Need Help Updating GPU driver
TL;DR, How do I update my hard drive?
I previously had Manjaro about 1 or 2 years ago but decided to return to Windows 10 because I kept running into road blocks and couldn’t get the hang of things. I just recently decided to return to Linux and instead of using just Manjaro I decided to Dual Boot Manjaro and Windows 10 on separate SSD’s so that I can work from home and have the option to switch between the two if a new video game is released and can not run on Linux.
Right now I am trying to update my GPU so that I can play video games but whenever I try to launch my games in Steam the game closes immediately before I can see anything. The games that I am currently trying to run are [Prototype], The Song Of Saya, DIsco Elysium and Doki Doki Literature Club Plus!. I’ve tried searching for help on ProtonDB but nothing works. Just recently I switched from Linux Mint to Manjaro GNOME and when I was with Mint I was able to get pretty much anything I wanted up and running doing the exact same thing that I am doing here. When I tried to download Lutris it said “Your NVIDIA driver is outdated. You are currently running driver 390.144 which does not fully support all features for Vulkan and DXVK games. PLease upgrade your driver as described in our installation guide.” https://paste.pics/94a0857083b21326e0a7eef45832194e but when I follow the installation guide this is what I get…
sudo pacman -S --needed nvidia-dkms nvidia-utils lib32-nvidia-utils nvidia-settings vulkan-icd-loader lib32-vulkan-icd-loader
error: target not found: nvidia-settings
warning: vulkan-icd-loader-1.2.194-1 is up to date -- skipping
warning: lib32-vulkan-icd-loader-1.2.194-1 is up to date -- skipping
I also tried updating my GPU through (manjaro settings>hardware configuration) but that did not work either.
How can I fix? Could you give me some tips on how to setup my OS for gaming? Please explain this to me in as simple terms as possible because as I said I am very new to this.
Thank you for your time and patience in advance.
inxi --admin --verbosity=7 --filter --width                      ✔
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ed309206-20bf-4ffe-9c0b-32297009c2f7 rw quiet splash apparmor=1
  Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac serial: <filter>
  UEFI-[Legacy]: American Megatrends v: P3.70 date: 11/18/2019
  RAM: total: 15.56 GiB used: 3.01 GiB (19.3%)
  Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
  family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
  bogomips: 81477
  Speed: 2235 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
  1: 2235 2: 1447 3: 2714 4: 1557 5: 2083 6: 3886 7: 1467 8: 1542 9: 2409
  10: 1281 11: 1384 12: 3631
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
  smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  disabled, RSB filling
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia
  v: 390.144 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1c03
  class-ID: 0300
  Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver:
  loaded: nvidia display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 541x301mm (21.3x11.9")
  s-diag: 619mm (24.4")
  Monitor-1: DP-4 res: 1920x1080 dpi: 90 size: 544x303mm (21.4x11.9")
  diag: 623mm (24.5")
  OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144
  direct render: Yes
  Device-1: NVIDIA GP106 High Definition Audio vendor: ZOTAC
  driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:10f1
  class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
  v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Corsair CORSAIR Slipstream Multi-Device Receiver type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:4 chip-ID: 1b1c:0a42
  class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
  v: kernel bus-ID: 08:00.0 chip-ID: 8086:24fb class-ID: 0280
  IF: wlp8s0 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
  port: f000 bus-ID: 09:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-6:5 chip-ID: 8087:0aa7 class-ID: e001
  Local Storage: total: 3.66 TiB used: 37.68 GiB (1.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 44.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
  type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
  type: SSD serial: <filter> rev: 4B6Q scheme: MBR
  ID-1: / raw-size: 953.86 GiB size: 937.82 GiB (98.32%)
  used: 37.68 GiB (4.0%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: ed309206-20bf-4ffe-9c0b-32297009c2f7
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: N/A
  uuid: 3d456880-f30d-4dc4-8d27-660956a41eb4
  ID-2: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: N/A
  uuid: 536677A8605E131D
  Device-1: 1-1:2 info: Razer USA Tartarus V2 type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1532:022b class-ID: 0300
  Device-2: 1-2:3 info: Microsoft Xbox360 Controller type: <vendor specific>
  driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
  chip-ID: 045e:028e class-ID: ff00 serial: <filter>
  Device-3: 1-4:4 info: Corsair CORSAIR Slipstream Multi-Device Receiver
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
  rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a42 class-ID: 0300
  serial: <filter>
  Device-4: 1-6:5 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Device-5: 1-7:6
  info: Corsair CORSAIR K100 RGB Optical-Mechanical Gaming Keyboard
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 480 Mb/s power: 500mA chip-ID: 1b1c:1b7c class-ID: 0300
  serial: <filter>
  Device-6: 1-10:7 info: Corsair CORSAIR DARK CORE RGB PRO SE Gaming Mouse
  type: Mouse,HID,Keyboard driver: hid-generic,usbhid interfaces: 5 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b7e class-ID: 0301
  serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 44.6 C mobo: N/A gpu: nvidia temp: 59 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
  Processes: 352 Uptime: 6h 51m wakeups: 10 Init: systemd v: 249
  tool: systemctl Compilers: gcc: N/A Packages: pacman: 1286 lib: 413
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.08
Start here:
Hi @SYFLDN, and welcome!
While I doubt I’ll be able to help you, for more than 1 reason, I can point you here, so long: How to provide good information and, if applicable, [HowTo] post screenshots and links.
Thank you @Mirdarthos.
  bogomips: 81477
  class-ID: 0300
  diag: 623mm (24.5")
  direct render: Yes
  class-ID: 0403
  serial: <filter>
  Device-5: 1-7:6
  serial: <filter>
  serial: <filter>
Does your card support newer drivers?
mhwd -l
@CSCS Don’t know.
 mhwd -l                                                          ✔
> 0000:0a:00.0 (0300:10de:1c03) Display controller nVidia Corporation:
          video-nvidia            2020.11.30               false            PCI
    video-nvidia-390xx            2020.11.30               false            PCI
           video-linux            2018.05.04                true            PCI
Doesnt look like it does.
mhwd offers 390, 470, and current (495) … if your card was supported by any of the other ones it would be offered.
I also wanted to mention that when I downloaded Manjaro GNOME Steam was not automatically installed like it was supposed to be. Maybe I should just try and re-install the whole OS and start from scratch.
I had everything working fine before on a different Linux OS. What should I do?
Could I log into my Windows 10 SSD and update the GPU with the Nvidia software?
That sounds like a better idea … then maybe we can help with what it is you want to do.
Ah. not the windoze thing … that wont change anything about the driver in linux.
As to ‘other distros’ … its possible they were still serving some deprecated nvidia driver between the versions we offer here.
just for understanding ,UEFI-[Legacy]
that means :
  1. disks will be formated as MBR
  2. Do not Mix MBR & GPT disks
try to get USB manjaro iso lastest version ,
if you choose No free drivers ( nvidia ) , you can check with live manjaro under terminal
nvidia-smi
kernels give a magic number that is required for build nvidia drivers ,
DO NOT BUILD from site Nvidia , in case of not matching with kernel , it wont start after.
using mhwd is only the solution
It does indeed. On the stable branch, video-nvidia is NVIDIA v470. In the testing and unstable branches, it’s 495 and video-nvidia-470xx was added.
That’s for Arch, not Manjaro. We don’t have a separate nvidia-settings package.
See Configure Graphics Cards - Manjaro
I tryed it. Didn’t work.
sudo mhwd -a pci free 0300                                       ✔
[sudo] password for sayfal-din:
> Skipping already installed config 'video-linux' for device: 0000:0a:00.0 (0300:10de:1c03) Display controller nVidia Corporation GP106 [GeForce GTX 1060 6GB]
These are the drivers available for my computer.
mhwd -l -d                                                ✔  8s 
> PCI Device: /devices/pci0000:00/0000:00:03.1/0000:0a:00.0 (0300:10de:1c03)
  > INSTALLED:
   ATTACHED:	PCI
   VERSION:	2020.11.30
   INFO:	Closed source NVIDIA drivers for linux.
   PRIORITY:	4
   FREEDRIVER:	false
   DEPENDS:	-
   CONFLICTS:	video*nvidia*
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2018.05.04
   INFO:	Standard open source drivers.
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300 0380 0302
   VENDORIDS:	1002 8086 10de
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2020.11.30
   PRIORITY:	4
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.11.30
   PRIORITY:	3
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   ATTACHED:	PCI
   VERSION:	2020.01.13
   INFO:	X.org modesetting video driver.
   PRIORITY:	1
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
   ATTACHED:	PCI
   VERSION:	2017.03.12
   INFO:	X.org vesa video driver.
   PRIORITY:	0
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
Warning: no configs for USB devices found!
But according to the Nvidia website the latest driver should be 470.86. So how do I get 470.86? Should I try a different Kernel?
You probably installed the MINIMAL version of Manjaro GNOME. Install the Full Manjaro GNOME ISO instead. Minimal version of Manjaro provides only the bare minimum packages for the system to be usable (web browser, text editor, things like that only), but nothing more and you’ll have to install many application by yourself to have a proper basic desktop experience.
Also installing video drivers for your Nvidia card is as simple as running the proper command
This is not the command written in the Manjaro WIKI to install Nvidia video drivers.
You don’t even have to use the command line. You can do that from Manjaro Settings → Hardware Configuration, right click driver and select Install or Remove.
You currently have video-linux (the open source video driver), remove it, remove the Nvidia driver, and reinstall the Nvidia video driver for the proper configuration.
sudo mhwd -r pci video-linux
sudo mhwd -r pci video-nvidia
sudo mhwd -i pci video-nvidia
You install what Manjaro provides. Currently, on the Stable branch of Manjaro, it is 470.63 (provided by video-nvidia). The 470.86 version is available on Testing branch (provided by video-nvidia-470xx, as well as the 495 version (provided by video-nvidia, the Testing branch provides more up to date packages, and the Unstable branch provides even more up to date packages, refer to Manjaro Features)
I recommend you stay on the Stable branch if you already have trouble configuring the system. No need to complicate things. Documentation for Manjaro branches is here though Switching Branches - Manjaro
EDIT: if you reinstall, boot Manjaro USB with proprietary drivers it will auto install Nvidia in theory.
Thank you so much @omano. I finally got it working. Your the greatest.
