No Icon Themes loading after update on XFCE
I just updated the system, but things didn’t go well like every time. It broke again, lightdm wasn’t starting, so I spent 2 hours fixing it up, then after I got into the system all the icons are messed, they are like default icons, so I went in appearance and tried to change to my icon theme, but all of the icon themes were looking same (with little difference) as default one, I downloaded few more icon themes to try but none of them are working, it’s showing it’s enabled but nothing is happening the ugly default icons remain the same and most of the icons are missing. I’ve again looking for more than 2 hours but can’t find anything. My guess is, still some issue with lightdm, it’s not able to render the icons or something. But I’m complete noob in Linux stuff all I know is how to google stuff when something goes wrong. But not able to find anything this time.
And I also did this, after looking at some forum
sudo gtk-update-icon-cache ~/.icons/WhiteSur
but this broke the icon settings, now I can’t open ‘settings < appearance’ or choose any icon, it just lags and crashes.
Please guide me on how to fix this, thanks for your time, and I don’t really know what kind of system info I should attach with the questions, so sorry for that
❯ inxi --admin --verbosity=7 --filter --no-host --width        ─╯
  Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
  root=UUID=4c33371e-a8f8-4d60-af19-33d087bc242a rw quiet
  resume=UUID=c354d7fe-c683-4a11-822b-281aff9f0021 udev.log_priority=3
  snd_hda_intel.dmic_detect=0
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
  wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
  base: Arch Linux
  Type: Portable System: Dell product: Inspiron 3542 v: N/A serial: <filter>
  Chassis: type: 8 serial: <filter>
  Mobo: Dell model: 0KHNVP v: A14 serial: <filter> BIOS: Dell v: A14
  date: 05/23/2018
  ID-1: BAT0 charge: 8.9 Wh (40.3%) condition: 22.1/41.4 Wh (53.4%)
  volts: 16.1 min: 14.8 model: SMP-SDI2.8 DELL FW1MN31 type: Li-ion
  serial: <filter> status: Charging
  RAM: total: 3.74 GiB used: 2.41 GiB (64.4%)
  Info: Dual Core model: Intel Core i3-4005U bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
  L2: 3 MiB bogomips: 13574
  Speed: 798 MHz min/max: 800/1700 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
  4: 798
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
  fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
  monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
  sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
  xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-1.5:3 chip-ID: 0bda:5756 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
  v: 4.5 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
  Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Dell driver: ath9k v: kernel port: f040 bus-ID: 06:00.0
  chip-ID: 168c:0036 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-1.6:20 chip-ID: 0cf3:0036 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 9 state: up address: see --recommends
  Local Storage: total: 465.76 GiB used: 111.02 GiB (23.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WD5000LPVX-75V0TT0 size: 465.76 GiB block-size: physical: 4096 B
  logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
  rev: 1A01 scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW SU-208FB rev: D200
  dev-links: cdrom
  ID-1: / raw-size: 100 GiB size: 97.93 GiB (97.93%) used: 23.85 GiB (24.4%)
  fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 4c33371e-a8f8-4d60-af19-33d087bc242a
  ID-2: /boot raw-size: 512 MiB size: 487.9 MiB (95.30%)
  used: 100.3 MiB (20.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 96f064ac-ac8e-482b-82b2-c78b729cf416
  ID-3: /home raw-size: 359.26 GiB size: 352.62 GiB (98.15%)
  used: 86.77 GiB (24.6%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
  uuid: 17676bf6-5c1b-4a77-b3ca-a9fa642f7368
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 6 GiB used: 312.6 MiB (5.1%) priority: -2
  dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: c354d7fe-c683-4a11-822b-281aff9f0021
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Device-1: 1-1.5:3 info: Realtek Integrated_Webcam_HD type: Video
  Device-2: 1-1.6:20 info: Qualcomm Atheros AR9462 Bluetooth type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
  Device-3: 1-1.8:5 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 70.0 C mobo: 65.0 C
  Fan Speeds (RPM): cpu: 3958
  Processes: 261 Uptime: 2d 8h 20m wakeups: 14 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1371
  lib: 425 Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.06
:+1: Welcome to Manjaro! :+1:
  1. Does this also happen if you create a new user profile and log in there?(E.G. random-pickle2) If yes, go to step #2 below. If no, please reply: I might have a workaround for you…
  2. Please read this:
    How to provide good information
    and press the three dots below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  3. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
The problem persists even with a new user.
I’m proving the the required Information…
Then you have an XFCE specific issue I can’t help you any further with, so the only thing I can do for you is edit your title to attract and XFCE expert.
:sob:
Look here
It’s a link to another forum post.
That was even just today and it looks like it could help you restore the default look
that somehow vanished during your efforts to fix your issue.
Sadly no effect after following this solution :frowning:
I don’t understand why this is happening, is there any cache for icons that got saved as default icon theme? I saw in logs when I did pacman -Syu, something like building or saving icon cache.
Really feeling helpless, tried many things but none worked
Thanks man, you did what you could :+1:
How did you install that icon theme?
AUR?
From some other source? There are several that I could find.
Maybe you just need to rebuild it?
and that right there could have been a big slipup - why would you run that command as root?
Unless you actually have icons installed there in that directory:
remove it
or at least make sure the ownership is not messed up
and then run the command again without sudo
rule #1 Do NOT run random commands found on the internet unless you know what you are doing.
I installed from some other source, i.e. downloaded from a site, it worked fine for months, all went wrong after the update.
I read in a forum, it was for rebuilding the icon cache,
So I ran it, but asked for root permission that’s why I ran with Sudo,
But this command did no changes to my system that I know, the issue was existing from before this command, I ran it few days later but nothing much happened, just little lag on startup of settings < appearance
And I don’t think ownership is messed
How can I rebuild it?
I know that, I was told it will update/rebuild the icon cache, and the issue will be solved, but it didn’t worked
How do you know?
… because you previously said:
which to me means that it clearly did something …
I was hoping that you would tell us from where exactly - and what you did to install it. :wink:
It seems to have been installed inside your $HOME directory only, not system wide.
What does
ls -hl $HOME/.icons/WhiteSur
say?
Is the file named “icon-theme.cache”
which should be there,
owned by you or by root?
This is the Icon theme I installed
And yes, icon-theme.cache exists in the directory
And it was working fine being in my $HOME for a long time.
I just went to that site, clicked on the “Files (8)” link, chose “01-WhiteSur.tar.xz”, downloaded it, unpacked it into $HOME/.icons (which I had to create first) - and it all works.
How did you install it?
There is also a link to github, where it came from.
If you used that, it would have been installed either system wide to
/usr/share/icons
or into
$HOME/.local/share/icons
Since it works for me I can only speculate why it wouldn’t work for you.
You might need to choose a different “Style” along with the icons?
I’m fresh out of ideas.
Sorry!
The theme is fine, and it doesn’t matter if it’s system-wide or user only, in this case, there’s something else wrong,
See all themes look the same
and I already have a style
I’m not trying to argue, but they don’t look all the same.
Most of those that you showed here are variants of the Papirus theme, of course they look similar. :wink:
… in that list, your theme should be listed further down if it is correctly installed
Is it listed?
I personally use the Numix style with the elementary Xfce dark icon set.
You seem to be using some theme reminiscent of MacOS - maybe that is somehow causing your trouble? Don’t know.
There is also another place where a style can be chosen - in addition to “Appearance” - under “Window Manager”, but that refers to how dialogs and buttons look.
… experiment - I can’t advise further
All the manually installed themes are listed and all are looking same even if they are not variant of Papirus :[
No themes worked I’ve tried,
I also tried, lxappearance to apply them,
Anyways glad you tried to help. Have a good day.
Very strange.
The only way that could be is when all the different names of themes exist as symlinks only - all pointing to one and the same theme.
To accomplish this by accident seems very unlikely.
But even in your picture - they don’t look the same.
Have you checked what is inside /usr/share/icons and in the directories below?
Same thing for $HOME/.icons and below that?
Are there actual files - and different ones - in there?
The file manager will show you the icons
or
ls -al /usr/share/icons
and
ls -al $HOME/.icons
in a terminal
ls -al /usr/share/icons/*
will print a list of everything that is in each directory
same for what is installed in your $HOME
ls -al $HOME/.icons/*
Again:
maybe the MacOS window theme (with the red,yellow, green buttons in the title bar)
is demanding specific icons?
Could it be? I don’t know.
What if you change that and see whether your icons then can actually be changed, too? :wink:
