Multiple Display Setup Problems after Systemupgrade
Hi :wave:,
i made a system upgrade today and for some reason i can only have now two of my three displays active. Two of the three displays are 2560*1440 (QHD, those are the ones the system defaults to) and my older widescreen (WS, 2560*1080). All are from LG if that matters. During login they are all active, but after logging in my WS turns off. Whenever I try to activate my third (WS)(pressing power button) it gets recognized for a very short time (around 1 sec) and then system settings default back to the two QHD-displays. When I disable one of the two active QHD-displays it instantly switches on my WS.
Does anyone have an idea how to fix that?
I’m running:
OS: Manjaro 21.2.4 Qonos
Kernel: x86_64 Linux 5.15.25-1-MANJARO
Uptime: 15m
Packages: 1754
Shell: zsh 5.8.1
Resolution: 5120x1440
DE: KDE 5.91.0 / Plasma 5.24.2
WM: KWin
GTK Theme: Breath-Dark [GTK2/3]
Icon Theme: Breeze Chameleon Dark
Disk: 815G / 5,1T (16%)
CPU: AMD Ryzen 9 5900X 12-Core @ 24x 3.7GHz
GPU: AMD Radeon RX 6700 XT (NAVY_FLOUNDER, DRM 3.42.0, 5.15.25-1-MANJARO, LLVM 13.0.1)
RAM: 64G (screenfetch gave a weird number so manually set this)
Thanks in advance!
Camrais
inxi is way better
because everyone is used to the output of inxi
How to increase your chances of solving your issue:
Please provide Information:
  Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=8732957a-e9cc-4505-a0f4-22ddbef00361 rw rootflags=subvol=@ quiet
    iommu=pt amd_iommu=on vfio-pci.ids=10de:1b80,10de:10f0 apparmor=1
    security=apparmor resume=UUID=bbfd8dca-3237-48c1-b2cb-0a13ec7245a9
    udev.log_priority=3
  Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3604
    date: 04/14/2021
  RAM: total: 62.71 GiB used: 4.22 GiB (6.7%)
  RAM Report:
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2596 high: 3599 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 2878
    3: 2879 4: 2877 5: 2877 6: 2877 7: 2194 8: 2199 9: 2199 10: 2198 11: 2197
    12: 2197 13: 3593 14: 2877 15: 2875 16: 2878 17: 2877 18: 2879 19: 2195
    20: 2197 21: 2196 22: 2195 23: 2197 24: 2196 bogomips: 177692
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: XFX
    driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,DP-2 off: DP-3 empty: HDMI-A-1 bus-ID: 0b:00.0
    chip-ID: 1002:73df class-ID: 0300
  Device-2: NVIDIA GP104 [GeForce GTX 1080] vendor: ZOTAC driver: vfio-pci
    v: N/A alternate: nouveau pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    lanes: 16 bus-ID: 0c:00.0 chip-ID: 10de:1b80 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.3x15.0")
    s-diag: 1407mm (55.4")
  Monitor-1: DisplayPort-0 mapped: DP-1 pos: primary,left
    model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2021 res: 2560x1440
    hz: 144 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.2") diag: 685mm (27")
    ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-2: DisplayPort-1 mapped: DP-2 pos: right
  OpenGL: renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.42.0
    5.15.25-1-MANJARO LLVM 13.0.1)
    v: 4.6 Mesa 21.3.7 direct render: Yes
  Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
    bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
    driver: vfio-pci alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s
    lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1 chip-ID: 10de:10f0
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Creative Sound BlasterX G1 type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: 041e:3245
    class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.47 running: yes
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
  Local Storage: total: 3.22 TiB used: 663.9 GiB (20.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 23.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 24.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Transcend model: TS512GSSD320
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> scheme: GPT
  ID-1: / raw-size: 916.13 GiB size: 916.13 GiB (100.00%) used: 75 GiB (8.2%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: root
    uuid: 8732957a-e9cc-4505-a0f4-22ddbef00361
  ID-2: /boot/efi raw-size: 488 MiB size: 487 MiB (99.80%)
    used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: BOOT
    uuid: 2023-9721
  ID-3: /home raw-size: 953.87 GiB size: 953.4 GiB (99.95%)
    used: 475.04 GiB (49.8%) fs: xfs dev: /dev/sda1 maj-min: 8:1 label: Home
    uuid: d09c9d8a-2a16-45ab-9d89-24159a846ea8
  ID-4: /home/<filter>/Daten raw-size: 476.94 GiB size: 476.71 GiB (99.95%)
    used: 6.28 GiB (1.3%) fs: xfs dev: /dev/sdb1 maj-min: 8:17 label: Data
    uuid: fd605b26-1629-4878-935f-bd629dbb0542
  ID-5: /run/media/markus/BA727456727418F9 raw-size: 930.89 GiB
    size: 930.89 GiB (100.00%) used: 107.58 GiB (11.6%) fs: ntfs
    dev: /dev/nvme1n1p3 maj-min: 259:7 label: N/A uuid: BA727456727418F9
  ID-6: /var/cache raw-size: 916.13 GiB size: 916.13 GiB (100.00%)
    used: 75 GiB (8.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: root
  ID-7: /var/log raw-size: 916.13 GiB size: 916.13 GiB (100.00%)
  ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
    uuid: bbfd8dca-3237-48c1-b2cb-0a13ec7245a9
  ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
    uuid: 066E-6628
  ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p4 maj-min: 259:8 size: 524 MiB fs: ntfs label: N/A
    uuid: 8A8E9DBD8E9DA26D
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-4:2 info: Logitech G910 Orion Spectrum Mechanical Keyboard
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 046d:c335 class-ID: 0300
    serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-2:2 info: Creative Sound BlasterX G1 type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 041e:3245 class-ID: 0300
    serial: <filter>
  Device-2: 3-4:3 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Logitech G502 Mouse type: Mouse,HID
    power: 300mA chip-ID: 046d:c07d class-ID: 0300 serial: <filter>
  Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 34.0 C mem: 34.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 545 Uptime: 3m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1777 pacman: 1747 lib: 452
  flatpak: 22 snap: 8 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
  running-in: yakuake inxi: 3.3.13
Here it is :slight_smile:
Also during login after boot all three are active. The WS turns off after logging in
As I realized from the
inxi --admin --verbosity=7 --filter --width
DP-2 was turned off for whatever reason. It seems the update did some weird configurations that it shouldn’t have done. After some searching I found under https://wiki.archlinux.org/title/Xrandr#Testing_configuration the part of
$ xrandr --output HDMI-1 --auto
which I modified to
$ xrandr --output DisplayPort-2 --auto
which finally turned my WS back on. Had to do some positioning afterwards in system settings as it overlayed on one of my other monitors but it did the trick. Just wanted to let you guys know and save whoever might stumble upon this in the future the around 4h of search I did.
