Continuing the discussion from Microphone disappeared after changing audio profile :
It happened exactly like with this user, I tried to remove the alsa folder in .config, but when I tried to search for it, it does not exist, just pulse
Only when I reinstall the
alsa-card-profiles
This is when the sound and me device detect again
Please post more information about system
inxi -Fazy
and audio card profiles available in PulseAudio or PipeWire
pactl list sinks
Ok, Thanks.
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=1e904ed4-424d-49c2-83bb-eb10a296828a rw splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: Acer product: Aspire A315-56 v: V1.26
serial: <superuser required>
Mobo: IL model: Sleepy_IL v: V1.26 serial: <superuser required>
UEFI: Insyde v: 1.26 date: 12/29/2021
ID-1: BAT1 charge: 31.5 Wh (88.7%) condition: 35.5/41.6 Wh (85.3%)
volts: 12.3 min: 11.2 model: LGC AP19B8K type: Li-ion serial: N/A
status: discharging
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC2
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 400 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 9524
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
class-ID: 0300
Device-2: Quanta VGA WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 0408:a031
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 11.21 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:8a56 surfaces: xcb,xlib
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Local Storage: total: 465.76 GiB used: 60.69 GiB (13.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS1031 500GB SSD
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CS103C00 temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 60.69 GiB (13.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 198 Uptime: 1m wakeups: 0 Memory: total: 12 GiB
available: 11.48 GiB used: 2.31 GiB (20.2%) Init: systemd v: 254
Packages: 1366 pm: pacman pkgs: 1359 libs: 438 tools: pamac pm: flatpak
pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Sink #52
State: SUSPENDED
Description: Dummy Output
Driver: PipeWire
Sample Specification: float32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 56411 / 86% / -3,91 dB, front-right: 56411 / 86% / -3,91 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: auto_null.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
node.name = "auto_null"
device.description = "Dummy Output"
audio.rate = "48000"
audio.channels = "2"
audio.position = "FL,FR"
media.class = "Audio/Sink"
factory.name = "support.null-audio-sink"
node.virtual = "true"
monitor.channel-volumes = "true"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "51"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "52"
object.serial = "52"
Formats:
pcm
Until now the problem continues, the sound category is without any options.
Dummy Output is created by PipeWire (or PulseAudio) if there is no audio output available for audio playback
Please post more information to show if onboard audio device is detected in PipeWire
pactl list cards
and more information to show ALSA audio controls for onboard audio device
amixer --card=0
Despite searches within the wiki and some KDE Plasma forums, a total solution for this problem has not been found.
Changing the profile usually results in editing the sound card output, which can cause loss of the sound card connection.
What I consider strange is not having an alsa folder with those configurations, in a previous installation I remember having it, unless it has been modified through Manjaro.
I had to resort to reinstalling the system since it became a loop of problems constantly reinstalling the mentioned package. It is a moderately new installation since I had to change storage disk recently. Although I personally dislike reinstalling for such simple things.
I even remember doing a How To a long time ago from the same forum, only that without the existence of the folder there is nothing to restore. If anyone has this problem and the folder exists, I would recommend doing what is mentioned in this How To.
$ Este articulo es mas relevante para un error común que suele pasar:
Puede que un dia hallas estado experimentando o diste con un problema con el sonido que realmente podría ser tu Dispositivo, y que hallas alterado el formato de salida u entrada del mismo.
En esta sección especifica:
[Example]
Alterar estas salidas a uno no compatible hará que pierdas tu dispositivo de sonido en KDE ya que no es una salida que Plasma pueda reconocer y entrara en conflicto.
La Solución para esto es algo s…
