Hello all, been needing a bit of help, have been at it for a good few hours. I got a new PC and my first instinct was, of course, Manjaro. Wi-Fi doesn’t work automatically, no biggie, I’ll download the drivers. Well, I’ve tried both broadcom-wl and broadcom-wl-dkms and neither seem to work. My WiFi card is detected as hardware. WL is running and active. There is simply zero WiFi interface or connection though and I am extremely confused as to why … I’m not even getting any errors (from what I can tell), updated kernel, and headers both to 6.6.26-1, both packages are fully updated with DKMS fully installed as well. I’ve tried all steps listed here multiple times to no luck: https://web.archive.org/web/20210124061531/https://archived.forum.manjaro.org/t/broadcom-wifi-driver-fails-to-install-properly/46316 – This will be a lot so thanks a lot in advance, please let me know if any logs or additional info is needed.
$uname -a
Linux leonis 6.6.26-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Apr 10 20:11:08 UTC 2024 x86_64 GNU/Linux
$ inxi -Fxxxza:
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF-ID-1: enp0s20f0u5i1 state: up speed: 425 Mbps duplex: half
mac: <filter>
Info: services: NetworkManager
$ dkms status:
broadcom-wl/6.30.223.271, 6.6.26-1-MANJARO, x86_64: installed
$ rfkill list all:
no output. Doesn’t hang, just nothing,
$ lspci -vnn -d 14e4:43a0
05:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4360 802.11ac Dual Band Wireless Network Adapter [14e4:43a0] (rev 03)
Subsystem: Broadcom Inc. and subsidiaries BCM4360 802.11ac Dual Band Wireless Network Adapter [14e4:0619]
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at 82400000 (64-bit, non-prefetchable) [size=32K]
Memory at 82200000 (64-bit, non-prefetchable) [size=2M]
Capabilities: <access denied>
Kernel driver in use: wl
Kernel modules: bcma, wl
$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 04:7c:16:01:8e:0e brd ff:ff:ff:ff:ff:ff
3: enp0s20f0u5i1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether 6a:f1:ce:a1:41:3f brd ff:ff:ff:ff:ff:ff
$ sudo dmesg | grep -Ei 'b43|bcma|brcm|wl|[F]irm|deauth'
[ 1.507268] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.20.0
[ 1.507276] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[ 1.507328] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adls_dmc_ver2_01.bin (v2.1)
[ 24.826731] wl: loading out-of-tree module taints kernel.
[ 24.826735] wl: module license 'MIXED/Proprietary' taints kernel.
[ 24.826736] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 24.826737] wl: module license taints kernel.
[ 24.830623] wl 0000:05:00.0: enabling device (0000 -> 0002)
[ 24.845290] Missing ENDBR: otp_read_bit+0x8ce/0x106c [wl]
[ 24.845361] RIP: 0010:otp_read_bit+0x8ce/0x106c [wl]
[ 24.845389] ? otp_init+0xa5/0xc3 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845407] otp_read_word+0x51/0x9d [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845425] ? si_set_sromctl+0x50/0x5b [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845451] wlc_phy_attach_acphy+0x164d/0x182d [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845493] ? wl_init_timer+0x6a/0xa0 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845533] wlc_phy_attach+0x818/0xfc2 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845575] ? osl_malloc+0x1d/0x50 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845613] wlc_bmac_attach+0x8ee/0x1215 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845649] ? osl_malloc+0x1d/0x50 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845691] ? wlc_scan_attach+0x161/0x1b9 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845731] wlc_attach+0x283/0x1a93 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845765] wl_pci_probe+0x2a0/0xf50 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
[ 24.845801] ? __UNIQUE_ID_vermagic197+0x36ffbc52f853/0x36ffbc52f853 [wl 6b6bc0ab06cd445651d23e7dc80a1b1c0a7df2ed]
$ grep -r "blacklist\|install\|options" /etc/modprobe.d/
/etc/modprobe.d/blacklist.conf:blacklist b43
/etc/modprobe.d/blacklist.conf:blacklist b43legacy
/etc/modprobe.d/blacklist.conf:blacklist ssb
/etc/modprobe.d/blacklist.conf:blacklist bcm43xx
/etc/modprobe.d/blacklist.conf:blacklist brcm80211
/etc/modprobe.d/blacklist.conf:blacklist brcmfmac
/etc/modprobe.d/blacklist.conf:blacklist brcmsmac
/etc/modprobe.d/blacklist.conf:blacklist bcma
$ pacman -Qsq linux | grep linux | grep -v -E '(arch|util|sys|api|firmware)' | grep -v nvidia
linux66
linux66-headers
$ hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
Model: "Broadcom BCM4360 802.11ac Wireless Network Adapter"
Driver: "wl"
Driver Status: bcma is not active
Driver Activation Cmd: "modprobe bcma"
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
Driver: "r8169"
Device File: enp4s0
Link detected: no
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Model: "Google Pixel 6"
Driver: "cdc_ncm"
Device File: enp0s20f0u5i1
Link detected: yes
Driver Status: cdc_ncm is active
Driver Activation Cmd: "modprobe cdc_ncm"
Driver Status: cdc_mbim is active
Driver Activation Cmd: "modprobe cdc_mbim"
