I work as a writer and I use fadein. Since my macbook is almost dead, I thought I should go back using linux. I bought a new computer and installed majaro kde plasma. I can find the fadein file in the package manager however I can not install the software.
I haven’t used linux in years and need fadein asap for my work. I am really thankful for any help.
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building fadein…
==> Making package: fadein 4.0.4-1 (Mi 23 Jun 2021 13:29:01)
==> Checking runtime dependencies…
==> Checking buildtime dependencies…
==> Retrieving sources…
→ Found fadein-4.0.4.tar.gz
==> Validating source files with md5sums…
fadein-4.0.4.tar.gz … FAILED
==> ERROR: One or more files did not pass the validity check!
Error: Failed to build fadein
Thats right. PKGBUILD version can be changed to 4.07. Not sure that matters as it looks like PKGBUILD instruction brings in 4.07 as you said.
MD5 for 4.07 appears to be: c0ceaca348c2313712f835a3944d9aad
which can be modified in the PKGBUILD
