Hi,
There is no sound in my machine. Its been for sometime. Any help ?
This is the result of alsa-info.sh
alsa-project . org / db / ?f=49eecb25210d44f0d3a12e2fbb44e67b319892d8
Thanks
Hi,
Thanks
Hi @pp.shew ![]()
Your alsa report proves the opposite. What makes you think that there is no sound? Did you mute it?
Maybe a similar issue to this? I have here CX20632 you have CX20751.
@megavolt
When i play video files using vlc, there is no audio.
I followed that link and it didn’t work.
Sorry, you don’t report any errors, so I have to assume that it is a user configuration. Did you set the correct source?
there is no error. i cant hear anything. but with headphone i can.
Obviously, you can hear something. Don’t be lazy and search the forum. There are good tutorials at Contributions > Tutorials ![]()
Maybe some basics:
Maybe start here:
inxi --admin --verbosity=7 --filter --width
pactl list sources short
Play some audio and run:
pactl list sinks short
Without information, no one can even guess what could be wrong on your system.
@megavolt , I really appreciate your help. Seriously, there is no sound from my device whether it is Youtube or VLC. I am attaching the output of the commands.
Kernel: 5.10.167-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c2e5b1d5-0d5a-4ff4-a1fe-9307e6dff5de rw quiet
resume=UUID=0bdc8b30-8b17-4d11-8e1a-296329ffa5d2 udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: UX305UA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX305UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: UX305UA.201 date: 10/12/2015
ID-1: BAT0 charge: 25.7 Wh (90.5%) condition: 28.4/56.0 Wh (50.7%)
volts: 11.3 min: 11.3 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging cycles: 882
RAM: total: 7.67 GiB used: 1.55 GiB (20.2%)
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 499 high: 500 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 500 2: 500 3: 500 4: 499
bogomips: 19204
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b56b class-ID: 0e02 serial: <filter>
Display: x11 server: X Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x272d built: 2015 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k5.10.167-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-8:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 2.29 TiB used: 159.6 GiB (6.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS512G39MND-3510A
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0P00 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD Elements 10B8 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1012 scheme: MBR
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 159.6 GiB (34.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c2e5b1d5-0d5a-4ff4-a1fe-9307e6dff5de
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: B2E7-A936
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 0bdc8b30-8b17-4d11-8e1a-296329ffa5d2
ID-1: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: N/A
uuid: 8ce728c7-14b6-468f-8963-f947d83ddf34
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Western Digital Elements Portable (WDBU6Y WDBUZG)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 1058:10b8 class-ID: 0806 serial: <filter>
Device-2: 1-5:3 info: Chicony USB2.0 HD UVC WebCam type: Video
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C pch: 30.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 207 Uptime: 4m wakeups: 1503 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1131 libs: 342 tools: pamac Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.25
0 alsa_output.pci-0000_00_1f.3.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
0 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 48000Hz RUNNING
As I see the driver is working:
Still, only pulseaudio is in use, but shouldn’t be a problem.
As you see, there is a sound device, and it plays sound as usual.
pavucontrolHowever, it seems to be rather a hardware issue.
Is the correct profile set?
from PulseAudio data, Profile is likely to be analog-stareo-output
to confirm Active Profile and check if Profiles/Ports are available:
pactl list cards
ALSA data in post#1 shows mixer control for headphone output is muted
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Limits: Playback 0 - 74
Mono:
Front Left: Playback 0 [0%] [-74.00dB] [off]
Front Right: Playback 0 [0%] [-74.00dB] [off]
Laptop headphone output would usually be muted if headphones are not plugged in and Auto-Mute is enabled, but control for Auto-Mute is disabled
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
I suggest unmute Headphone output
amixer -c0 sset 'Headphone' 90% unmute
When audio playback is working to both speakers and headphone jack, enable Auto-Mute
amixer -c0 sset 'Auto-Mute Mode' Enabled
I also suggest:
sudo mhwd-kernel -i linux61
rm ~/.config/pulse/pulse.cookie ~/.config/pulse/*.tdb
