If you can help me I would greatly appreciate it.
inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.19.0-3-rt10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-rt-x86_64
root=UUID=32721d68-a917-412b-818b-83ade466c493 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TOSHIBA product: TECRA Z40-C v: PT463U-08J02S
serial: <superuser required> Chassis: type: 10 v: Version 1.0
Mobo: TOSHIBA model: TECRA Z40-C v: Version A0
serial: <superuser required> UEFI-[Legacy]: TOSHIBA v: Version 6.80
date: 11/21/2018
ID-1: BAT1 charge: 33.5 Wh (71.0%) condition: 47.2/59.2 Wh (79.7%)
volts: 14.5 min: 14.5 model: G71C000GB510 type: Li-ion serial: N/A
status: charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 7.67 GiB used: 1.84 GiB (24.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 400/3000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19999
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Toshiba driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14b7 built: 2014 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Toshiba
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k5.19.0-3-rt10-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Ethernet I219-LM vendor: Toshiba driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 10.5 GiB (4.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNTY256HDHP-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 100Q scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 233.67 GiB (97.99%) used: 10.5 GiB (4.5%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 32721d68-a917-412b-818b-83ade466c493
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7:3 info: Validity Sensors VFS Fingerprint sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:0010 class-ID: ff00 serial: <filter>
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C pch: 36.5 C mobo: N/A
Processes: 227 Uptime: 16m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1209 libs: 317 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
