Wolfi
25 October 2021 11:02
1
Hi everybody
I’m new to Manjaro and a while ago I had issues installing Fadein.
Hi everybody
I work as a writer and I use fadein. Since my macbook is almost dead, I thought I should go back using linux. I bought a new computer and installed majaro kde plasma. I can find the fadein file in the package manager however I can not install the software.
I haven’t used linux in years and need fadein asap for my work. I am really thankful for any help.
Thanks, have a great day
Since I had a lot of work, I skipped the last Update but I have to install
the new Version (4.0.11) because my co-writers updated it.
Should I download fadein-linux-amd64-demo.tar.gz or is there a other maybe
easier way?
Thanks so much for your help! Have a great day
The answer is right in the solution to the post that you referenced here.
cscs
25 October 2021 11:19
3
I prefer to use git to check out … that way you can do it again later … ex:
(maybe start from a particular directory like ~/Downloads/aur/)
git clone https://aur.archlinux.org/fadein.git
cd fadein
makepkg -sric
In the future you can again from the fadein directory
git pull
makepkg -sric
Wolfi
25 October 2021 12:43
4
Hi! The links is for the version 4.0.09 and I tried and got an error validity check. I’m sorry
Wolfi
25 October 2021 13:01
5
This also leads to the problem that the version is 4.0.09 and I get an error with the validity check.
cscs
25 October 2021 13:06
6
please run updpkgsums
before makepkg again, or you can manually download and get the sums and apply them to the PKGBUILD, or as in the other thread you can use --skipchecksums
with makepkg if you just want to … well skip the check.
Wolfi
1 November 2021 13:54
7
Thanks for your answer. I didn’t get it, I tried the commands but the version still was 4.0.09.
I just reinstalled the new version manually.
