Thank you for your help, here are infos
System info:
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=5ea4210e-c1e8-4b56-ba8f-bb3ec9b6c2d2 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 81YQ v: IdeaPad 5 15ARE05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN
serial: <superuser required> part-nu: LENOVO_MT_81YQ_BU_idea_FM_IdeaPad 5
15ARE05 uuid: <superuser required> UEFI: LENOVO v: E7CN40WW
date: 01/29/2021
ID-1: BAT0 charge: 22.3 Wh (45.1%) condition: 49.5/57.0 Wh (86.9%)
power: 16.0 W volts: 11.1 min: 11.5 model: Celxpert L19C3PF5 type: Li-poly
serial: <filter> status: discharging cycles: 603
System RAM: total: 16 GiB available: 14.99 GiB used: 8.8 GiB (58.7%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
part-no: HMAA1GS6CMR6N-XN serial: N/A
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1937 high: 2495 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2154 2: 2495
3: 1248 4: 2075 5: 2066 6: 2144 7: 1247 8: 2073 bogomips: 31948
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: spec_rstack_overflow mitigation: SMT disabled
Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 50.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b6ee
Display: x11 server: X.Org v: 21.1.12 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x151e built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349
green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.54 6.6.26-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:1636 surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-aceb76aeaafc state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 476.94 GiB used: 398.4 GiB (83.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SSSTC model: CL1-4D512
lanes: 4 tech: SSD serial: <filter> fw-rev: AS962 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 398.4 GiB (85.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5ea4210e-c1e8-4b56-ba8f-bb3ec9b6c2d2
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 705C-997C
Device-1: 1-3:2 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b6ee class-ID: 0e02 serial: <filter>
Device-1: 3-1:2 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 3-4:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c58 class-ID: 0000
System Temperatures: cpu: 52.9 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1623 libs: 407 tools: pamac pm: flatpak pkgs: 0
1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
3: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
4: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
5: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
6: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
7: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
8: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
9: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
10: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
11: https://repos.silknet.com/manjaro/stable/$repo/$arch
12: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
14: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
15: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
16: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
17: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
18: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
20: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
21: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
22: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
23: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
24: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
25: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
26: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
27: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
28: https://mirrors2.manjaro.org/stable/$repo/$arch
29: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
30: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
31: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
32: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
33: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
34: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
35: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
36: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
38: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
39: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
40: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
41: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
42: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
43: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
44: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
45: https://mirror.zetup.net/manjaro/stable/$repo/$arch
46: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
47: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
48: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
49: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
51: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
52: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
53: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
54: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
55: http://manjaro.grena.ge/stable/$repo/$arch
56: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
57: https://mirror.23m.com/manjaro/stable/$repo/$arch
58: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
59: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
60: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
61: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
62: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
63: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
64: http://mirror.fcix.net/manjaro/stable/$repo/$arch
65: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
66: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
67: https://manjaro.kyberorg.fi/stable/$repo/$arch
68: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
69: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
70: https://mirror.koddos.net/manjaro/stable/$repo/$arch
71: https://mirror.easyname.at/manjaro/stable/$repo/$arch
72: https://linorg.usp.br/manjaro/stable/$repo/$arch
73: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
74: https://mirrors.manjaro.org/repo/stable/$repo/$arch
75: https://muug.ca/mirror/manjaro/stable/$repo/$arch
76: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
77: https://mirrors.netix.net/manjaro/stable/$repo/$arch
78: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
79: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
80: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
81: http://manjaro.mirror.ac.za/stable/$repo/$arch
82: https://manjaro.kurdy.org/stable/$repo/$arch
83: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
84: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
85: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
86: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
87: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
88: https://mirror.funami.tech/manjaro/stable/$repo/$arch
89: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
90: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
91: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
92: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
93: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
94: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
95: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
96: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
97: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
98: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
99: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
100: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
101: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
102: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
103: https://mirror.init7.net/manjaro/stable/$repo/$arch
104: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
105: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
106: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
107: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
108: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
109: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
110: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
111: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
112: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
113: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
114: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
115: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
116: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
117: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
118: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
119: https://mirror.dc.uz/manjaro/stable/$repo/$arch
120: https://manjaro.ynh.ovh/stable/$repo/$arch
121: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
122: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
123: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 314
1: cpu: 149%
command: Z:\home\tomask\.local\share\Steam\steamapps\common\Dune pid: 8324
mem: 1177.0 MiB (7.6%)
2: cpu: 31.1% command: firefox pid: 2017 mem: 614.5 MiB (4.0%)
3: cpu: 23.5% command: firefox pid: 6622 mem: 556.2 MiB (3.6%)
4: cpu: 18.7% command: firefox pid: 2516 mem: 80.9 MiB (0.5%)
5: cpu: 15.4% command: steamwebhelper pid: 7339 mem: 257.4 MiB (1.6%)
Memory top: 5 of 314
1: mem: 1177.0 MiB (7.6%)
cpu: 149%
2: mem: 614.5 MiB (4.0%) command: firefox pid: 2017 cpu: 31.1%
3: mem: 556.2 MiB (3.6%) command: firefox pid: 6622 cpu: 23.5%
4: mem: 546.8 MiB (3.5%) command: steamwebhelper pid: 7439 cpu: 15.1%
5: mem: 452.4 MiB (2.9%) command: ./steamwebhelper pid: 7303 cpu: 1.3%
Processes: 314 Power: uptime: 1h 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.34
Recent logs:
kvě 03 23:56:43 tomas-pc kernel: integrity: Problem loading X.509 certificate -65
kvě 03 23:56:45 tomas-pc kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
kvě 03 23:56:47 tomas-pc bluetoothd[576]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
kvě 03 23:56:47 tomas-pc bluetoothd[576]: Failed to clear UUIDs: Failed (0x03)
kvě 03 23:56:47 tomas-pc bluetoothd[576]: Failed to add UUID: Failed (0x03)
kvě 03 23:56:47 tomas-pc bluetoothd[576]: Failed to set mode: Failed (0x03)
kvě 03 23:56:47 tomas-pc bluetoothd[576]: Too small Add Device complete event
kvě 03 23:56:48 tomas-pc kernel: amdgpu 0000:03:00.0: amdgpu: Secure display: Generic Failure.
kvě 03 23:56:48 tomas-pc kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
