No sound after fresh install
I have installed Manjaro kde 20.2 on my Asus Zenbook 14 UM433IQ. I am not getting any sound. What do I need to provide in order for someone to help me with this issue? Thanks in advance
Hi daakbahok,
Welcome to the forum! Please read this post on how to provide good information.
here is the output from inxi -Fazy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=be1d827c-145b-4113-84f3-854267aad632 rw quiet
  acpi_backlight=vendor apparmor=1 security=apparmor
  resume=UUID=5ad608f6-3bbd-4502-b22d-3dab48e2c0a9 udev.log_priority=3
  snd-intel-dspcfg.dsp_driver=1
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: ZenBook UX434IQ_UM433IQ v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: UX434IQ v: 1.0 serial: <filter>
  UEFI: American Megatrends v: UX434IQ_UM433IQ.302 date: 07/10/2020
  ID-1: BAT0 charge: 29.8 Wh condition: 49.4/50.0 Wh (99%) volts: 11.9/11.9
  model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
  cycles: 30
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
  status: Discharging
  Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 L2 cache: 4 MiB
  bogomips: 31959
  Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1397 4: 1398 5: 1397 6: 1397 7: 1397 8: 1397
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: disabled, RSB filling
  Device-1: NVIDIA GP107M [GeForce MX350] vendor: ASUSTeK driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:1c96
  Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
  bus ID: 04:00.0 chip ID: 1002:1636
  Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
  bus ID: 3-2:2 chip ID: 13d3:56cb serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
  driver: amdgpu,ati,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
  diag: 355mm (14")
  OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.0)
  v: 4.6 Mesa 20.3.1 direct render: Yes
  Device-1: AMD driver: snd_hda_intel v: kernel bus ID: 04:00.1
  chip ID: 1002:1637
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
  driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 04:00.5
  chip ID: 1022:15e2
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
  bus ID: 02:00.0 chip ID: 8086:2723
  Local Storage: total: 953.87 GiB used: 28.1 GiB (2.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
  size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 42B2S7JA temp: 26.9 C
  ID-1: / raw size: 146.48 GiB size: 143.19 GiB (97.75%)
  used: 21.5 GiB (15.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw size: 550 MiB size: 546 MiB (99.27%)
  used: 41.6 MiB (7.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw size: 570.31 GiB size: 560.36 GiB (98.26%)
  used: 6.56 GiB (1.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p4 maj-min: 259:4
  System Temperatures: cpu: 35.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  GPU: device: amdgpu temp: 35.0 C device: nouveau temp: 34.0 C
  Processes: 301 Uptime: 2m wakeups: 52 Memory: 15.13 GiB
  used: 1.76 GiB (11.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.0 Packages: pacman: 1793 lib: 426 flatpak: 0 Shell: Zsh v: 5.8
  running in: konsole inxi: 3.2.01
Here is a driver missing.
So what do I need to do? some instructions would be helpful.
Kernel: 5.9.16-1 was marked End Of Life in [Stable Update] 2020-12-30 announcement
I suggest you use Manjaro Settings Manager to install kernel v5.10
manjaro-settings-manager -m msm_kernel
then reboot system and check inxi again
Another user had problems with AMD Raven/Raven2/FireFlight/Renoir Audio Processor audio last year has posted today that kernel update resolved their audio problem
Thanks, will try it. I had installed 5.10 a few days ago but had blank screen (I later saw that it was known issue and there is a solution to resolve it). Will try later today and report back
Hi, I reveived my device today and also have no sound. A card is present in the system but no output. I also tried plugging in some headphones. They get recognized but also do not produce any sound at all.
I tried with the latest beta kernel but also no sound.
Here is my inxi
  Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=41ac020a-fd2c-4ba4-9c9e-c6b9df4f7e7b ro quiet apparmor=1
  Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  serial: <filter>
  ID-1: BAT0 charge: 48.6 Wh condition: 48.6/50.0 Wh (97%) volts: 11.9/11.9
  model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
  cycles: 1
  bogomips: 31952
  Speed: 1569 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
  1: 1569 2: 1449 3: 1654 4: 3657 5: 1397 6: 1397 7: 1397 8: 1397
  Device-1: NVIDIA GP107M [GeForce MX350] vendor: ASUSTeK driver: nvidia
  v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1c96
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa display ID: :0 screens: 1
  diag: 355mm (14")
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.7-3-MANJARO LLVM 11.0.1)
  v: 4.6 Mesa 20.3.3 direct render: Yes
  chip ID: 1002:1637
  chip ID: 1022:15e2
  Sound Server: ALSA v: k5.10.7-3-MANJARO
  Local Storage: total: 476.94 GiB used: 10.69 GiB (2.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000
  size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: FXV7000Q temp: 53.9 C
  ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%)
  used: 10.69 GiB (2.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  System Temperatures: cpu: 64.5 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (RPM): cpu: 3200
  Processes: 262 Uptime: 7m wakeups: 521 Memory: 15.13 GiB
  used: 2.54 GiB (16.8%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
  pacman: 1253 lib: 376 flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole
  inxi: 3.2.02
