Hello, I can’t seem to watch Netflix in Firefox nor Chromium browsers.
See attached image.
I’ve read something about DRM plugins but I don’t seem to find to enable it on firefox nor Chromium.
Help, newbiew here. Thanks!
See attached image.
Netflix (and other Widevine content) only works on armv7h software.
To get around this, you can install chromium-docker from the repo, which will set up an armv7h chromium installation with Widevine.
Thank you for quick response @Strit
I installed chromium-docker, but I got this error:
Here’s the script from chromium-armhf:
I don’t understand what’s going on here. What argument am I missing? (I did not change anything in the script file.)
Thanks!
@spikerguy any idea?
Yes,
Looks like the pkgs.install was not completed.
Remove the pkg
sudo pacman -R chromium-docker
Install it again
sudo pacman -S chromium-docker
Share the installation output. I think it should install fine on the second attempt.
Dang, it didn’t work for me either the first time… lol, all I had to do was try twice??! hahaha.
Anyway, it’s worth understanding the technical reason for this. There’s no aarm64 version of widevine available right now so the strategy of getting an armv7h library from a chromebook restore image and using the binary won’t work. This is also why Raspberry Pi OS has this working out of the gate: it’s arm 7 hard float 32bit and chromium has a widevine extension installed already. Having said that, it didn’t work last time I tried on hulu because location services were broken on google apis for the arm chromium api key.
Long story short, arm widevine works on phones all the time and chromebook all the time, but there isn’t any current native solution on aarm64 yet, but there will be soon, but right now, we’re a little too fringe to partake in the DRM goodness.
It finally worked. Thanks @spikerguy
Here’s the installation output:
resolving dependencies...
Packages (1) chromium-docker-4.10.1610.6-3
Total Installed Size: 0.14 MiB
(1/1) checking keys in keyring [#######################################################################################] 100%
(1/1) checking package integrity [#######################################################################################] 100%
(1/1) loading package files [#######################################################################################] 100%
(1/1) checking for file conflicts [#######################################################################################] 100%
(1/1) checking available disk space [#######################################################################################] 100%
(1/1) installing chromium-docker [#######################################################################################] 100%
groupadd: group 'docker' already exists
Cloning docker-chromium-armhf from Git Repo
Cloning into '/usr/share/chromium-docker/git'...
remote: Enumerating objects: 246, done.
Receiving objects: 29% (72/246), 68.77 MiB | 6.60 MiB/s
Receiving objects: 65% (160/246), 68.77 MiB | 6.60 MiB/s
Receiving objects: 92% (227/246), 118.85 MiB | 6.07 MiB/s
remote: Total 246 (delta 0), reused 0 (delta 0), pack-reused 246
Receiving objects: 100% (246/246), 130.88 MiB | 5.06 MiB/s, done.
Resolving deltas: 63% (77/121)
Resolving deltas: 100% (121/121), done.
Downloading ChromeOs - Will take sometime
chromeos_12739.111. 3%[ ] 36.09M 7.02MB/s eta 2m 7s
chromeos_12739.111. 7%[> ] 68.09M 6.07MB/s eta 2m 17s
chromeos_12739.111. 10%[=> ] 98.60M 5.35MB/s eta 2m 20s
chromeos_12739.111. 12%[=> ] 121.84M 4.87MB/s eta 2m 26s
chromeos_12739.111. 15%[==> ] 152.80M 6.28MB/s eta 2m 21s
chromeos_12739.111. 18%[==> ] 182.65M 6.03MB/s eta 2m 17s
chromeos_12739.111. 21%[===> ] 209.57M 4.74MB/s eta 2m 14s
chromeos_12739.111. 25%[====> ] 242.60M 5.92MB/s eta 2m 7s
chromeos_12739.111. 28%[====> ] 273.85M 5.60MB/s eta 2m 1s
chromeos_12739.111. 31%[=====> ] 306.01M 6.04MB/s eta 1m 56s
chromeos_12739.111. 34%[=====> ] 337.16M 6.27MB/s eta 1m 49s
chromeos_12739.111. 37%[======> ] 367.61M 6.27MB/s eta 1m 44s
chromeos_12739.111. 40%[=======> ] 394.05M 6.14MB/s eta 1m 40s
chromeos_12739.111. 44%[=======> ] 432.84M 6.65MB/s eta 92s
chromeos_12739.111. 48%[========> ] 464.16M 5.83MB/s eta 87s
chromeos_12739.111. 51%[=========> ] 497.13M 5.93MB/s eta 81s
chromeos_12739.111. 54%[=========> ] 529.18M 5.84MB/s eta 76s
chromeos_12739.111. 58%[==========> ] 560.27M 6.10MB/s eta 69s
chromeos_12739.111. 61%[===========> ] 591.96M 5.82MB/s eta 64s
chromeos_12739.111. 64%[===========> ] 621.24M 6.09MB/s eta 59s
chromeos_12739.111. 67%[============> ] 653.07M 5.86MB/s eta 54s
chromeos_12739.111. 70%[=============> ] 686.29M 6.20MB/s eta 48s
chromeos_12739.111. 73%[=============> ] 713.77M 4.88MB/s eta 44s
chromeos_12739.111. 77%[==============> ] 747.27M 5.66MB/s eta 38s
chromeos_12739.111. 80%[==============> ] 772.99M 4.44MB/s eta 34s
chromeos_12739.111. 83%[===============> ] 808.04M 5.78MB/s eta 27s
chromeos_12739.111. 86%[================> ] 840.13M 6.02MB/s eta 22s
chromeos_12739.111. 90%[=================> ] 872.12M 6.11MB/s eta 16s
chromeos_12739.111. 93%[=================> ] 904.60M 6.13MB/s eta 11s
chromeos_12739.111. 96%[==================> ] 935.07M 6.06MB/s eta 6s
chromeos_12739.111. 99%[==================> ] 966.66M 5.99MB/s eta 1s
chromeos_12739.111. 100%[===================>] 967.54M 5.79MB/s in 2m 44s
Extracting
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,64 bits,4 CPUs LE)
Scanning the drive for archives:
1 file, 1014539111 bytes (968 MiB)
Extracting archive: /usr/share/chromium-docker/chromeos_12739.111.0_elm_recovery_stable-channel_mp-v2.bin.zip
Path = /usr/share/chromium-docker/chromeos_12739.111.0_elm_recovery_stable-channel_mp-v2.bin.zip
Type = zip
Physical Size = 1014539111
Everything is Ok
Compressed: 1014539111
1 file, 2321571840 bytes (2215 MiB)
Type = GPT
Physical Size = 2321571840
ID = A8734E1B-69A5-D348-99E3-79185C104D22
Everything is Ok
Compressed: 2321571840
1 file, 2147483648 bytes (2048 MiB)
Extracting archive: /usr/share/chromium-docker/ROOT-A.img
WARNINGS:
There are data after the end of archive
Path = /usr/share/chromium-docker/ROOT-A.img
Type = Ext
WARNINGS:
Physical Size = 2087714816
Tail Size = 59768832
Cluster Size = 4096
Free Space = 604098560
Modified = 2020-03-31 16:15:03
Created = 2020-03-31 14:56:31
Mount Time = 2020-03-31 16:15:00
Last Check Time = 2009-11-20 03:00:00
Host OS = Linux
Revision = 1
inode Size = 256
Code Page = UTF-8
Label = ROOT-A
Last Mounted = /tmp/tmp.pFHw3S6h21
Characteristics = EXT_ATTR RESIZE_INODE DIR_INDEX
Incompatible Features = FILETYPE
Readonly-compatible Features = SPARSE_SUPER LARGE_FILE 0xFF000000
Written KiB = 2248072
Everything is Ok
Archives with Warnings: 1
Warnings: 1
Compressed: 2147483648
Building Docker Image - This will take sometime
Sending build context to Docker daemon 228MB
Step 1/16 : FROM docker.io/arm32v7/ubuntu:bionic
bionic: Pulling from arm32v7/ubuntu
74cafcd4ef02: Pulling fs layer
b11c6b5e0a0a: Pulling fs layer
92494e4cae3e: Pulling fs layer
92494e4cae3e: Verifying Checksum
92494e4cae3e: Download complete
b11c6b5e0a0a: Verifying Checksum
74cafcd4ef02: Verifying Checksum
74cafcd4ef02: Download complete
74cafcd4ef02: Pull complete
b11c6b5e0a0a: Pull complete
92494e4cae3e: Pull complete
Digest: sha256:bbd6b66af80a9bf9c3a8f897bbc27ddf8b39216d37114ac093826c4576088ae0
Status: Downloaded newer image for arm32v7/ubuntu:bionic
---> 6129fe7526d5
Step 2/16 : MAINTAINER Furkan Kardame <furkan@fkardame.com>
---> [Warning] The requested image's platform (linux/arm) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
---> Running in 479873b48e0a
Removing intermediate container 479873b48e0a
---> 2aca620df352
Step 3/16 : ENV DEBIAN_FRONTEND noninteractive
---> Running in edda008e4def
Removing intermediate container edda008e4def
---> 33494e49cb3c
Step 4/16 : RUN apt-get update && apt-get install -y --no-install-recommends git fontconfig fontconfig-config fonts-dejavu-core gconf-service gconf2-common libasn1-8-heimdal libasound2 libasound2-data libatk1.0-0 libatk1.0-data libavahi-client3 libavahi-common-data libavahi-common3 libcairo2 libcups2 libdatrie1 libdbus-1-3 libdbus-glib-1-2 libexpat1 libfontconfig1 libfreetype6 libgconf-2-4 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgmp10 libgnutls30 libgraphite2-3 libgssapi-krb5-2 libgssapi3-heimdal libgtk2.0-0 libgtk2.0-common libharfbuzz0b libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhogweed4 libhx509-5-heimdal libjbig0 libk5crypto3 libkeyutils1 libkrb5-26-heimdal libkrb5-3 libkrb5support0 libldap-2.4-2 libnettle6 libnspr4 libnss3 libp11-kit0 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libpng16-16 libroken18-heimdal libsasl2-2 libsasl2-modules-db libsqlite3-0 libtasn1-6 libthai-data libthai0 libtiff5 libwind0-heimdal libx11-6 libx11-data libxau6 libxcb-render0 libxcb-shm0 libxcb1 libxcomposite1 libxcursor1 libxdamage1 libxdmcp6 libxext6 libxfixes3 libxi6 libxinerama1 libxml2 libxrandr2 libxrender1 libxss1 libxtst6 shared-mime-info ucf x11-common xdg-utils libpulse0 pulseaudio-utils wget libatk-bridge2.0-0 libatspi2.0-0 libgtk-3-0 mesa-va-drivers mesa-vdpau-drivers mesa-utils libosmesa6 libegl1-mesa libwayland-egl1-mesa libgl1-mesa-dri
---> Running in c44a4aca7eff
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease [242 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [74.6 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic/restricted armhf Packages [12.5 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse armhf Packages [157 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf Packages [1277 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf Packages [11.0 MB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf Packages [1310 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/restricted armhf Packages [14.5 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse armhf Packages [7276 B]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe armhf Packages [1759 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe armhf Packages [11.0 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports bionic-backports/main armhf Packages [11.2 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports bionic-security/main armhf Packages [937 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic-security/restricted armhf Packages [7193 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse armhf Packages [2424 B]
Get:18 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe armhf Packages [1087 kB]
Fetched 18.0 MB in 10s (1890 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
libgmp10 is already the newest version (2:6.1.2+dfsg-2).
libhogweed4 is already the newest version (3.4-1).
libnettle6 is already the newest version (3.4-1).
libp11-kit0 is already the newest version (0.23.9-2).
libtasn1-6 is already the newest version (4.13-2).
libgnutls30 is already the newest version (3.5.18-1ubuntu1.4).
The following additional packages will be installed:
adwaita-icon-theme dconf-gsettings-backend dconf-service
gconf-service-backend git-man glib-networking glib-networking-common
glib-networking-services gsettings-desktop-schemas gtk-update-icon-cache
hicolor-icon-theme humanity-icon-theme libapparmor1 libasyncns0 libbsd0
libcairo-gobject2 libcap2 libcolord2 libcroco3 libcurl3-gnutls libdconf1
libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libedit2
libegl-mesa0 libegl1 libelf1 libepoxy0 liberror-perl libflac8 libgbm1
libgdbm-compat4 libgdbm5 libgl1 libglapi-mesa libglib2.0-0 libglvnd0
libglx-mesa0 libglx0 libgtk-3-common libice6 libicu60 libjpeg-turbo8
libjpeg8 libjson-glib-1.0-0 libjson-glib-1.0-common liblcms2-2
libldap-common libllvm10 libnghttp2-14 libogg0 libperl5.26 libproxy1v5
libpsl5 libpulsedsp librest-0.7-0 librsvg2-2 librsvg2-common librtmp1
libsensors4 libsm6 libsndfile1 libsoup-gnome2.4-1 libsoup2.4-1 libssl1.1
libvdpau1 libvorbis0a libvorbisenc2 libwayland-client0 libwayland-cursor0
libwayland-egl1 libwayland-server0 libwrap0 libx11-xcb1 libxcb-dri2-0
libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-sync1 libxcb-xfixes0
libxkbcommon0 libxshmfence1 libxxf86vm1 multiarch-support perl
perl-modules-5.26 ubuntu-mono xkb-data
Suggested packages:
gettext-base git-daemon-run | git-daemon-sysvinit git-doc git-el git-email
git-gui gitk gitweb git-cvs git-mediawiki git-svn libasound2-plugins
alsa-utils colord cups-common gdbm-l10n krb5-doc krb5-user gvfs
liblcms2-utils pulseaudio librsvg2-bin lm-sensors perl-doc
libterm-readline-gnu-perl | libterm-readline-perl-perl make avahi-daemon
Recommended packages:
patch less ssh-client at-spi2-core ca-certificates dbus libgdk-pixbuf2.0-bin
libglib2.0-data xdg-user-dirs libgtk-3-bin libgail-common libgtk2.0-bin
krb5-locales publicsuffix libsasl2-modules netbase libfile-mimeinfo-perl
libnet-dbus-perl libx11-protocol-perl x11-utils x11-xserver-utils
The following NEW packages will be installed:
adwaita-icon-theme dconf-gsettings-backend dconf-service fontconfig
fontconfig-config fonts-dejavu-core gconf-service gconf-service-backend
gconf2-common git git-man glib-networking glib-networking-common
hicolor-icon-theme humanity-icon-theme libapparmor1 libasn1-8-heimdal
libasound2 libasound2-data libasyncns0 libatk-bridge2.0-0 libatk1.0-0
libatk1.0-data libatspi2.0-0 libavahi-client3 libavahi-common-data
libavahi-common3 libbsd0 libcairo-gobject2 libcairo2 libcap2 libcolord2
libcroco3 libcups2 libcurl3-gnutls libdatrie1 libdbus-1-3 libdbus-glib-1-2
libdconf1 libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1
libdrm2 libedit2 libegl-mesa0 libegl1 libegl1-mesa libelf1 libepoxy0
liberror-perl libexpat1 libflac8 libfontconfig1 libfreetype6 libgbm1
libgconf-2-4 libgdbm-compat4 libgdbm5 libgdk-pixbuf2.0-0
libgdk-pixbuf2.0-common libgl1 libgl1-mesa-dri libglapi-mesa libglib2.0-0
libglvnd0 libglx-mesa0 libglx0 libgraphite2-3 libgssapi-krb5-2
libgssapi3-heimdal libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-common
libhx509-5-heimdal libice6 libicu60 libjbig0 libjpeg-turbo8 libjpeg8
libjson-glib-1.0-0 libjson-glib-1.0-common libk5crypto3 libkeyutils1
libkrb5-26-heimdal libkrb5-3 libkrb5support0 liblcms2-2 libldap-2.4-2
libldap-common libllvm10 libnghttp2-14 libnspr4 libnss3 libogg0 libosmesa6
libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libperl5.26
libpixman-1-0 libpng16-16 libproxy1v5 libpsl5 libpulse0 libpulsedsp
librest-0.7-0 libroken18-heimdal librsvg2-2 librsvg2-common librtmp1
libsasl2-2 libsasl2-modules-db libsensors4 libsm6 libsndfile1
libsoup-gnome2.4-1 libsoup2.4-1 libsqlite3-0 libssl1.1 libthai-data libthai0
libtiff5 libvdpau1 libvorbis0a libvorbisenc2 libwayland-client0
libwayland-cursor0 libwayland-egl1 libwayland-egl1-mesa libwayland-server0
libwind0-heimdal libwrap0 libx11-6 libx11-data libx11-xcb1 libxau6
libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-render0
libxcb-shm0 libxcb-sync1 libxcb-xfixes0 libxcb1 libxcomposite1 libxcursor1
libxdamage1 libxdmcp6 libxext6 libxfixes3 libxi6 libxinerama1 libxkbcommon0
libxml2 libxrandr2 libxrender1 libxshmfence1 libxss1 libxtst6 libxxf86vm1
mesa-utils mesa-va-drivers mesa-vdpau-drivers multiarch-support perl
perl-modules-5.26 pulseaudio-utils shared-mime-info ubuntu-mono ucf wget
x11-common xdg-utils xkb-data
0 upgraded, 184 newly installed, 0 to remove and 4 not upgraded.
Need to get 68.2 MB of archives.
After this operation, 696 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf multiarch-support armhf 2.27-3ubuntu1.4 [6944 B]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxau6 armhf 1:1.0.8-1ubuntu1 [6736 B]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libbsd0 armhf 0.8.7-1ubuntu0.1 [40.4 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxdmcp6 armhf 1:1.1.2-3 [9316 B]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb1 armhf 1.13-2~ubuntu18.04 [41.2 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libx11-data all 2:1.6.4-3ubuntu0.3 [114 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libx11-6 armhf 2:1.6.4-3ubuntu0.3 [515 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxext6 armhf 2:1.3.3-1 [25.1 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libexpat1 armhf 2.2.5-3ubuntu0.2 [59.6 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpng16-16 armhf 1.6.34-1ubuntu0.18.04.2 [159 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libfreetype6 armhf 2.8.1-2ubuntu2.1 [280 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf ucf all 3.0038 [50.5 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf fonts-dejavu-core all 2.37-1 [1041 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf fontconfig-config all 2.12.6-0ubuntu2 [55.8 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libfontconfig1 armhf 2.12.6-0ubuntu2 [120 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf fontconfig armhf 2.12.6-0ubuntu2 [167 kB]
Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libjpeg-turbo8 armhf 1.5.2-0ubuntu5.18.04.4 [87.7 kB]
Get:18 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libogg0 armhf 1.3.2-1 [14.6 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf x11-common all 1:7.7+19ubuntu7.1 [22.5 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libice6 armhf 2:1.0.9-2 [33.5 kB]
Get:21 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libsm6 armhf 2:1.2.2-1 [13.9 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxinerama1 armhf 2:1.1.3-1 [7278 B]
Get:23 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxss1 armhf 1:1.2.2-1 [7652 B]
Get:24 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxxf86vm1 armhf 1:1.1.4-1 [9770 B]
Get:25 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf perl-modules-5.26 all 5.26.1-6ubuntu0.5 [2762 kB]
Get:26 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgdbm5 armhf 1.14.1-6 [23.4 kB]
Get:27 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgdbm-compat4 armhf 1.14.1-6 [5764 B]
Get:28 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libperl5.26 armhf 5.26.1-6ubuntu0.5 [2889 kB]
Get:29 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf perl armhf 5.26.1-6ubuntu0.5 [201 kB]
Get:30 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libapparmor1 armhf 2.12-4ubuntu5.1 [27.1 kB]
Get:31 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libcap2 armhf 1:2.25-1.2 [11.7 kB]
Get:32 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdbus-1-3 armhf 1.12.2-1ubuntu1.2 [153 kB]
Get:33 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libelf1 armhf 0.170-0.4ubuntu0.1 [42.9 kB]
Get:34 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libglib2.0-0 armhf 2.56.4-0ubuntu0.18.04.6 [1017 kB]
Get:35 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libicu60 armhf 60.2-3ubuntu3.1 [7802 kB]
Get:36 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsqlite3-0 armhf 3.22.0-1ubuntu0.4 [424 kB]
Get:37 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libssl1.1 armhf 1.1.1-1ubuntu2.1~18.04.7 [1069 kB]
Get:38 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxml2 armhf 2.9.4+dfsg1-6.1ubuntu1.3 [568 kB]
Get:39 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf shared-mime-info armhf 1.9-2 [424 kB]
Get:40 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf xkb-data all 2.23.1-1ubuntu1.18.04.1 [325 kB]
Get:41 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm-common all 2.4.101-2~18.04.1 [5560 B]
Get:42 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm2 armhf 2.4.101-2~18.04.1 [28.2 kB]
Get:43 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libedit2 armhf 3.1-20170329-1 [61.9 kB]
Get:44 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libkrb5support0 armhf 1.16-2ubuntu0.2 [27.2 kB]
Get:45 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libk5crypto3 armhf 1.16-2ubuntu0.2 [83.1 kB]
Get:46 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libkeyutils1 armhf 1.5.9-9.2ubuntu2 [7796 B]
Get:47 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libkrb5-3 armhf 1.16-2ubuntu0.2 [233 kB]
Get:48 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgssapi-krb5-2 armhf 1.16-2ubuntu0.2 [101 kB]
Get:49 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libpsl5 armhf 0.19.1-5build1 [40.5 kB]
Get:50 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf wget armhf 1.19.4-1ubuntu2.2 [293 kB]
Get:51 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf hicolor-icon-theme all 0.17-2 [9976 B]
Get:52 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libjpeg8 armhf 8c-2ubuntu8 [2202 B]
Get:53 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libjbig0 armhf 2.1-3.1build1 [23.9 kB]
Get:54 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libtiff5 armhf 4.0.9-5ubuntu0.3 [135 kB]
Get:55 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgdk-pixbuf2.0-common all 2.36.11-2 [4536 B]
Get:56 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgdk-pixbuf2.0-0 armhf 2.36.11-2 [149 kB]
Get:57 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf gtk-update-icon-cache armhf 3.22.30-1ubuntu4 [27.1 kB]
Get:58 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libpixman-1-0 armhf 0.34.0-2 [157 kB]
Get:59 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-render0 armhf 1.13-2~ubuntu18.04 [13.9 kB]
Get:60 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-shm0 armhf 1.13-2~ubuntu18.04 [5416 B]
Get:61 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxrender1 armhf 1:0.9.10-1 [15.6 kB]
Get:62 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcairo2 armhf 1.15.10-2ubuntu0.1 [506 kB]
Get:63 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libcroco3 armhf 0.6.12-2 [69.4 kB]
Get:64 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libthai-data all 0.1.27-2 [133 kB]
Get:65 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libdatrie1 armhf 0.2.10-7 [14.5 kB]
Get:66 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libthai0 armhf 0.1.27-2 [14.7 kB]
Get:67 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpango-1.0-0 armhf 1.40.14-1ubuntu0.1 [137 kB]
Get:68 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgraphite2-3 armhf 1.3.11-2 [67.5 kB]
Get:69 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libharfbuzz0b armhf 1.7.2-1ubuntu1 [205 kB]
Get:70 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpangoft2-1.0-0 armhf 1.40.14-1ubuntu0.1 [28.5 kB]
Get:71 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpangocairo-1.0-0 armhf 1.40.14-1ubuntu0.1 [17.5 kB]
Get:72 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf librsvg2-2 armhf 2.40.20-2ubuntu0.2 [83.9 kB]
Get:73 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf librsvg2-common armhf 2.40.20-2ubuntu0.2 [4656 B]
Get:74 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf humanity-icon-theme all 0.6.15 [1250 kB]
Get:75 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf ubuntu-mono all 16.10+18.04.20181005-0ubuntu1 [149 kB]
Get:76 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf adwaita-icon-theme all 3.28.0-1ubuntu1 [3306 kB]
Get:77 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libdconf1 armhf 0.26.0-2ubuntu3 [29.3 kB]
Get:78 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf dconf-service armhf 0.26.0-2ubuntu3 [24.5 kB]
Get:79 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf dconf-gsettings-backend armhf 0.26.0-2ubuntu3 [16.3 kB]
Get:80 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libdbus-glib-1-2 armhf 0.110-2 [48.2 kB]
Get:81 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf gconf2-common all 3.2.6-4ubuntu1 [700 kB]
Get:82 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf libgconf-2-4 armhf 3.2.6-4ubuntu1 [74.9 kB]
Get:83 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libroken18-heimdal armhf 7.5.0+dfsg-1 [34.1 kB]
Get:84 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libasn1-8-heimdal armhf 7.5.0+dfsg-1 [136 kB]
Get:85 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libheimbase1-heimdal armhf 7.5.0+dfsg-1 [24.1 kB]
Get:86 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libhcrypto4-heimdal armhf 7.5.0+dfsg-1 [76.5 kB]
Get:87 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libwind0-heimdal armhf 7.5.0+dfsg-1 [47.2 kB]
Get:88 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libhx509-5-heimdal armhf 7.5.0+dfsg-1 [87.9 kB]
Get:89 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libkrb5-26-heimdal armhf 7.5.0+dfsg-1 [168 kB]
Get:90 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libheimntlm0-heimdal armhf 7.5.0+dfsg-1 [13.1 kB]
Get:91 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgssapi3-heimdal armhf 7.5.0+dfsg-1 [78.8 kB]
Get:92 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsasl2-modules-db armhf 2.1.27~101-g0780600+dfsg-3ubuntu2.1 [13.1 kB]
Get:93 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsasl2-2 armhf 2.1.27~101-g0780600+dfsg-3ubuntu2.1 [42.0 kB]
Get:94 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libldap-common all 2.4.45+dfsg-1ubuntu1.8 [17.0 kB]
Get:95 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libldap-2.4-2 armhf 2.4.45+dfsg-1ubuntu1.8 [132 kB]
Get:96 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf gconf-service-backend armhf 3.2.6-4ubuntu1 [50.0 kB]
Get:97 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf gconf-service armhf 3.2.6-4ubuntu1 [2036 B]
Get:98 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libnghttp2-14 armhf 1.30.0-1ubuntu1 [67.4 kB]
Get:99 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf librtmp1 armhf 2.4+20151223.gitfa8646d.1-1 [49.1 kB]
Get:100 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcurl3-gnutls armhf 7.58.0-2ubuntu3.12 [182 kB]
Get:101 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf liberror-perl all 0.17025-1 [22.8 kB]
Get:102 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf git-man all 1:2.17.1-1ubuntu0.7 [804 kB]
Get:103 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf git armhf 1:2.17.1-1ubuntu0.7 [2816 kB]
Get:104 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libproxy1v5 armhf 0.4.15-1ubuntu0.2 [42.1 kB]
Get:105 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf glib-networking-common all 2.56.0-1ubuntu0.1 [3476 B]
Get:106 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf glib-networking-services armhf 2.56.0-1ubuntu0.1 [8016 B]
Get:107 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf gsettings-desktop-schemas all 3.28.0-1ubuntu1 [27.8 kB]
Get:108 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf glib-networking armhf 2.56.0-1ubuntu0.1 [49.3 kB]
Get:109 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libasound2-data all 1.1.3-5ubuntu0.5 [38.7 kB]
Get:110 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libasound2 armhf 1.1.3-5ubuntu0.5 [306 kB]
Get:111 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libasyncns0 armhf 0.8-6 [11.0 kB]
Get:112 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatk1.0-data all 2.28.1-1 [2992 B]
Get:113 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatk1.0-0 armhf 2.28.1-1 [36.9 kB]
Get:114 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatspi2.0-0 armhf 2.28.0-1 [49.9 kB]
Get:115 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatk-bridge2.0-0 armhf 2.26.2-1 [48.9 kB]
Get:116 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libavahi-common-data armhf 0.7-3.1ubuntu1.2 [22.1 kB]
Get:117 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libavahi-common3 armhf 0.7-3.1ubuntu1.2 [18.4 kB]
Get:118 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libavahi-client3 armhf 0.7-3.1ubuntu1.2 [21.7 kB]
Get:119 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcairo-gobject2 armhf 1.15.10-2ubuntu0.1 [16.1 kB]
Get:120 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf liblcms2-2 armhf 2.9-1ubuntu0.1 [114 kB]
Get:121 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libcolord2 armhf 1.3.3-2build1 [95.3 kB]
Get:122 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcups2 armhf 2.2.7-1ubuntu2.8 [181 kB]
Get:123 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm-amdgpu1 armhf 2.4.101-2~18.04.1 [16.7 kB]
Get:124 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm-nouveau2 armhf 2.4.101-2~18.04.1 [14.7 kB]
Get:125 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm-radeon1 armhf 2.4.101-2~18.04.1 [19.6 kB]
Get:126 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-server0 armhf 1.16.0-1ubuntu1.1~18.04.3 [23.6 kB]
Get:127 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgbm1 armhf 20.0.8-0ubuntu1~18.04.1 [24.0 kB]
Get:128 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libglapi-mesa armhf 20.0.8-0ubuntu1~18.04.1 [33.1 kB]
Get:129 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-client0 armhf 1.16.0-1ubuntu1.1~18.04.3 [18.7 kB]
Get:130 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libx11-xcb1 armhf 2:1.6.4-3ubuntu0.3 [9560 B]
Get:131 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-dri2-0 armhf 1.13-2~ubuntu18.04 [6716 B]
Get:132 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-dri3-0 armhf 1.13-2~ubuntu18.04 [6328 B]
Get:133 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-present0 armhf 1.13-2~ubuntu18.04 [5480 B]
Get:134 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-sync1 armhf 1.13-2~ubuntu18.04 [8280 B]
Get:135 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-xfixes0 armhf 1.13-2~ubuntu18.04 [9044 B]
Get:136 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxshmfence1 armhf 1.3-1 [4792 B]
Get:137 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libegl-mesa0 armhf 20.0.8-0ubuntu1~18.04.1 [77.8 kB]
Get:138 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libglvnd0 armhf 1.0.0-2ubuntu2.3 [47.3 kB]
Get:139 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libegl1 armhf 1.0.0-2ubuntu2.3 [26.5 kB]
Get:140 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libegl1-mesa armhf 20.0.8-0ubuntu1~18.04.1 [6416 B]
Get:141 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libepoxy0 armhf 1.4.3-1 [161 kB]
Get:142 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libflac8 armhf 1.3.2-1 [142 kB]
Get:143 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libllvm10 armhf 1:10.0.0-4ubuntu1~18.04.2 [13.5 MB]
Get:144 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libsensors4 armhf 1:3.4.0-4 [25.8 kB]
Get:145 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgl1-mesa-dri armhf 20.0.8-0ubuntu1~18.04.1 [5856 kB]
Get:146 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-glx0 armhf 1.13-2~ubuntu18.04 [20.2 kB]
Get:147 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxdamage1 armhf 1:1.1.4-3 [6488 B]
Get:148 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxfixes3 armhf 1:5.0.3-1 [9390 B]
Get:149 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libglx-mesa0 armhf 20.0.8-0ubuntu1~18.04.1 [121 kB]
Get:150 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgtk-3-common all 3.22.30-1ubuntu4 [229 kB]
Get:151 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libjson-glib-1.0-common all 1.4.2-3ubuntu0.18.04.1 [3480 B]
Get:152 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libjson-glib-1.0-0 armhf 1.4.2-3ubuntu0.18.04.1 [51.2 kB]
Get:153 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsoup2.4-1 armhf 2.62.1-1ubuntu0.4 [249 kB]
Get:154 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsoup-gnome2.4-1 armhf 2.62.1-1ubuntu0.4 [4728 B]
Get:155 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf librest-0.7-0 armhf 0.8.0-2 [26.9 kB]
Get:156 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-cursor0 armhf 1.16.0-1ubuntu1.1~18.04.3 [9008 B]
Get:157 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-egl1 armhf 1.16.0-1ubuntu1.1~18.04.3 [5336 B]
Get:158 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxcomposite1 armhf 1:0.4.4-2 [7684 B]
Get:159 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxcursor1 armhf 1:1.1.15-1 [16.9 kB]
Get:160 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxi6 armhf 2:1.7.9-1 [26.1 kB]
Get:161 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxkbcommon0 armhf 0.8.2-1~ubuntu18.04.1 [86.3 kB]
Get:162 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxrandr2 armhf 2:1.5.1-1 [15.5 kB]
Get:163 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgtk-3-0 armhf 3.22.30-1ubuntu4 [2135 kB]
Get:164 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgtk2.0-common all 2.24.32-1ubuntu1 [125 kB]
Get:165 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgtk2.0-0 armhf 2.24.32-1ubuntu1 [1509 kB]
Get:166 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libnspr4 armhf 2:4.18-1ubuntu1 [89.8 kB]
Get:167 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libnss3 armhf 2:3.35-2ubuntu2.12 [1053 kB]
Get:168 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libvorbis0a armhf 1.3.5-4.2 [75.6 kB]
Get:169 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libvorbisenc2 armhf 1.3.5-4.2 [64.5 kB]
Get:170 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsndfile1 armhf 1.0.28-4ubuntu0.18.04.1 [159 kB]
Get:171 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libwrap0 armhf 7.6.q-27 [43.5 kB]
Get:172 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpulse0 armhf 1:11.1-1ubuntu7.11 [236 kB]
Get:173 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpulsedsp armhf 1:11.1-1ubuntu7.11 [30.1 kB]
Get:174 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libvdpau1 armhf 1.1.1-3ubuntu1 [23.3 kB]
Get:175 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-egl1-mesa armhf 20.0.8-0ubuntu1~18.04.1 [6444 B]
Get:176 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxtst6 armhf 2:1.2.3-1 [11.4 kB]
Get:177 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe armhf mesa-va-drivers armhf 20.0.8-0ubuntu1~18.04.1 [2083 kB]
Get:178 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf mesa-vdpau-drivers armhf 20.0.8-0ubuntu1~18.04.1 [2199 kB]
Get:179 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf pulseaudio-utils armhf 1:11.1-1ubuntu7.11 [63.3 kB]
Get:180 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf xdg-utils all 1.1.2-1ubuntu2.4 [60.5 kB]
Get:181 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libglx0 armhf 1.0.0-2ubuntu2.3 [23.3 kB]
Get:182 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgl1 armhf 1.0.0-2ubuntu2.3 [94.2 kB]
Get:183 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libosmesa6 armhf 20.0.8-0ubuntu1~18.04.1 [2257 kB]
Get:184 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf mesa-utils armhf 8.4.0-1 [29.9 kB]
debconf: delaying package configuration, since apt-utils is not installed
Fetched 68.2 MB in 44s (1552 kB/s)
Selecting previously unselected package multiarch-support.
(Reading database ... 4039 files and directories currently installed.)
Preparing to unpack .../0-multiarch-support_2.27-3ubuntu1.4_armhf.deb ...
Unpacking multiarch-support (2.27-3ubuntu1.4) ...
Selecting previously unselected package libxau6:armhf.
Preparing to unpack .../1-libxau6_1%3a1.0.8-1ubuntu1_armhf.deb ...
Unpacking libxau6:armhf (1:1.0.8-1ubuntu1) ...
Selecting previously unselected package libbsd0:armhf.
Preparing to unpack .../2-libbsd0_0.8.7-1ubuntu0.1_armhf.deb ...
Unpacking libbsd0:armhf (0.8.7-1ubuntu0.1) ...
Selecting previously unselected package libxdmcp6:armhf.
Preparing to unpack .../3-libxdmcp6_1%3a1.1.2-3_armhf.deb ...
Unpacking libxdmcp6:armhf (1:1.1.2-3) ...
Selecting previously unselected package libxcb1:armhf.
Preparing to unpack .../4-libxcb1_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb1:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libx11-data.
Preparing to unpack .../5-libx11-data_2%3a1.6.4-3ubuntu0.3_all.deb ...
Unpacking libx11-data (2:1.6.4-3ubuntu0.3) ...
Selecting previously unselected package libx11-6:armhf.
Preparing to unpack .../6-libx11-6_2%3a1.6.4-3ubuntu0.3_armhf.deb ...
Unpacking libx11-6:armhf (2:1.6.4-3ubuntu0.3) ...
Setting up multiarch-support (2.27-3ubuntu1.4) ...
Selecting previously unselected package libxext6:armhf.
(Reading database ... 4329 files and directories currently installed.)
Preparing to unpack .../000-libxext6_2%3a1.3.3-1_armhf.deb ...
Unpacking libxext6:armhf (2:1.3.3-1) ...
Selecting previously unselected package libexpat1:armhf.
Preparing to unpack .../001-libexpat1_2.2.5-3ubuntu0.2_armhf.deb ...
Unpacking libexpat1:armhf (2.2.5-3ubuntu0.2) ...
Selecting previously unselected package libpng16-16:armhf.
Preparing to unpack .../002-libpng16-16_1.6.34-1ubuntu0.18.04.2_armhf.deb ...
Unpacking libpng16-16:armhf (1.6.34-1ubuntu0.18.04.2) ...
Selecting previously unselected package libfreetype6:armhf.
Preparing to unpack .../003-libfreetype6_2.8.1-2ubuntu2.1_armhf.deb ...
Unpacking libfreetype6:armhf (2.8.1-2ubuntu2.1) ...
Selecting previously unselected package ucf.
Preparing to unpack .../004-ucf_3.0038_all.deb ...
Moving old data out of the way
Unpacking ucf (3.0038) ...
Selecting previously unselected package fonts-dejavu-core.
Preparing to unpack .../005-fonts-dejavu-core_2.37-1_all.deb ...
Unpacking fonts-dejavu-core (2.37-1) ...
Selecting previously unselected package fontconfig-config.
Preparing to unpack .../006-fontconfig-config_2.12.6-0ubuntu2_all.deb ...
Unpacking fontconfig-config (2.12.6-0ubuntu2) ...
Selecting previously unselected package libfontconfig1:armhf.
Preparing to unpack .../007-libfontconfig1_2.12.6-0ubuntu2_armhf.deb ...
Unpacking libfontconfig1:armhf (2.12.6-0ubuntu2) ...
Selecting previously unselected package fontconfig.
Preparing to unpack .../008-fontconfig_2.12.6-0ubuntu2_armhf.deb ...
Unpacking fontconfig (2.12.6-0ubuntu2) ...
Selecting previously unselected package libjpeg-turbo8:armhf.
Preparing to unpack .../009-libjpeg-turbo8_1.5.2-0ubuntu5.18.04.4_armhf.deb ...
Unpacking libjpeg-turbo8:armhf (1.5.2-0ubuntu5.18.04.4) ...
Selecting previously unselected package libogg0:armhf.
Preparing to unpack .../010-libogg0_1.3.2-1_armhf.deb ...
Unpacking libogg0:armhf (1.3.2-1) ...
Selecting previously unselected package x11-common.
Preparing to unpack .../011-x11-common_1%3a7.7+19ubuntu7.1_all.deb ...
dpkg-query: no packages found matching nux-tools
Unpacking x11-common (1:7.7+19ubuntu7.1) ...
Selecting previously unselected package libice6:armhf.
Preparing to unpack .../012-libice6_2%3a1.0.9-2_armhf.deb ...
Unpacking libice6:armhf (2:1.0.9-2) ...
Selecting previously unselected package libsm6:armhf.
Preparing to unpack .../013-libsm6_2%3a1.2.2-1_armhf.deb ...
Unpacking libsm6:armhf (2:1.2.2-1) ...
Selecting previously unselected package libxinerama1:armhf.
Preparing to unpack .../014-libxinerama1_2%3a1.1.3-1_armhf.deb ...
Unpacking libxinerama1:armhf (2:1.1.3-1) ...
Selecting previously unselected package libxss1:armhf.
Preparing to unpack .../015-libxss1_1%3a1.2.2-1_armhf.deb ...
Unpacking libxss1:armhf (1:1.2.2-1) ...
Selecting previously unselected package libxxf86vm1:armhf.
Preparing to unpack .../016-libxxf86vm1_1%3a1.1.4-1_armhf.deb ...
Unpacking libxxf86vm1:armhf (1:1.1.4-1) ...
Selecting previously unselected package perl-modules-5.26.
Preparing to unpack .../017-perl-modules-5.26_5.26.1-6ubuntu0.5_all.deb ...
Unpacking perl-modules-5.26 (5.26.1-6ubuntu0.5) ...
Selecting previously unselected package libgdbm5:armhf.
Preparing to unpack .../018-libgdbm5_1.14.1-6_armhf.deb ...
Unpacking libgdbm5:armhf (1.14.1-6) ...
Selecting previously unselected package libgdbm-compat4:armhf.
Preparing to unpack .../019-libgdbm-compat4_1.14.1-6_armhf.deb ...
Unpacking libgdbm-compat4:armhf (1.14.1-6) ...
Selecting previously unselected package libperl5.26:armhf.
Preparing to unpack .../020-libperl5.26_5.26.1-6ubuntu0.5_armhf.deb ...
Unpacking libperl5.26:armhf (5.26.1-6ubuntu0.5) ...
Selecting previously unselected package perl.
Preparing to unpack .../021-perl_5.26.1-6ubuntu0.5_armhf.deb ...
Unpacking perl (5.26.1-6ubuntu0.5) ...
Selecting previously unselected package libapparmor1:armhf.
Preparing to unpack .../022-libapparmor1_2.12-4ubuntu5.1_armhf.deb ...
Unpacking libapparmor1:armhf (2.12-4ubuntu5.1) ...
Selecting previously unselected package libcap2:armhf.
Preparing to unpack .../023-libcap2_1%3a2.25-1.2_armhf.deb ...
Unpacking libcap2:armhf (1:2.25-1.2) ...
Selecting previously unselected package libdbus-1-3:armhf.
Preparing to unpack .../024-libdbus-1-3_1.12.2-1ubuntu1.2_armhf.deb ...
Unpacking libdbus-1-3:armhf (1.12.2-1ubuntu1.2) ...
Selecting previously unselected package libelf1:armhf.
Preparing to unpack .../025-libelf1_0.170-0.4ubuntu0.1_armhf.deb ...
Unpacking libelf1:armhf (0.170-0.4ubuntu0.1) ...
Selecting previously unselected package libglib2.0-0:armhf.
Preparing to unpack .../026-libglib2.0-0_2.56.4-0ubuntu0.18.04.6_armhf.deb ...
Unpacking libglib2.0-0:armhf (2.56.4-0ubuntu0.18.04.6) ...
Selecting previously unselected package libicu60:armhf.
Preparing to unpack .../027-libicu60_60.2-3ubuntu3.1_armhf.deb ...
Unpacking libicu60:armhf (60.2-3ubuntu3.1) ...
Selecting previously unselected package libsqlite3-0:armhf.
Preparing to unpack .../028-libsqlite3-0_3.22.0-1ubuntu0.4_armhf.deb ...
Unpacking libsqlite3-0:armhf (3.22.0-1ubuntu0.4) ...
Selecting previously unselected package libssl1.1:armhf.
Preparing to unpack .../029-libssl1.1_1.1.1-1ubuntu2.1~18.04.7_armhf.deb ...
Unpacking libssl1.1:armhf (1.1.1-1ubuntu2.1~18.04.7) ...
Selecting previously unselected package libxml2:armhf.
Preparing to unpack .../030-libxml2_2.9.4+dfsg1-6.1ubuntu1.3_armhf.deb ...
Unpacking libxml2:armhf (2.9.4+dfsg1-6.1ubuntu1.3) ...
Selecting previously unselected package shared-mime-info.
Preparing to unpack .../031-shared-mime-info_1.9-2_armhf.deb ...
Unpacking shared-mime-info (1.9-2) ...
Selecting previously unselected package xkb-data.
Preparing to unpack .../032-xkb-data_2.23.1-1ubuntu1.18.04.1_all.deb ...
Unpacking xkb-data (2.23.1-1ubuntu1.18.04.1) ...
Selecting previously unselected package libdrm-common.
Preparing to unpack .../033-libdrm-common_2.4.101-2~18.04.1_all.deb ...
Unpacking libdrm-common (2.4.101-2~18.04.1) ...
Selecting previously unselected package libdrm2:armhf.
Preparing to unpack .../034-libdrm2_2.4.101-2~18.04.1_armhf.deb ...
Unpacking libdrm2:armhf (2.4.101-2~18.04.1) ...
Selecting previously unselected package libedit2:armhf.
Preparing to unpack .../035-libedit2_3.1-20170329-1_armhf.deb ...
Unpacking libedit2:armhf (3.1-20170329-1) ...
Selecting previously unselected package libkrb5support0:armhf.
Preparing to unpack .../036-libkrb5support0_1.16-2ubuntu0.2_armhf.deb ...
Unpacking libkrb5support0:armhf (1.16-2ubuntu0.2) ...
Selecting previously unselected package libk5crypto3:armhf.
Preparing to unpack .../037-libk5crypto3_1.16-2ubuntu0.2_armhf.deb ...
Unpacking libk5crypto3:armhf (1.16-2ubuntu0.2) ...
Selecting previously unselected package libkeyutils1:armhf.
Preparing to unpack .../038-libkeyutils1_1.5.9-9.2ubuntu2_armhf.deb ...
Unpacking libkeyutils1:armhf (1.5.9-9.2ubuntu2) ...
Selecting previously unselected package libkrb5-3:armhf.
Preparing to unpack .../039-libkrb5-3_1.16-2ubuntu0.2_armhf.deb ...
Unpacking libkrb5-3:armhf (1.16-2ubuntu0.2) ...
Selecting previously unselected package libgssapi-krb5-2:armhf.
Preparing to unpack .../040-libgssapi-krb5-2_1.16-2ubuntu0.2_armhf.deb ...
Unpacking libgssapi-krb5-2:armhf (1.16-2ubuntu0.2) ...
Selecting previously unselected package libpsl5:armhf.
Preparing to unpack .../041-libpsl5_0.19.1-5build1_armhf.deb ...
Unpacking libpsl5:armhf (0.19.1-5build1) ...
Selecting previously unselected package wget.
Preparing to unpack .../042-wget_1.19.4-1ubuntu2.2_armhf.deb ...
Unpacking wget (1.19.4-1ubuntu2.2) ...
Selecting previously unselected package hicolor-icon-theme.
Preparing to unpack .../043-hicolor-icon-theme_0.17-2_all.deb ...
Unpacking hicolor-icon-theme (0.17-2) ...
Selecting previously unselected package libjpeg8:armhf.
Preparing to unpack .../044-libjpeg8_8c-2ubuntu8_armhf.deb ...
Unpacking libjpeg8:armhf (8c-2ubuntu8) ...
Selecting previously unselected package libjbig0:armhf.
Preparing to unpack .../045-libjbig0_2.1-3.1build1_armhf.deb ...
Unpacking libjbig0:armhf (2.1-3.1build1) ...
Selecting previously unselected package libtiff5:armhf.
Preparing to unpack .../046-libtiff5_4.0.9-5ubuntu0.3_armhf.deb ...
Unpacking libtiff5:armhf (4.0.9-5ubuntu0.3) ...
Selecting previously unselected package libgdk-pixbuf2.0-common.
Preparing to unpack .../047-libgdk-pixbuf2.0-common_2.36.11-2_all.deb ...
Unpacking libgdk-pixbuf2.0-common (2.36.11-2) ...
Selecting previously unselected package libgdk-pixbuf2.0-0:armhf.
Preparing to unpack .../048-libgdk-pixbuf2.0-0_2.36.11-2_armhf.deb ...
Unpacking libgdk-pixbuf2.0-0:armhf (2.36.11-2) ...
Selecting previously unselected package gtk-update-icon-cache.
Preparing to unpack .../049-gtk-update-icon-cache_3.22.30-1ubuntu4_armhf.deb ...
No diversion 'diversion of /usr/sbin/update-icon-caches to /usr/sbin/update-icon-caches.gtk2 by libgtk-3-bin', none removed.
No diversion 'diversion of /usr/share/man/man8/update-icon-caches.8.gz to /usr/share/man/man8/update-icon-caches.gtk2.8.gz by libgtk-3-bin', none removed.
Unpacking gtk-update-icon-cache (3.22.30-1ubuntu4) ...
Selecting previously unselected package libpixman-1-0:armhf.
Preparing to unpack .../050-libpixman-1-0_0.34.0-2_armhf.deb ...
Unpacking libpixman-1-0:armhf (0.34.0-2) ...
Selecting previously unselected package libxcb-render0:armhf.
Preparing to unpack .../051-libxcb-render0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-render0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxcb-shm0:armhf.
Preparing to unpack .../052-libxcb-shm0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-shm0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxrender1:armhf.
Preparing to unpack .../053-libxrender1_1%3a0.9.10-1_armhf.deb ...
Unpacking libxrender1:armhf (1:0.9.10-1) ...
Selecting previously unselected package libcairo2:armhf.
Preparing to unpack .../054-libcairo2_1.15.10-2ubuntu0.1_armhf.deb ...
Unpacking libcairo2:armhf (1.15.10-2ubuntu0.1) ...
Selecting previously unselected package libcroco3:armhf.
Preparing to unpack .../055-libcroco3_0.6.12-2_armhf.deb ...
Unpacking libcroco3:armhf (0.6.12-2) ...
Selecting previously unselected package libthai-data.
Preparing to unpack .../056-libthai-data_0.1.27-2_all.deb ...
Unpacking libthai-data (0.1.27-2) ...
Selecting previously unselected package libdatrie1:armhf.
Preparing to unpack .../057-libdatrie1_0.2.10-7_armhf.deb ...
Unpacking libdatrie1:armhf (0.2.10-7) ...
Selecting previously unselected package libthai0:armhf.
Preparing to unpack .../058-libthai0_0.1.27-2_armhf.deb ...
Unpacking libthai0:armhf (0.1.27-2) ...
Selecting previously unselected package libpango-1.0-0:armhf.
Preparing to unpack .../059-libpango-1.0-0_1.40.14-1ubuntu0.1_armhf.deb ...
Unpacking libpango-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Selecting previously unselected package libgraphite2-3:armhf.
Preparing to unpack .../060-libgraphite2-3_1.3.11-2_armhf.deb ...
Unpacking libgraphite2-3:armhf (1.3.11-2) ...
Selecting previously unselected package libharfbuzz0b:armhf.
Preparing to unpack .../061-libharfbuzz0b_1.7.2-1ubuntu1_armhf.deb ...
Unpacking libharfbuzz0b:armhf (1.7.2-1ubuntu1) ...
Selecting previously unselected package libpangoft2-1.0-0:armhf.
Preparing to unpack .../062-libpangoft2-1.0-0_1.40.14-1ubuntu0.1_armhf.deb ...
Unpacking libpangoft2-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Selecting previously unselected package libpangocairo-1.0-0:armhf.
Preparing to unpack .../063-libpangocairo-1.0-0_1.40.14-1ubuntu0.1_armhf.deb ...
Unpacking libpangocairo-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Selecting previously unselected package librsvg2-2:armhf.
Preparing to unpack .../064-librsvg2-2_2.40.20-2ubuntu0.2_armhf.deb ...
Unpacking librsvg2-2:armhf (2.40.20-2ubuntu0.2) ...
Selecting previously unselected package librsvg2-common:armhf.
Preparing to unpack .../065-librsvg2-common_2.40.20-2ubuntu0.2_armhf.deb ...
Unpacking librsvg2-common:armhf (2.40.20-2ubuntu0.2) ...
Selecting previously unselected package humanity-icon-theme.
Preparing to unpack .../066-humanity-icon-theme_0.6.15_all.deb ...
Unpacking humanity-icon-theme (0.6.15) ...
Selecting previously unselected package ubuntu-mono.
Preparing to unpack .../067-ubuntu-mono_16.10+18.04.20181005-0ubuntu1_all.deb ...
Unpacking ubuntu-mono (16.10+18.04.20181005-0ubuntu1) ...
Selecting previously unselected package adwaita-icon-theme.
Preparing to unpack .../068-adwaita-icon-theme_3.28.0-1ubuntu1_all.deb ...
Unpacking adwaita-icon-theme (3.28.0-1ubuntu1) ...
Selecting previously unselected package libdconf1:armhf.
Preparing to unpack .../069-libdconf1_0.26.0-2ubuntu3_armhf.deb ...
Unpacking libdconf1:armhf (0.26.0-2ubuntu3) ...
Selecting previously unselected package dconf-service.
Preparing to unpack .../070-dconf-service_0.26.0-2ubuntu3_armhf.deb ...
Unpacking dconf-service (0.26.0-2ubuntu3) ...
Selecting previously unselected package dconf-gsettings-backend:armhf.
Preparing to unpack .../071-dconf-gsettings-backend_0.26.0-2ubuntu3_armhf.deb ...
Unpacking dconf-gsettings-backend:armhf (0.26.0-2ubuntu3) ...
Selecting previously unselected package libdbus-glib-1-2:armhf.
Preparing to unpack .../072-libdbus-glib-1-2_0.110-2_armhf.deb ...
Unpacking libdbus-glib-1-2:armhf (0.110-2) ...
Selecting previously unselected package gconf2-common.
Preparing to unpack .../073-gconf2-common_3.2.6-4ubuntu1_all.deb ...
Unpacking gconf2-common (3.2.6-4ubuntu1) ...
Selecting previously unselected package libgconf-2-4:armhf.
Preparing to unpack .../074-libgconf-2-4_3.2.6-4ubuntu1_armhf.deb ...
Unpacking libgconf-2-4:armhf (3.2.6-4ubuntu1) ...
Selecting previously unselected package libroken18-heimdal:armhf.
Preparing to unpack .../075-libroken18-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libroken18-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libasn1-8-heimdal:armhf.
Preparing to unpack .../076-libasn1-8-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libasn1-8-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libheimbase1-heimdal:armhf.
Preparing to unpack .../077-libheimbase1-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libheimbase1-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libhcrypto4-heimdal:armhf.
Preparing to unpack .../078-libhcrypto4-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libhcrypto4-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libwind0-heimdal:armhf.
Preparing to unpack .../079-libwind0-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libwind0-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libhx509-5-heimdal:armhf.
Preparing to unpack .../080-libhx509-5-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libhx509-5-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libkrb5-26-heimdal:armhf.
Preparing to unpack .../081-libkrb5-26-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libkrb5-26-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libheimntlm0-heimdal:armhf.
Preparing to unpack .../082-libheimntlm0-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libheimntlm0-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libgssapi3-heimdal:armhf.
Preparing to unpack .../083-libgssapi3-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libgssapi3-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libsasl2-modules-db:armhf.
Preparing to unpack .../084-libsasl2-modules-db_2.1.27~101-g0780600+dfsg-3ubuntu2.1_armhf.deb ...
Unpacking libsasl2-modules-db:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2.1) ...
Selecting previously unselected package libsasl2-2:armhf.
Preparing to unpack .../085-libsasl2-2_2.1.27~101-g0780600+dfsg-3ubuntu2.1_armhf.deb ...
Unpacking libsasl2-2:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2.1) ...
Selecting previously unselected package libldap-common.
Preparing to unpack .../086-libldap-common_2.4.45+dfsg-1ubuntu1.8_all.deb ...
Unpacking libldap-common (2.4.45+dfsg-1ubuntu1.8) ...
Selecting previously unselected package libldap-2.4-2:armhf.
Preparing to unpack .../087-libldap-2.4-2_2.4.45+dfsg-1ubuntu1.8_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.45+dfsg-1ubuntu1.8) ...
Selecting previously unselected package gconf-service-backend.
Preparing to unpack .../088-gconf-service-backend_3.2.6-4ubuntu1_armhf.deb ...
Unpacking gconf-service-backend (3.2.6-4ubuntu1) ...
Selecting previously unselected package gconf-service.
Preparing to unpack .../089-gconf-service_3.2.6-4ubuntu1_armhf.deb ...
Unpacking gconf-service (3.2.6-4ubuntu1) ...
Selecting previously unselected package libnghttp2-14:armhf.
Preparing to unpack .../090-libnghttp2-14_1.30.0-1ubuntu1_armhf.deb ...
Unpacking libnghttp2-14:armhf (1.30.0-1ubuntu1) ...
Selecting previously unselected package librtmp1:armhf.
Preparing to unpack .../091-librtmp1_2.4+20151223.gitfa8646d.1-1_armhf.deb ...
Unpacking librtmp1:armhf (2.4+20151223.gitfa8646d.1-1) ...
Selecting previously unselected package libcurl3-gnutls:armhf.
Preparing to unpack .../092-libcurl3-gnutls_7.58.0-2ubuntu3.12_armhf.deb ...
Unpacking libcurl3-gnutls:armhf (7.58.0-2ubuntu3.12) ...
Selecting previously unselected package liberror-perl.
Preparing to unpack .../093-liberror-perl_0.17025-1_all.deb ...
Unpacking liberror-perl (0.17025-1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../094-git-man_1%3a2.17.1-1ubuntu0.7_all.deb ...
Unpacking git-man (1:2.17.1-1ubuntu0.7) ...
Selecting previously unselected package git.
Preparing to unpack .../095-git_1%3a2.17.1-1ubuntu0.7_armhf.deb ...
Unpacking git (1:2.17.1-1ubuntu0.7) ...
Selecting previously unselected package libproxy1v5:armhf.
Preparing to unpack .../096-libproxy1v5_0.4.15-1ubuntu0.2_armhf.deb ...
Unpacking libproxy1v5:armhf (0.4.15-1ubuntu0.2) ...
Selecting previously unselected package glib-networking-common.
Preparing to unpack .../097-glib-networking-common_2.56.0-1ubuntu0.1_all.deb ...
Unpacking glib-networking-common (2.56.0-1ubuntu0.1) ...
Selecting previously unselected package glib-networking-services.
Preparing to unpack .../098-glib-networking-services_2.56.0-1ubuntu0.1_armhf.deb ...
Unpacking glib-networking-services (2.56.0-1ubuntu0.1) ...
Selecting previously unselected package gsettings-desktop-schemas.
Preparing to unpack .../099-gsettings-desktop-schemas_3.28.0-1ubuntu1_all.deb ...
Unpacking gsettings-desktop-schemas (3.28.0-1ubuntu1) ...
Selecting previously unselected package glib-networking:armhf.
Preparing to unpack .../100-glib-networking_2.56.0-1ubuntu0.1_armhf.deb ...
Unpacking glib-networking:armhf (2.56.0-1ubuntu0.1) ...
Selecting previously unselected package libasound2-data.
Preparing to unpack .../101-libasound2-data_1.1.3-5ubuntu0.5_all.deb ...
Unpacking libasound2-data (1.1.3-5ubuntu0.5) ...
Selecting previously unselected package libasound2:armhf.
Preparing to unpack .../102-libasound2_1.1.3-5ubuntu0.5_armhf.deb ...
Unpacking libasound2:armhf (1.1.3-5ubuntu0.5) ...
Selecting previously unselected package libasyncns0:armhf.
Preparing to unpack .../103-libasyncns0_0.8-6_armhf.deb ...
Unpacking libasyncns0:armhf (0.8-6) ...
Selecting previously unselected package libatk1.0-data.
Preparing to unpack .../104-libatk1.0-data_2.28.1-1_all.deb ...
Unpacking libatk1.0-data (2.28.1-1) ...
Selecting previously unselected package libatk1.0-0:armhf.
Preparing to unpack .../105-libatk1.0-0_2.28.1-1_armhf.deb ...
Unpacking libatk1.0-0:armhf (2.28.1-1) ...
Selecting previously unselected package libatspi2.0-0:armhf.
Preparing to unpack .../106-libatspi2.0-0_2.28.0-1_armhf.deb ...
Unpacking libatspi2.0-0:armhf (2.28.0-1) ...
Selecting previously unselected package libatk-bridge2.0-0:armhf.
Preparing to unpack .../107-libatk-bridge2.0-0_2.26.2-1_armhf.deb ...
Unpacking libatk-bridge2.0-0:armhf (2.26.2-1) ...
Selecting previously unselected package libavahi-common-data:armhf.
Preparing to unpack .../108-libavahi-common-data_0.7-3.1ubuntu1.2_armhf.deb ...
Unpacking libavahi-common-data:armhf (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libavahi-common3:armhf.
Preparing to unpack .../109-libavahi-common3_0.7-3.1ubuntu1.2_armhf.deb ...
Unpacking libavahi-common3:armhf (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libavahi-client3:armhf.
Preparing to unpack .../110-libavahi-client3_0.7-3.1ubuntu1.2_armhf.deb ...
Unpacking libavahi-client3:armhf (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libcairo-gobject2:armhf.
Preparing to unpack .../111-libcairo-gobject2_1.15.10-2ubuntu0.1_armhf.deb ...
Unpacking libcairo-gobject2:armhf (1.15.10-2ubuntu0.1) ...
Selecting previously unselected package liblcms2-2:armhf.
Preparing to unpack .../112-liblcms2-2_2.9-1ubuntu0.1_armhf.deb ...
Unpacking liblcms2-2:armhf (2.9-1ubuntu0.1) ...
Selecting previously unselected package libcolord2:armhf.
Preparing to unpack .../113-libcolord2_1.3.3-2build1_armhf.deb ...
Unpacking libcolord2:armhf (1.3.3-2build1) ...
Selecting previously unselected package libcups2:armhf.
Preparing to unpack .../114-libcups2_2.2.7-1ubuntu2.8_armhf.deb ...
Unpacking libcups2:armhf (2.2.7-1ubuntu2.8) ...
Selecting previously unselected package libdrm-amdgpu1:armhf.
Preparing to unpack .../115-libdrm-amdgpu1_2.4.101-2~18.04.1_armhf.deb ...
Unpacking libdrm-amdgpu1:armhf (2.4.101-2~18.04.1) ...
Selecting previously unselected package libdrm-nouveau2:armhf.
Preparing to unpack .../116-libdrm-nouveau2_2.4.101-2~18.04.1_armhf.deb ...
Unpacking libdrm-nouveau2:armhf (2.4.101-2~18.04.1) ...
Selecting previously unselected package libdrm-radeon1:armhf.
Preparing to unpack .../117-libdrm-radeon1_2.4.101-2~18.04.1_armhf.deb ...
Unpacking libdrm-radeon1:armhf (2.4.101-2~18.04.1) ...
Selecting previously unselected package libwayland-server0:armhf.
Preparing to unpack .../118-libwayland-server0_1.16.0-1ubuntu1.1~18.04.3_armhf.deb ...
Unpacking libwayland-server0:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Selecting previously unselected package libgbm1:armhf.
Preparing to unpack .../119-libgbm1_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libgbm1:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libglapi-mesa:armhf.
Preparing to unpack .../120-libglapi-mesa_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libglapi-mesa:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libwayland-client0:armhf.
Preparing to unpack .../121-libwayland-client0_1.16.0-1ubuntu1.1~18.04.3_armhf.deb ...
Unpacking libwayland-client0:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Selecting previously unselected package libx11-xcb1:armhf.
Preparing to unpack .../122-libx11-xcb1_2%3a1.6.4-3ubuntu0.3_armhf.deb ...
Unpacking libx11-xcb1:armhf (2:1.6.4-3ubuntu0.3) ...
Selecting previously unselected package libxcb-dri2-0:armhf.
Preparing to unpack .../123-libxcb-dri2-0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-dri2-0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxcb-dri3-0:armhf.
Preparing to unpack .../124-libxcb-dri3-0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-dri3-0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxcb-present0:armhf.
Preparing to unpack .../125-libxcb-present0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-present0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxcb-sync1:armhf.
Preparing to unpack .../126-libxcb-sync1_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-sync1:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxcb-xfixes0:armhf.
Preparing to unpack .../127-libxcb-xfixes0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-xfixes0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxshmfence1:armhf.
Preparing to unpack .../128-libxshmfence1_1.3-1_armhf.deb ...
Unpacking libxshmfence1:armhf (1.3-1) ...
Selecting previously unselected package libegl-mesa0:armhf.
Preparing to unpack .../129-libegl-mesa0_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libegl-mesa0:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libglvnd0:armhf.
Preparing to unpack .../130-libglvnd0_1.0.0-2ubuntu2.3_armhf.deb ...
Unpacking libglvnd0:armhf (1.0.0-2ubuntu2.3) ...
Selecting previously unselected package libegl1:armhf.
Preparing to unpack .../131-libegl1_1.0.0-2ubuntu2.3_armhf.deb ...
Unpacking libegl1:armhf (1.0.0-2ubuntu2.3) ...
Selecting previously unselected package libegl1-mesa:armhf.
Preparing to unpack .../132-libegl1-mesa_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libegl1-mesa:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libepoxy0:armhf.
Preparing to unpack .../133-libepoxy0_1.4.3-1_armhf.deb ...
Unpacking libepoxy0:armhf (1.4.3-1) ...
Selecting previously unselected package libflac8:armhf.
Preparing to unpack .../134-libflac8_1.3.2-1_armhf.deb ...
Unpacking libflac8:armhf (1.3.2-1) ...
Selecting previously unselected package libllvm10:armhf.
Preparing to unpack .../135-libllvm10_1%3a10.0.0-4ubuntu1~18.04.2_armhf.deb ...
Unpacking libllvm10:armhf (1:10.0.0-4ubuntu1~18.04.2) ...
Selecting previously unselected package libsensors4:armhf.
Preparing to unpack .../136-libsensors4_1%3a3.4.0-4_armhf.deb ...
Unpacking libsensors4:armhf (1:3.4.0-4) ...
Selecting previously unselected package libgl1-mesa-dri:armhf.
Preparing to unpack .../137-libgl1-mesa-dri_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libgl1-mesa-dri:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libxcb-glx0:armhf.
Preparing to unpack .../138-libxcb-glx0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-glx0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxdamage1:armhf.
Preparing to unpack .../139-libxdamage1_1%3a1.1.4-3_armhf.deb ...
Unpacking libxdamage1:armhf (1:1.1.4-3) ...
Selecting previously unselected package libxfixes3:armhf.
Preparing to unpack .../140-libxfixes3_1%3a5.0.3-1_armhf.deb ...
Unpacking libxfixes3:armhf (1:5.0.3-1) ...
Selecting previously unselected package libglx-mesa0:armhf.
Preparing to unpack .../141-libglx-mesa0_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libglx-mesa0:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libgtk-3-common.
Preparing to unpack .../142-libgtk-3-common_3.22.30-1ubuntu4_all.deb ...
Unpacking libgtk-3-common (3.22.30-1ubuntu4) ...
Selecting previously unselected package libjson-glib-1.0-common.
Preparing to unpack .../143-libjson-glib-1.0-common_1.4.2-3ubuntu0.18.04.1_all.deb ...
Unpacking libjson-glib-1.0-common (1.4.2-3ubuntu0.18.04.1) ...
Selecting previously unselected package libjson-glib-1.0-0:armhf.
Preparing to unpack .../144-libjson-glib-1.0-0_1.4.2-3ubuntu0.18.04.1_armhf.deb ...
Unpacking libjson-glib-1.0-0:armhf (1.4.2-3ubuntu0.18.04.1) ...
Selecting previously unselected package libsoup2.4-1:armhf.
Preparing to unpack .../145-libsoup2.4-1_2.62.1-1ubuntu0.4_armhf.deb ...
Unpacking libsoup2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Selecting previously unselected package libsoup-gnome2.4-1:armhf.
Preparing to unpack .../146-libsoup-gnome2.4-1_2.62.1-1ubuntu0.4_armhf.deb ...
Unpacking libsoup-gnome2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Selecting previously unselected package librest-0.7-0:armhf.
Preparing to unpack .../147-librest-0.7-0_0.8.0-2_armhf.deb ...
Unpacking librest-0.7-0:armhf (0.8.0-2) ...
Selecting previously unselected package libwayland-cursor0:armhf.
Preparing to unpack .../148-libwayland-cursor0_1.16.0-1ubuntu1.1~18.04.3_armhf.deb ...
Unpacking libwayland-cursor0:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Selecting previously unselected package libwayland-egl1:armhf.
Preparing to unpack .../149-libwayland-egl1_1.16.0-1ubuntu1.1~18.04.3_armhf.deb ...
Unpacking libwayland-egl1:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Selecting previously unselected package libxcomposite1:armhf.
Preparing to unpack .../150-libxcomposite1_1%3a0.4.4-2_armhf.deb ...
Unpacking libxcomposite1:armhf (1:0.4.4-2) ...
Selecting previously unselected package libxcursor1:armhf.
Preparing to unpack .../151-libxcursor1_1%3a1.1.15-1_armhf.deb ...
Unpacking libxcursor1:armhf (1:1.1.15-1) ...
Selecting previously unselected package libxi6:armhf.
Preparing to unpack .../152-libxi6_2%3a1.7.9-1_armhf.deb ...
Unpacking libxi6:armhf (2:1.7.9-1) ...
Selecting previously unselected package libxkbcommon0:armhf.
Preparing to unpack .../153-libxkbcommon0_0.8.2-1~ubuntu18.04.1_armhf.deb ...
Unpacking libxkbcommon0:armhf (0.8.2-1~ubuntu18.04.1) ...
Selecting previously unselected package libxrandr2:armhf.
Preparing to unpack .../154-libxrandr2_2%3a1.5.1-1_armhf.deb ...
Unpacking libxrandr2:armhf (2:1.5.1-1) ...
Selecting previously unselected package libgtk-3-0:armhf.
Preparing to unpack .../155-libgtk-3-0_3.22.30-1ubuntu4_armhf.deb ...
Unpacking libgtk-3-0:armhf (3.22.30-1ubuntu4) ...
Selecting previously unselected package libgtk2.0-common.
Preparing to unpack .../156-libgtk2.0-common_2.24.32-1ubuntu1_all.deb ...
Unpacking libgtk2.0-common (2.24.32-1ubuntu1) ...
Selecting previously unselected package libgtk2.0-0:armhf.
Preparing to unpack .../157-libgtk2.0-0_2.24.32-1ubuntu1_armhf.deb ...
Unpacking libgtk2.0-0:armhf (2.24.32-1ubuntu1) ...
Selecting previously unselected package libnspr4:armhf.
Preparing to unpack .../158-libnspr4_2%3a4.18-1ubuntu1_armhf.deb ...
Unpacking libnspr4:armhf (2:4.18-1ubuntu1) ...
Selecting previously unselected package libnss3:armhf.
Preparing to unpack .../159-libnss3_2%3a3.35-2ubuntu2.12_armhf.deb ...
Unpacking libnss3:armhf (2:3.35-2ubuntu2.12) ...
Selecting previously unselected package libvorbis0a:armhf.
Preparing to unpack .../160-libvorbis0a_1.3.5-4.2_armhf.deb ...
Unpacking libvorbis0a:armhf (1.3.5-4.2) ...
Selecting previously unselected package libvorbisenc2:armhf.
Preparing to unpack .../161-libvorbisenc2_1.3.5-4.2_armhf.deb ...
Unpacking libvorbisenc2:armhf (1.3.5-4.2) ...
Selecting previously unselected package libsndfile1:armhf.
Preparing to unpack .../162-libsndfile1_1.0.28-4ubuntu0.18.04.1_armhf.deb ...
Unpacking libsndfile1:armhf (1.0.28-4ubuntu0.18.04.1) ...
Selecting previously unselected package libwrap0:armhf.
Preparing to unpack .../163-libwrap0_7.6.q-27_armhf.deb ...
Unpacking libwrap0:armhf (7.6.q-27) ...
Selecting previously unselected package libpulse0:armhf.
Preparing to unpack .../164-libpulse0_1%3a11.1-1ubuntu7.11_armhf.deb ...
Unpacking libpulse0:armhf (1:11.1-1ubuntu7.11) ...
Selecting previously unselected package libpulsedsp:armhf.
Preparing to unpack .../165-libpulsedsp_1%3a11.1-1ubuntu7.11_armhf.deb ...
Unpacking libpulsedsp:armhf (1:11.1-1ubuntu7.11) ...
Selecting previously unselected package libvdpau1:armhf.
Preparing to unpack .../166-libvdpau1_1.1.1-3ubuntu1_armhf.deb ...
Unpacking libvdpau1:armhf (1.1.1-3ubuntu1) ...
Selecting previously unselected package libwayland-egl1-mesa:armhf.
Preparing to unpack .../167-libwayland-egl1-mesa_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libwayland-egl1-mesa:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package libxtst6:armhf.
Preparing to unpack .../168-libxtst6_2%3a1.2.3-1_armhf.deb ...
Unpacking libxtst6:armhf (2:1.2.3-1) ...
Selecting previously unselected package mesa-va-drivers:armhf.
Preparing to unpack .../169-mesa-va-drivers_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking mesa-va-drivers:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package mesa-vdpau-drivers:armhf.
Preparing to unpack .../170-mesa-vdpau-drivers_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking mesa-vdpau-drivers:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package pulseaudio-utils.
Preparing to unpack .../171-pulseaudio-utils_1%3a11.1-1ubuntu7.11_armhf.deb ...
Unpacking pulseaudio-utils (1:11.1-1ubuntu7.11) ...
Selecting previously unselected package xdg-utils.
Preparing to unpack .../172-xdg-utils_1.1.2-1ubuntu2.4_all.deb ...
Unpacking xdg-utils (1.1.2-1ubuntu2.4) ...
Selecting previously unselected package libglx0:armhf.
Preparing to unpack .../173-libglx0_1.0.0-2ubuntu2.3_armhf.deb ...
Unpacking libglx0:armhf (1.0.0-2ubuntu2.3) ...
Selecting previously unselected package libgl1:armhf.
Preparing to unpack .../174-libgl1_1.0.0-2ubuntu2.3_armhf.deb ...
Unpacking libgl1:armhf (1.0.0-2ubuntu2.3) ...
Selecting previously unselected package libosmesa6:armhf.
Preparing to unpack .../175-libosmesa6_20.0.8-0ubuntu1~18.04.1_armhf.deb ...
Unpacking libosmesa6:armhf (20.0.8-0ubuntu1~18.04.1) ...
Selecting previously unselected package mesa-utils.
Preparing to unpack .../176-mesa-utils_8.4.0-1_armhf.deb ...
Unpacking mesa-utils (8.4.0-1) ...
Setting up libedit2:armhf (3.1-20170329-1) ...
Setting up libglvnd0:armhf (1.0.0-2ubuntu2.3) ...
Setting up git-man (1:2.17.1-1ubuntu0.7) ...
Setting up libexpat1:armhf (2.2.5-3ubuntu0.2) ...
Setting up libicu60:armhf (60.2-3ubuntu3.1) ...
Setting up libjson-glib-1.0-common (1.4.2-3ubuntu0.18.04.1) ...
Setting up libgtk2.0-common (2.24.32-1ubuntu1) ...
Setting up libllvm10:armhf (1:10.0.0-4ubuntu1~18.04.2) ...
Setting up libasyncns0:armhf (0.8-6) ...
Setting up glib-networking-common (2.56.0-1ubuntu0.1) ...
Setting up libnghttp2-14:armhf (1.30.0-1ubuntu1) ...
Setting up libpng16-16:armhf (1.6.34-1ubuntu0.18.04.2) ...
Setting up liblcms2-2:armhf (2.9-1ubuntu0.1) ...
Setting up libjbig0:armhf (2.1-3.1build1) ...
Setting up libldap-common (2.4.45+dfsg-1ubuntu1.8) ...
Setting up fonts-dejavu-core (2.37-1) ...
Setting up libpsl5:armhf (0.19.1-5build1) ...
Setting up libelf1:armhf (0.170-0.4ubuntu0.1) ...
Setting up libglib2.0-0:armhf (2.56.4-0ubuntu0.18.04.6) ...
Setting up libasound2-data (1.1.3-5ubuntu0.5) ...
Setting up libxshmfence1:armhf (1.3-1) ...
Setting up libcap2:armhf (1:2.25-1.2) ...
Setting up libwayland-client0:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Setting up xkb-data (2.23.1-1ubuntu1.18.04.1) ...
Setting up libsasl2-modules-db:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2.1) ...
Setting up libproxy1v5:armhf (0.4.15-1ubuntu0.2) ...
Setting up libsasl2-2:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2.1) ...
Setting up libgdk-pixbuf2.0-common (2.36.11-2) ...
Setting up glib-networking-services (2.56.0-1ubuntu0.1) ...
Setting up libdatrie1:armhf (0.2.10-7) ...
Setting up libjpeg-turbo8:armhf (1.5.2-0ubuntu5.18.04.4) ...
Setting up libroken18-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libglapi-mesa:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up librtmp1:armhf (2.4+20151223.gitfa8646d.1-1) ...
Setting up perl-modules-5.26 (5.26.1-6ubuntu0.5) ...
Setting up libgdbm5:armhf (1.14.1-6) ...
Setting up libbsd0:armhf (0.8.7-1ubuntu0.1) ...
Setting up libkrb5support0:armhf (1.16-2ubuntu0.2) ...
Setting up libnspr4:armhf (2:4.18-1ubuntu1) ...
Setting up ucf (3.0038) ...
Setting up libxml2:armhf (2.9.4+dfsg1-6.1ubuntu1.3) ...
Setting up libfreetype6:armhf (2.8.1-2ubuntu2.1) ...
Setting up libasound2:armhf (1.1.3-5ubuntu0.5) ...
Setting up libdrm-common (2.4.101-2~18.04.1) ...
Setting up libjson-glib-1.0-0:armhf (1.4.2-3ubuntu0.18.04.1) ...
Setting up libgraphite2-3:armhf (1.3.11-2) ...
Setting up libcroco3:armhf (0.6.12-2) ...
Setting up libogg0:armhf (1.3.2-1) ...
Setting up libatk1.0-data (2.28.1-1) ...
Setting up libx11-xcb1:armhf (2:1.6.4-3ubuntu0.3) ...
Setting up libpixman-1-0:armhf (0.34.0-2) ...
Setting up libepoxy0:armhf (1.4.3-1) ...
Setting up libapparmor1:armhf (2.12-4ubuntu5.1) ...
Setting up libssl1.1:armhf (1.1.1-1ubuntu2.1~18.04.7) ...
Setting up libatk1.0-0:armhf (2.28.1-1) ...
Setting up libheimbase1-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up wget (1.19.4-1ubuntu2.2) ...
Setting up libsqlite3-0:armhf (3.22.0-1ubuntu0.4) ...
Setting up libdconf1:armhf (0.26.0-2ubuntu3) ...
Setting up libsensors4:armhf (1:3.4.0-4) ...
Setting up shared-mime-info (1.9-2) ...
Setting up libxkbcommon0:armhf (0.8.2-1~ubuntu18.04.1) ...
Setting up libcolord2:armhf (1.3.3-2build1) ...
Setting up libthai-data (0.1.27-2) ...
Setting up libxdmcp6:armhf (1:1.1.2-3) ...
Setting up libgdbm-compat4:armhf (1.14.1-6) ...
Setting up libkeyutils1:armhf (1.5.9-9.2ubuntu2) ...
Setting up libvorbis0a:armhf (1.3.5-4.2) ...
Setting up x11-common (1:7.7+19ubuntu7.1) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up xdg-utils (1.1.2-1ubuntu2.4) ...
Setting up hicolor-icon-theme (0.17-2) ...
Setting up libwayland-cursor0:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Setting up libwayland-egl1:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Setting up libx11-data (2:1.6.4-3ubuntu0.3) ...
Setting up libxau6:armhf (1:1.0.8-1ubuntu1) ...
Setting up libdbus-1-3:armhf (1.12.2-1ubuntu1.2) ...
Setting up libwrap0:armhf (7.6.q-27) ...
Setting up libavahi-common-data:armhf (0.7-3.1ubuntu1.2) ...
Setting up libwayland-server0:armhf (1.16.0-1ubuntu1.1~18.04.3) ...
Setting up libjpeg8:armhf (8c-2ubuntu8) ...
Setting up gconf2-common (3.2.6-4ubuntu1) ...
Creating config file /etc/gconf/2/path with new version
Setting up libk5crypto3:armhf (1.16-2ubuntu0.2) ...
Setting up fontconfig-config (2.12.6-0ubuntu2) ...
Setting up libwind0-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up dconf-service (0.26.0-2ubuntu3) ...
Setting up libdbus-glib-1-2:armhf (0.110-2) ...
Setting up libosmesa6:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libasn1-8-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libgconf-2-4:armhf (3.2.6-4ubuntu1) ...
Setting up libhcrypto4-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libflac8:armhf (1.3.2-1) ...
Setting up libnss3:armhf (2:3.35-2ubuntu2.12) ...
Setting up libharfbuzz0b:armhf (1.7.2-1ubuntu1) ...
Setting up libtiff5:armhf (4.0.9-5ubuntu0.3) ...
Setting up libthai0:armhf (0.1.27-2) ...
Setting up libhx509-5-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libdrm2:armhf (2.4.101-2~18.04.1) ...
Setting up libperl5.26:armhf (5.26.1-6ubuntu0.5) ...
Setting up libice6:armhf (2:1.0.9-2) ...
Setting up libkrb5-3:armhf (1.16-2ubuntu0.2) ...
Setting up libavahi-common3:armhf (0.7-3.1ubuntu1.2) ...
Setting up libdrm-radeon1:armhf (2.4.101-2~18.04.1) ...
Setting up libkrb5-26-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libvorbisenc2:armhf (1.3.5-4.2) ...
Setting up libdrm-nouveau2:armhf (2.4.101-2~18.04.1) ...
Setting up dconf-gsettings-backend:armhf (0.26.0-2ubuntu3) ...
Setting up libxcb1:armhf (1.13-2~ubuntu18.04) ...
Setting up libheimntlm0-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libxcb-present0:armhf (1.13-2~ubuntu18.04) ...
Setting up libfontconfig1:armhf (2.12.6-0ubuntu2) ...
Setting up libxcb-dri2-0:armhf (1.13-2~ubuntu18.04) ...
Setting up libsm6:armhf (2:1.2.2-1) ...
Setting up libxcb-dri3-0:armhf (1.13-2~ubuntu18.04) ...
Setting up libxcb-glx0:armhf (1.13-2~ubuntu18.04) ...
Setting up libxcb-xfixes0:armhf (1.13-2~ubuntu18.04) ...
Setting up libxcb-render0:armhf (1.13-2~ubuntu18.04) ...
Setting up gsettings-desktop-schemas (3.28.0-1ubuntu1) ...
Setting up libdrm-amdgpu1:armhf (2.4.101-2~18.04.1) ...
Setting up libgtk-3-common (3.22.30-1ubuntu4) ...
Setting up libgbm1:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libx11-6:armhf (2:1.6.4-3ubuntu0.3) ...
Setting up libgl1-mesa-dri:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libxcb-sync1:armhf (1.13-2~ubuntu18.04) ...
Setting up libgssapi-krb5-2:armhf (1.16-2ubuntu0.2) ...
Setting up perl (5.26.1-6ubuntu0.5) ...
Setting up libsndfile1:armhf (1.0.28-4ubuntu0.18.04.1) ...
Setting up mesa-va-drivers:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up glib-networking:armhf (2.56.0-1ubuntu0.1) ...
Setting up libxcomposite1:armhf (1:0.4.4-2) ...
Setting up libxcb-shm0:armhf (1.13-2~ubuntu18.04) ...
Setting up libxrender1:armhf (1:0.9.10-1) ...
Setting up libavahi-client3:armhf (0.7-3.1ubuntu1.2) ...
Setting up libegl-mesa0:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libgssapi3-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up fontconfig (2.12.6-0ubuntu2) ...
Regenerating fonts cache... done.
Setting up libcups2:armhf (2.2.7-1ubuntu2.8) ...
Setting up libxdamage1:armhf (1:1.1.4-3) ...
Setting up libxext6:armhf (2:1.3.3-1) ...
Setting up libxfixes3:armhf (1:5.0.3-1) ...
Setting up liberror-perl (0.17025-1) ...
Setting up libatspi2.0-0:armhf (2.28.0-1) ...
Setting up libxss1:armhf (1:1.2.2-1) ...
Setting up libgdk-pixbuf2.0-0:armhf (2.36.11-2) ...
Setting up libsoup2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Setting up libvdpau1:armhf (1.1.1-3ubuntu1) ...
Setting up libsoup-gnome2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Setting up libpulse0:armhf (1:11.1-1ubuntu7.11) ...
Setting up libxtst6:armhf (2:1.2.3-1) ...
Setting up libegl1:armhf (1.0.0-2ubuntu2.3) ...
Setting up gtk-update-icon-cache (3.22.30-1ubuntu4) ...
Setting up libxcursor1:armhf (1:1.1.15-1) ...
Setting up libldap-2.4-2:armhf (2.4.45+dfsg-1ubuntu1.8) ...
Setting up libpango-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Setting up libwayland-egl1-mesa:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libatk-bridge2.0-0:armhf (2.26.2-1) ...
Setting up librest-0.7-0:armhf (0.8.0-2) ...
Setting up libxxf86vm1:armhf (1:1.1.4-1) ...
Setting up libxrandr2:armhf (2:1.5.1-1) ...
Setting up libglx-mesa0:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libegl1-mesa:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libxi6:armhf (2:1.7.9-1) ...
Setting up libcairo2:armhf (1.15.10-2ubuntu0.1) ...
Setting up libxinerama1:armhf (2:1.1.3-1) ...
Setting up libpulsedsp:armhf (1:11.1-1ubuntu7.11) ...
Setting up pulseaudio-utils (1:11.1-1ubuntu7.11) ...
Setting up libcurl3-gnutls:armhf (7.58.0-2ubuntu3.12) ...
Setting up mesa-vdpau-drivers:armhf (20.0.8-0ubuntu1~18.04.1) ...
Setting up libcairo-gobject2:armhf (1.15.10-2ubuntu0.1) ...
Setting up libpangoft2-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Setting up libglx0:armhf (1.0.0-2ubuntu2.3) ...
Setting up git (1:2.17.1-1ubuntu0.7) ...
Setting up libpangocairo-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Setting up libgl1:armhf (1.0.0-2ubuntu2.3) ...
Setting up mesa-utils (8.4.0-1) ...
Setting up librsvg2-2:armhf (2.40.20-2ubuntu0.2) ...
Setting up librsvg2-common:armhf (2.40.20-2ubuntu0.2) ...
Setting up gconf-service-backend (3.2.6-4ubuntu1) ...
Setting up adwaita-icon-theme (3.28.0-1ubuntu1) ...
update-alternatives: using /usr/share/icons/Adwaita/cursor.theme to provide /usr/share/icons/default/index.theme (x-cursor-theme) in auto mode
Setting up libgtk2.0-0:armhf (2.24.32-1ubuntu1) ...
Setting up humanity-icon-theme (0.6.15) ...
Setting up libgtk-3-0:armhf (3.22.30-1ubuntu4) ...
Setting up gconf-service (3.2.6-4ubuntu1) ...
Setting up ubuntu-mono (16.10+18.04.20181005-0ubuntu1) ...
Processing triggers for libc-bin (2.27-3ubuntu1.3) ...
Processing triggers for libgdk-pixbuf2.0-0:armhf (2.36.11-2) ...
Removing intermediate container c44a4aca7eff
---> 499e305e318f
Step 5/16 : ADD dependencies/chromium-browser_78.0.3904.97-0ubuntu0.16.04.1_armhf.deb chromium-browser.deb
---> 4cba271ba483
Step 6/16 : ADD dependencies/chromium-codecs-ffmpeg-extra_78.0.3904.97-0ubuntu0.16.04.1_armhf.deb chromium-codecs.deb
---> 6ba0644aa349
Step 7/16 : RUN echo "Updating Chromium..." && dpkg -i chromium-codecs.deb && dpkg -i chromium-browser.deb
---> [Warning] The requested image's platform (linux/arm) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
---> Running in 68f386382ecb
Selecting previously unselected package chromium-codecs-ffmpeg-extra.
(Reading database ... 22326 files and directories currently installed.)
Preparing to unpack chromium-codecs.deb ...
Unpacking chromium-codecs-ffmpeg-extra (78.0.3904.97-0ubuntu0.16.04.1) ...
Setting up chromium-codecs-ffmpeg-extra (78.0.3904.97-0ubuntu0.16.04.1) ...
Selecting previously unselected package chromium-browser.
(Reading database ... 22332 files and directories currently installed.)
Preparing to unpack chromium-browser.deb ...
Unpacking chromium-browser (78.0.3904.97-0ubuntu0.16.04.1) ...
Setting up chromium-browser (78.0.3904.97-0ubuntu0.16.04.1) ...
update-alternatives: using /usr/bin/chromium-browser to provide /usr/bin/x-www-browser (x-www-browser) in auto mode
update-alternatives: using /usr/bin/chromium-browser to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode
Processing triggers for hicolor-icon-theme (0.17-2) ...
Removing intermediate container 68f386382ecb
---> f02686c841b6
Step 8/16 : ADD widevine/libwidevinecdm.so /usr/lib/chromium-browser
---> b2856e90332d
Step 9/16 : ADD widevine/PepperFlash /usr/lib/chromium-browser/pepper
---> 8118497a198b
Step 10/16 : ADD widevine/netflix-1080p-1.20.1 /usr/lib/chromium-browser/netflix-1080p
---> f13d10d0fc2a
Step 11/16 : COPY pulse-client.conf /etc/pulse/client.conf
---> e8c09d57c3f2
Step 12/16 : ENV UNAME mediaguy
---> Running in f7b56f207afe
Removing intermediate container f7b56f207afe
---> 9199d16c15d0
Step 13/16 : RUN export UNAME=$UNAME UID=1000 GID=1000 && mkdir -p "/home/${UNAME}" && echo "${UNAME}:x:${UID}:${GID}:${UNAME} User,,,:/home/${UNAME}:/bin/bash" >> /etc/passwd && echo "${UNAME}:x:${UID}:" >> /etc/group && mkdir -p /etc/sudoers.d && echo "${UNAME} ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/${UNAME} && chmod 0440 /etc/sudoers.d/${UNAME} && chown ${UID}:${GID} -R /home/${UNAME} && gpasswd -a ${UNAME} audio
---> Running in d5994a35c232
Adding user mediaguy to group audio
Removing intermediate container d5994a35c232
---> aeeaf44b96fe
Step 14/16 : USER $UNAME
---> Running in 8a08411d2b58
Removing intermediate container 8a08411d2b58
---> 50242cd61ce9
Step 15/16 : ENV HOME /home/${UNAME}
---> Running in 4c56785788fb
Removing intermediate container 4c56785788fb
---> 37b3a1be4a0b
Step 16/16 : CMD ["/usr/bin/chromium-browser", "--user-agent='Mozilla/5.0 (X11; CrOS armv7l 12607.82.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.123 Safari/537.36'"]
---> Running in 1cefc7e62116
Removing intermediate container 1cefc7e62116
---> 431aba2d76ec
Successfully built 431aba2d76ec
Successfully tagged hthiemann/chromium-armhf:latest
Enabling xhost forwarding
non-network local connections being added to access control list
chromium_home
Cleaning Up
Installing Chromium inside Docker Image Completed
Open Chromium from Applications List
Docker requires a reboot for the permissions to be set
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the desktop file MIME type cache...
I just noticed this Warning,
[Warning] The requested image’s platform (linux/arm) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
Should I be bothered with this in the future? Anyways thank you everyone ![]()
It should be. Since Apple has moved from Intel to Arm, we might get a better support for most of our queries. I’m waiting for Displaylink to have a better arm64 support in the future too. (I know it’s off topic
just sharing tho.)
I tried one today on Pinebookpro and it doesn’t work. Other connections like usb and audio works but no display out.
@Ace Which device are you using?
@spikerguy, I’m using Raspberry Pi 4B 8GB RAM. Amazed by how this little computer would do considering for its price.
I’ve been using a 2.0Ghz OC RPi4 for weeks as my daily. Plasma w/ composition turned off is great. I still have my i7-9700 and ryzen 3700x, but, right now it’s pi time.
