Received notification with new updates available. Updated all.
What can be causing the problem?
You tell us. What’s the output running nicotine from the terminal?
Please see:
sorry, completely forgot to check that. here it is:
File “/usr/bin/nicotine”, line 38, in
ApplyTranslation()
File “/usr/lib/python3.8/site-packages/pynicotine/utils.py”, line 250, in ApplyTranslation
locale.setlocale(locale.LC_ALL, ‘’)
File “/usr/lib/python3.8/locale.py”, line 608, in setlocale
return _setlocale(category, locale)
locale.Error: unsupported locale setting
It’s an upstream issue that was already fixed in a recent commit. Install nicotine-plus-git from the AUR for now.
when trying to build nicotine-plus-git: “Failed to build python-pytaglib”
I’ll take a look when I get home from work.
In the meantime, please create a new topic in #support:aur since this is a separate issue.
I just discovered it has to do with the locale settings being broken with the update. It happened again.
Solved through other post. Can’t link it.
Sure you can:
Thanks!
This was the solution to locale problem: ht!tps://archived.forum.manjaro.org/t/trouble-setting-up-locale/121209/7
