Can it really be the ignored sequence command that borks the whole pipewire?
