No sound - Maybe update? Installed new soundcard, still don't work
Dear all,
I do have an odyssey about my sound. Somewhen last three weeks after having an update, my sound did not work at all.
First, I had a soundblaster Z installed. Great sound with headphones. But suddently, I call it like that, it did not work at all. I checked this forum for some support:
I thought that my soundcard got broken, because sound worked with onboard chip and external USB headset.
I bought a brandnew soundblaster AE 7. Installed it, faced the same problem as with the soundblaster Z.
Now, I am curious that something with Pulse audio may not work.
ALSA seems to work fine. Started with kernel 5.13, did not work. Migrated down to 5.10, did not work. Pavu only gives me the possibility to use digital port, but not analog one. I checked all options in alsamixer, nothing worked. I am absolutely down and do not know what the problem is.
Inxi:
System:    Host: coyote Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 Desktop: GNOME 40.4 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0 serial: <superuser required>
           UEFI: American Megatrends v: H.70 date: 01/09/2020
CPU:       Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP cache: L2: 4 MiB
           Speed: 3588 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 3588 2: 2057 3: 2052 4: 3597 5: 2163 6: 2159
           7: 4316 8: 2161 9: 2059 10: 3600 11: 2160 12: 2163 13: 4339 14: 2166 15: 3599 16: 2056
Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 470.63.01
           Display: x11 server: X.org 1.20.13 driver: loaded: nvidia resolution: <missing: xdpyinfo>
           OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
Audio:     Device-1: Creative Labs driver: snd_hda_intel
           Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
           Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
           Sound Server-2: PulseAudio v: 15.0 running: yes
           Sound Server-3: PipeWire v: 0.3.33 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: 2c:f0:5d:0a:09:c8
Drives:    Local Storage: total: 2.52 TiB used: 1.02 TiB (40.4%)
           ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 476.94 GiB
           ID-2: /dev/nvme1n1 vendor: Toshiba model: RD400 size: 238.47 GiB
           ID-3: /dev/sda vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
Partition: ID-1: / size: 468.09 GiB used: 21.16 GiB (4.5%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 44.9 C mobo: N/A gpu: nvidia temp: 39 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Info:      Processes: 323 Uptime: 18m Memory: 15.64 GiB used: 2.34 GiB (15.0%) Shell: Zsh inxi: 3.3.06
System has 2 incompatible sound servers running
  Sound Server-4: PipeWire v: 0.3.33 running: yes
Pipewire cannot support audio unless PulseAudio is removed and replaced, but it might impede PulseAudio functions
Use this command to stop, disable and mask Pipewire services
systemctl --user disable --now pipewire.socket && systemctl --user disable --now pipewire.service && systemctl --user mask pipewire.socket
If audio is still not working please post ALSA information
sudo alsa-info.sh --upload
Hi,
disabling pipewire was somehow the key. Now, sound is working and it is such a pleasure using this soundcard!
But it still had some issue to get it really working. I had to switch on off the use of different channels in the audio settings of Gnome and pavucontrol. And it inferred with alsamixer.
In alsamixer I had to turn on all surround sound outputs. Only with this combination it do work. Strange, but hey, it works.
Here is my alsa information:
!!ALSA Information Script v 0.5.0
!!Script ran on: Mon Aug 30 21:15:58 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Micro-Star International Co., Ltd.
Product Name:      MS-7C37
Product Version:   3.0
Firmware Version:  H.70
System SKU:        To be filled by O.E.M.
Board Vendor:      Micro-Star International Co., Ltd.
Board Name:        X570-A PRO (MS-7C37)
!!ACPI Device Status Information
/sys/bus/acpi/devices/AMDI0030:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0501:00/status 	 15
/sys/bus/acpi/devices/PNP0A08:00/status 	 15
/sys/bus/acpi/devices/PNP0C01:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:01/status 	 15
/sys/bus/acpi/devices/PNP0C02:03/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:01/status 	 11
/sys/bus/acpi/devices/PNP0C0F:02/status 	 11
/sys/bus/acpi/devices/PNP0C0F:03/status 	 11
/sys/bus/acpi/devices/PNP0C0F:04/status 	 11
/sys/bus/acpi/devices/PNP0C0F:05/status 	 11
/sys/bus/acpi/devices/PNP0C0F:06/status 	 11
/sys/bus/acpi/devices/PNP0C0F:07/status 	 11
!!Kernel Information
Kernel release:    5.13.12-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.13.12-1-MANJARO
Library version:    1.2.5.1
Utilities version:  1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - No
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [Creative       ]: HDA-Intel - HDA Creative
                      HDA Creative at 0xf7404000 irq 95
 1 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xf7080000 irq 96
!!PCI Soundcards installed in the system
2a:00.0 Audio device [0403]: Creative Labs Device [1102:0010] (rev 01)
	Subsystem: Creative Labs Device [1102:0081]
2e:00.1 Audio device [0403]: NVIDIA Corporation GP106 High Definition Audio Controller [10de:10f1] (rev a1)
	Subsystem: PNY Device [196e:119f]
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
	dmic_detect : Y
	enable_msi : -1
	pm_blacklist : Y
	power_save : 0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Creative Sound Blaster AE-7
Address: 1
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x11020011
Subsystem Id: 0x11020081
Revision Id: 0x100918
No Modem Function Group found
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3 D3cold S3D3cold CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=1
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=1, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x49d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="CA0132 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x5a, nsteps=0x63, stepsize=0x03, mute=1
  Amp-Out vals:  [0x63 0x63]
  Converter: stream=5, channel=0
  PCM:
    rates [0x1e4]: 16000 44100 48000 88200 96000
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Unsolicited: tag=00, enabled=0
  Power states:  D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x49d: Stereo Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Switch", index=0, device=0
  Converter: stream=0, channel=0
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x49d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Control: name="Surround Playback Switch", index=0, device=0
  PCM:
    rates [0x5ec]: 16000 22050 44100 48000 88200 96000 192000
    bits [0x1f]: 8 16 20 24 32
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x691: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
  Device: name="CA0132 Digital", type="SPDIF", device=1
  Digital: GenLevel
  Digital category: 0x2
  IEC Coding Type: 0x0
  PCM:
    rates [0x1e0]: 44100 48000 88200 96000
    bits [0xa]: 16 24
    formats [0x5]: PCM AC3
Node 0x06 [Audio Output] wcaps 0x691: Stereo Digital
  Digital:
  Digital category: 0x0
  PCM:
    rates [0x5e0]: 44100 48000 88200 96000 192000
    bits [0x1e]: 16 20 24 32
Node 0x07 [Audio Input] wcaps 0x10059b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Amp-In caps: ofs=0x5a, nsteps=0x63, stepsize=0x03, mute=1
  Amp-In vals:  [0x63 0x63]
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Connection: 1
     0x12
Node 0x08 [Audio Input] wcaps 0x10059b: Stereo Amp-In
  Amp-In vals:  [0x5a 0x5a]
  SDI-Select: 0
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Connection: 1
     0x11
Node 0x09 [Audio Input] wcaps 0x100791: Stereo Digital
  SDI-Select: 0
  Digital:
  PCM:
    rates [0x1f0]: 32000 44100 48000 88200 96000
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Connection: 1
     0x0e
Node 0x0a [Audio Input] wcaps 0x10079b: Stereo Digital Amp-In
  Control: name="What U Hear Capture Volume", index=0, device=0
  Control: name="What U Hear Capture Switch", index=0, device=0
  Device: name="CA0132 What U Hear", type="Audio", device=2
  Amp-In vals:  [0x00 0x00]
  SDI-Select: 0
  Digital:
  PCM:
    rates [0x1ec]: 16000 22050 44100 48000 88200 96000
    bits [0x1b]: 8 16 24 32
    formats [0x1]: PCM
  Connection: 1
     0x13
Node 0x0b [Pin Complex] wcaps 0x400581: Stereo
  Pincap 0x00010014: OUT EAPD Detect
  EAPD 0x0:
  Pin Default 0x01014010: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=06, enabled=1
  Connection: 1
     0x02
Node 0x0c [Pin Complex] wcaps 0x400701: Stereo Digital
  Pincap 0x00000010: OUT
  Pin Default 0x014580f0: [Jack] SPDIF Out at Ext Rear
    Conn = Optical, Color = Purple
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x05
Node 0x0d [Pin Complex] wcaps 0x400501: Stereo
  Pin Default 0x014570f0: [Jack] SPDIF Out at Ext Rear
    Conn = Optical, Color = Yellow
  Pin-ctls: 0x00:
  Connection: 1
     0x06
Node 0x0e [Pin Complex] wcaps 0x400681: Stereo Digital
  Pincap 0x00000020: IN
  Pin Default 0x01c530f0: [Jack] SPDIF In at Ext Rear
    Conn = Optical, Color = Blue
  Pin-ctls: 0x20: IN
Node 0x0f [Pin Complex] wcaps 0x400581: Stereo
  Pincap 0x0000001c: OUT HP Detect
  Pin Default 0x0221401f: [Jack] HP Out at Ext Front
    DefAssociation = 0x1, Sequence = 0xf
  Pin-ctls: 0x00:
  Connection: 1
     0x02
Node 0x10 [Pin Complex] wcaps 0x400581: Stereo
  Pin Default 0x02216011: [Jack] HP Out at Ext Front
    Conn = 1/8, Color = Orange
    DefAssociation = 0x1, Sequence = 0x1
  Pin-ctls: 0x00:
  Unsolicited: tag=04, enabled=1
  Connection: 1
     0x03
Node 0x11 [Pin Complex] wcaps 0x40058b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00003734: IN OUT Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x02012014: [Jack] Line Out at Ext Front
    Conn = 1/8, Color = Grey
    DefAssociation = 0x1, Sequence = 0x4
  Pin-ctls: 0x40: OUT VREF_HIZ
  Unsolicited: tag=01, enabled=1
  Connection: 1
     0x04
Node 0x12 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x02, stepsize=0x27, mute=0
  Pincap 0x00003724: IN Detect
  Pin Default 0x37a791f0: [Jack] Mic at Oth Mobile-In
    Conn = Analog, Color = Pink
    Misc = NO_PRESENCE
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
Node 0x13 [Pin Complex] wcaps 0x400681: Stereo Digital
  Pin Default 0x908700f0: [Fixed] Line In at Int N/A
    Conn = Analog, Color = Unknown
  Pin-ctls: 0x20: IN
Node 0x14 [Beep Generator Widget] wcaps 0x70040c: Mono Amp-Out
  Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-Out vals:  [0x1c]
Node 0x15 [Vendor Defined Widget] wcaps 0xf00600: Mono Digital
Node 0x16 [Vendor Defined Widget] wcaps 0xf00680: Mono Digital
  Unsolicited: tag=03, enabled=1
Node 0x17 [Audio Output] wcaps 0x49d: Stereo Amp-Out
  Amp-Out vals:  [0x5a 0x5a]
  PCM:
    formats [0x1]: PCM
Node 0x18 [Pin Complex] wcaps 0x400581: Stereo
  Pin Default 0x500000f0: [N/A] Line Out at Int N/A
    Conn = Unknown, Color = Unknown
  Pin-ctls: 0x00:
  Connection: 1
     0x17
Codec: Nvidia GPU 84 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0084
Subsystem Id: 0x196e119f
Revision Id: 0x100100
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pincap 0x09000094: OUT Detect HBR HDMI DP
  Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
  Pin-ctls: 0x00:
  Devices: 4
     Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x0a* 0x0b 0x0c 0x0d ]
     Dev 01: PD = 0, ELDV = 0, IA = 0, Connections [ 0x0a* 0x0b 0x0c 0x0d ]
     Dev 02: PD = 0, ELDV = 0, IA = 0, Connections [ 0x0a* 0x0b 0x0c 0x0d ]
    *Dev 03: PD = 0, ELDV = 0, IA = 0, Connections [ 0x0a* 0x0b 0x0c 0x0d ]
  Connection: 4
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=05, enabled=1
  Devices: 4
  Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=09, enabled=1
  Devices: 4
    *Dev 00: PD = 1, ELDV = 1, IA = 0, Connections [ 0x0a* 0x0b 0x0c 0x0d ]
  Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=0d, enabled=1
  Devices: 4
  Connection: 4
Node 0x08 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
  Pin-ctls: 0x00:
  Devices: 4
    *Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x0a* 0x0b 0x0c 0x0d ]
     Dev 01: PD = 0, ELDV = 0, IA = 0, Connections [ 0x00* 0x00 0x00 0x00 ]
     Dev 02: PD = 0, ELDV = 0, IA = 0, Connections [ 0x00* 0x00 0x00 0x00 ]
     Dev 03: PD = 0, ELDV = 0, IA = 0, Connections [ 0x00* 0x00 0x00 0x00 ]
  Connection: 4
Node 0x09 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Devices: 4
  Connection: 4
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Device: name="HDMI 4", type="HDMI", device=10
  Digital: Enabled GenLevel
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0xe]: 16 20 24
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Node 0x0c [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Node 0x0d [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116, 16 Aug 30 23:03 /dev/snd/controlC0
crw-rw----  1 root audio 116, 10 Aug 30 23:03 /dev/snd/controlC1
crw-rw----  1 root audio 116, 15 Aug 30 23:03 /dev/snd/hwC0D1
crw-rw----  1 root audio 116,  9 Aug 30 23:03 /dev/snd/hwC1D0
crw-rw----  1 root audio 116, 12 Aug 30 23:04 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116, 11 Aug 30 23:04 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116, 14 Aug 30 23:04 /dev/snd/pcmC0D1p
crw-rw----  1 root audio 116, 13 Aug 30 23:03 /dev/snd/pcmC0D2c
crw-rw----  1 root audio 116,  6 Aug 30 23:04 /dev/snd/pcmC1D10p
crw-rw----  1 root audio 116,  7 Aug 30 23:03 /dev/snd/pcmC1D11p
crw-rw----  1 root audio 116,  8 Aug 30 23:03 /dev/snd/pcmC1D12p
crw-rw----  1 root audio 116,  2 Aug 30 23:04 /dev/snd/pcmC1D3p
crw-rw----  1 root audio 116,  3 Aug 30 23:03 /dev/snd/pcmC1D7p
crw-rw----  1 root audio 116,  4 Aug 30 23:03 /dev/snd/pcmC1D8p
crw-rw----  1 root audio 116,  5 Aug 30 23:03 /dev/snd/pcmC1D9p
crw-rw----  1 root audio 116,  1 Aug 30 23:03 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Aug 30 23:03 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Aug 30 23:03 .
drwxr-xr-x 3 root root 400 Aug 30 23:03 ..
lrwxrwxrwx 1 root root  12 Aug 30 23:03 pci-0000:2a:00.0 -> ../controlC0
lrwxrwxrwx 1 root root  12 Aug 30 23:03 pci-0000:2e:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Creative [HDA Creative], device 0: CA0132 Analog [CA0132 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: Creative [HDA Creative], device 1: CA0132 Digital [CA0132 Digital]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
  Subdevices: 0/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 0/1
card 0: Creative [HDA Creative], device 2: CA0132 What U Hear [CA0132 What U Hear]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card Creative
Card sysdefault:0 'Creative'/'HDA Creative at 0xf7404000 irq 95'
  Mixer name	: 'Creative Sound Blaster AE-7'
  Components	: 'HDA:11020011,11020081,00100918'
  Controls      : 62
  Simple ctrls  : 36
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 99
  Mono: Playback 99 [100%] [0.00dB] [on]
Simple mixer control 'Bass Redirection',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'Bass Redirection Crossover',0
  Capabilities: volume volume-joined
  Capture channels: Mono
  Limits: 1 - 100
  Mono: 1 [0%]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 99 [100%] [9.00dB] [on]
  Front Right: Playback 99 [100%] [9.00dB] [on]
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Surround Channel Config',0
  Capabilities: enum
  Items: '2.0' '2.1' '4.0' '4.1' '5.1'
  Item0: '2.0'
Simple mixer control 'Center',0
  Mono: Playback 99 [100%] [9.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Mic Boost',0
  Capabilities: cenum
  Items: '0 dB' '10 dB' '20 dB' '30 dB'
  Item0: '0 dB'
Simple mixer control 'IEC958',0
Simple mixer control 'IEC958 Default PCM',0
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 99
  Front Left: Capture 99 [100%] [9.00dB] [on]
  Front Right: Capture 99 [100%] [9.00dB] [on]
Simple mixer control 'AE-5: Headphone Gain',0
  Capabilities: enum
  Items: 'Low (16-31  Ohms)' 'Medium (32-149  Ohms)' 'High (150-600  Ohms)'
  Item0: 'Low (16-31  Ohms)'
Simple mixer control 'AE-5: Sound Filter',0
  Capabilities: enum
  Items: 'Slow Roll Off' 'Minimum Phase' 'Fast Roll Off'
  Item0: 'Slow Roll Off'
Simple mixer control 'Enable InFX',0
  Capabilities: cswitch cswitch-joined
  Mono: Capture [off]
Simple mixer control 'Enable OutFX',0
  Mono: Playback [on]
Simple mixer control 'FX: Crystalizer',0
  Limits: Playback 0 - 100
  Mono: Playback 65 [65%] [off]
Simple mixer control 'FX: Dialog Plus',0
  Mono: Playback 50 [50%] [off]
Simple mixer control 'FX: Equalizer',0
  Mono: Playback [on]
Simple mixer control 'FX: Equalizer Preset',0
  Capabilities: enum
  Items: 'Flat' 'Acoustic' 'Classical' 'Country' 'Dance' 'Jazz' 'New Age' 'Pop' 'Rock' 'Vocal'
  Item0: 'Dance'
Simple mixer control 'FX: Mic SVM',0
  Mono: Capture [on]
Simple mixer control 'FX: Noise Reduction',0
  Mono: Capture [on]
Simple mixer control 'FX: Smart Volume',0
  Mono: Playback 74 [74%] [off]
Simple mixer control 'FX: Smart Volume Setting',0
  Capabilities: enum
  Items: 'Normal' 'Loud' 'Night'
  Item0: 'Normal'
Simple mixer control 'FX: Surround',0
  Mono: Playback 67 [67%] [off]
Simple mixer control 'FX: Voice Focus',0
  Mono: Capture [on]
Simple mixer control 'FX: X-Bass',0
  Mono: Playback 100 [100%] [on]
Simple mixer control 'FX: X-Bass Crossover',0
  Limits: Playback 1 - 100
  Mono: Playback 3 [2%]
Simple mixer control 'Full-Range Front Speakers',0
Simple mixer control 'Full-Range Rear Speakers',0
Simple mixer control 'HP/Speaker Auto Detect',0
  Mono: Playback [on]
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Microphone' 'Line In' 'Front Microphone'
  Item0: 'Microphone'
Simple mixer control 'Output Select',0
  Capabilities: enum
  Items: 'Speakers' 'Headphone'
  Item0: 'Headphone'
Simple mixer control 'VoiceFX',0
  Capabilities: cenum
  Items: 'Neutral' 'Female2Male' 'Male2Female' 'ScrappyKid' 'Elderly' 'Orc' 'Elf' 'Dwarf' 'AlienBrute' 'Robot' 'Marine' 'Emo' 'DeepVoice' 'Munchkin'
  Item0: 'Neutral'
Simple mixer control 'What U Hear',0
  Front Left: Capture 0 [0%] [-90.00dB] [on]
  Front Right: Capture 0 [0%] [-90.00dB] [on]
!!-------Mixer controls for card NVidia
Card sysdefault:1 'NVidia'/'HDA NVidia at 0xf7080000 irq 96'
  Mixer name	: 'Nvidia GPU 84 HDMI/DP'
  Components	: 'HDA:10de0084,196e119f,00100100'
  Controls      : 49
  Simple ctrls  : 7
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'IEC958',5
  Mono: Playback [on]
Simple mixer control 'IEC958',6
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.Creative {
	control.1 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 99
		value.1 99
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 99'
			dbmin -9000
			dbmax 900
			dbvalue.0 900
			dbvalue.1 900
	control.2 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 99
		value.1 99
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 99'
			dbmin -9000
			dbmax 900
			dbvalue.0 900
			dbvalue.1 900
	control.4 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Center Playback Volume'
		value 99
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 99'
			dbmin -9000
			dbmax 900
			dbvalue.0 900
	control.6 {
		iface MIXER
		name 'Center Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.7 {
		iface MIXER
		name 'LFE Playback Volume'
		value 99
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 99'
			dbmin -9000
			dbmax 900
			dbvalue.0 900
	control.8 {
		iface MIXER
		name 'LFE Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'Capture Volume'
		value.0 99
		value.1 99
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 99'
			dbmin -9000
			dbmax 900
			dbvalue.0 900
			dbvalue.1 900
	control.10 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'What U Hear Capture Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 99'
			dbmin -9000
			dbmax 900
			dbvalue.0 -9000
			dbvalue.1 -9000
	control.12 {
		iface MIXER
		name 'What U Hear Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.13 {
		iface MIXER
		name 'HP/Speaker Auto Detect Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		name 'Master Playback Volume'
		value 99
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 99'
			dbmin -9900
			dbmax 0
			dbvalue.0 0
	control.15 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.16 {
		iface MIXER
		name 'FX: Surround Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'FX: Crystalizer Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface MIXER
		name 'FX: Dialog Plus Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.19 {
		iface MIXER
		name 'FX: Smart Volume Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		name 'FX: X-Bass Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.21 {
		iface MIXER
		name 'FX: Equalizer Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.22 {
		iface MIXER
		name 'FX: Voice Focus Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.23 {
		iface MIXER
		name 'FX: Mic SVM Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface MIXER
		name 'FX: Noise Reduction Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.25 {
		iface MIXER
		name 'FX: Smart Volume Setting'
		value Normal
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Normal
			item.1 Loud
			item.2 Night
	control.26 {
		iface MIXER
		name 'FX: Equalizer Preset Switch'
		value Dance
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Flat
			item.1 Acoustic
			item.2 Classical
			item.3 Country
			item.4 Dance
			item.5 Jazz
			item.6 'New Age'
			item.7 Pop
			item.8 Rock
			item.9 Vocal
	control.27 {
		iface MIXER
		name 'Enable OutFX Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.28 {
		iface MIXER
		name 'Enable InFX Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.29 {
		iface MIXER
		name 'FX: Surround Playback Volume'
		value 67
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 100 (step 1)'
	control.30 {
		iface MIXER
		name 'FX: Crystalizer Playback Volume'
		value 65
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.31 {
		iface MIXER
		name 'FX: Dialog Plus Playback Volume'
		value 50
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.32 {
		iface MIXER
		name 'FX: Smart Volume Playback Volume'
		value 74
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.33 {
		iface MIXER
		name 'FX: X-Bass Playback Volume'
		value 100
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.34 {
		iface MIXER
		name 'FX: X-Bass Crossover Playback Volume'
		value 3
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '1 - 100 (step 1)'
	control.35 {
		iface MIXER
		name 'VoiceFX Capture Switch'
		value Neutral
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Neutral
			item.1 Female2Male
			item.2 Male2Female
			item.3 ScrappyKid
			item.4 Elderly
			item.5 Orc
			item.6 Elf
			item.7 Dwarf
			item.8 AlienBrute
			item.9 Robot
			item.10 Marine
			item.11 Emo
			item.12 DeepVoice
			item.13 Munchkin
	control.36 {
		iface MIXER
		name 'Output Select'
		value Headphone
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Speakers
			item.1 Headphone
	control.37 {
		iface MIXER
		name 'Surround Channel Config'
		value '2.0'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '2.0'
			item.1 '2.1'
			item.2 '4.0'
			item.3 '4.1'
			item.4 '5.1'
	control.38 {
		iface MIXER
		name 'Full-Range Front Speakers'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.39 {
		iface MIXER
		name 'Full-Range Rear Speakers'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.40 {
		iface MIXER
		name 'Bass Redirection Crossover'
		value 1
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.41 {
		iface MIXER
		name 'Bass Redirection'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.42 {
		iface MIXER
		name 'Mic Boost Capture Switch'
		value '0 dB'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '0 dB'
			item.1 '10 dB'
			item.2 '20 dB'
			item.3 '30 dB'
	control.43 {
		iface MIXER
		name 'Input Source'
		value Microphone
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Microphone
			item.1 'Line In'
			item.2 'Front Microphone'
	control.44 {
		iface MIXER
		name 'AE-5: Headphone Gain'
		value 'Low (16-31  Ohms)'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Low (16-31  Ohms)'
			item.1 'Medium (32-149  Ohms)'
			item.2 'High (150-600  Ohms)'
	control.45 {
		iface MIXER
		name 'AE-5: Sound Filter'
		value 'Slow Roll Off'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Slow Roll Off'
			item.1 'Minimum Phase'
			item.2 'Fast Roll Off'
	control.46 {
		iface CARD
		name 'Mic Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.47 {
		iface CARD
		name 'Line Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.48 {
		iface CARD
		name 'Line Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.49 {
		iface CARD
		name 'Line Out Front Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.50 {
		iface CARD
		name 'Line Out Surround Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.51 {
		iface CARD
		name 'Line Out CLFE Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.52 {
		iface CARD
		name 'SPDIF Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.53 {
		iface CARD
		name 'SPDIF In Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.54 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.55 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.56 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.57 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.58 {
		iface MIXER
		name 'IEC958 Default PCM Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.59 {
		iface PCM
		name 'Playback Channel Map'
		value.0 3
		value.1 4
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		comment {
			access read
			type INTEGER
			count 6
			range '0 - 36'
	control.60 {
		iface PCM
		device 2
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.61 {
		iface PCM
		device 1
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.62 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
state.NVidia {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value '100008006d14000100400000000000001e6d095b4c4720556c7472612048440a200907070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			type BYTES
			count 95
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value '100008006d14000100100000000000001e6d095b4c4720556c7472612048440a200907070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			type BYTES
			count 95
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write locked'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=11 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 5
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 5
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 11
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface CARD
		name 'HDMI/DP,pcm=12 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.38 {
		iface MIXER
		index 6
		comment {
			access read
			type IEC958
			count 1
	control.39 {
		iface MIXER
		index 6
		comment {
			access read
			type IEC958
			count 1
	control.40 {
		iface MIXER
		index 6
		comment {
			access 'read write'
			type IEC958
			count 1
	control.41 {
		iface MIXER
		index 6
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.42 {
		iface PCM
		device 12
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.43 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.44 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.45 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.46 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.47 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.48 {
		iface PCM
		device 11
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.49 {
		iface PCM
		device 12
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
--endcollapse--
!!All Loaded Modules
acpi_cpufreq
aesni_intel
agpgart
ccp
cec
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
edac_mce_amd
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
i2c_piix4
intel_rapl_common
intel_rapl_msr
ip_tables
irqbypass
jbd2
joydev
k10temp
kvm
kvm_amd
libphy
loop
mac_hid
mbcache
mdio_devres
mousedev
nvidia
nvidia_drm
nvidia_modeset
pcspkr
pinctrl_amd
r8169
rapl
realtek
rfkill
rng_core
snd
snd_hda_codec
snd_hda_codec_ca0132
snd_hda_codec_hdmi
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_timer
soundcore
sp5100_tco
squashfs
syscopyarea
sysfillrect
sysimgblt
uinput
usbhid
vfat
wmi
wmi_bmof
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D1/init_pin_configs:
0x0b 0x01014010
0x0c 0x014580f0
0x0d 0x014570f0
0x0e 0x01c530f0
0x0f 0x0221401f
0x10 0x02216011
0x11 0x02012014
0x12 0x37a791f0
0x13 0x908700f0
0x18 0x500000f0
/sys/class/sound/hwC0D1/driver_pin_configs:
0x0b 0x01017010
0x0c 0x014510f0
0x0d 0x414510f0
0x0e 0x01c520f0
0x0f 0x01017114
0x10 0x01017011
0x11 0x018170ff
0x12 0x01a170f0
0x13 0x908700f0
0x18 0x500000f0
/sys/class/sound/hwC0D1/user_pin_configs:
/sys/class/sound/hwC0D1/init_verbs:
/sys/class/sound/hwC0D1/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
0x08 0x585600f0
0x09 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[    0.147651] ACPI: Added _OSI(Linux-Dell-Video)
[    0.147651] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.147651] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    1.936709] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    1.938156] snd_hda_intel 0000:2a:00.0: enabling device (0000 -> 0002)
[    1.938289] snd_hda_intel 0000:2a:00.0: Disabling MSI
[    1.938292] snd_hda_intel 0000:2a:00.0: Force to non-snoop mode
[    1.938770] snd_hda_intel 0000:2e:00.1: enabling device (0000 -> 0002)
[    1.938833] snd_hda_intel 0000:2e:00.1: Disabling MSI
[    1.938844] snd_hda_intel 0000:2e:00.1: Handle vga_switcheroo audio client
[    1.964561] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[    1.965290] snd_hda_codec_ca0132 hdaudioC0D1: autoconfig for Sound Blaster AE-7: line_outs=3 (0xb/0xf/0x10/0x0/0x0) type:line
[    1.965294] snd_hda_codec_ca0132 hdaudioC0D1:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    1.965295] snd_hda_codec_ca0132 hdaudioC0D1:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    1.965296] snd_hda_codec_ca0132 hdaudioC0D1:    mono: mono_out=0x0
[    1.965297] snd_hda_codec_ca0132 hdaudioC0D1:    dig-out=0xc/0x0
[    1.965298] snd_hda_codec_ca0132 hdaudioC0D1:    inputs:
[    1.965299] snd_hda_codec_ca0132 hdaudioC0D1:      Mic=0x12
[    1.965300] snd_hda_codec_ca0132 hdaudioC0D1:      Line=0x11
[    1.965301] snd_hda_codec_ca0132 hdaudioC0D1:      Line=0x13
[    1.965302] snd_hda_codec_ca0132 hdaudioC0D1:    dig-in=0xe
[    1.965420] nvidia 0000:2e:00.0: vgaarb: changed VGA decodes: olddecodes=io mem,decodes=none:owns=none
[    1.980112] SVM: Virtual GIF supported
[    1.987764] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input3
[    1.987791] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input4
[    1.987812] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input5
[    1.987832] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input6
[    1.987851] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input7
[    1.987869] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input8
[    1.987888] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:2e:00.1/sound/card1/input9
[    2.082151] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.63.01  Tue Aug  3 20:44:16 UTC 2021
[    2.976378] mousedev: PS/2 mouse device common for all mice
[    3.557024] snd_hda_codec_ca0132 hdaudioC0D1: ca0132 DSP downloaded and running
[    5.112610] rfkill: input handler disabled
[    5.564262] audit: type=1334 audit(1630357395.830:83): prog-id=22 op=LOAD
[    5.572890] input: HDA Creative Mic as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:07.0/0000:29:00.0/0000:2a:00.0/sound/card0/input17
[    5.572958] input: HDA Creative Line as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:07.0/0000:29:00.0/0000:2a:00.0/sound/card0/input18
[    5.573014] input: HDA Creative Line Out Front as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:07.0/0000:29:00.0/0000:2a:00.0/sound/card0/input19
[    5.573071] input: HDA Creative Line Out CLFE as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:07.0/0000:29:00.0/0000:2a:00.0/sound/card0/input20
[    5.599491] audit: type=1130 audit(1630357395.863:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
I was cheering too early. Now, the soundcard disappeared completely. I can’t even see it in alsamixer.
Now Inxi is like:
  Host: coyote Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 Desktop: GNOME 40.4
  serial: <superuser required> UEFI: American Megatrends v: H.70
  date: 01/09/2020
  L2: 4 MiB
  Speed: 2218 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2218 2: 2123
  3: 2057 4: 2059 5: 2089 6: 2095 7: 3633 8: 2077 9: 2054 10: 2055 11: 2206
  12: 2111 13: 2510 14: 2136 15: 3605 16: 2052
  Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
  driver: r8169
  ID-1: / size: 468.09 GiB used: 22.02 GiB (4.7%) fs: ext4
  dev: /dev/nvme0n1p2
  dev: /dev/nvme0n1p1
  System Temperatures: cpu: 50.2 C mobo: N/A gpu: nvidia temp: 38 C
  Processes: 330 Uptime: 10m Memory: 15.58 GiB used: 2.56 GiB (16.4%)
This rm command thing, doesn’t find anything:
rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie         ✔
rm: das Entfernen von '/home/danny/.config/pulse/cookie' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
It is contnuing that I do have problems with my sound.
I can get it working, if I switch on all sorround channels in alsamixer. Then I need to toggle back and forth the playback channel for my Nvidia HDMI. Then I switch back to the soundcard, only then it works for a while. Until the playing audio stream is interupted, then it stops working and I need to do the whole excercise again.
I am frustrated!
Error message advises cookie file was not found, but no error finding .tdb files
If you check the systemd service and socket are functioning correctly
systemctl --user status pulseaudio*
and the service is active (running) with no error messages, new cookie and database files would have been created when PulseAudio restarted
Hi,
I had some excursion to Ubuntu and back. On Ubuntu 21.04 sound worked and with the update to 21.10 it has the same problem as Manjaro had it.
I changed my system back to Manjaro and still have no sound.
But here is the output information:
 pulseaudio.service - Sound Service
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
     Active: active (running) since Thu 2021-10-21 23:28:27 CEST; 30min ago
TriggeredBy: ● pulseaudio.socket
   Main PID: 1713 (pulseaudio)
      Tasks: 8 (limit: 19123)
     Memory: 7.5M
        CPU: 14.007s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
             ├─1713 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─2056 /usr/lib/pulse/gsettings-helper
Okt 21 23:28:26 coyote systemd[1568]: Starting Sound Service...
Okt 21 23:28:27 coyote pulseaudio[1713]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Okt 21 23:28:27 coyote systemd[1568]: Started Sound Service.
Okt 21 23:28:52 coyote pulseaudio[1713]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked t>
I have a Creative AE-5 (non-Plus) there is no sound issues besides, that my centerspeaker from my 5.1 system won’t work sometimes (but reactivated when i boot into windows and reboot in Manjaro).
Headphones always working, no matter which Linux Kernel i use.
My information about AE-7 are not up to date, but befor i bought my AE-5 Soundcard 1 year ago, i read alot bad stuff that the AE-7 is not really supported. Because this model is to rare and expensive and far away from mainstream.
Since you got problems with even your Soundblaster Z maybe there is another issue going on in your system, maybe try to deactivate Onboard Sound (if you had this enabled) in your Bios, you could also try to deactivate the nvidia Sound. Maybe there is other Sound devices (like a VR HMD or USB Headphones) on your PC connected that interference with your Soundcard.
Yeah, kind of an issue with the AE-7. Looks stunning, would be a good device but too rare.
I already deactivated the on board sound. I would like to give he deactivation of the NV sound a go. Do you know how to deactivate it?
I can’t tell how that works in gnome but in KDE you can deactivate under System Settings>Audio>Configure>Tue102 HD Audio Controller>Profile: OFF.
