Hi all,
Been scratching my head for a few days over this one. I inadvertently put my machine (Lenovo IdeaPad Flex 5) to sleep a few days ago and when I opened it again, everything was frozen. I turned the machine off using the power button and since then I haven’t been able to connect to wifi (no connections available). I’ve tried everything I’ve seen on the forums including disabling MAC randomization (Realtek Wifi not working rtw_8822ce - #10 by garvitjoshi9 ), installing the rtl8822ce package + headers (Wifi adapter not found RTL8821CE - #2 by Strit ), cold restart (Can't enable wifi, no connections available ) and blacklisting some other drivers (No available Wi-Fi Network Detected - #58 by ldhacker ).
Below is my output from inxi:
[stefan@stefan-81x2 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5678b701-6a76-405e-960b-061f1a0970f9 rw quiet apparmor=1
security=apparmor udev.log_priority=3 i915.enable_dpcd_backlight=0
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
serial: <superuser required> UEFI: LENOVO v: EECN20WW date: 04/08/2020
ID-1: BAT0 charge: 31.3 Wh (68.6%) condition: 45.6/52.5 Wh (86.9%)
volts: 11.7 min: 11.5 model: Celxpert L19C3PD6 type: Li-poly
serial: <filter> status: Discharging cycles: 145
RAM: total: 15.07 GiB used: 3.09 GiB (20.5%)
RAM Report:
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600102
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1537 high: 1939 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1588 2: 1397
3: 1397 4: 1383 5: 1939 6: 1521 bogomips: 28455
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 5986:212a class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce,wl port: 2000
bus-ID: 02:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-2:2 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0f4u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
IP v6: <filter> scope: link
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 344.71 GiB (72.3%)
model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: 3L1QEXF7 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 344.71 GiB (73.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5678b701-6a76-405e-960b-061f1a0970f9
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4DDF-225F
ID-3: /home/<filter>/onedrive raw-size: N/A size: 5 TiB
used: 52.75 GiB (1.0%) fs: fuse.rclone remote: onedrive:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-4:2 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:212a
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55b4 class-ID: ef00
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 42.0 C mobo: 40.0 C gpu: amdgpu temp: 38.0 C
Processes: 250 Uptime: 14m wakeups: 4 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1967 pacman: 1934 lib: 460
flatpak: 16 snap: 17 Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
Nothing appears to be blocked in rfkill:
[stefan@stefan-81x2 ~]$ rfkill list all
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Any advice or directions are greatly appreciated, many thanks.
Hanzel
15 December 2021 09:52
2
Some observations from the inxi:
Adding some swap will probably not cause the issue with sleep
According to the chip-id and the linux hardware database you are on the right track to solving this issue.
One thing to try is a LTS kernel, like 5.10 and check what that does?
Thanks for your reply Hanzel, adding the swap was a great idea. I also switched my kernel to 5.10. Below are the new outputs from inxi
. I still have no available connections, and I re-tried strategies from other posts to no avail.
Kernel: 5.10.83-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
ID-1: BAT0 charge: 27.3 Wh (59.3%) condition: 46.0/52.5 Wh (87.7%)
volts: 11.6 min: 11.5 model: Celxpert L19C3PD6 type: Li-poly
RAM: total: 15.07 GiB used: 2.57 GiB (17.1%)
RAM Report:
desc: 2x4 MiB
Speed (MHz): avg: 1397 high: 1400 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1397 5: 1400 6: 1397 bogomips: 28455
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:5
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Sound Server-1: ALSA v: k5.10.83-1-MANJARO running: yes
IF-ID-1: enp4s0f3u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) type: USB
driver: rndis_host v: kernel bus-ID: 1-2:7 chip-ID: 04e8:6863 class-ID: 0a00
serial: <filter>
Device-2: Realtek Bluetooth Radio type: USB driver: N/A bus-ID: 3-4:3
Local Storage: total: 476.94 GiB used: 348.76 GiB (73.1%)
rev: 3L1QEXF7 temp: 38.9 C scheme: GPT
used: 348.76 GiB (74.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
uuid: 4DDF-225F
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-2: 1-1:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 1-1.2:4 info: Primax USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d22 class-ID: 0301
Device-2: 1-1.3:6 info: Dell KB212-B Quiet Key Keyboard type: Keyboard
power: 100mA chip-ID: 413c:2107 class-ID: 0301
Device-3: 1-2:7 info: Samsung Galaxy series misc. (tethering mode)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 96mA chip-ID: 04e8:6863 class-ID: 0a00
serial: <filter>
Device-4: 1-4:5 info: Acer Integrated Camera type: Video driver: uvcvideo
class-ID: 0e02
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: N/A
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:c123
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.8 C mobo: 38.0 C gpu: amdgpu temp: 38.0 C
Processes: 284 Uptime: 17m wakeups: 3 Init: systemd v: 249 tool: systemctl
Also here is some output from mhwd
if it is of any use to anyone:
[stefan@stefan-81x2 ~]$ mhwd -lh -d --pci | grep -A 30 "Ethernet"
14: PCI 200.0: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:02.2/0000:02:00.0
SysFS BusID: 0000:02:00.0
Hardware Class: network
Model: "Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0xc822 "RTL8822CE 802.11ac PCIe Wireless Network Adapter"
SubVendor: pci 0x17aa "Lenovo"
SubDevice: pci 0xc123
Driver: "rtw_8822ce"
Driver Modules: "rtw88_8822ce"
Device File: wlp2s0
I/O Ports: 0x2000-0x20ff (rw)
Memory Range: 0xfc700000-0xfc70ffff (rw,non-prefetchable)
IRQ: 80 (1 event)
HW Address: 1c:bf:c0:0c:ce:9b
Permanent HW Address: 1c:bf:c0:0c:ce:9b
Link detected: no
Module Alias: "pci:v000010ECd0000C822sv000017AAsd0000C123bc02sc80i00"
Driver Info #0:
Driver Status: rtw88_8822ce is active
Driver Activation Cmd: "modprobe rtw88_8822ce"
Driver Info #1:
Driver Status: rtw_8822ce is active
Driver Activation Cmd: "modprobe rtw_8822ce"
Driver Info #2:
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
Attached to: #32 (PCI bridge)
Well, after a few more days of wrestling with this I couldn’t find a cause or solution. I just re-installed and everything is working great again.
system
Closed
20 December 2021 20:21
5
