After latest updated sound does not work at all
Hi all,
after I have ran the latest update my sound does not work. i use Gnome and the level indicators are showing something when playing sound but I do not hear a thing.
Here is my inxi
  Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ea4a44f2-d7c9-4923-9701-dcf3e20b4b79 rw quiet splash apparmor=1
  Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
  serial: <filter> UEFI: American Megatrends v: H.70 date: 01/09/2020
  RAM: total: 15.58 GiB used: 2.74 GiB (17.6%)
  Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
  L2: 4 MiB bogomips: 115232
  Speed: 3597 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 3597 2: 2056 3: 2055 4: 2053 5: 2125 6: 2058 7: 3594 8: 2055 9: 2056
  10: 2057 11: 2053 12: 2052 13: 4073 14: 2055 15: 3601 16: 2056
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  conditional, RSB filling
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: PNY driver: nvidia
  v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
  chip-ID: 10de:1c03 class-ID: 0300
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: nvidia resolution: <missing: xdpyinfo>
  OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
  Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
  driver: snd_hda_intel v: kernel bus-ID: 29:00.0 chip-ID: 1102:0012
  class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: PNY
  driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f1
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
  bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.52 TiB used: 1.06 TiB (42.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: A-Data model: SX8200PNP
  lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Toshiba model: RD400
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 57CZ4102 temp: 51.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
  type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
  used: 67.61 GiB (14.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
  label: N/A uuid: ea4a44f2-d7c9-4923-9701-dcf3e20b4b79
  used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
  label: NO_LABEL uuid: 32E4-AF57
  ID-3: /home/archive raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
  used: 808.14 GiB (44.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: fe589e0c-5f87-4a48-967c-76bacc348a19
  ID-4: /home/steam raw-size: 238.47 GiB size: 233.73 GiB (98.01%)
  used: 209.97 GiB (89.8%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:1
  label: Steam-Machine uuid: cc6964b8-666f-4949-9d1a-4cded5e71ccd
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
  Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-4:2 info: Cherry CHERRY Wireless Device type: Keyboard,Mouse
  power: 100mA chip-ID: 046a:0114 class-ID: 0301
  Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 51.1 C mobo: N/A gpu: nvidia temp: 38 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
  Processes: 357 Uptime: 4m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1296 lib: 402
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Now I changed to pipewire, but it did not change a thing.
  RAM: total: 15.58 GiB used: 2.36 GiB (15.1%)
  Speed: 3774 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 3774 2: 2055 3: 2053 4: 2054 5: 2057 6: 2059 7: 3770 8: 2052 9: 2115
  10: 2055 11: 2055 12: 2067 13: 3601 14: 2125 15: 3597 16: 2057
  class-ID: 0403
  class-ID: 0403
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 39.9 C scheme: GPT
  lanes: 4 type: SSD serial: <filter> rev: 57CZ4102 temp: 56.9 C scheme: GPT
  used: 67.59 GiB (14.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
  System Temperatures: cpu: 48.9 C mobo: N/A gpu: nvidia temp: 41 C
  Processes: 360 Uptime: 4m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1292 lib: 402
Have you tried the fix from the announcement thread?
Hi,
Yes I tried it already but it did not change a thing. I tried that three times also with sudo. Even if it is nonsense.
Have you tried the usual… different Kernel e.g 5.10 LTS and/or 5.4 LTS?
If you had switched to Pipewire by installing manjaro-pipewire to get the additional dependencies, package pipewire-pulse would require removal of conflicting packages pulseaudio and pulseaudio-bluetooth. But data in post #3 shows PulseAudio is still installed
Hi folks,
okay, here is what I have done:
I changed to pipewire - did not change a thing.
I installed the whole system freshly - did not change a thing
With new install I downgraded to kernel 5.10 - did not change a thing
The strange thing about it, all the settings are the same. I still see the sound levels in the setiings of Gnome. Alsamixer is everything like it is ever been. I plugged out and in in each of the input of the sound card. I changed headphones.
But it keeps to be quite. Not a crack at all.
I am really frustrated.
I tried one other thing. I plugged in a Jabra Headset with its own USB dongle. It instantly worked.
Could it be a hardware defect of the soundcard?
Me again, instead of using my soundblaster Z I activated the internal soundcard of my motherboard. And it also is working. Seems that it is a failure of my soundblaster Z.
