My RTX 3070 has a problem with drivers and kernel
So I just got and I am new to linux. I already made a post about this problem that when I updated everthing after installing Manjaro and then I restart it. I cant go in Manjaro anymore and I am stuck with this message /dev/nvme1n1p6: clean, 295648/2883584 files, 3592623/11520000 blocks . I tried to fix it but didn’t work, so I reinstalled manjaro. I did this many times to find the exact problem and then to fix the problem, but it didnt work.
What I think is the problem is in that message: Warning: installing nvidia-utils (495.46-3) breaks dependency 'nvidia-utils=470.63.01' required by linux513-nvidia Add linux513-nvidia to remove
I changed my kernel to 510 because it should work and updated my proprietary nvidia driver. But it still didn’t work.
Also I am dual booting because of gaming and my system info is here and thanks for the help in advance.
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=db466d65-3dae-4ba6-812e-9114cce9bc02 rw quiet apparmor=1
  Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
    v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.53
    date: 12/30/2020
  RAM: total: 31.28 GiB used: 2.57 GiB (8.2%)
  RAM Report:
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2989 high: 3599 min/max: 2200/4650 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3004 2: 3596
    3: 2586 4: 2658 5: 2875 6: 2875 7: 3177 8: 3599 9: 2876 10: 2879 11: 2873
    12: 2879 bogomips: 88827
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
    v: 470.63.01 bus-ID: 2d:00.0 chip-ID: 10de:2484 class-ID: 0300
  Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.4x13.5")
    s-diag: 1252mm (49.3")
  Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.2") diag: 685mm (27")
  Monitor-2: DP-0 res: 2560x1440 hz: 60 dpi: 109
  Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:228b
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: TC Electronic GoXLRMini type: USB driver: snd-usb-audio
    bus-ID: 1-2:3 chip-ID: 1220:8fe4 class-ID: 0102
  Device-4: C-Media Schiit Modi 3 type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 0d8c:0066
    class-ID: 0300
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel port: f000 bus-ID: 26:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
    chip-ID: 8086:2723 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
  Local Storage: total: 3.67 TiB used: 13.82 GiB (0.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 type: SSD serial: <filter> rev: P3CR021 temp: 36.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    rev: 233010WD temp: 36.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: A-Data
    model: USB Flash Drive size: 28.91 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
  ID-1: / raw-size: 43.95 GiB size: 42.95 GiB (97.74%) used: 12.7 GiB (29.6%)
    fs: ext4 dev: /dev/nvme1n1p6 maj-min: 259:6 label: N/A
    uuid: db466d65-3dae-4ba6-812e-9114cce9bc02
    used: 25.4 MiB (26.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:8
    label: N/A uuid: 520E-80E6
  ID-3: /home raw-size: 86.42 GiB size: 84.5 GiB (97.79%)
    used: 1.09 GiB (1.3%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A
    uuid: 4e5fb66e-76b2-43bc-a895-7f9ea8a3a58d
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p5 maj-min: 259:5 label: N/A
    uuid: b749e743-3492-4ada-806c-3e693825accf
  ID-1: /dev/nvme0n1p2 maj-min: 259:9 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:10 size: 930.9 GiB fs: ntfs label: N/A
    uuid: B4EC13BEEC137A36
  ID-3: /dev/nvme0n1p4 maj-min: 259:11 size: 505 MiB fs: ntfs label: N/A
    uuid: 5262D05462D03E83
  ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
  ID-5: /dev/nvme1n1p2 maj-min: 259:2 size: 785.01 GiB fs: ntfs
    label: 2. SSd uuid: 9C94664294661F50
  ID-6: /dev/nvme1n1p4 maj-min: 259:4 size: 512 MiB fs: vfat label: NO_LABEL
    uuid: 5102-AD3A
  ID-7: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-8: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: Disk drive
    uuid: EA10F91A10F8EF07
  ID-9: /dev/sdb1 maj-min: 8:17 size: 3.24 GiB fs: iso9660
  ID-10: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 99C0-51B6
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-1:2 info: KBDFANS KBD67MKIIRGBV3 type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 4b42:0100 class-ID: 0300
  Device-2: 1-2:3 info: TC Electronic GoXLRMini type: Audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s
  Device-3: 1-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 1462:7c84 class-ID: 0300 serial: <filter>
  Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-1:2 info: A-DATA ADATA USB Flash Drive type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 504mA
    chip-ID: 125f:db8a class-ID: 0806 serial: <filter>
  Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: C-Media Schiit Modi 3 type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 0d8c:0066 class-ID: 0300
  Device-2: 5-4:3 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
    driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 480mA
    chip-ID: 258a:0033 class-ID: 0301
  Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 31.1 C mobo: N/A gpu: nvidia temp: 44 C
  Processes: 298 Uptime: 9m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1236 lib: 342
  flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.12
The 5.13 kernel is EOL and has been dropped from the repositories, as well as the Nvidia headers for it.
You need to use a currently maintained kernel and remove 5.13.
Yea I did, I have now 5.10, is recommended and has tsl. But it still didnt work
From the error message, you still have packages related to linux513. You must remove them.
sudo pacman -R `pacman -Qqs .*linux513.*`
It didnt work.
zsh: no matches found: .*linux513.*
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for rafael:
error: no targets specified (use -h for help)
So I did other code I got from a reddit article that helped me finding my problem.Also I did the code in root. It didn’t work because the 5.13 was not found able. Is there any way too check if you have still have old kernel.
 pacman -Rs linux513 linux513-nvidia
error: target not found: linux513
error: target not found: linux513-nvidia
Edit: I maybe found my problem, because the kernel will stay 5.13 till I restart. So I think I will reinstall manjaro, update the kernel to 5.10, then restart and then make the updates.
Another Edit: I tried installing manjaro then first and only thing deinstalling 5.13 and the installing 5.10. but when I rebooted I had the error. I have no Idea if it’s the graphics card driver ore kernel.
if you can log in TTY
sudo mhwd -li
sudo mhwd-kernel -li
sudo ls /etc/mkinitcpio.d/*.preset
sudo ls /boot/
sudo ls /lib/modules/
or by USB live manjaro and chroot
sudo manjaro-chroot  -a
mhwd -li
mhwd-kernel -li
ls /boot/
ls /lib/modules/
exit (end chroot )
Sorry took so long but i did it in live mode and here is what I got.
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme1n1p6]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
 --> mount: [/mnt/home]
[manjaro /]# mhwd -li
> Installed PCI configs:
          video-nvidia            2020.11.30               false            PCI
[manjaro /]# mhwd-kernel -li
Currently running: 5.13.19-2-MANJARO (linux513)
   * linux510
[manjaro /]# ls /etc/mkinitcpio.d/*.preset
/etc/mkinitcpio.d/linux510.preset
[manjaro /]# ls /boot/
amd-ucode.img  efi  grub  initramfs-5.10-x86_64-fallback.img  initramfs-5.10-x86_64.img  linux510-x86_64.kver  memtest86+  vmlinuz-5.10-x86_64
[manjaro /]# ls /lib/modules/
5.10.93-1-MANJARO  extramodules-5.10-MANJARO
[manjaro /]# exit
exit
 --> umount: [/mnt/home]
 --> umount: [/mnt/boot/efi]
 --> umount: [/mnt]
then
mhwd -r pci video-modesetting
pacman -Syyu
mhwd-kernel -i linux515
mhwd-kernel -i linux516
exit (end chroot )
hello, when i executed the mhwd -r video-modesetting,. I see you wanna remove video modesetting, but I also dont know what wrong with this line
Edit: I solved it, I am now installing stuff
Error: invalid use of option: -r/--remove
Usage: mhwd [OPTIONS] <config(s)>
  --pci                                 list only pci devices and driver configs
  --usb                                 list only usb devices and driver configs
  -h/--help                             show help
  -v/--version                          show version of mhwd
  -f/--force                            force reinstallation
  -d/--detail                           show detailed info for -l/-li/-lh
  -l/--list                             list available configs for devices
  -la/--listall                         list all driver configs
  -li/--listinstalled                   list installed driver configs
  -lh/--listhardware                    list hardware information
  -i/--install <usb/pci> <config(s)>    install driver config(s)
  -ic/--installcustom <usb/pci> <path>  install custom config(s)
  -r/--remove <usb/pci> <config(s)>     remove driver config(s)
  -a/--auto <usb/pci> <free/nonfree> <classid>  auto install configs for classid
  --pmcachedir <path>                   set package manager cache path
  --pmconfig <path>                     set package manager config
  --pmroot <path>                       set package manager root
try
ok, so i did it, I also installed -Syyu. But mhwd-kernel -i linux515 :: Synchronizing package databases... core 167.7 KiB 838 KiB/s 00:00 [######################################################################] 100% extra 1899.9 KiB 14.3 MiB/s 00:00 [######################################################################] 100% community 6.9 MiB 28.9 MiB/s 00:00 [######################################################################] 100% multilib 174.3 KiB 5.01 MiB/s 00:00 [######################################################################] 100% error: no targets specified (use -h for help)
I am trying to find the porblem but I am slow so yea
exit ( end-chroot )
then reboot
you can add after others kernels
Ok I try rebooting into 5.10 but still didn’t work, I am using tty to install 5.15 and 5.16 and try booting in those. I also checked, I just have the Nvidia proprietary drivers
you have version 495.46 nvidia installed ?
How can I check?
with inxi -Fza or pacman -Qs nvidia
Sorry taking so long, I got this, there were to many nvidia versions.
[manjaro /]# pacman -Qs nvidia
local/egl-wayland 2:1.1.9+r3+g582b2d3-1
    EGLStream-based Wayland external platform
local/lib32-libvdpau 1.4-1
    Nvidia VDPAU library
local/lib32-nvidia-utils 495.46-1
    NVIDIA drivers utilities (32-bit)
local/libvdpau 1.4-1
local/libxnvctrl 495.46-1.0
    NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 495.46-3
    MHWD module-ids for nvidia 495.46
local/mhwd-nvidia-390xx 390.147-2
    MHWD module-ids for nvidia 390.147
local/mhwd-nvidia-470xx 470.94-1
    MHWD module-ids for nvidia 470.94
local/nvidia-utils 495.46-3
mhwd-nvidia are scripts only
have you try with only one monitor ?
i think that conf file Xorg should be updated for working with 2 monitors screen
gonna try
Edit: I tried with 1 Monitor but it didn’t work
Another Edit: Tried it with 5.10, 5.15, 5.16 and also didn’t work.
:cry::sweat:
What should I do?
then try this
TTY
sudo pacman -Syyu
sudo mhwd -a pci free 0300
sudo mhwd -a pci nonfree 0300
or under chroot ( with USB live Iso )
pacman -Syyu
exit ( end-chroot )
check also version xorg config from nvidia-setting
see this
