No audio from internal speakers KDE Asus Zenbook
I have a recent install of Manjaro KDE. I am getting audio from bluetooth but not internal speakers. Windows is fine.
I’ve checked that they aren’t muted, and have tried to test the audio in system settings.
I replaced pulseaudio with manjaro-pipewire, but this didn’t help.
Here are the threads I’ve checked so far:
Upload from sudo alsa-info.sh --upload :
http://alsa-project.org/db/?f=18abdaf7740db3699877c557cf6a46687233a241
System info:
[manjaro@manjaro ~]$ inxi -Fazy
  Kernel: 6.1.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=24a7d751-12cc-4b32-a731-708d2714f659 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Type: Laptop System: ASUSTeK product: Zenbook UM3402YAR_UM3402YA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UM3402YAR v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: UM3402YAR.204 date: 12/08/2022
  ID-1: BATT charge: 45.2 Wh (61.0%) condition: 74.1/75.4 Wh (98.4%) volts: 8.0
    min: 8.0 model: ASUSTeK UM3402 type: Li-ion serial: <filter>
    status: discharging cycles: 3
  Info: model: AMD Ryzen 5 7530U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000D
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1663 high: 2832 min/max: 1600/4547 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1386 2: 2832
    3: 1444 4: 1600 5: 1380 6: 2000 7: 1347 8: 1392 9: 1600 10: 1600 11: 1380
    12: 2000 bogomips: 47923
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Barcelo vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300
    temp: 42.0 C
  Device-2: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 3277:0010
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 res: 1707x1067 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
    15.0.7 DRM 3.49 6.1.29-1-MANJARO) direct-render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.29-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: 1: pipewire-pulse
    status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
  Device-1: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 14c3:7922
    class-ID: 0280
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3568
  Local Storage: total: 476.94 GiB used: 10.23 GiB (2.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 237.74 GiB size: 232.95 GiB (97.99%) used: 10.19 GiB (4.4%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 45.8 MiB (17.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 48.2 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Processes: 300 Uptime: 58m wakeups: 830 Memory: available: 15.03 GiB
  used: 5.61 GiB (37.3%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1144 libs: 327 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
This:
https://wiki.archlinux.org/title/ASUS_Zenbook_UM3402YAR
Which links sound issue to this:
Have fun. :slight_smile:
PS
:warning: Do note you have a BIOS upgrade available and you should commit that before following the guide.
