I have no sound from laptop speakers
first code.
i have used linux for over 10 years (linux mint), and recently got a new computer asus zenbook).
linuxmint has many issues to get it running properly (sound, hdmi related), and on the internet i saw recommendations on using manjaro for this computer.
i am currently testing it on a livedisk, and get no sound from the built in speakers, but the headphones work.
below is my system details:
[manjaro@manjaro ~]$ inxi -Fazy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  misobasedir=manjaro misolabel=MANJARO_XFCE_2021 quiet systemd.show_status=1
  apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1
  radeon.modeset=1
  Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: ZenBook UX325EA_UX325EA v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: UX325EA v: 1.0 serial: <filter>
  UEFI: American Megatrends LLC. v: UX325EA.207 date: 09/14/2020
  ID-1: BAT0 charge: 67.8 Wh condition: 67.8/67.1 Wh (101%) volts: 15.9/15.9
  model: ASUSTeK UX325 type: Li-ion serial: <filter> status: Full
  Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 56
  L2 cache: 12 MiB
  bogomips: 44864
  Speed: 1400 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 1400 2: 1400
  3: 1400 4: 1345 5: 1400 6: 1400 7: 1400 8: 1207
  Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 0000:00:02.0 chip ID: 8086:9a49
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus ID: 3-6:3 chip ID: 13d3:56eb serial: <filter>
  Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
  alternate: fbdev,vesa display ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
  diag: 336mm (13.2")
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 20.3.1
  direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
  driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci
  bus ID: 0000:00:1f.3 chip ID: 8086:a0c8
  Device-2: ESS Asus USB DAC type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-4:5 chip ID: 0495:3042
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
  bus ID: 0000:00:14.3 chip ID: 8086:a0f0
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
  v: 0.6 port: 3000 bus ID: 0000:00:0e.0 chip ID: 8086.9a0b rev: N/A
  Local Storage: total: 961.33 GiB used: 222.2 MiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
  size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 004C temp: 33.9 C
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Toshiba model: TransMemory
  size: 7.46 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.00
  ID-1: / raw size: N/A size: 11.51 GiB used: 222.2 MiB (1.9%) fs: overlay
  source: ERR-102
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 255 Uptime: 8m wakeups: 680 Memory: 15.34 GiB
  used: 2.01 GiB (13.1%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
  pacman: 1203 lib: 370 flatpak: 0 Shell: Bash v: 5.1.0
  running in: xfce4-terminal inxi: 3.2.01
what should i do ?
thank you
Have you asked for help on Linux Mint forum ?
they have a good expert (Mr Een) for troubleshooting audio
If you have Linux Mint installed you should get a full ALSA diagnostic from installed OS
sudo alsa-info.sh --upload
and post the link to the ALSA data to Mint forum
You could run the same ALSA diagnostic on the Manjaro ISO and post it here
but it may not be possible to add a fix or workaround to the live ISO
and audio hardware may work better once OS is installed and updated
nikgnomic, thank you for your suggestion.
yes, MrEen did hel me a lot and got sound working, but internal mike and hdmi ooutput did not work.
so i came to try an arch distro instead.
i have installed the Manjaro OS, and am now facing a problem booting into it, which i have posted on the installation sub forum
tks
nals
